3C Passat 3.2 - High Pressure Fuel Pressure always too high
Rekked
Australia
C?ID=224535
Hi Guys,
Having problems with a customers Passat, it barely presents with any symptoms except for a MIL on the dash.
once in every 3 or 4 cold starts in the morning it will cough and splutter like it has got no fuel and then after an instant re start it runs fine. (im trying to log some data during this sort of start up)
Ive logged a few channels this morning but it started and ran as though there was no faults.
My first thought was a faulty sensor G247 and i had a known good sensor to try so i fitted this and no difference - still reading 120 ish BAR.
I plugged the old sensor into the loom whilst not installed into the rail and the measuring block value went down to 0 BAR.
Having experienced a few HPFP's on 2.0T engines fail and stick open, i proceeded to order a Genuine HPFP and after fitting i once again had exactally the same fault code " 000401 - Fuel Pressure Sensor (G247) " return instantly, (the others return after a 10min or so road test)
I was after your opinion of the logged data, Fuel pressure regulator starts at about 17, moves up to say 40 and then heads backwards to -300.
And is the low pressure fuel pressure of 7 BAR too high? can this relate to the High Pressure value being soo high?
What is the next step in testing? inspection of the ECU plugs? or is there a way to scope the HPFP wiring?
Any help would be much appreciated.
Thanks, Andy
Thursday,09,February,2017,09:59:30:58435
VCDS Version: 17.1.2.0
Data version: 20170131 DS267.1
VIN: WVWZZZ3CZ6E155749   License Plate: UCB304
Mileage: 120400km-74813mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 53 56 62 65 72
          76 77
VIN: WVWZZZ3CZ6E155749   Mileage: 120400km-74813miles
Address 01: Engine        Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 997 033 K    HW: Hardware No
   Component: P3.2 FSI-EU4    G00 2368
   Revision: --H08---    Serial number: VWZCZ000000000
   Coding: 0000175
   Shop #: WSC 30023 959 91515
   VCID: 3561015E5CA535E900-8060
               P0191 - 001 - Implausible Signal - MIL ON
                    Fault Status: 11100001
                    Fault Frequency: 102
                    Mileage: 120319 km
                    Date: 2017.02.02
                    Time: 16:58:56
                    RPM: 687 /min
                    Load: 26.7 %
                    Temperature: 87.0°C
                    Temperature: 54.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.081 V
004133 - Fuel Pressure Regulation Valve (N276)
               P1025 - 004 - Mechanical Failure
                    Mileage: 120319 km
                    Date: 2017.02.02
                    Time: 16:58:56
012555 - Low Pressure Fuel regulation
               P310B - 004 - Fuel Pressure Outside Specification - Intermittent
                    Mileage: 120328 km
                    Date: 2017.02.03
                    Time: 11:51:34
                    RPM: 626 /min
                    Load: 25.1 %
                    Speed: 3.0 km/h
                    Temperature: 65.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.970 V
012408 - Throttle Control
               P3078 - 002 - Airflow at Idle too Low
                    Mileage: 120328 km
                    Date: 2017.02.03
                    Time: 11:51:34
Readiness: 0010 0000
   Part No SW: 02E 300 047 J    HW: 02E 927 770 AE
   Component: GSG DSG         070 1112
   Revision: 04507000    Serial number: 00000511240146
   Shop #: WSC 44551 111 44551
   VCID: 1F4DC3F6CE599FB9FA-804A
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0658571812
   Coding: 0046535
   Shop #: WSC 05311 000 00000
   VCID: 306F304AA3C710C153-8064
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
   Component: ClimatronicPQ46 050 0404
   Revision: 00050005    Serial number: 00000000000000
   VCID: 62CB8A02BDABF25195-8036
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000005275868
   Coding: E18C8F0700041A00000A00000F00000000085D435C0000
   Subsystem 1 - Part No: 3C2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 05311
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 05311
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 17 AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3PSCV46-
   Coding: 0012599
   VCID: 2E532E32B9F3063141-807A
   Subsystem 1 - Serial number: 6332MSME0D595D63P
   Subsystem 2 - Serial number: 6342MSME0E095859M
   Subsystem 3 - Serial number: 6351HTS6I2II0BN2F
   Subsystem 4 - Serial number: 6361HTS63IKQ5BU2$
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C9953507P
   Coding: 0001112
   Component: E0221           007 0050
   Part No SW: 3C0 920 870 P    HW: 3C0 920 870 P
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: X0033000    Serial number: 00000000000000
   Coding: 0007705
   Shop #: WSC 06335 444 64523
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C05C2100F2
   Coding: BFFD1E04C62003
   Shop #: WSC 05311 123 12345
   VCID: 2149C50EF82DA949CC-8074
                    Reset counter: 77
                    Mileage: 120407 km
                    Date: 2017.02.09
                    Time: 09:53:38
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 C
   Component: HALDEX 4Motion      0108
   Coding: 0000001
   VCID: 2D51293EB4F57D2978-8078
   Part No SW: 3C0 959 433 P    HW: 3C0 959 433 P
   Component:    IMMO         043 0364
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 377D0B5646A9C7F912-8062
   Subsystem 1 - Part No: 3C0 905 861 D
   Component:    ELV          024 0370
   3C0905861D     ELV          024 0370
