2.0 tdi skoda octavia vrs issues
ghosty
bonnie scotland UK
C?ID=277897
hi guys
since i have my car running after used ecu cured lot of faults also new intank pump an tandem pump due to oil an fuel mix also replaced injector loom
am getting some other faults
glow plug light flashing loss of turbo ie limp home turn it off engine restart full power again but some times it shuts down completely an is very hard to start normaly while giving it the beans or slowing down
could it be dirty injectors due to oil
sticky turbo
n75
crank sensor as dualmass seen better days due to get replaced with kavlar/carbon setup
map sensor
maf sensor
as for egr blocked it off with blanking plate due to get deleted with delete pipe as well as remap to remove dpf also
on scan 2 only showing injector fault but it jumps about 3 or 4 or 2 or 1 different injectors every scan
i will post 3 scans one with injectors at idle values but they jump up an down hence am thinking dirt
smell of diesel will burn you eyes out at rear of car u can see it
i do have new seal kit blots etc for injectors an also a ultra sonic cleaner on hand to help
Wednesday,08,March,2017,16:59:07:52445
VCDS Version: 17.1.3.0 (x64)
VIN: TMBEH21Z078013513   License Plate:
Mileage: 256520km-159394mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: TMBEH21Z078013513   Mileage: 256520km-159394miles
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 EL    HW: 03G 906 018 EL
   Component: R4 2.0l PPD1.2      9953
   Revision: --H22---    Serial number: SKZ7Z0F3704520
   Coding: 0000072
   Shop #: WSC 10091 074 64911
   VCID: 73E5A4601279F5D9E4-8026
               P0299 - 006 - Control Range Not Reached - Intermittent
                    Fault Status: 00010001
                    Mileage: 256525 km
                    Time: 05:28:34
                    RPM: 2112 /min
                    Torque: 224.0 Nm
                        99.45 %
                    Voltage: 14.35 V
                    Pressure: 2619.9 mbar
                    Pressure: 1235.4 mbar
001026 - EGR System
               P0402 - 006 - Excessive Flow - Intermittent
                    Mileage: 256525 km
                    Time: 05:28:34
004710 - PD Unit Injector: Cylinder 3 (N242)
               P1266 - 006 - Implausible Signal
                    Fault Status: 01100001
                    Mileage: 256525 km
                    Time: 05:30:54
                    RPM: 2016 /min
                    Torque: 144.0 Nm
                        44.85 %
                    Text:  6.000    uF
                    Time: 0.00 ms
                    Text:  0.00    mJ
004713 - PD Unit Injector: Cylinder 4 (N243)
               P1269 - 006 - Implausible Signal - Intermittent
                    Mileage: 256525 km
                    Time: 05:30:54
004707 - PD Unit Injector: Cylinder 2 (N241)
               P1263 - 006 - Implausible Signal - Intermittent
                    Fault Status: 00100001
                    Mileage: 256525 km
                    Time: 05:30:54
                    RPM: 2016 /min
                    Torque: 144.0 Nm
                        62.40 %
                    Text:  5.250    uF
                    Time: 0.00 ms
                    Text:  0.00    mJ
004704 - PD Unit Injector: Cylinder 1 (N240)
               P1260 - 006 - Implausible Signal - Intermittent
                    Mileage: 256525 km
                    Time: 05:30:54
Readiness: N/A
   Revision: 00H11001
   Coding: 0006786
   Shop #: WSC 73430 790 00000
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   VCID: 3B754C407AA97D99FC-806E
            009 - Open or Short to Ground
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000004308895
   Coding: 01880F030004140000110D000000000000087F075C
   VCID: 2B557C008AC9ED196C-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00063477
   Shop #: WSC 73430
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0N8CY/
   Coding: 0020788
   VCID: 3D71425864BD73A9C2-8068
   Subsystem 1 - Serial number: 6332MSME125C5A48I
   Subsystem 2 - Serial number: 6342MSME1210007C
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 035 0070
   Coding: 0000012
   VCID: 74E7A77C1777F2E1FD-8020
   Part No SW: 1Z0 920 912 E    HW: 1Z0 920 912 E
