2007 Passat ECU replacement
techterr
C?ID=49768
Hello to the fine folks of the forum..
Have another B6 Passat question.. I swear they follow me around:)...
Have a shop who did diagnostics on a 2007 Passat, it kept having a high pressure fuel sensor problem. They replaced the high pressure fuel pump, and the sensor, ohm'd out the wiring from the sensor to the ECU. There manual said to replace the ECU. They sent away for a replacement ECU, it came programmed with the VIN and CS and Mac, when they put it into the car, it went into safe mode and is imobilized... I put there old ECU back in, read the VIN, CS, MAC and power class with AVDI, then put there new ECU in and looked at those values.. They were all the same... Hooked up VCDS, went to engine, put in pin, went to adaptation, channel 50, and it says error.. Went to 25, immo, put in pin, went to channel 50, and it also says error.. Read the info about replacing an ECU with immo 4 about the immo challenge, went to the ECU and read the immo challenge, not sure where to use that info though... This is the first time I have had an issue with the MED9.1.... Usually I can read the info from the ECU, then write that to a used ECU and put it in the car and the car accepts the ECU, I didn't want to mess with the ECU they had purchased and I didn't have a 3.6 MED9.1 laying around... Does anyone know if there is anything that needs to be done thru the imobilizer? or the ECU to make the car happy... Thanks for any and all ideas... And yes, I did a scan...
Saturday,11,March,2017,11:46:50:20932
VCDS Version: 16.8.3.1
VIN: WVWAU73C26P090534   License Plate: LOYAL1
Mileage: 187360km-116420mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
          72
VIN: WVWAU73C26P090534   Mileage: 187360km-116420miles
Address 01: Engine        Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 997 033 N    HW: Hardware No
   Component: P3.6-FSI-LEV2   G00 2371
   Revision: --H08---    Serial number: VWZCZ000000000
   Coding: 0000075
   Shop #: WSC 00028 028 00001
   VCID: 387503184B024F8244-806C
000290 - Throttle Position Sensor (G69)
               P0122 - 002 - Signal too Low - Intermittent
                    Fault Status: 00110010
                    Temperature: -40.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.843 V
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 002 - Signal Too Low - Intermittent
                    Temperature: 11.0°C
                    Voltage: 13.843 V
000280 - Engine Coolant Temp. Sensor (G62)
               P0118 - 002 - Signal too High - Intermittent
                    Temperature: 11.0°C
                    Voltage: 13.970 V
000400 - Fuel Pressure Sensor (G247)
               P0190 - 001 - Circuit Malfunction - Intermittent
                    Fault Status: 00100001
                    Temperature: 11.0°C
                    Voltage: 13.970 V
Readiness: 0110 0101
   Part No SW: 09G 927 750 HK    HW: 09G 927 750 AJ
   Component: AQ 250 6F           1271
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 23322 444 54723
   VCID: 0103AEFC5858CE4AB3-8054
            004 - No Signal/Communication - Intermittent - MIL ON
                    Fault Status: 10100100
                    Reset counter: 44
                    Mileage: 60772 km
                    Date: 2008.08.05
                    Time: 11:58:58
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0658198180
   Coding: 0046541
   VCID: 30653B38A37297C20C-8064
                    Fault Status: 00101101
                    Reset counter: 36
                    Mileage: 187365 km
                    Date: 2017.03.09
                    Time: 18:31:16
                    Reset counter: 36
                    Mileage: 187365 km
                    Date: 2017.03.09
                    Time: 18:31:16
01795 - Vacuum System for Brakes
                    Fault Status: 00100011
                    Reset counter: 36
                    Mileage: 187365 km
                    Date: 2017.03.09
                    Time: 18:34:16
   Part No: 1K0 820 047 DL
   Component: Climatic PQ35   090 0505
   VCID: 71E3FE3C68F8DECA43-8024
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000003594365
   Coding: 148C8F0340041000000A00000F00000000285D435C0000
   Shop #: WSC 09550 758 180955
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00065493
   Shop #: WSC 09550
                    Fault Status: 01101100
                    Reset counter: 37
                    Mileage: 187365 km
                    Date: 2017.03.04
                    Time: 23:45:00
                    Voltage: 11.55 V
                    Reset counter: 77
                    Mileage: 187365 km
                    Date: 2017.03.09
                    Time: 18:31:00
                    Voltage: 14.00 V
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7E3034556
   VCID: 2B5F2C548A54F41A39-807E
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 33
                    Mileage: 165177 km
                    Date: 2015.12.02
                    Time: 12:02:30