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2366
   Coding: 0000693
   VCID: 3663065241A33EF109-8062
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 34673C5A57DF2CE137-8060
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 RDK 043 0213
   Coding: 0191020851030E763804941570085FCE101800
   Subsystem 2 - Part No: 3C0 951 171 A
   Component: Neigungssensor  002 0508
   Subsystem 3 - Part No: 3C0 951 171 A
   Component: Innenraumueberw.002 0508
   Part No: 1K0 959 702 K
   Coding: 0000692
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000012
   Part No: 1K0 035 195 B
   Component: Radio BVX       008 0015
   Coding: 0040400
   VCID: 2541D11EEC054569B0-8070
   Part No: 3C9 959 703
   Component: Tuer-SG         021 2505
   Coding: 0000144
   VCID: 70EFF04A634750C113-8024
   Component:    RDK              0391
   Coding: 0161211
   Part No: 3C9 959 704
   Coding: 0000144
   VCID: 71E9F54E684D59C91C-8024
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 B    HW: 3C0 919 283 B
   Component: Parkhilfe 8-Kan 004 0011
   Revision: 00004000    Serial number: 82930535505756
   Coding: 0001024
   VCID: 285FD82A9B1758018B-807C
Address 77: Telephone
End-------------------------(Elapsed Time: 02:43)--------------------------
Thursday	9	March	2017	08:27:32:5	VCDS Ver	Data version: 20170220 DS267.3
03H 997 033 K	P3.2 FSI-EU4    G00 2368
Group A:	'103		Group B:	'231		Group C:	 Not Running
Current	Fuel Press	Adaptatio	Demand controlled	Steering	Rail Press	Rail Press	Bin. Bits
TIME	Fuel Press	Regulator	elect. Fue	Fuel Pum	TIME		(specified	(actual)		TIME
Marker	STAMP	 bar		STAMP	°	 bar	 bar		STAMP
0.17	6.64	17	196	Test OFF	0.05	-110.4	35	6.64	0
0.45	6.64	17	196	Test OFF	0.3	-110.4	35	6.64	0
0.71	6.64	17	196	Test OFF	0.58	-110.4	35	6.64	0
0.99	6.64	17	196	Test OFF	0.83	-110.4	35	6.64	0
1.25	6.64	17	196	Test OFF	1.12	-110.4	35	6.64	0
1.52	6.64	17	196	Test OFF	1.38	-110.4	35	6.64	0
1.78	6.64	17	196	Test OFF	1.66	-110.4	35	6.64	0
2.06	6.63	17	196	Test OFF	1.91	-110.4	35	6.63	0
2.31	6.5	20	196	Test OFF	2.19	-110.4	35	6.62	0
2.58	6.4	26	196	Test OFF	2.44	113.6	23.18	23.24	1
2.85	6.59	31	196	Test OFF	2.72	113.6	39.24	39.54	1
3.12	6.63	35	196	Test OFF	2.97	113.6	39.58	44.62	1
3.38	6.73	38	196	Test OFF	3.25	16	53.22	86.77	1
3.65	6.9	39	196	Test OFF	3.5	16	70.5	129.78	1
3.9	6.99	38	196	Test OFF	3.78	16	76.24	129.74	1
4.18	7.04	37	196	Test OFF	4.03	16	75.33	129.91	1
4.43	7.08	35	196	Test OFF	4.31	16	74.4	129.81	1
4.71	7.1	33	196	Test OFF	4.56	14.4	73.17	129.46	1
4.96	7.12	31	196	Test OFF	4.84	14.4	70.55	128.58	1
5.25	7.11	28	196	Test OFF	5.09	11.2	70.02	129.03	1
5.52	7.1	26	196	Test OFF	5.39	11.2	70	128.32	1
5.8	7.1	24	196	Test OFF	5.65	11.2	70	128.33	1
6.05	7.1	22	196	Test OFF	5.93	11.2	70	127.56	1
6.34	7.09	19	196	Test OFF	6.19	11.2	70	127.44	1
6.59	7.1	17	196	Test OFF	6.47	11.2	70	128.19	1
6.86	7.1	15	196	Test OFF	6.71	11.2	70	127.85	1
7.12	7.1	13	196	Test OFF	6.99	11.2	70	127.67	1
7.39	7.1	11	196	Test OFF	7.24	9.6	70	128.01	1
7.65	7.1	9	196	Test OFF	7.52	9.6	70	127.26	1	L36
7.92	7.1	7	196	Test OFF	7.77	11.2	70	127.64	1
8.18	7.11	4	196	Test OFF	8.05	9.6	70	127.72	1
8.45	7.1	2	196	Test OFF	8.3	9.6	70	128.01	1
8.71	7.1	0	196	Test OFF	8.58	9.6	70	127.25	1
8.98	7.09	-2	196	Test OFF	8.83	9.6	70	127.36	1
9.24	7.1	-4	196	Test OFF	9.11	9.6	70	127.9	1
9.51	7.09	-6	196	Test OFF	9.36	11.2	70	128.01	1
9.77	7.1	-8	196	Test OFF	9.64	9.6	70	127.12	1
10.05	7.09	-11	196	Test OFF	9.9	9.6	70	127.51	1
10.31	7.11	-13	196	Test OFF	10.18	11.2	70	127.9	1
10.58	7.1	-15	196	Test OFF	10.43	11.2	70	127.85	1
10.84	7.1	-17	196	Test OFF	10.71	9.6	70	127.3	1
11.11	7.1	-19	196	Test OFF	10.96	11.2	70	127.7	1
11.37	7.1	-21	196	Test OFF	11.24	11.2	70	127.46	1
11.65	7.09	-23	196	Test OFF	11.49	11.2	70	128.02	1
11.9	7.1	-25	196	Test OFF	11.77	11.2	70	127.63	1
12.17	7.1	-28	196	Test OFF	12.02	11.2	70	128.05	1
12.43	7.09	-30	196	Test OFF	12.3	9.6	70	127.2	1
12.72	7.1	-32	196	Test OFF	12.56	9.6	70	127.41	1
12.98	7.09	-34	196	Test OFF	12.85	11.2	70	127.41	1
13.26	7.09	-36	196	Test OFF	13.11	11.2	70	127.32	1
13.52	7.09	-38	196	Test OFF	13.39	11.2	70	127.76	1
13.79	7.09	-40	196	Test OFF	13.64	9.6	70	127.96	1
14.05	7.09	-42	196	Test OFF	13.92	9.6	70	127.43	1
14.32	7.09	-44	196	Test OFF	14.17	11.2	70	127.78	1
14.58	7.09	-46	196	Test OFF	14.46	11.2	70	127.13	1
14.85	7.09	-48	196	Test OFF	14.7	11.2	70	127.47	1
15.11	7.09	-50	196	Test OFF	14.98	9.6	70	127.9	1
15.38	7.09	-52	196	Test OFF	15.24	9.6	70	127.57	1
15.64	7.08	-54	196	Test OFF	15.52	11.2	70	127.94	1
15.95	7.08	-57	196	Test OFF	15.79	11.2	70	127.87	1
16.21	7.09	-59	196	Test OFF	16.08	9.6	70	127.6	1
16.51	7.09	-61	196	Test OFF	16.35	9.6	70	127.08	1
16.77	7.09	-63	196	Test OFF	16.64	9.6	70	127.16	1
17.06	7.08	-65	196	Test OFF	16.91	9.6	70	127.76	1
17.31	7.09	-67	196	Test OFF	17.19	9.6	70	127.1	1
17.6	7.1	-69	196	Test OFF	17.44	11.2	70	127.65	1
17.86	7.08	-71	196	Test OFF	17.73	9.6	70	127.3	1
18.16	7.08	-74	196	Test OFF	18	9.6	70	128.03	1
18.42	7.08	-76	196	Test OFF	18.29	9.6	70	127.67	1
18.71	7.08	-78	196	Test OFF	18.56	9.6	70	127.27	1
18.96	7.08	-80	196	Test OFF	18.84	11.2	70	127.99	1
19.25	7.08	-82	196	Test OFF	19.09	11.2	70	127.98	1
19.51	7.07	-84	196	Test OFF	19.39	11.2	70	128.1	1
19.82	7.07	-86	196	Test OFF	19.66	9.6	70	127.96	1
20.08	7.09	-88	196	Test OFF	19.95	9.6	70	128.06	1
20.38	7.09	-90	196	Test OFF	20.21	9.6	70	127.58	1
20.64	7.09	-92	196	Test OFF	20.51	9.6	70	127.55	1
20.94	7.09	-94	196	Test OFF	20.78	9.6	70	127.84	1
21.2	7.08	-96	196	Test OFF	21.07	9.6	70	128.06	1
21.47	7.09	-98	196	Test OFF	21.32	9.6	70	127.73	1
21.73	7.09	-100	196	Test OFF	21.6	9.6	70	128.03	1
