Request: BCM admap for 2017 Golf mk7 (any version)?
Hope you can help - I'm trying to make sense of the changed naming convention that appears to have occurred for the adaptation channels in the BCM for the 2017 Golf (mk7). It appears that VW have re-defined the database structure for the adaptation channels (and created new "Parent" names) in this module.
Can anyone supply a copy of this admap - please?
Thanks in advance
Since this does not involve a broken car, I'm moving it to the Reference Scans section.
OK, I've found an Admap that Dana posted for a 2017 NAR Golf Alltrack (in the reference scan section)
SW:5Q0-937-087-AA   HW:5Q0-937-087-AA ---  Cent. Elect.
;Component:BCM PQ37BOSCH 028 0162
The admap looks fairly standard - so clearly there must have been a change in a later incarnation of the BCM
I have a sort of admap from another type of diagnostic cable from a 2017 MK7 GTI Sport -the owner is from California. It looks like this:
**** vehicle history log
Date: 2017-03-02 21:02
    VIN:
    Car: Volkswagen Golf
    Year: 2017
    Engine: CXCB
    Mileage: 535 KM
Backup
    Control unit: 09 Central Electrics
    System description: BCM PQ37BOSCH
    Software number: 5Q0937087AN
    Software version: 0223
    Hardware number: 5Q0937087AN
    Hardware version: 032
    Serial number: C86419121600ZO
    ODX name: EV_BodyContrModul1UDSBosc
    ODX version: 017002
    Backup name: centralE Backup
    Long coding:
    Subsystems:
        Subsystem: WWS    160603
        Long coding: 0E4DDD
    Adaptations:
        Leuchte 0 BLK VL B36:
            Lasttyp 0:
                12 - Blinkleuchten
            Lampendefektbit Position 0:
                34
            Fehlerort mittleres Byte DTC-DFCC 0:
                14
            Lichtfunktion A 0:
                Blinken links Hellphase
            Lichtfunktion B 0:
                nicht aktiv
            Dimmwert AB 0:
                100
            Lichtansteuerung HD AB 0:
                always
            Lichtfunktion C 0:
                nicht aktiv
            Lichtfunktion D 0:
                nicht aktiv
            Dimmwert CD 0:
            Dimming Direction CD 0:
                maximize
            Lichtfunktion E 0:
                nicht aktiv
            Lichtfunktion F 0:
                nicht aktiv
            Dimmwert EF 0:
            Dimming Direction EF 0:
                maximize
            Lichtfunktion H 0:
                nicht aktiv
            Dimmwert GH 0:
            Dimming Direction GH 0:
                maximize
            Lichtfunktion G 0:
                nicht aktiv
        Leuchte1BLK VRB20:
            Lasttyp 1:
                12 - Blinkleuchten
            Lampendefektbitposition 1:
                3e
            Fehlerort mittleres Byte DTC-DFCC 1:
                15
            Lichtfunktion A 1:
                Blinken rechts Hellphase
            Lichtfunktion B 1:
                nicht aktiv
            Dimmwert AB 1:
                100
            Lichtansteuerung HD AB 1:
                always
            Lichtfunktion C 1:
                nicht aktiv
            Lichtfunktion D 1:
                nicht aktiv
            Dimmwert CD 1:
            Dimming Direction CD 1:
                maximize
            Lichtfunktion E 1:
                nicht aktiv
            Lichtfunktion F 1:
                nicht aktiv
            Dimmwert EF 1:
            Dimming Direction EF 1:
                maximize
            Lichtfunktion G 1:
                nicht aktiv
            Lichtfunktion H 1:
                nicht aktiv
            Dimmwert GH 1:
            Dimming Direction GH 1:
                maximize
        Leuchte2SL VLB10:
            Lasttyp 2:
                4 - LED Tagfahrlichtmodul Signal
            Lampendefektbitposition 2:
                48
            Fehlerort mittleres Byte DTC-DFCC 2:
                4a
            Lichtfunktion A 2:
                Tagfahrlicht
            Lichtfunktion B 2:
                nicht aktiv
            Dimmwert AB 2:
                100
            Lichtansteuerung HD AB 2:
                always
            Lichtfunktion C 2:
                Blinken links aktiv (beide Phasen)
            Lichtfunktion D 2:
                nicht aktiv
            Dimmwert CD 2:
            Dimming Direction CD 2:
                minimize
            Lichtfunktion E 2:
                Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
            Lichtfunktion F 2:
                Parklicht links (beidseitiges Parklicht aktiviert li & re)
            Dimmwert EF 2:
                26
            Dimming Direction EF 2:
                maximize
            Lichtfunktion G 2:
                nicht aktiv
            Lichtfunktion H 2:
                nicht aktiv
            Dimmwert GH 2:
            Dimming Direction GH 2:
                maximize
        Leuchte3SL VRB21:
            Lasttyp 3:
            Lampendefektbitposition 3:
                4c
            Fehlerort mittleres Byte DTC-DFCC 3:
                4c
            Lichtfunktion A 3:
                Tagfahrlicht
            Lichtfunktion B 3:
                nicht aktiv
            Dimmwert AB 3:
                100
            Lichtansteuerung HD AB 3:
                always
            Lichtfunktion C 3:
                Blinken rechts aktiv (beide Phasen)
            Lichtfunktion D 3:
                nicht aktiv
            Dimmwert CD 3:
            Dimming Direction CD 3:
                minimize
            Lichtfunktion E 3:
            Lichtfunktion F 3:
                Parklicht rechts
            Dimmwert EF 3:
                26
            Dimming Direction EF 3:
                maximize
            Lichtfunktion G 3:
                nicht aktiv
            Lichtfunktion H 3:
                nicht aktiv
            Dimmwert GH 3:
            Dimming Direction GH 3:
                maximize
        Leuchte4TFL LB4:
            Lasttyp 4:
                1 - LED Tagfahrlichtmodul Versorgung
            Lampendefektbitposition 4:
                3a
            Fehlerort mittleres Byte DTC-DFCC 4:
                49
            Lichtfunktion A 4:
                Tagfahrlicht
            Lichtfunktion B 4:
                nicht aktiv
            Dimmwert AB 4:
                127
            Lichtansteuerung HD AB 4:
                always
            Lichtfunktion C 4:
            Lichtfunktion D 4:
                nicht aktiv
            Dimmwert CD 4:
            Dimming Direction CD 4:
                minimize
            Lichtfunktion E 4:
            Lichtfunktion F 4:
            Dimmwert EF 4:
                127
            Dimming Direction EF 4:
                maximize
            Lichtfunktion G 4:
                nicht aktiv
            Lichtfunktion H 4:
                nicht aktiv
            Dimmwert GH 4:
            Dimming Direction GH 4:
                maximize
        Leuchte5 TFL RB32:
            Lasttyp 5:
            Lampendefektbitposition 5:
                44
            Fehlerort mittleres Byte DTC-DFCC 5:
                4b
            Lichtfunktion A 5:
                Tagfahrlicht
            Lichtfunktion B 5:
                nicht aktiv
            Dimmwert AB 5:
                127
            Lichtansteuerung HD AB 5:
                always
            Lichtfunktion C 5:
            Lichtfunktion D 5:
                nicht aktiv
            Dimmwert CD 5:
            Dimming Direction CD 5:
                minimize
            Lichtfunktion E 5:
            Lichtfunktion F 5:
                Parklicht rechts
            Dimmwert EF 5:
                127
            Dimming Direction EF 5:
                maximize
            Lichtfunktion G 5:
                nicht aktiv
            Lichtfunktion H 5:
                nicht aktiv
            Dimmwert GH 5:
            Dimming Direction GH 5:
                maximize
        Leuchte6ABL LC5:
            Lasttyp 6:
                3 - Xenon Abblendlicht
            Lampendefektbitposition 6:
                36
            Fehlerort mittleres Byte DTC-DFCC 6:
                1a
            Lichtfunktion A 6:
                Abblendlicht links
            Lichtfunktion B 6:
                Lichthupe generell
            Dimmwert AB 6:
                127
            Lichtansteuerung HD AB 6:
                always
            Lichtfunktion C 6:
                nicht aktiv
            Lichtfunktion D 6:
                nicht aktiv
            Dimmwert CD 6:
            Dimming Direction CD 6:
                maximize
            Lichtfunktion E 6:
                nicht aktiv
            Lichtfunktion F 6:
                nicht aktiv
            Dimmwert EF 6:
            Dimming Direction EF 6:
                maximize
            Lichtfunktion G 6:
                nicht aktiv
            Lichtfunktion H 6:
                nicht aktiv
            Dimmwert GH 6:
            Dimming Direction GH 6:
                maximize
        Leuchte7ABL RB1:
            Lasttyp 7:
            Lampendefektbitposition 7:
                40
            Fehlerort mittleres Byte DTC-DFCC 7:
                1b
            Lichtfunktion A 7:
                Abblendlicht rechts
            Lichtfunktion B 7:
                Lichthupe generell
            Dimmwert AB 7:
                127
            Lichtansteuerung HD AB 7:
                always
            Lichtfunktion C 7:
                nicht aktiv
            Lichtfunktion D 7:
                nicht aktiv
            Dimmwert CD 7:
            Dimming Direction CD 7:
                maximize
            Lichtfunktion E 7:
                nicht aktiv
            Lichtfunktion F 7:
                nicht aktiv
            Dimmwert EF 7:
            Dimming Direction EF 7:
                maximize
            Lichtfunktion G 7:
                nicht aktiv
            Lichtfunktion H 7:
                nicht aktiv
            Dimmwert GH 7:
            Dimming Direction GH 7:
                maximize
        Leuchte8FL LB39:
            Lasttyp 8:
                36 - LED Kleinleistung
            Lampendefektbitposition 8:
                35
            Fehlerort mittleres Byte DTC-DFCC 8:
                26
            Lichtfunktion A 8:
            Lichtfunktion B 8:
            Dimmwert AB 8:
                127
            Lichtansteuerung HD AB 8:
                always
            Lichtfunktion C 8:
                nicht aktiv
            Lichtfunktion D 8:
                nicht aktiv
            Dimmwert CD 8:
            Dimming Direction CD 8:
                maximize
            Lichtfunktion E 8:
                nicht aktiv
            Lichtfunktion F 8:
                nicht aktiv
            Dimmwert EF 8:
            Dimming Direction EF 8:
                maximize
            Lichtfunktion G 8:
                nicht aktiv
            Lichtfunktion H 8:
                nicht aktiv
            Dimmwert GH 8:
            Dimming Direction GH 8:
                maximize
        Leuchte9FL RB2:
            Lasttyp 9:
            Lampendefektbitposition 9:
                3f
            Fehlerort mittleres Byte DTC-DFCC 9:
                27
            Lichtfunktion A 9:
            Lichtfunktion B 9:
                Parklicht rechts
            Dimmwert AB 9:
                127
            Lichtansteuerung HD AB 9:
                always
            Lichtfunktion C 9:
                nicht aktiv
            Lichtfunktion D 9:
                nicht aktiv
            Dimmwert CD 9:
            Dimming Direction CD 9:
                maximize
            Lichtfunktion E 9:
                nicht aktiv
            Lichtfunktion F 9:
                nicht aktiv
            Dimmwert EF 9:
            Dimming Direction EF 9:
                maximize
            Lichtfunktion G 9:
                nicht aktiv
            Lichtfunktion H 9:
                nicht aktiv
            Dimmwert GH 9:
            Dimming Direction GH 9:
                maximize
        Leuchte10SHUTTER LB23:
            Lasttyp 10:
                2 - Shutter, Diagnosesensierung für 'LED low'
            Lampendefektbitposition 10:
                37
            Fehlerort mittleres Byte DTC-DFCC 10:
                1e
            Lichtfunktion A 10:
                Fernlicht links
            Lichtfunktion B 10:
                Lichthupe generell
            Dimmwert AB 10:
                127
            Lichtansteuerung HD AB 10:
                always
            Lichtfunktion C 10:
                nicht aktiv
            Lichtfunktion D 10:
                nicht aktiv
            Dimmwert CD 10:
            Dimming Direction CD 10:
                maximize
            Lichtfunktion E 10:
                nicht aktiv
            Lichtfunktion F 10:
                nicht aktiv
            Dimmwert EF 10:
            Dimming Direction EF 10:
                maximize
            Lichtfunktion G 10:
                nicht aktiv
            Lichtfunktion H 10:
                nicht aktiv
            Dimmwert GH 10:
            Dimming Direction GH 10:
                maximize
        Leuchte11SHUTTER RB22:
            Lasttyp 11:
            Lampendefektbitposition 11:
                41
            Fehlerort mittleres Byte DTC-DFCC 11:
                1f
            Lichtfunktion A 11:
                Fernlicht rechts
            Lichtfunktion B 11:
                Lichthupe generell
            Dimmwert AB 11:
                127
            Lichtansteuerung HD AB 11:
                always
            Lichtfunktion C 11:
                nicht aktiv
            Lichtfunktion D 11:
                nicht aktiv
            Dimmwert CD 11:
            Dimming Direction CD 11:
                maximize
            Lichtfunktion E 11:
                nicht aktiv
            Lichtfunktion F 11:
                nicht aktiv
            Dimmwert EF 11:
            Dimming Direction EF 11:
                maximize
            Lichtfunktion G 11:
                nicht aktiv
            Lichtfunktion H 11:
                nicht aktiv
            Dimmwert GH 11:
            Dimming Direction GH 11:
                maximize
        Leuchte12NL LB45:
            Lasttyp 12:
                not active
            Lampendefektbitposition 12:
            Fehlerort mittleres Byte DTC-DFCC 12:
            Lichtfunktion A 12:
                nicht aktiv
            Lichtfunktion B 12:
                nicht aktiv
            Dimmwert AB 12:
            Lichtansteuerung HD AB 12:
                always
            Lichtfunktion C 12:
                nicht aktiv
            Lichtfunktion D 12:
                nicht aktiv
            Dimmwert CD 12:
            Dimming Direction CD 12:
                maximize
            Lichtfunktion E 12:
                nicht aktiv
            Lichtfunktion F 12:
                nicht aktiv
            Dimmwert EF 12:
            Dimming Direction EF 12:
                maximize
            Lichtfunktion G 12:
                nicht aktiv
            Lichtfunktion H 12:
                nicht aktiv
            Dimmwert GH 12:
            Dimming Direction GH 12:
                maximize
        Leuchte13NL RB5:
            Lasttyp 13:
                not active
            Lampendefektbitposition 13:
            Fehlerort mittleres Byte DTC-DFCC 13:
            Lichtfunktion A 13:
                nicht aktiv
            Lichtfunktion B 13:
                nicht aktiv
            Dimmwert AB 13:
            Lichtansteuerung HD AB 13:
                always
            Lichtfunktion C 13:
                nicht aktiv
            Lichtfunktion D 13:
                nicht aktiv
            Dimmwert CD 13:
            Dimming Direction CD 13:
                maximize
            Lichtfunktion E 13:
                nicht aktiv
            Lichtfunktion F 13:
                nicht aktiv
            Dimmwert EF 13:
            Dimming Direction EF 13:
                maximize
            Lichtfunktion G 13:
                nicht aktiv
            Lichtfunktion H 13:
                nicht aktiv
            Dimmwert GH 13:
            Dimming Direction GH 13:
                maximize
        Leuchte 35 LED Warnblinktaster C48:
            Lasttyp 15:
                41 - LED Kleinleistung
            Lampendefektbitposition 15:
            Fehlerort mittleres Byte DTC-DFCC 15:
                6
            Lichtfunktion A 15:
                nicht_definiert_4C
            Lichtfunktion B 15:
                nicht aktiv
            Dimmwert AB 15:
                100
            Lichtansteuerung HD AB 15:
                always
            Lichtfunktion C 15:
                nicht aktiv
            Lichtfunktion D 15:
                nicht aktiv
            Dimmwert CD 15:
            Dimming Direction CD 15:
                maximize
            Lichtfunktion E 15:
                nicht aktiv
            Lichtfunktion F 15:
                nicht aktiv
            Dimmwert EF 15:
            Dimming Direction EF 15:
                maximize
            Lichtfunktion G 15:
                nicht aktiv
            Lichtfunktion H 15:
                nicht aktiv
            Dimmwert GH 15:
            Dimming Direction GH 15:
                maximize
        Leuchte16BLK SLB35BLK SL KC9:
            Lasttyp 16:
                not active
            Lampendefektbitposition 16:
            Fehlerort mittleres Byte DTC-DFCC 16:
            Lichtfunktion A 16:
                nicht aktiv
            Lichtfunktion B 16:
                nicht aktiv
            Dimmwert AB 16:
            Lichtansteuerung HD AB 16:
                always
            Lichtfunktion C 16:
                nicht aktiv
            Lichtfunktion D 16:
                nicht aktiv
            Dimmwert CD 16:
            Dimming Direction CD 16:
                maximize
            Lichtfunktion E 16:
                nicht aktiv
            Lichtfunktion F 16:
                nicht aktiv
            Dimmwert EF 16:
            Dimming Direction EF 16:
                maximize
            Lichtfunktion G 16:
                nicht aktiv
            Lichtfunktion H 16:
                nicht aktiv
            Dimmwert GH 16:
            Dimming Direction GH 16:
                maximize