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610036    Serial number: SKZ7Z0F3704520
   Coding: 0003401
   Shop #: WSC 01286 386 08256
   VCID: 377D5070468159F918-8062
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 253
                    Mileage: 256525 km
                    Time: 00:06:24
00771 - Fuel Level Sensor (G)
                    Reset counter: 253
                    Mileage: 256525 km
                    Time: 00:06:24
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001067010707
   Coding: 3D3F074007001303
   VCID: 2C577F1C8FC7EA2165-8078
   Component: IMMO            VD1 1610
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0954
   Coding: 0000756
   VCID: 387F534C4B9F568111-806C
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 35615A785C8DABE90A-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Component:    KSG PQ35 G2  020 0202
   Coding: 01801A085283007F3F04850540085F96907CA0
   VCID: 0305F4A042D9C559F4-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Component:       NGS n.mounted
                    Reset counter: 38
                    Mileage: 256525 km
                    Time: 22:56:39
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Component: Tuer-SG         005 0944
   Coding: 0000756
   VCID: 3979564870954F89EE-806C
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0034
   Revision: 00019000    Serial number: SKZ7Z3F0041077
   Coding: 0000402
   VCID: 2E537514B9DB98314B-807A
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
End-------------------------(Elapsed Time: 01:44)--------------------------
Mileage: 256550km-159412mi   Repair Order:
VIN: TMBEH21Z078013513   Mileage: 256550km-159412miles
   Coding: 0000072
                    Mileage: 256548 km
                    Time: 05:38:04
                    RPM: 1952 /min
                    Torque: 0.0 Nm
                    Speed: 29.0 km/h
                        41.73 %
                    Text:  6.000    uF
                    Time: 0.00 ms
                    Text:  0.00    mJ
Readiness: N/A
   Revision: 00H11001
   Coding: 0006786
   Coding: 00063477
   Shop #: WSC 73430
   Coding: 0020788
   Coding: 0000012
   Coding: 0003401
                    Reset counter: 0
                    Mileage: 256536 km
                    Time: 05:20:35
   Coding: 0000756
   Coding: 00000000
   Shop #: WSC 73430
   Coding: 0000756
   Coding: 0000402
   Coding: 0000144
   Coding: 0000144
   Coding: 0000001
End-------------------------(Elapsed Time: 01:39)--------------------------
Sunday,12,March,2017,16:57:46:52445
                Address 01: Engine  (03G 906 018 EL)
16:57:27 Group 013: Idle Stabilization (Injection Quantity Deviation)
  0.04 mg/str  Injection Quantity Deviation Cyl. 1
  -0.34 mg/str  Injection Quantity Deviation Cyl. 2
  -0.60 mg/str  Injection Quantity Deviation Cyl. 3
  0.90 mg/str  Injection Quantity Deviation Cyl. 4
these jump up an down dirty injectors maybe
TFSI
Maryland, USA
C?ID=66650
I was trying to respond to this inquiry but I do not seem to understand what the exact issue is or the question. You mean loss of turbo effect? Have you done charge pressure check and what was the results?
NostraJackAss
Bad cam settings for gap lash on PD rocker?
Bad WG control, turbo or restricted exhaust or intake........or injector faults inducing limp mode.
ghosty
bonnie scotland UK
C?ID=277897
ok i will explain turbo works on car to start with after a couple of runs up an down gears then its starts to reduce power like holding back when that happens the glow plug light flashes an it does not rev over 3000 rpm till i turn car off an restart then i get boost back again but sometimes it kills the engine an is very hard to restart
i hope everyone can understand now sorry for confusing anyone thanks
ghosty
bonnie scotland UK
C?ID=277897
ok thanks do you know how to check them ie wg control etc injector faults runs fine but shuts down under boost call me a newbie still learning thanks
TFSI
Maryland, USA
C?ID=66650
Most likely exhaust line partly blocked. Whats the reading on mass air flow? Post MVBs on air intake, injection quantity,etc. Make sure diesel quality is good. Make sure all those vacuum lines are all intact. When the engine dies and hard to restart, what faults then do you have recorded in memory?