22	7.08	-102	196	Test OFF	21.85	9.6	70	127.43	1
22.26	7.09	-104	196	Test OFF	22.13	9.6	70	128.35	1
22.57	7.08	-106	196	Test OFF	22.4	9.6	70	127.88	1
22.85	7.09	-109	196	Test OFF	22.71	9.6	70	128.15	1
23.12	7.09	-110	196	Test OFF	22.97	11.2	70	128.37	1
23.38	7.08	-112	196	Test OFF	23.26	9.6	70	127.83	1
23.65	7.09	-115	196	Test OFF	23.5	9.6	70	127.47	1
23.91	7.09	-116	196	Test OFF	23.79	9.6	70	128.14	1
24.18	7.08	-118	196	Test OFF	24.04	9.6	70	127.57	1
24.44	7.08	-120	196	Test OFF	24.31	9.6	70	128.3	1
24.72	7.08	-122	196	Test OFF	24.57	9.6	70	128.31	1
24.97	7.08	-124	196	Test OFF	24.84	9.6	70	127.49	1
25.26	7.08	-126	196	Test OFF	25.1	9.6	70	127.8	1
25.52	7.07	-128	196	Test OFF	25.39	9.6	70	127.81	1
25.81	7.08	-130	196	Test OFF	25.66	9.6	70	128.35	1
26.06	7.08	-132	196	Test OFF	25.94	11.2	70	127.63	1
26.35	7.08	-134	196	Test OFF	26.19	9.6	70	127.39	1
26.61	7.08	-136	196	Test OFF	26.48	9.6	70	127.49	1
26.91	7.08	-138	196	Test OFF	26.75	9.6	70	128	1
27.17	7.08	-140	196	Test OFF	27.04	9.6	70	128.03	1
27.44	7.07	-142	196	Test OFF	27.29	9.6	70	127.66	1
27.7	7.08	-144	196	Test OFF	27.58	9.6	70	128.11	1
28	7.09	-146	196	Test OFF	27.84	9.6	70	128.16	1
28.26	7.07	-148	196	Test OFF	28.14	9.6	70	127.61	1
28.54	7.07	-150	196	Test OFF	28.39	9.6	70	127.85	1
28.8	7.07	-152	196	Test OFF	28.67	9.6	70	127.77	1
29.1	7.07	-154	196	Test OFF	28.94	9.6	70	127.48	1
29.36	7.07	-155	196	Test OFF	29.23	9.6	70	127.6	1
29.66	7.07	-158	196	Test OFF	29.5	9.6	70	128.31	1
29.92	7.07	-159	196	Test OFF	29.79	9.6	70	128.19	1
30.2	7.07	-161	196	Test OFF	30.06	9.6	70	128.26	1
30.46	7.07	-163	196	Test OFF	30.34	9.6	70	127.81	1
30.74	7.07	-165	196	Test OFF	30.59	9.6	70	127.56	1
31.01	7.07	-167	196	Test OFF	30.87	9.6	70	127.86	1
31.3	7.07	-169	196	Test OFF	31.15	9.6	70	128.29	1
31.55	7.06	-171	196	Test OFF	31.43	9.6	70	128.24	1
31.83	7.07	-173	196	Test OFF	31.68	9.6	70	128.22	1
32.08	7.06	-174	196	Test OFF	31.96	9.6	70	127.47	1
32.36	7.07	-176	196	Test OFF	32.21	9.6	70	127.75	1
32.61	7.07	-178	196	Test OFF	32.49	11.2	70	128.21	1
32.89	7.07	-180	196	Test OFF	32.74	11.2	70	128.06	1
33.15	7.06	-181	196	Test OFF	33.02	9.6	70	128.3	1
33.43	7.06	-183	196	Test OFF	33.27	9.6	70	128	1
33.68	7.06	-185	196	Test OFF	33.55	9.6	70	127.48	1
33.95	7.07	-187	196	Test OFF	33.8	9.6	70	127.69	1
34.21	7.07	-189	196	Test OFF	34.08	9.6	70	127.7	1
34.51	7.06	-191	196	Test OFF	34.35	9.6	70	127.57	1
34.77	7.06	-192	196	Test OFF	34.64	9.6	70	127.85	1
35.04	7.06	-194	196	Test OFF	34.89	9.6	70	127.63	1
35.3	7.07	-196	196	Test OFF	35.17	9.6	70	127.83	1
35.57	7.06	-198	196	Test OFF	35.42	9.6	70	127.41	1
35.83	7.07	-199	196	Test OFF	35.71	9.6	70	128.05	1
36.11	7.06	-201	196	Test OFF	35.95	9.6	70	128.15	1
36.36	7.06	-203	196	Test OFF	36.24	9.6	70	127.91	1
36.65	7.06	-205	196	Test OFF	36.49	9.6	70	128.23	1
36.91	7.06	-207	196	Test OFF	36.78	9.6	70	127.59	1
37.21	7.05	-209	196	Test OFF	37.05	11.2	70	128.07	1
37.47	7.07	-210	196	Test OFF	37.34	11.2	70	128.18	1
37.76	7.05	-212	196	Test OFF	37.61	9.6	70	127.37	1
38.03	7.06	-214	196	Test OFF	37.89	9.6	70	128.18	1
38.3	7.06	-216	196	Test OFF	38.15	9.6	70	127.51	1
38.56	7.06	-217	196	Test OFF	38.43	9.6	70	128.16	1
38.86	7.06	-219	196	Test OFF	38.7	9.6	70	127.76	1
39.12	7.06	-221	196	Test OFF	38.99	9.6	70	127.54	1
39.4	7.05	-223	196	Test OFF	39.24	9.6	70	128.02	1
39.65	7.07	-224	196	Test OFF	39.52	9.6	70	128.13	1
39.95	7.07	-226	196	Test OFF	39.8	11.2	70	127.56	1
40.22	7.06	-228	196	Test OFF	40.09	9.6	70	128.18	1
40.52	7.06	-230	196	Test OFF	40.36	9.6	70	128.07	1
40.77	7.05	-232	196	Test OFF	40.65	9.6	70	127.42	1
41.05	7.06	-233	196	Test OFF	40.9	9.6	70	127.83	1
41.3	7.06	-235	196	Test OFF	41.18	9.6	70	127.63	1
41.57	7.05	-237	196	Test OFF	41.42	9.6	70	127.91	1
41.83	7.05	-238	196	Test OFF	41.7	9.6	70	128.16	1
42.11	7.05	-240	196	Test OFF	41.95	9.6	70	127.89	1
42.38	7.06	-242	196	Test OFF	42.25	9.6	70	128.11	1
42.65	7.05	-243	196	Test OFF	42.5	9.6	70	127.7	1
42.91	7.04	-245	196	Test OFF	42.78	9.6	70	128.11	1
43.18	7.05	-247	196	Test OFF	43.04	9.6	70	128.18	1
43.44	7.05	-248	196	Test OFF	43.32	9.6	70	127.28	1
43.72	7.05	-250	196	Test OFF	43.57	9.6	70	127.9	1
43.97	7.05	-251	196	Test OFF	43.85	9.6	70	127.43	1
44.27	7.05	-253	196	Test OFF	44.11	9.6	70	127.62	1
44.53	7.04	-255	196	Test OFF	44.41	9.6	70	127.64	1
44.81	7.05	-257	196	Test OFF	44.66	9.6	70	127.38	1
45.06	7.05	-258	196	Test OFF	44.94	9.6	70	127.9	1
45.34	7.04	-260	196	Test OFF	45.19	9.6	70	127.36	1
45.6	7.04	-261	196	Test OFF	45.47	9.6	70	128.13	1
45.87	7.04	-263	196	Test OFF	45.72	9.6	70	128.12	1
46.12	7.04	-264	196	Test OFF	46	9.6	70	127.94	1
46.4	7.05	-266	196	Test OFF	46.25	9.6	70	128.16	1
46.65	7.04	-267	196	Test OFF	46.53	9.6	70	127.68	1
46.93	7.05	-269	196	Test OFF	46.78	9.6	70	127.39	1
47.18	7.03	-270	196	Test OFF	47.06	9.6	70	128.22	1
47.47	7.04	-272	196	Test OFF	47.31	9.6	70	127.71	1
47.73	7.04	-274	196	Test OFF	47.61	9.6	70	128.26	1
48	7.05	-275	196	Test OFF	47.85	9.6	70	127.7	1
48.26	7.04	-277	196	Test OFF	48.14	9.6	70	128.15	1
48.53	7.04	-278	196	Test OFF	48.39	9.6	70	128.17	1
48.79	7.04	-280	196	Test OFF	48.66	9.6	70	127.49	1
49.08	7.03	-281	196	Test OFF	48.93	9.6	70	128.16	1
49.34	7.03	-283	196	Test OFF	49.22	9.6	70	128.21	1
49.62	7.04	-284	196	Test OFF	49.46	9.6	70	127.93	1
49.87	7.04	-286	196	Test OFF	49.74	11.2	70	127.36	1
50.14	7.03	-287	196	Test OFF	49.99	11.2	70	127.95	1
50.4	7.04	-289	196	Test OFF	50.27	11.2	70	128.15	1
50.67	7.03	-290	196	Test OFF	50.52	9.6	70	128.18	1
50.93	7.03	-291	196	Test OFF	50.8	9.6	70	127.73	1
51.2	7.04	-293	196	Test OFF	51.05	9.6	70	127.48	1
51.46	7.04	-294	196	Test OFF	51.33	9.6	70	127.81	1
