2016 VW Passat GT Bi-Turbo TDI
drennie599
Northern Ireland
C?ID=109519
Sunday,12,March,2017,17:34:52:49196
VCDS Version: 17.1.3.0 (x64)
VIN: WVWZZZ3CZGxxxxxx   License Plate: EJ16
Mileage: 16490km-10246mi   Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
          BB BC
VIN: WVWZZZ3CZGxxxxxx   Mileage: 16490km-10246miles
Address 01: Engine (J623-CUAA)       Labels: 03N-906-026-CUA.clb
   Part No SW: 03N 906 026 E    HW: 03N 907 309
   Component: R4 2,0L EDC   H23 1754
   Revision: A1H23---
   Coding: 01250012036705083000
   Shop #: WSC 05311 115 00300
   ASAM Dataset: EV_ECM20BTD01103N906026E 001002
   ROD: EV_ECM20BTD01103N906026E.rod
   VCID: 2D55717A7CD1122972-8078
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0DL 300 011 H    HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5201
   Revision: 00H10V01
   ROD: EV_TCMDQ500021_VW41.rod
   Revision: 00000000    Serial number: 62615000001225
   Coding: 0EEC938F54280B6E077E070841C46970C92AD0E0E08296F5186250F8C209
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 7AFF8A26FD1F7591A7-802E
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0710
   Revision: 00026000    Serial number: 0380968757
   Coding: 000F0F0703
   VCID: 397D552AB899BE89EE-806C
   Part No SW: 5G0 907 044 BG    HW: 5G0 907 044 BG
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 1112010420210001101550000010180A
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   VCID: 6DD5B17ABC51D22932-8038
   Air quality sensor:
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86580309150065
   Coding: 03011C46C2C102FF07804094B11807281880000000000000000000000000
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 0301F7C28AD53459F4-8056
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150727  043 0607
   Serial number:         150820165011
   Component: RLHS  037 0059
   Serial number: S2Y15M09D23H21M17S56
   Coding: 90A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 11 06 2015  10001099
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY152170WU6
   Serial number: 00000000000063683899
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391526001331
   Coding: 0071051811
   Shop #: WSC 05311 115 00090
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 448334DECF5BF3618D-8010
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Coding: 3200678251FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3463641E9FFB43E13D-8060
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 19091541350191
   ROD: EV_DRCONTITEMIC.rod
   VCID: 377953128E8DA8F918-8062
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSPJF5JS+
   Coding: 98FCC0C0008000005C5400CC008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EF78636E13759B19B-802A
   Belt Pretensioner left:
   Serial number: 3G2857705E0261P00127
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 3G2857706E0260P01251
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 000 609 15
   Serial number: 3576U0000001C969661F
   Subsystem 4 - Part No SW: -----------    HW: 454 000 609 15
   Serial number: 3586U0000006D969661M
   Subsystem 5 - Part No SW: -----------    HW: 454 800 609 15
   Serial number: 3516R78332908000000$
   Subsystem 6 - Part No SW: -----------    HW: 454 800 909 15
   Serial number: 3526R5E0B61080000002
   Subsystem 7 - Part No SW: -----------    HW: 454 803 108 15
   Serial number: 3556V386625080000002
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521     HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20150915401118
   Coding: 0010
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 3G0 920 951 A    HW: 3G0 920 951 A
   Component: KOMBI         301 6421
   Coding: 27A50018BF80260001887B011000000000000000
   Shop #: WSC 00015 115 00001
   VCID: 2545895A24212A69BA-8070
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 16091510800242
   Coding: 030300045F017300FB00025E9C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75E5991AD4011AE9CA-8020
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001861380085383
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 6808707503
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 0308201500010237
   Serial number: HA1-00028.07.15
   Coding: 0301
   VCID: 4A9F1AE6ED7F251177-801E
   Serial number: 15000073687012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71EDAD0AA06936C916-8024
   Serial number: 140915BIC20916
   Coding: 003F0A20D001028000001000
   VCID: 438137C2CA55F459B4-8016
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 8103
   Shop #: WSC 00015 115 00300
   Serial number: 100915BIA01933
   Coding: 003F0020D001028000001000
   VCID: 428F32C6D54FFD51BF-8016
   Component: AFS-ECU       H01 0110
   Coding: 03A602000F200200
   Shop #: WSC 05311 000 08193
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3F893B32A6BD90B9D0-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    820 0627
   Coding: 02840101FF00000051111101008808001F0100C601200100CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 306B680E6BE37FC159-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9R2580238
   Subsystem 2 - Part No SW: 3G0 919 866 S    HW: -----------
   Component: ECE1 2016/17  --- 0635
Address BB: Door Rear Drv (J388)       Labels: None
   Serial number: 270815BHR05229
   Coding: 000E00200101028000001000
   VCID: 458529DAC461CA699A-8010
Address BC: Door Rear Pass (J389)       Labels: None
   Serial number: 270815BHR0522B
End-------------------------(Elapsed Time: 05:25)--------------------------