ghosty
bonnie scotland UK
C?ID=277897
ok thank you i will post them tomorrow also will try see if i can make it die an see what comes up think underboost fault an injector fault but it jumps from injector to injector
ghosty
bonnie scotland UK
C?ID=277897
Tuesday,14,March,2017,16:40:46:52445
                Address 01: Engine       Labels: 03G-906-018-BMN.CLB
Control Module Part Number: 03G 906 018 EL    HW: 03G 906 018 EL
  Component and/or Version: R4 2.0l PPD1.2      9953
           Software Coding: 0000072
            Work Shop Code: WSC 10091 074 64911
9 Faults Found:
                    Mileage: 256548 km
                    Time: 05:38:04
                    RPM: 1952 /min
                    Torque: 0.0 Nm
                        65.13 %
                    Text:  5.375    uF
                    Time: 0.00 ms
                    Text:  0.00    mJ
001025 - EGR System
               P0401 - 006 - Insufficient Flow - MIL ON
                    Mileage: 256548 km
                    Time: 05:38:04
004720 - PD Unit Injector: Cylinder 4 (N243)
               P1270 - 006 - Regulation Range Exceeded - Intermittent
                    Mileage: 256551 km
                    Time: 02:47:54
                    RPM: 832 /min
                    Torque: 24.0 Nm
                        86.97 %
                    Text:  4.875    uF
                    Text: 14.00    mJ
                    Text:      3    mJ
                    Voltage: 63.25 V
004711 - PD Unit Injector: Cylinder 3 (N242)
               P1267 - 006 - Regulation Range Exceeded - Intermittent
                    Mileage: 256551 km
                    Time: 02:47:54
               P1266 - 006 - Implausible Signal - Intermittent
                    Mileage: 256551 km
                    Time: 02:47:54
                    Mileage: 256551 km
                    Time: 02:47:54
004708 - PD Unit Injector: Cylinder 2 (N241)
               P1264 - 006 - Regulation Range Exceeded - Intermittent
                    Mileage: 256551 km
                    Time: 05:09:15
                    RPM: 2848 /min
                    Torque: 120.0 Nm
                        86.58 %
                    Text:  5.000    uF
                    Text: 13.75    mJ
                    Text:      3    mJ
                    Voltage: 63.25 V
                    Mileage: 256551 km
                    Time: 05:09:15
                    Mileage: 256552 km
                    Time: 05:27:47
                    RPM: 2720 /min
                    Torque: 112.0 Nm
                    Speed: 41.0 km/h
                        42.12 %
                    Text:  5.500    uF
                    Time: 0.00 ms
                    Text:  0.00    mJ
Readiness: N/A
Tuesday,14,March,2017,15:56:32:52445
15:56:07 Group 010: Charge Pressure Control
  650.7 mg/str  Mass Air Flow (actual)
  1030.9 mbar  Atmospheric Pressure
  1326.2 mbar  Boost Pressure (actual)
  99.9 %  Accel. Pedal Pos. Sensor 1 (G79)
15:57:40 Group 013: Idle Stabilization (Injection Quantity Deviation)
  -1.69 mg/str  Injection Quantity Deviation Cyl. 1
  0.58 mg/str  Injection Quantity Deviation Cyl. 2
  1.68 mg/str  Injection Quantity Deviation Cyl. 3
  -0.56 mg/str  Injection Quantity Deviation Cyl. 4
16:01:03 Group 013: Idle Stabilization (Injection Quantity Deviation)
  -1.16 mg/str  Injection Quantity Deviation Cyl. 1
  -0.23 mg/str  Injection Quantity Deviation Cyl. 2
  1.43 mg/str  Injection Quantity Deviation Cyl. 3
  -0.02 mg/str  Injection Quantity Deviation Cyl. 4
16:01:03 Group 004: Unit Injector
  808 /min  Engine Speed (G28)
  5.0 °ATDC  Injection Start (specified)
  3.7°KW  Injection Duration (specified)
  1.49°  Torsion Value
16:01:03 Group 018: Piezo Unit Injector Status
  0.0  Injector Status Cylinder 1
  999  Injector Status Cylinder 2
  999  Injector Status Cylinder 3
  999  Injector Status Cylinder 4
16:03:06 Group 019
  167.50 V  Voltage
  159.25 V  Voltage
  160.25 V  Voltage
  163.25 V  Voltage
TFSI
Maryland, USA
C?ID=66650
Very unlikely all unit injectors could fail at one time. Check the black connector for the unit injectors on the side of cylinder head for proper/tight connection. If possible disconnect and check contacts for rusts, clean and reconnect. If possible, unplug the mass flow sensor and drive to see if it makes any change.
Has there been any recent work on this engine?
ghosty
bonnie scotland UK
C?ID=277897
ok will do thanks as for work new tandem an intank pump an ecu and injector loom as the other ecu had been mucked about with ie bad tuning is what i was told after i got the car. Needing a new dual mass also as shes banging a bit i have a new one on order i might get egr deleted an dpf make it breath better
is it worth ultra sonic cleaning injectors an putting new seals on an cleaning the turbo vnt with cleaner
ghosty
bonnie scotland UK
C?ID=277897
ok today i disconnected the maf still holds limp home back if u hold it in gear an spool the turbo checked for faults same as above 4 injectors an a under boost fault dpf light is now on an its not going into regen also pulled the egr blanking plate out an tried again still nothing so i forced a regen an went for a 30 min drive sill nothing its now sitting a 67% full
ghosty
bonnie scotland UK
C?ID=277897
ok dpf gutted an deleted egr deleted car runs better but still have injector faults an when driving sometimes the car cuts out an will not start leave it for 5 mins an crank over for 20 secs an it restarts any ideas injector 3 showing 999
MartinsX
Riga, Latvia
C?ID=268515
Post some more measurements, 0x01 MVB013.
Try to swap injector #3 to another cylinder or replace it and compare deviations.
ghosty
bonnie scotland UK
C?ID=277897
hello all am back still got the car never got to the problem ie fixing it am going to try again
i have a other problem now the car battery went flat an now the car rpm goes nuts high idle i will post a video of this on youtube an post the link as any fault codes stored most people would have gave up not me :)