51.73	7.02	-296	196	Test OFF	51.59	9.6	70	127.43	1
51.99	7.02	-297	196	Test OFF	51.86	9.6	70	127.97	1
52.26	7.02	-299	196	Test OFF	52.11	9.6	70	128.22	1
52.52	7.02	-300	196	Test OFF	52.4	9.6	70	127.87	1
52.79	7.03	-301	196	Test OFF	52.64	9.6	70	128.17	1
53.05	7.01	-302	196	Test OFF	52.93	9.6	70	127.57	1
53.33	7.03	-304	196	Test OFF	53.18	9.6	70	127.36	1
53.58	7.03	-305	196	Test OFF	53.46	9.6	70	128.16	1
53.86	7.03	-307	196	Test OFF	53.71	9.6	70	127.65	1
54.11	7	-308	196	Test OFF	53.99	9.6	70	128.16	1
54.4	7.02	-309	196	Test OFF	54.24	9.6	70	128.03	1
54.66	6.99	-310	196	Test OFF	54.53	9.6	70	128.04	1
54.94	7.01	-311	196	Test OFF	54.79	9.6	70	127.96	1
55.21	7.02	-313	196	Test OFF	55.08	11.2	70	128.1	1
55.49	6.99	-314	196	Test OFF	55.34	11.2	70	128.16	1
55.75	6.98	-315	196	Test OFF	55.62	11.2	70	127.56	1
56.04	6.96	-316	196	Test OFF	55.89	9.6	70	127.51	1
56.3	6.98	-316	196	Test OFF	56.17	9.6	70	128.09	1
56.59	7	-318	196	Test OFF	56.44	9.6	70	127.87	1
56.85	7	-319	196	Test OFF	56.72	9.6	70	128.15	1
57.13	6.98	-320	196	Test OFF	56.98	9.6	70	128.13	1
57.4	6.97	-321	196	Test OFF	57.27	9.6	70	128.08	1
57.68	6.95	-321	196	Test OFF	57.53	9.6	70	128.22	1
57.93	6.96	-322	196	Test OFF	57.81	9.6	70	127.89	1
58.21	6.97	-323	196	Test OFF	58.06	9.6	70	128.41	1
58.46	6.97	-323	196	Test OFF	58.34	9.6	70	127.84	1
58.74	6.99	-324	196	Test OFF	58.59	9.6	70	127.56	1
58.99	6.99	-325	196	Test OFF	58.87	9.6	70	128.68	1
59.27	6.99	-326	196	Test OFF	59.12	9.6	70	128.08	1
59.54	6.98	-327	196	Test OFF	59.4	9.6	69.93	128.06	1
59.83	6.98	-328	196	Test OFF	59.68	9.6	69.64	128.03	1
60.1	6.99	-329	196	Test OFF	59.96	9.6	69.4	128.39	1
60.39	6.97	-330	196	Test OFF	60.22	9.6	69.42	128.05	1
60.65	6.96	-331	196	Test OFF	60.52	9.6	69.29	127.93	1
60.92	6.96	-331	196	Test OFF	60.77	9.6	69.31	128.4	1
61.18	6.95	-332	196	Test OFF	61.05	8	69.63	128.74	1
61.47	6.96	-333	196	Test OFF	61.31	8	69.46	127.92	1
61.73	6.94	-333	196	Test OFF	61.6	9.6	69.53	128.04	1
62	6.95	-334	196	Test OFF	61.85	9.6	69.44	127.98	1
62.26	6.94	-334	196	Test OFF	62.13	9.6	69.48	127.96	1
62.55	6.92	-334	196	Test OFF	62.4	9.6	69.46	127.68	1
62.8	6.93	-335	196	Test OFF	62.67	9.6	69.55	128.58	1
63.07	6.93	-335	196	Test OFF	62.92	11.2	69.81	128.01	1
63.33	6.93	-336	196	Test OFF	63.21	9.6	69.66	127.46	1
63.6	6.94	-336	196	Test OFF	63.46	11.2	69.59	128.13	1
63.86	6.91	-336	196	Test OFF	63.73	11.2	69.59	127.9	1
64.13	6.91	-337	196	Test OFF	63.99	11.2	69.37	127.62	1
64.39	6.92	-337	196	Test OFF	64.27	11.2	69.47	127.93	1
64.66	6.9	-337	196	Test OFF	64.51	11.2	69.59	127.21	1
64.93	6.89	-337	196	Test OFF	64.79	11.2	69.55	127.79	1
65.21	6.9	-337	196	Test OFF	65.06	11.2	69.5	127	1
65.47	6.88	-337	196	Test OFF	65.34	11.2	69.56	128.05	1
65.75	6.89	-337	196	Test OFF	65.6	11.2	69.44	127.82	1
66	6.88	-337	196	Test OFF	65.88	11.2	69.58	126.94	1
66.29	6.9	-337	196	Test OFF	66.13	11.2	69.63	127.86	1
66.54	6.89	-337	196	Test OFF	66.42	11.2	69.4	127.6	1
66.82	6.89	-336	196	Test OFF	66.67	11.2	69.4	127.71	1
67.08	6.85	-336	196	Test OFF	66.95	11.2	69.56	127.06	1
67.35	6.84	-335	196	Test OFF	67.2	11.2	69.7	127.7	1
67.61	6.86	-335	196	Test OFF	67.48	11.2	69.74	127.72	1
67.88	6.85	-334	196	Test OFF	67.73	11.2	69.62	126.61	1
68.15	6.88	-334	196	Test OFF	68.01	11.2	69.59	127.21	1
68.43	6.87	-333	196	Test OFF	68.28	11.2	69.7	126.88	1
68.68	6.87	-333	196	Test OFF	68.56	11.2	69.71	126.56	1
68.96	6.85	-332	196	Test OFF	68.81	11.2	69.67	127.41	1
69.22	6.84	-332	196	Test OFF	69.08	11.2	69.64	126.78	1
69.52	6.87	-331	196	Test OFF	69.36	11.2	69.52	127.53	1
69.77	6.84	-331	196	Test OFF	69.65	11.2	69.63	126.94	1
70.04	6.84	-330	196	Test OFF	69.9	11.2	69.7	127.96	1
70.31	6.86	-330	196	Test OFF	70.18	11.2	69.64	128.08	1
70.58	6.88	-329	196	Test OFF	70.43	11.2	69.55	127.17	1
70.84	6.86	-329	196	Test OFF	70.71	11.2	69.56	127.45	1
71.11	6.87	-328	196	Test OFF	70.95	11.2	69.63	127.74	1
71.37	6.87	-328	196	Test OFF	71.23	11.2	69.71	127.65	1
71.65	6.84	-327	196	Test OFF	71.49	11.2	69.52	127.82	1
71.91	6.86	-326	196	Test OFF	71.79	11.2	69.67	127.98	1
72.19	6.87	-326	196	Test OFF	72.03	11.2	69.64	126.54	1
72.45	6.85	-325	196	Test OFF	72.32	11.2	69.63	126.61	1
72.71	6.85	-325	196	Test OFF	72.57	11.2	69.54	127.93	1
72.97	6.85	-324	196	Test OFF	72.85	11.2	69.5	128.01	1
73.25	6.87	-324	196	Test OFF	73.1	11.2	69.67	127	1
73.51	6.85	-323	196	Test OFF	73.38	11.2	69.56	127.01	1
73.81	6.87	-323	196	Test OFF	73.65	11.2	69.52	127.16	1
74.06	6.86	-322	196	Test OFF	73.94	11.2	69.64	127.7	1
74.33	6.86	-322	196	Test OFF	74.19	11.2	69.6	127.8	1
74.6	6.84	-321	196	Test OFF	74.47	11.2	69.53	127.78	1
74.89	6.84	-321	196	Test OFF	74.74	11.2	69.5	127.73	1
75.16	6.86	-320	196	Test OFF	75.02	11.2	69.53	127.53	1
75.43	6.86	-320	196	Test OFF	75.28	11.2	69.62	127.93	1
75.68	6.88	-319	196	Test OFF	75.57	11.2	69.52	127.9	1
75.97	6.87	-319	196	Test OFF	75.81	11.2	69.68	127.64	1
76.23	6.84	-318	196	Test OFF	76.11	11.2	69.62	126.58	1
76.52	6.84	-318	196	Test OFF	76.36	11.2	69.6	127.89	1
76.78	6.86	-317	196	Test OFF	76.66	11.2	69.77	127.57	1
77.06	6.86	-317	196	Test OFF	76.91	11.2	69.5	127.92	1
77.31	6.87	-316	196	Test OFF	77.19	11.2	69.53	127.91	1
77.58	6.83	-316	196	Test OFF	77.43	11.2	69.69	127.63	1
77.86	6.83	-315	196	Test OFF	77.72	11.2	69.63	127.75	1
78.13	6.84	-314	196	Test OFF	77.98	11.2	69.8	127.02	1
78.38	6.84	-314	196	Test OFF	78.26	12.8	69.68	126.75	1
78.66	6.83	-313	196	Test OFF	78.51	11.2	69.83	127.49	1
78.93	6.86	-312	196	Test OFF	78.79	12.8	69.93	127.54	1
79.2	6.87	-312	196	Test OFF	79.05	11.2	69.79	127.59	1
79.48	6.87	-311	196	Test OFF	79.34	11.2	69.78	127.6	1
79.76	6.87	-311	196	Test OFF	79.61	11.2	69.67	127.68	1
80.04	6.87	-310	196	Test OFF	79.9	11.2	69.5	127.98	1
