Replacement USB Cable
bluestar
C?ID=296157
My HEX-USB+CAN VCDS has a damaged USB cable. The insulation near the male plug is split, exposing some wires (see pic). It works, even when wiggling the cable end, but at some point I imagine it will no longer work.
Is it possible to order a replacement cable from Ross-Tech? Mind you, I bought the VCDS second-hand, so I'm not looking for a free repair; I just want to buy a replacement USB cable.
I recently bought a new HEX-V2 and use it exclusively because the interface is faster than the old HEX+CAN. I want to repair the old one so I can resell it without the buyer having to worry about reliability.
Sure, we can hook you up. You understand the other end is soldered to the board, right?
bluestar
C?ID=296157
Fantastic! Who do I contact?
Yes, the 4 USB leads are soldered to the CB. I searched earlier and found some good pics in this thread:
http://forums.ross-tech.com/showthr...in-8-1-machines/page2&highlight=cable+replace
Those pics are for an earlier model VCDS, but I don't think it will be that different from mine.
With soldering, I'm mediocre at best and my iron has no heat control. Rather than risk heat damage to the CB, I would snip the wires and leave them as leads to be spliced. After splicing color-to-color, I'd solder each joint and insulate individually with shrink-tubing. Looks like there's plenty of room in the head to store a bit more wire.
Thanks!
bluestar
C?ID=296157
Dana,
I got your email. Thanks so much for providing a replacement cable. I'll await its arrival by mail.
Ross-Tech's outstanding customer service is much appreciated! :thumbs:
-Paul
Internal ref: ST?ID=74224
Paul, that wire shipped and tracking looks like you'll get it on Saturday.
