2017 A4 Avant Q 2.0 TFSI
Here is the result of auto scan:
And, this is result of 'Controller Channel Map' of 01 Engine (nothing entry...):
VCDS Version: 17.1.3.0 (x64)
VIN: WAUZZZF43HA****** License Plate:
Chassis Type F4 (8W2)
Scan: 01 02 03 08 09 13 15 16 17 19 42 44 52 57 5F 6C 6D 81 8B A5
BB BC
Address 01: Engine (J623-CYRB) Labels: None
Part No SW: 8W0 906 259 M HW: 06L 907 425
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 122500322366050B34000000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TFS0208W0906259M 001002
ROD: N/A
VCID: 4B9E99D1E24352194C-801E
No ASAM data for: "EV_ECM20TFS0208W0906259M" (AU49)
Readiness: 0010 0001
Address 02: Auto Trans (J217) Labels: None
Part No SW: 8W1 927 155 M HW: 0CJ 927 156
Component: 0CL 20TFSIRdW H03 0009
Revision: --H03--- Serial number: 0000001392
ASAM Dataset: EV_TCMDL382021 002024
ROD: EV_TCMDL382021_VW51.rod
VCID: 4A909CD5ED394B1177-801E
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071160298000370
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8W0 907 379 H HW: 8W0 907 379 D
Component: ESP9 Premium H09 0719
Coding: 18AA409928AB0A9B119F489A008452A2E6A5D2180214508812004A4567A54B
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: N/A
No ASAM data for: "EV_ESP9BOSCHCMP" (AU49)
Address 08: Auto HVAC (E87) Labels: None
Part No SW: 8W0 820 043 G HW: 8W0 820 043 G
Component: Klima Zone 3 H32 0071
Coding: 240801885544040D10000100880000000000000000000000000000000000
Shop #: WSC 06325 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 3776D5218ECBC6F918-8062
Subsystem 1 - Part No SW: 4M2 820 021 HW: 4M2 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000001113769
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0005
Serial number: 2B98075800PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: Klima Heck H40 0073
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0266
Coding: 07500B43C13900CD051587145BAF80F9110B31080000000000000000200016010A44022B025605
ROD: EV_BCM1BOSCHAU736_016.rod
VCID: 020074F595895351FF-8056
Subsystem 1 - Part No SW: 8W2 955 119 HW: 8V2 955 119 A
Component: WWS491 160818 043 0813
Serial number: 89425300301623101161
Coding: 5BC7F7
Serial number: 20106182X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 29 06 2016 00491068
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE119081612010988
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B10386128
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2616000129456001
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8W0 907 561 B HW: 8W0 907 561
Component: LRR4 H10 0220
Coding: 3472E7E258FFEC0A949880A0
ASAM Dataset: EV_ACCBOSCHAU49X 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 3D7AC709ACF7ECA9C2-8068
Address 15: Airbags (J234) Labels: None
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0103
Serial number: 003UP00049VG
Coding: AACCF0000080000098000033D0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005013
ROD: EV_AirbaAU10BPAAU736_AU49.rod
VCID: 4C9C9ACDE74D552145-8018
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 8W0857705A0291Q00836
Coding: 88001B
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 8W0857706A0292Q00471
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 442 061 110 16
Serial number: 3577Y00B3209FF41324$
Subsystem 4 - Part No SW: ----------- HW: 442 061 110 16
Serial number: 3587Y00B1209FF4261A4
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 409 16
Serial number: 3517700B321DBB2551FH
Subsystem 6 - Part No SW: ----------- HW: 442 0B0 509 16
Serial number: 3527700A3217248672D3
Subsystem 7 - Part No SW: ----------- HW: 442 0C0 210 16
Component: FrontSensor_D 1C5 014A
Serial number: 35575009B21E602210B+
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 442 0C0 210 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B321E6023C40+
Part No SW: 4M0 907 129 HL HW: 4M0 907 129 HL
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 01027BF9908F4849E6-8054
Address 17: Instruments (J285) Labels: None
Part No SW: 8W5 920 790 C HW: 8W5 920 790 C
Component: FBenRDW H15 0307
Coding: 248D69C07C80000E0FA3E8601000000000000000
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736.rod