80.34	6.84	-310	196	Test OFF	80.18	12.8	69.81	127.56	1
80.6	6.87	-309	196	Test OFF	80.47	11.2	69.63	127.52	1
80.87	6.87	-309	196	Test OFF	80.73	11.2	69.54	126.55	1
81.13	6.88	-308	196	Test OFF	81.01	11.2	69.78	126.47	1
81.42	6.88	-308	196	Test OFF	81.27	11.2	69.49	127.38	1
81.68	6.87	-308	196	Test OFF	81.55	11.2	69.63	127.43	1
81.98	6.89	-307	196	Test OFF	81.82	11.2	69.55	127.3	1
82.23	6.86	-307	196	Test OFF	82.11	11.2	69.55	127.15	1
82.51	6.86	-307	196	Test OFF	82.36	12.8	69.69	127.95	1
82.77	6.88	-306	196	Test OFF	82.64	12.8	69.71	127.92	1
83.04	6.89	-306	196	Test OFF	82.89	11.2	64.37	127.54	1
83.3	6.86	-306	196	Test OFF	83.17	11.2	56.26	127.39	1
83.57	6.87	-305	196	Test OFF	83.42	11.2	48.83	127.86	1
83.83	6.88	-305	196	Test OFF	83.7	11.2	44.7	127.91	1
84.1	6.88	-304	196	Test OFF	83.95	11.2	44.65	127.48	1
84.36	6.86	-304	196	Test OFF	84.23	11.2	44.69	127.46	1
84.63	6.87	-304	196	Test OFF	84.48	11.2	44.73	127.83	1
84.89	6.88	-303	196	Test OFF	84.77	11.2	44.69	127.88	1
85.16	6.88	-303	196	Test OFF	85.01	11.2	44.71	127.64	1
85.41	6.88	-303	196	Test OFF	85.29	11.2	44.62	127.58	1
85.69	6.88	-302	196	Test OFF	85.54	11.2	44.79	127.71	1
85.95	6.88	-302	196	Test OFF	85.83	11.2	44.7	127.56	1
86.22	6.88	-302	196	Test OFF	86.07	11.2	44.73	127.85	1
86.48	6.89	-302	196	Test OFF	86.36	11.2	44.77	127.77	1
86.77	6.86	-301	196	Test OFF	86.61	11.2	44.74	127	1
87.04	6.89	-301	196	Test OFF	86.9	12.8	44.79	126.72	1
87.33	6.89	-301	196	Test OFF	87.17	11.2	44.74	126.58	1
87.57	6.86	-300	196	Test OFF	87.45	11.2	44.67	126.73	1
87.86	6.87	-300	196	Test OFF	87.7	11.2	44.74	127.92	1
88.12	6.88	-300	196	Test OFF	88	11.2	44.7	127.41	1
88.42	6.86	-299	196	Test OFF	88.26	11.2	44.77	127.86	1
88.69	6.87	-299	196	Test OFF	88.56	11.2	44.74	127.47	1
88.98	6.86	-299	196	Test OFF	88.83	11.2	44.76	127.83	1
89.24	6.89	-298	196	Test OFF	89.12	11.2	44.81	127.6	1
89.52	6.89	-298	196	Test OFF	89.37	11.2	44.72	126.64	1
89.78	6.87	-298	196	Test OFF	89.65	11.2	44.75	126.8	1
90.08	6.88	-297	196	Test OFF	89.92	11.2	44.8	126.72	1
90.34	6.86	-297	196	Test OFF	90.21	11.2	44.74	126.9	1
90.64	6.89	-297	196	Test OFF	90.48	11.2	44.78	127.32	1
90.9	6.86	-296	196	Test OFF	90.77	12.8	44.63	127.15	1
91.2	6.88	-296	196	Test OFF	91.04	12.8	44.75	127.37	1
91.46	6.85	-296	196	Test OFF	91.33	11.2	44.76	127.55	1
91.73	6.88	-295	196	Test OFF	91.58	12.8	44.82	127.13	1
91.99	6.85	-295	196	Test OFF	91.86	11.2	44.74	126.75	1
92.29	6.88	-294	196	Test OFF	92.13	11.2	44.78	127.45	1
92.55	6.85	-294	196	Test OFF	92.43	11.2	44.78	126.37	1
92.84	6.85	-294	196	Test OFF	92.67	11.2	44.83	127.22	1
93.09	6.88	-293	196	Test OFF	92.97	11.2	44.79	127.83	1
93.38	6.88	-293	196	Test OFF	93.23	11.2	44.78	126.47	1
93.64	6.84	-293	196	Test OFF	93.51	11.2	44.82	123.24	1
93.92	6.83	-292	196	Test OFF	93.76	12.8	44.75	124.55	1
94.17	6.85	-291	196	Test OFF	94.05	11.2	44.78	122.07	1
94.46	6.84	-290	196	Test OFF	94.31	11.2	44.76	124.57	1
94.71	6.82	-290	196	Test OFF	94.59	11.2	44.7	121.44	1
94.99	6.8	-289	196	Test OFF	94.84	11.2	44.76	124.35	1
95.24	6.86	-288	196	Test OFF	95.12	12.8	44.74	122.54	1
95.51	6.82	-287	196	Test OFF	95.37	12.8	44.81	123.48	1
95.76	6.85	-286	196	Test OFF	95.63	11.2	44.82	123.39	1
96.03	6.82	-285	196	Test OFF	95.88	12.8	44.87	123.4	1
96.29	6.83	-285	196	Test OFF	96.17	12.8	44.77	124.93	1
96.56	6.84	-284	196	Test OFF	96.41	12.8	44.87	123.11	1
96.85	6.84	-283	196	Test OFF	96.7	11.2	44.77	124.9	1
97.13	6.84	-282	196	Test OFF	96.98	12.8	44.89	121.59	1
97.41	6.83	-281	196	Test OFF	97.27	12.8	44.86	123.58	1
97.69	6.84	-281	196	Test OFF	97.54	12.8	44.78	124.75	1
97.94	6.85	-280	196	Test OFF	97.82	11.2	44.83	121.94	1
98.23	6.85	-279	196	Test OFF	98.07	11.2	44.76	124.95	1
98.48	6.84	-278	196	Test OFF	98.37	11.2	44.77	121.88	1
98.77	6.82	-277	196	Test OFF	98.62	12.8	44.87	123.66	1
99.02	6.86	-277	196	Test OFF	98.9	11.2	44.7	124.92	1
99.29	6.87	-276	196	Test OFF	99.14	11.2	44.81	123.27	1
99.55	6.83	-276	196	Test OFF	99.42	11.2	44.74	124.96	1
99.83	6.85	-275	196	Test OFF	99.68	12.8	44.83	122.31	1
100.08	6.84	-274	196	Test OFF	99.96	12.8	44.78	124.27	1
100.36	6.87	-274	196	Test OFF	100.21	11.2	44.78	122.09	1
100.62	6.85	-273	196	Test OFF	100.49	12.8	44.85	124.11	1
100.89	6.88	-272	196	Test OFF	100.74	11.2	44.76	121.23	1
101.16	6.87	-272	196	Test OFF	101.03	11.2	44.75	123.11	1
101.43	6.82	-271	196	Test OFF	101.29	11.2	44.72	124.61	1
101.69	6.87	-271	196	Test OFF	101.57	12.8	44.8	122.17	1
101.96	6.85	-270	196	Test OFF	101.82	11.2	44.77	124.83	1
102.22	6.87	-269	196	Test OFF	102.09	11.2	44.78	121.93	1
102.5	6.88	-269	196	Test OFF	102.35	11.2	44.74	124.55	1
102.75	6.84	-268	196	Test OFF	102.63	12.8	44.83	121.44	1
103.03	6.85	-268	196	Test OFF	102.88	11.2	44.75	124.42	1
103.28	6.89	-268	196	Test OFF	103.16	11.2	44.74	122.89	1
103.57	6.88	-267	196	Test OFF	103.41	11.2	44.78	123.45	1
103.83	6.84	-267	196	Test OFF	103.7	11.2	44.75	125.01	1
104.1	6.88	-267	196	Test OFF	103.95	12.8	44.89	122.48	1
104.36	6.86	-266	196	Test OFF	104.24	12.8	44.84	124.48	1
104.63	6.85	-266	196	Test OFF	104.49	12.8	44.86	122.28	1
104.89	6.87	-265	196	Test OFF	104.76	11.2	44.77	124.29	1
105.18	6.88	-265	196	Test OFF	105.03	11.2	44.8	123.17	1
105.45	6.88	-264	196	Test OFF	105.32	11.2	44.84	122.62	1
105.73	6.84	-264	196	Test OFF	105.58	12.8	44.76	125.07	1
105.99	6.85	-264	196	Test OFF	105.86	11.2	44.74	121.72	1
106.27	6.87	-263	196	Test OFF	106.12	12.8	44.71	124.19	1
106.53	6.9	-263	196	Test OFF	106.4	12.8	44.74	123.92	1
106.8	6.89	-263	196	Test OFF	106.65	11.2	44.72	123.77	1
107.06	6.85	-262	196	Test OFF	106.93	11.2	44.7	124.71	1
107.33	6.89	-262	196	Test OFF	107.18	11.2	44.75	122.77	1