02788 - Internal Communications Error
            000 -  -
                    Fault Frequency: 11
                    Reset counter: 77
                    Mileage: 187365 km
                    Date: 2017.03.05
                    Time: 20:07:59
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
   Part No SW: 3C0 909 605 G    HW: 3C0 909 605 G
   Component: 0E AIRBAG VW8R  029 2421
   Revision: 09029000    Serial number: 0039VSL0LQ8I
   Coding: 0012357
   VCID: 2A51295085AEED12C2-807E
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 00000000030QQE
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0B7E5B50Oÿ†63
   Subsystem 5 - Serial number: E5B50Oÿ†6342MSME0C092278Cÿ†63
   Subsystem 6 - Serial number: 92278Cÿ†6351HTS69SDAE8A2Hÿ†63
   Subsystem 7 - Serial number: AE8A2Hÿ†6361HTS69SD6MO82-ÿ†63
   Subsystem 8 - Serial number: 6MO82-ÿ†63727TS65CHU15N2Bÿ†63
   Subsystem 9 - Serial number: U15N2Bÿ†63827TS65CHUPKK25ÿ
   Subsystem 10 - Serial number: UPKK25ÿ
   Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C5953507R
   Coding: 0002013
   VCID: 31633E3CA8789ECA03-8064
   Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: X0033000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 23328 067 57207
   VCID: 336F34345264ACDA71-8066
                    Reset counter: 77
                    Mileage: 187365 km
                    Date: 2017.03.09
                    Time: 18:31:27
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C059200E94
   Coding: 3FFD0E04D31002
   VCID: 2143CE7CF8982E4A93-8074
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0002
   Revision: 00005000    Serial number: 1166279TNXZZ04
   VCID: 6DDBE24C74C03A2A67-8038
   Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
   Component:    IMMO         041 0364
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 23328 444 54029
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2365
   Coding: 0001205
   VCID: 36690D204116B9F256-8062
   Part No: 3C1 909 144 B
   Component: EPS_ZFLS Kl.5   D04 1607
   VCID: 244DC768E78A3B62F8-8070
                    Mileage: 7360 km
                    Temperature: 9.0°C
                    Voltage: 14.10 V
                    Voltage: 13.80 V
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 RDK 041 0213
   Coding: 13910F8801862E521804141FF00A0F0E081800
00956 - Key 2
                    Fault Status: 01100101
                    Reset counter: 37
                    Mileage: 187365 km
                    Date: 2017.03.04
                    Time: 23:41:53
   Part No: 1K0 959 702 K
   Coding: 0001204
   VCID: 37770024461C40FA4D-8062
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000013
                    Reset counter: 77
                    Mileage: 187360 km
                    Date: 2017.03.09
                    Time: 18:56:07
                    Voltage: 13.25 V
                    Count: 27
                    Reset counter: 77
                    Mileage: 187360 km
                    Date: 2017.03.09
                    Time: 18:31:27
                    Voltage: 13.66 V
                    Count: 241
   Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
   Component: Radio PM6       016 0017
   Revision: 00016000    Serial number: VWZ5Z7E2022312
   Coding: 0040400
   VCID: 2045CB78F39227429C-8074
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2432
   Coding: 0000144
   Component:    RDK              0391
   Coding: 0100101
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 32613130AD7EA5D27A-8066
End-------------------------(Elapsed Time: 02:37)--------------------------
          72
   Coding: 0000075
                    Temperature: 11.0°C
                    Voltage: 13.843 V
                    Temperature: 11.0°C
                    Voltage: 13.843 V
                    Temperature: 11.0°C
                    Voltage: 13.970 V
                    Temperature: 11.0°C
                    Voltage: 13.970 V
   Coding: 0000072
   Coding: 0046541
   Coding: 00065493
   Shop #: WSC 09550
            014 - Defective
                    Reset counter: 33
                    Mileage: 165177 km
                    Date: 2015.12.02
                    Time: 12:02:30
   Coding: 0012357
   Coding: 0002013
   Coding: 0007205
   Coding: 0001205
   Coding: 0001204
   Revision:   013
   Coding: 0000013
   Coding: 0040400
   Coding: 0000144
   Component:    RDK              0391
   Coding: 0100101
   Coding: 0000144
End-------------------------(Elapsed Time: 02:20)--------------------------
Gone But Not Forgotten
Send me the units and I can do a real data transfer for you with proper documentation verified.
techterr
C?ID=49768
Once the data is transfered, does anything have to be done to adapt the ECU into the car? The reason I ask is that is what was done to the replacement ECU... and it is kicking off the safe mode... I actually found an ECU in the garage, why I have a 3.6, I don't know... But I was able to change the VIN, CS and MAC and power class, figured I would give it a try... If it doesn't work, I will give them your info..