VCID: 4280B4F5D5099351BF-8016
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 8W2 907 468 D HW: 8W2 907 468 D
Component: Gateway H30 0308
Revision: 5F030001 Serial number: 0185F004416A28
Coding: 030100010000864029070000005900125C900007100000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 002040
ROD: EV_CGateCONTIAU491.rod
VCID: 4796A5E1FE2BB67968-8012
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20161019173912 21832
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 1113551904
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 8W0 959 593 E HW: 8W0 959 593
Component: TSG FS 005 0055
Serial number: 0000225153173
Coding: 001F1B205001008000001080
ROD: EV_DCU2DriveSideMAXHCONT.rod
Address 44: Steering Assist (J500) Labels: None
Part No SW: 8W0 909 144 F HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0407
Coding: 0D008380008080
ASAM Dataset: EV_EPSZFAU49X 002015
ROD: EV_EPSZFAU49X.rod
VCID: 4084BEFDDB058141A9-8014
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 8W0 959 592 E HW: 8W0 959 592
Component: TSG BFS 005 0055
Serial number: 0000223816470
Coding: 001F1B205C01008000001080
ROD: EV_DCU2PasseSideMAXHCONT.rod
Address 57: TV Tuner (R78) Labels: None
Part No SW: 8V0 919 129 E HW: 8V0 919 129 D
Component: JP-DTV H12 2070
Coding: 01041C0000000100000002
ASAM Dataset: EV_TVMELC 001039
ROD: EV_TVMELC_AU49.rod
Part No SW: 8W0 035 897 B HW: 8W0 035 897 A
Component: MU-P-LN-JP 053 0713
Serial number: K5F AW7R80CSCL
Coding: 01940206FF00000053330001001200102F0002E6017001007E
ASAM Dataset: EV_MUHig4CGen2AW7 001290
ROD: EV_MUHig4CGen2AW7_VW37.rod
VCID: 4182BBF9D00F8849A6-8014
Subsystem 1 - Part No SW: V03 959 801 KN HW: -----------
Component: JPN 2017 --- 7720
Subsystem 2 - Part No SW: 8W8 919 605 HW: 8W8 919 605
Component: DU High AU49x H31 0160
Serial number: TPO00104081600820232
Chip Card Reader Control Module:
Subsystem 3 - Part No SW: 8V0 919 813 B HW: 8V0 919 813 B
Component: DSRC UNIT H09 0002
Serial number: 502129418235
Traffic Data Aerial:
Subsystem 4 - Part No SW: 8W0 035 504 HW: 8W0 035 504
Component: VICS Antenna H06 0001
Serial number: 543030019804
Multimedia Operating Unit:
Subsystem 5 - Part No SW: 8W0 919 615 HW: 8W0 919 615
Component: ControlUnit_H H30 0206
Serial number: APVAK126091600020048
Compact Disc Database:
Subsystem 6 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 2013
Address 6C: Back-up Cam. (J772) Labels: None
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0240
Coding: 0294020102002001400040
ROD: EV_CamSysRVRVCPANAMLBEv_AU49.rod
VCID: 336EE1319AB32AD924-8066
Address 6D: Trunk Elect. (J605) Labels: 5Q0-959-107.clb
Part No SW: 4M0 959 107 B HW: 4M0 959 107 A
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31007449800000
Coding: 0570
VCID: 3260E43565A923D12F-8066
Address 81: Gear Shift (J587) Labels: None
Part No SW: 8W2 713 041 J HW: 8W2 713 041 J
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20161018000384
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 3B7EC911B2E3E299FC-806E
Address 8B: Adaptive Cruise 2 (J850) Labels: None
Part No SW: 8W0 907 541 B HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 002018
ROD: EV_ACC2BOSCHAU736_AU73.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 8W0 907 217 B HW: 8W0 907 217
Component: BVS H15 0042
Coding: 0404090200000504024020A4AD0000FCA0F0C0200280
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 8W0 959 595 E HW: 8W0 959 595
Component: TSG HFS 005 0055
Serial number: 0000225587343
Coding: 000F19200001008000001080
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 4E9890C5115167312B-801A
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 005 0055
Serial number: 0000225585054
ROD: EV_DCU2RearPasseMAXHCONT.rod
End-------------------------(Elapsed Time: 04:47)--------------------------
;SW:8W0-906-259-M HW:06L-907-425 --- Engine
;Component:2.0l R4 TFSI H13 0002, Coding:122500322366050B34000000000000000000000000000000
;EV_ECM20TFS0208W0906259M,001002,
;Saturday,04,February,2017,13:59:55:34370
;VCDS Version: Release 17.1.2 (x64) Data version: 20170131 DS267.1
;VCID: 4B9E99D1E243521946-801E
Elapsed Time: 00:00