107.59	6.85	-262	196	Test OFF	107.46	12.8	44.81	124.59	1
107.89	6.91	-262	196	Test OFF	107.73	12.8	44.76	121.94	1
108.15	6.87	-261	196	Test OFF	108.03	12.8	44.82	123.25	1
108.44	6.85	-261	196	Test OFF	108.29	12.8	44.84	124.23	1
108.71	6.89	-261	196	Test OFF	108.57	12.8	44.89	122.46	1
109	6.89	-260	196	Test OFF	108.83	11.2	44.79	124.91	1
109.26	6.86	-260	196	Test OFF	109.13	11.2	44.84	121.68	1
109.54	6.85	-260	196	Test OFF	109.39	12.8	44.88	123.67	1
109.79	6.89	-260	196	Test OFF	109.66	11.2	44.83	124.65	1
110.08	6.9	-259	196	Test OFF	109.92	11.2	44.84	123.52	1
110.34	6.86	-259	196	Test OFF	110.21	12.8	44.85	124.62	1
110.64	6.92	-259	196	Test OFF	110.48	11.2	44.78	121.85	1
110.9	6.87	-259	196	Test OFF	110.77	11.2	44.78	123.03	1
111.17	6.86	-258	196	Test OFF	111.02	11.2	44.7	123.16	1
111.43	6.9	-258	196	Test OFF	111.3	11.2	44.78	122.62	1
111.7	6.86	-258	196	Test OFF	111.55	11.2	44.71	125.1	1
111.96	6.89	-258	196	Test OFF	111.83	12.8	44.79	121.71	1
112.26	6.86	-258	196	Test OFF	112.1	11.2	44.75	124.41	1
112.52	6.92	-257	196	Test OFF	112.39	11.2	44.77	124.67	1
112.79	6.91	-257	196	Test OFF	112.64	11.2	44.77	123.54	1
113.05	6.9	-257	196	Test OFF	112.92	12.8	44.69	124.99	1
113.32	6.9	-257	196	Test OFF	113.17	12.8	44.89	122.56	1
113.58	6.86	-257	196	Test OFF	113.45	11.2	44.71	124.48	1
113.86	6.88	-257	196	Test OFF	113.71	11.2	44.77	122.27	1
114.11	6.89	-257	196	Test OFF	113.99	11.2	44.73	124.27	1
114.4	6.91	-257	196	Test OFF	114.23	12.8	44.83	121.36	1
114.67	6.87	-256	196	Test OFF	114.53	12.8	44.79	123.44	1
114.96	6.89	-256	196	Test OFF	114.8	11.2	44.75	124.97	1
115.22	6.87	-256	196	Test OFF	115.09	12.8	44.74	121.77	1
115.49	6.89	-256	196	Test OFF	115.34	11.2	44.72	124.4	1
115.75	6.9	-256	196	Test OFF	115.62	11.2	44.72	122.73	1
116.02	6.88	-256	196	Test OFF	115.87	12.8	44.81	124.08	1
116.28	6.9	-256	196	Test OFF	116.15	11.2	44.79	123.82	1
116.55	6.88	-255	196	Test OFF	116.4	12.8	44.85	123.32	1
116.81	6.88	-255	196	Test OFF	116.68	12.8	44.74	124.98	1
117.08	6.89	-255	196	Test OFF	116.93	11.2	44.82	123	1
117.34	6.87	-255	196	Test OFF	117.21	11.2	44.74	124.76	1
117.62	6.87	-255	196	Test OFF	117.47	11.2	44.76	122.04	1
117.87	6.9	-255	196	Test OFF	117.75	11.2	44.79	124.03	1
118.15	6.91	-255	196	Test OFF	118	12.8	44.97	121.76	1
118.4	6.91	-255	196	Test OFF	118.28	11.2	44.8	123.84	1
118.68	6.93	-255	196	Test OFF	118.53	11.2	44.73	122.24	1
118.95	6.91	-255	196	Test OFF	118.81	11.2	44.79	122.82	1
119.22	6.87	-255	196	Test OFF	119.07	12.8	44.76	124.88	1
119.48	6.9	-254	196	Test OFF	119.35	11.2	44.78	121.86	1
119.77	6.86	-254	196	Test OFF	119.62	12.8	44.81	124.42	1
120.04	6.91	-254	196	Test OFF	119.9	11.2	44.77	122.19	1
120.31	6.9	-254	196	Test OFF	120.16	12.8	44.88	123.63	1
120.57	6.92	-254	196	Test OFF	120.44	11.2	44.76	124.6	1
120.84	6.91	-254	196	Test OFF	120.69	11.2	44.86	122.8	1
121.1	6.87	-254	196	Test OFF	120.98	11.2	44.75	124.57	1
121.37	6.88	-254	196	Test OFF	121.23	11.2	44.84	122.52	1
121.63	6.89	-254	196	Test OFF	121.51	11.2	44.74	124.29	1
121.9	6.9	-254	196	Test OFF	121.75	11.2	44.8	121.42	1
122.16	6.87	-253	196	Test OFF	122.04	12.8	44.81	123.4	1
122.44	6.89	-253	196	Test OFF	122.29	11.2	44.8	121.45	1
122.69	6.87	-253	196	Test OFF	122.57	12.8	44.77	123.07	1
122.98	6.88	-253	196	Test OFF	122.82	11.2	44.81	124.66	1
123.24	6.88	-253	196	Test OFF	123.11	11.2	44.81	122.17	1
123.54	6.88	-253	196	Test OFF	123.38	11.2	44.82	124.11	1
123.8	6.9	-253	196	Test OFF	123.67	11.2	44.81	123.95	1
124.07	6.91	-253	196	Test OFF	123.92	11.2	44.81	123.22	1
124.33	6.88	-253	196	Test OFF	124.2	11.2	44.74	124.88	1
124.6	6.88	-253	196	Test OFF	124.45	11.2	44.84	122.85	1
124.86	6.87	-253	196	Test OFF	124.73	11.2	44.79	124.67	1
125.15	6.92	-253	196	Test OFF	124.99	11.2	44.79	121.97	1
125.41	6.88	-253	196	Test OFF	125.28	11.2	44.78	123.89	1
125.68	6.93	-253	196	Test OFF	125.53	12.8	44.76	122.2	1
125.94	6.88	-253	196	Test OFF	125.81	12.8	44.83	122.88	1
126.21	6.86	-252	196	Test OFF	126.06	11.2	44.75	123.51	1
126.47	6.9	-252	196	Test OFF	126.34	12.8	44.85	122.64	1
126.74	6.86	-252	196	Test OFF	126.59	11.2	44.78	124.98	1
127	6.9	-252	196	Test OFF	126.87	12.8	44.79	121.85	1
127.3	6.86	-252	196	Test OFF	127.14	12.8	44.75	124.46	1
127.56	6.9	-252	196	Test OFF	127.43	12.8	44.79	124.16	1
127.86	6.9	-251	196	Test OFF	127.7	12.8	44.81	123.16	1
128.12	6.86	-251	196	Test OFF	127.99	12.8	44.84	124.47	1
128.43	6.91	-251	196	Test OFF	128.26	11.2	44.85	121.77	1
128.68	6.87	-251	196	Test OFF	128.56	12.8	44.81	123.22	1
128.97	6.85	-251	196	Test OFF	128.82	12.8	44.9	124.1	1
129.25	6.9	-251	196	Test OFF	129.11	11.2	44.86	122.61	1
129.53	6.87	-250	196	Test OFF	129.38	12.8	44.89	124.62	1
129.79	6.86	-250	196	Test OFF	129.67	11.2	44.81	121.25	1
130.08	6.87	-250	196	Test OFF	129.92	12.8	44.89	124.02	1
Gone But Not Forgotten
Check lift pump & prime function measuring PSI/volume when car is unarmed cold or door first opened before commencing crank.
Check integrated FPR function!
Rekked
Australia
C?ID=224535
Hi Jack, thanks for your reply.
I connected the fuel gauge and when the door is first opened a flow rate of 2 litres (occurs for 3 or 4 seconds) per minute and a pressure of 6.5 BAR happens.
residual pressure stays above 3 bar as it should.
When the vehicle is running with the needle style pressure gauge, the needle bounces pretty rapidly between 5 and 7 BAR.
The flow rate stays at basically nothing, is this because it is a non return fuel system and the idle rpm isn't consuming much fuel?
When you say checking the integrated FPR is this just confirming that it gets to and holds at 6.5 BAR or is there something else i should be checking.