Thanks for the reply,
Tim
Tim
Not the way I do it...........
techterr
C?ID=49768
Hi Jack,
I failed miserably.... not sure if the CCM is the old version of software that won't let you adapt anything to it or what... Gave them your info, they might call you, or they are going to take it to the dealer.. If you get a chance, please take a look at this vid and see if I did anything wrong...
Thanks in advance,
Tim
https://www.youtube.com/watch?v=vZTOZN7gmhU
Zenerdiode
Newcastle, England
C?ID=24330
Two things I want to comment on:
*Always* read back form your ECU to make sure what you think has been programmed, actually has been.
The Abritus program says 'Switch of ignition'. What you're doing (by unplugging from the wall) is killing ALL power to the ECU. I presume the Abritus software works by doing DMA changes in RAM. Well, when you switch off the ignition (T15) to an ECU; you still have a T30 connection. So when ignition off, the ECU carries out some housekeeping, including writing some variables from RAM to EEPROM. It can't do that if killed T30 too.
Finally, please add some switches to your harness, for T15 and T30. Depending on how the regulation and smoothing is carried out in the wall PSU, when pulling the plug the power to the ECU will decay as the internal capacitors of the PSU discharge, this could be even more detrimental to the ECU as you may get partial writes to the EEPROM/Flash and 'brick' the ECU.
techterr
C?ID=49768
Thanks for the advice... I did read back from the ECU, and it had the same data as the original ECU. I will try adding the switches to the ign feed to the ECU, sure couldn't hurt... I have done about 10 of these this exact same way, and the car accepts the ECU as it's own... Still can't figure out why this car will not accept any ECU other than the original... I have had two cars that the ECU was blank.. when you went to read them, the showed up as a ME7.1 or 7.5.. I even tried to read them on my BDM, and then upload a clean bin to them.. I am wondering what is happening to these ECU's...
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Check your private message.
Jetta 97
C?ID=81680
Solution,
This is VCDS forum and I do not think we should talk here about other devices. I respect Ross-Tech team and do not want to talk about other devices.
His device has Forum as well .
Solution,
Sounds like BS to me..........
I was going to check in on this and ask if the OP did a login within immobilizer and then a swap........
A login can indeed be executed in VCDS if it's correct.
Everybody has different opinion , it is free Country Jack :D
Was your solution procedure only possible with a different tool or could it be done with VCDS?
Because I can align a used or transferred immobilizer with VCDS by the method I aforementioned or AVDI..........
Just looking for clarity.......not the actual procedure pushing you for any BS hidden information.
If it can be done with VCDS then it is totally permitted for discussion & if done by a standard diagnostic procedure.
I liked Dr. Z's post on the terminal 15 and 30 because this is absolutely true and critical.
Now I am going to share a problem I have found within the factory stack that even circumvents the OEM GeKo process to date!
I have seen where an ECU is new it starts with an empty EEPROM & its IMMO block XXXXX etc. usually to the term of 3 redundant rows of IMMO block data.
This data when new the tester writes the 3 blocks and everything is happy times.
The ECU now needs to be replaced and if new is usually happy times again using GeKo or most tools, however, if used there can be some discrepancies even if read with a BDM or other OBD tools like aforementioned of the OP.
In the USA starting in ME7.1.1 & MED9 which supported a larger EEPROM for some controllers but not all.
When these tools read or write via the BDM or OBD process they may not be reading the entire EEPROM or virtual EEPROM and only the RAM area.
Additionally, some flash stacks deploy a watchdog if turned on to circumvent a read or write to certain sectors, or deploy the shadow.
If the ECU is programmed via GeKo or OBD AFT tools it is by design to keep a record of the old data and tries to keep a shadow for forensics of the old identity.
In some cases this shadow identity can be used to circumvent a GeKo, so that a used component can't be used as I suspect described by OP.
To me it seems deliberate by the OEM to steer you toward a new controller but I have solved this problem when I first saw it in 2003 when observed.
This can be why the OP has described it the way he has.
I see this as relevant because if the OEM tester bricks controllers, than it is important to note this and it becomes standard diagnostic related to VCDS.