I also managed to get some data when the car starts up rough. High Pressure Fuel Pressure in the Rail runs at exactly the same as Low Pressure Fuel Pressure
see below
Group A:	'103				Group B:	'106				Group C:	'231
		Current	Fuel Pressure	Adaptation Value	Demand controlled		Fuel Rail	Electrical	 	Shut-Off Time		Steering Angle	Rail Pressure	Rail Pressure	Bin. Bits
	TIME	Fuel Pressure	Regulator	elect. Fuel Pump	Fuel Pump Adapt.	TIME	Pressure	Fuel Pump			TIME		(specified)	(actual)
Marker	STAMP	 bar				STAMP	 bar	 %		 s	STAMP	°	 bar	 bar
	0.02	6.97	-203	196	Test OFF	0.14	6.82	67.8	 	655.35	0.28	-97.6	44.31	7.02	1
	0.4	6.95	-203	196	Test OFF	0.55	6.92	68.2	 	655.35	0.68	-97.6	44.36	7.01	1
	0.81	7	-203	196	Test OFF	0.93	6.81	67.8	 	655.35	1.08	-97.6	44.32	6.97	1
	1.21	7.02	-203	196	Test OFF	1.34	6.84	67.8	 	655.35	1.48	-97.6	44.36	6.98	1
	1.64	6.89	-203	196	Test OFF	1.76	6.99	67.8	 	655.35	1.89	-97.6	44.32	6.92	1
	2.01	6.8	-203	196	Test OFF	2.15	7	67.8	 	655.35	2.29	-97.6	44.13	6.94	1
	2.42	7.01	-203	196	Test OFF	2.54	6.9	67.5	 	655.35	2.69	-97.6	44.21	6.89	1
	2.82	6.99	-203	196	Test OFF	2.95	6.97	67.8	 	655.35	3.07	-97.6	44.19	6.82	1
	3.22	6.89	-203	196	Test OFF	3.35	6.97	68.2	 	655.35	3.48	-97.6	44.18	6.8	1
	3.6	6.87	-202	196	Test OFF	3.75	7.01	67.8	 	655.35	3.88	-97.6	44.26	6.79	1
	4.01	6.99	-202	196	Test OFF	4.15	6.91	67.8	 	655.35	4.3	-97.6	44.22	6.94	1
	4.43	6.9	-202	196	Test OFF	4.57	6.87	67.5	 	655.35	4.71	-97.6	44.17	7	1
	4.86	6.81	-202	196	Test OFF	4.99	6.95	67.5	 	655.35	5.12	-97.6	44.19	7.01	1
	5.24	6.98	-202	196	Test OFF	5.39	6.96	68.2	 	655.35	5.52	-97.6	44.22	6.94	1
	5.66	6.89	-201	196	Test OFF	5.79	6.97	67.8	 	655.35	5.94	-97.6	44.18	6.8	1
	6.07	6.79	-201	196	Test OFF	6.19	6.91	68.2	 	655.35	6.32	-97.6	44.22	6.78	1
	6.47	6.92	-201	196	Test OFF	6.6	6.82	68.2	 	655.35	6.72	-97.6	44.19	6.84	1
	6.85	6.93	-201	196	Test OFF	7.01	6.79	68.2	 	655.35	7.14	-97.6	44.18	6.93	1
	7.27	7	-201	196	Test OFF	7.39	6.82	67.8	 	655.35	7.54	-97.6	44.18	6.99	1
	7.67	6.96	-201	196	Test OFF	7.8	6.91	68.2	 	655.35	7.92	-97.6	44.18	7.01	1
	8.07	6.89	-201	196	Test OFF	8.2	6.97	67.5	 	655.35	8.33	-97.6	44.14	6.98	1
	8.45	6.84	-201	196	Test OFF	8.6	6.98	67.5	 	655.35	8.73	-97.6	44.21	6.86	1
	8.85	6.97	-201	196	Test OFF	8.98	6.96	68.2	 	655.35	9.13	-97.6	44.19	6.8	1
	9.26	7.02	-201	196	Test OFF	9.39	6.91	67.5	 	655.35	9.52	-97.6	44.17	6.81	1
	9.67	7	-201	196	Test OFF	9.79	6.83	67.5	 	655.35	9.92	-97.6	44.19	6.83	1
	10.05	6.79	-200	196	Test OFF	10.2	6.8	67.5	 	655.35	10.33	-97.6	44.17	6.94	1
	10.45	6.91	-201	196	Test OFF	10.58	6.86	67.1	 	655.35	10.74	-97.6	44.11	7	1
	10.87	6.78	-201	196	Test OFF	11	6.88	68.2	 	655.35	11.14	-97.6	44.15	7.01	1
	11.29	6.92	-201	196	Test OFF	11.42	6.97	67.5	 	655.35	11.54	-97.6	44.1	6.97	1
	11.67	6.83	-200	196	Test OFF	11.83	7.01	68.2	 	655.35	11.96	-97.6	44.2	6.96	1
	12.09	6.8	-201	196	Test OFF	12.23	7.02	67.8	 	655.35	12.38	-97.6	44.12	6.79	1
	12.51	6.89	-200	196	Test OFF	12.65	6.91	67.5	 	655.35	12.78	-97.6	44.11	6.84	1
	12.92	6.99	-200	196	Test OFF	13.05	6.88	67.5	 	655.35	13.18	-97.6	43.93	6.99	1
	13.33	7.01	-201	196	Test OFF	13.49	6.86	67.5	 	655.35	13.62	-97.6	43.85	7	1
	13.75	6.97	-201	196	Test OFF	13.89	6.94	68.2	 	655.35	14.04	-97.6	43.85	6.96	1
	14.18	6.85	-200	196	Test OFF	14.31	6.99	67.5	 	655.35	14.45	-97.6	43.88	6.84	1
	14.59	6.79	-200	196	Test OFF	14.73	6.92	68.2	 	655.35	14.87	-97.6	43.84	6.79	1
	14.99	6.88	-200	196	Test OFF	15.14	6.87	67.5	 	655.35	15.27	-97.6	43.84	6.82	1
	15.4	6.91	-200	196	Test OFF	15.52	6.83	68.6	 	655.35	15.67	-97.6	43.8	6.87	1
	15.8	6.98	-200	196	Test OFF	15.93	6.79	67.5	 	655.35	16.05	-97.6	43.82	6.94	1
	16.2	7.02	-200	196	Test OFF	16.33	6.84	67.5	 	655.35	16.46	-97.6	43.77	6.99	1
	16.58	6.79	-200	196	Test OFF	16.73	6.91	68.2	 	655.35	16.86	-97.6	43.83	7	1
	16.99	6.82	-200	196	Test OFF	17.11	6.99	68.2	 	655.35	17.26	-97.6	43.86	6.97	1
	17.39	6.82	-200	196	Test OFF	17.52	7.01	67.5	 	655.35	17.64	-97.6	43.84	6.85	1
	17.82	6.9	-200	196	Test OFF	17.96	6.92	67.5	 	655.35	18.08	-97.6	43.83	6.78	1
	18.2	6.9	-200	196	Test OFF	18.35	6.84	67.5	 	655.35	18.49	-97.6	43.84	6.85	1
	18.61	6.97	-200	196	Test OFF	18.73	6.78	68.2	 	655.35	18.88	-97.6	43.86	6.95	1
	19.01	6.99	-200	196	Test OFF	19.14	6.85	67.8	 	655.35	19.26	-97.6	43.81	7	1
	19.41	6.96	-200	196	Test OFF	19.54	6.96	67.5	 	655.35	19.67	-97.6	43.78	6.98	1
	19.79	6.84	-200	196	Test OFF	19.94	6.98	68.2	 	655.35	20.07	-97.6	43.93	6.9	1
	20.2	6.79	-200	196	Test OFF	20.33	6.97	67.5	 	655.35	20.47	-97.6	43.84	6.79	1
	20.61	6.91	-200	196	Test OFF	20.73	6.82	67.5	 	655.35	20.86	-97.6	43.85	6.84	1
	21	6.99	-200	196	Test OFF	21.14	6.8	67.5	 	655.35	21.26	-97.6	43.89	7	1
	21.39	6.8	-200	196	Test OFF	21.53	6.9	68.2	 	655.35	21.67	-97.6	43.86	6.99	1
	21.8	6.82	-200	196	Test OFF	21.94	6.99	68.6	 	655.35	22.09	-97.6	43.9	6.9	1
	22.23	7	-200	196	Test OFF	22.35	7	67.8	 	655.35	22.48	-97.6	43.86	6.79	1
	22.63	6.82	-200	196	Test OFF	22.76	6.83	67.5	 	655.35	22.88	-97.6	46.37	6.8	1
	23.01	6.84	-199	196	Test OFF	23.17	7.03	68.6	 	655.35	23.31	-99.2	55.64	6.98	1
	23.45	7.04	-201	196	Test OFF	23.59	7.04	68.6	 	655.35	23.75	-99.2	66.53	7.01	1
	23.88	7.02	-203	196	Test OFF	24.02	7.02	69.8	 	655.35	24.15	-96	86.17	7	1
	24.31	7	-205	196	Test OFF	24.44	7.04	71	 	655.35	24.57	-80	84.72	56.09	1
	24.71	6.38	-202	196	Test OFF	24.86	132.98	72.2	 	655.35	24.99	-33.6	126.86	126.86	0
	25.13	6.85	-198	196	Test OFF	25.27	122.91	34.9	 	655.35	25.44	-36.8	122.34	122.34	0
	25.57	6.89	-198	196	Test OFF	25.69	130.02	69.8	 	655.35	25.84	12.8	83.66	130.33	1
	26	6.78	-195	196	Test OFF	26.13	130.49	69.8	 	655.35	26.26	12.8	69.02	130.54	1
	26.39	6.95	-195	196	Test OFF	26.54	130.33	69	 	655.35	26.68	12.8	68.99	130.3	1
	26.8	6.97	-196	196	Test OFF	26.92	124	31.8	 	655.35	27.07	12.8	115.41	129.14	1
	27.21	6.89	-196	196	Test OFF	27.35	129.12	67.8	 	655.35	27.49	9.6	91.19	128.83	1
	27.64	6.95	-196	196	Test OFF	27.77	124.47	69	 	655.35	27.89	9.6	46.37	124.05	1
	28.02	7	-197	196	Test OFF	28.19	122.61	68.6	 	655.35	28.33	11.2	44.24	122.6	1
	28.45	7.01	-199	196	Test OFF	28.58	122.79	67.8	 	655.35	28.74	11.2	43.13	122.6	1
	28.88	7	-201	196	Test OFF	29	124.62	68.2	 	655.35	29.13	12.8	43.35	122.88	1
	29.27	6.98	-202	196	Test OFF	29.4	122.91	68.2	 	655.35	29.53	12.8	43.53	124.6	1
	29.66	6.9	-202	196	Test OFF	29.8	121.53	68.2	 	655.35	29.94	12.8	43.65	123.4	1
	30.06	6.91	-203	196	Test OFF	30.19	123.83	68.2	 	655.35	30.34	12.8	43.61	121.67	1
	30.48	6.91	-203	196	Test OFF	30.61	124.05	68.2	 	655.35	30.73	12.8	43.56	124.95	1
	30.88	6.9	-204	196	Test OFF	31.01	122.32	68.2	 	655.35	31.14	12.8	43.64	124.05	1
	31.26	6.93	-204	196	Test OFF	31.41	123.99	68.6	 	655.35	31.54	12.8	43.61	122.45	1
	31.67	6.92	-204	196	Test OFF	31.81	124.51	67.5	 	655.35	31.97	12.8	43.62	124.77	1
	32.1	6.88	-205	196	Test OFF	32.23	122.28	68.2	 	655.35	32.35	12.8	43.58	123.95	1
	32.5	6.9	-205	196	Test OFF	32.64	123.52	69	 	655.35	32.76	9.6	52.58	127.11	1
	32.88	6.96	-205	196	Test OFF	33.03	127.89	31.8	 	655.35	33.16	-41.6	123.7	123.7	0
	33.29	6.98	-206	196	Test OFF	33.43	128.91	68.2	 	655.35	33.59	9.6	90.52	124.36	1
	33.71	6.89	-206	196	Test OFF	33.83	128.5	70.2	 	655.35	33.96	12.8	92.88	128.69	1
	34.11	6.96	-207	196	Test OFF	34.24	127.11	31.8	 	655.35	34.36	-36.8	123.5	123.5	0
	34.49	7	-207	196	Test OFF	34.64	122.36	38	 	655.35	34.77	14.4	117.01	126.08	1
	34.9	6.87	-207	196	Test OFF	35.02	128.79	69	 	655.35	35.17	11.2	88.6	129.37	1
	35.3	6.95	-207	196	Test OFF	35.43	128.11	68.2	 	655.35	35.55	9.6	68.11	128.66	1
	35.7	7.01	-208	196	Test OFF	35.83	124.96	67.8	 	655.35	35.96	9.6	46.08	124.59	1
	36.08	7.01	-210	196	Test OFF	36.23	124.46	67.5	 	655.35	36.36	11.2	44.49	124.33	1
	36.49	6.98	-212	196	Test OFF	36.61	123.88	67.8	 	655.35	36.76	11.2	43.47	124.27	1
	36.89	6.98	-213	196	Test OFF	37.01	123.15	67.8	 	655.35	37.14	11.2	43.34	123.97	1
	37.29	6.92	-214	196	Test OFF	37.42	124.25	67.8	 	655.35	37.55	12.8	43.5	121.95	1
	37.67	6.95	-214	196	Test OFF	37.82	124.15	68.2	 	655.35	37.95	12.8	43.5	124.16	1
	38.08	6.94	-215	196	Test OFF	38.21	123.11	67.8	 	655.35	38.37	12.8	43.53	123.55	1
	38.5	6.9	-215	196	Test OFF	38.63	122.46	67.8	 	655.35	38.75	12.8	43.6	122.53	1
	38.91	6.88	-215	196	Test OFF	39.03	124.59	67.8	 	655.35	39.16	12.8	43.62	121.72	1
	39.3	6.94	-215	196	Test OFF	39.46	122.55	67.1	 	655.35	39.59	12.8	43.6	123.57	1
	39.72	6.9	-215	196	Test OFF	39.86	122.37	67.1	 	655.35	40.02	12.8	43.57	121.33	1
	40.15	6.93	-215	196	Test OFF	40.28	124.05	67.8	 	655.35	40.42	12.8	43.61	124.85	1
	40.58	6.91	-216	196	Test OFF	40.71	121.21	68.6	 	655.35	40.84	12.8	43.64	122.97	1
	40.97	6.87	-216	196	Test OFF	41.11	124.8	68.2	 	655.35	41.24	12.8	43.57	121.34	1
	41.37	6.9	-216	196	Test OFF	41.51	123.32	67.8	 	655.35	41.67	9.6	51.13	125.29	1
	41.81	6.94	-216	196	Test OFF	41.94	128.4	70.2	 	655.35	42.08	16	72.18	129.05	1
	42.24	6.98	-217	196	Test OFF	42.37	129.96	71.8	 	655.35	42.5	-36.8	126.31	126.31	0
	42.64	7.03	-218	196	Test OFF	42.8	122.58	35.7	 	655.35	42.93	-33.6	122.37	122.37	0
	43.06	6.98	-218	196	Test OFF	43.2	121.98	40.8	 	655.35	43.35	12.8	111.06	128.99	1
	43.48	6.82	-218	196	Test OFF	43.6	129.45	67.8	 	655.35	43.73	11.2	86.62	129.1	1
	43.88	6.94	-217	196	Test OFF	44.01	122.87	67.8	 	655.35	44.15	9.6	46.96	125.02	1
	44.27	6.97	-218	196	Test OFF	44.43	123.78	68.2	 	655.35	44.57	9.6	45.24	123.22	1
	44.69	6.99	-220	196	Test OFF	44.82	123.4	67.8	 	655.35	44.98	11.2	43.54	122.89	1
	45.11	7	-221	196	Test OFF	45.24	124.34	67.5	 	655.35	45.38	11.2	42.97	124.73	1
	45.54	6.95	-222	196	Test OFF	45.67	121.45	67.5	 	655.35	45.8	12.8	43.29	123.27	1
	45.93	6.88	-222	196	Test OFF	46.07	124.24	67.5	 	655.35	46.2	12.8	43.38	121.1	1
	46.33	6.88	-222	196	Test OFF	46.45	124.51	67.5	 	655.35	46.6	12.8	43.39	124.73	1
	46.73	6.91	-222	196	Test OFF	46.85	123.42	67.5	 	655.35	46.99	12.8	43.48	124.45	1
	47.14	6.88	-222	196	Test OFF	47.26	121.46	67.1	 	655.35	47.39	12.8	43.5	123.22	1
	47.52	6.87	-222	196	Test OFF	47.66	123.04	67.5	 	655.35	47.8	12.8	43.44	121.71	1
	47.92	6.9	-221	196	Test OFF	48.05	124.53	67.5	 	655.35	48.19	12.8	43.46	124.22	1
	48.33	6.89	-221	196	Test OFF	48.45	123.42	67.1	 	655.35	48.58	12.8	43.44	124.84	1
You will need to change the HPP with N276 valve and additionally inspect cam and cam follower.
Rekked
Australia
C?ID=224535
Hi Jack,
I have replaced the HPFP with a genuine unit and the problems were all the same, i didnt look at the cam but the follower is the one with the roller attached, not just the bucket type.
If there was a problem with the Cam, i wouldnt expect to see the constant High Pressures that i see 95% of the time. Am i wrong here? its not too hard to remove so i can verify the cam is in good condition