        Leuchte17TFL R BLK SRB3TFL R BLK SR KC3:
            Lasttyp 17:
                not active
            Lampendefektbitposition 17:
            Fehlerort mittleres Byte DTC-DFCC 17:
            Lichtfunktion A 17:
                nicht aktiv
            Lichtfunktion B 17:
                nicht aktiv
            Dimmwert AB 17:
            Lichtansteuerung HD AB 17:
                always
            Lichtfunktion C 17:
                nicht aktiv
            Lichtfunktion D 17:
                nicht aktiv
            Dimmwert CD 17:
            Dimming Direction CD 17:
                maximize
            Lichtfunktion E 17:
                nicht aktiv
            Lichtfunktion F 17:
                nicht aktiv
            Dimmwert EF 17:
            Dimming Direction EF 17:
                maximize
            Lichtfunktion G 17:
                nicht aktiv
            Lichtfunktion H 17:
                nicht aktiv
            Dimmwert GH 17:
            Dimming Direction GH 17:
                maximize
        Leuchte18BLK HLA60:
            Lasttyp 18:
                not active
            Lampendefektbitposition 18:
            Fehlerort mittleres Byte DTC-DFCC 18:
            Lichtfunktion A 18:
                nicht aktiv
            Lichtfunktion B 18:
                nicht aktiv
            Dimmwert AB 18:
            Lichtansteuerung HD AB 18:
                always
            Lichtfunktion C 18:
                nicht aktiv
            Lichtfunktion D 18:
                nicht aktiv
            Dimmwert CD 18:
            Dimming Direction CD 18:
                maximize
            Lichtfunktion E 18:
                nicht aktiv
            Lichtfunktion F 18:
                nicht aktiv
            Dimmwert EF 18:
            Dimming Direction EF 18:
                maximize
            Lichtfunktion G 18:
                nicht aktiv
            Lichtfunktion H 18:
                nicht aktiv
            Dimmwert GH 18:
            Dimming Direction GH 18:
                maximize
        Leuchte19BLK HRC31:
            Lasttyp 19:
                not active
            Lampendefektbitposition 19:
            Fehlerort mittleres Byte DTC-DFCC 19:
            Lichtfunktion A 19:
                nicht aktiv
            Lichtfunktion B 19:
                nicht aktiv
            Dimmwert AB 19:
            Lichtansteuerung HD AB 19:
                always
            Lichtfunktion C 19:
                nicht aktiv
            Lichtfunktion D 19:
                nicht aktiv
            Dimmwert CD 19:
            Dimming Direction CD 19:
                maximize
            Lichtfunktion E 19:
                nicht aktiv
            Lichtfunktion F 19:
                nicht aktiv
            Dimmwert EF 19:
            Dimming Direction EF 19:
                maximize
            Lichtfunktion G 19:
                nicht aktiv
            Lichtfunktion H 19:
                nicht aktiv
            Dimmwert GH 19:
            Dimming Direction GH 19:
                maximize
        Leuchte20BR LA71:
            Lasttyp 20:
                14 - kombinierte Blink- Bremsleuchten
            Lampendefektbitposition 20:
                13
            Fehlerort mittleres Byte DTC-DFCC 20:
                3d
            Lichtfunktion A 20:
                Bremslicht
            Lichtfunktion B 20:
            Dimmwert AB 20:
                100
            Lichtansteuerung HD AB 20:
                always
            Lichtfunktion C 20:
                Blinken links Dunkelphase
            Lichtfunktion D 20:
                nicht aktiv
            Dimmwert CD 20:
            Dimming Direction CD 20:
                minimize
            Lichtfunktion E 20:
            Lichtfunktion F 20:
                nicht aktiv
            Dimmwert EF 20:
                28
            Dimming Direction EF 20:
                maximize
            Lichtfunktion G 20:
                nicht aktiv
            Lichtfunktion H 20:
                nicht aktiv
            Dimmwert GH 20:
            Dimming Direction GH 20:
                maximize
        Leuchte21BR RC8:
            Lasttyp 21:
            Lampendefektbitposition 21:
                23
            Fehlerort mittleres Byte DTC-DFCC 21:
                3e
            Lichtfunktion A 21:
                Bremslicht
            Lichtfunktion B 21:
            Dimmwert AB 21:
                100
            Lichtansteuerung HD AB 21:
                always
            Lichtfunktion C 21:
                Blinken rechts Dunkelphase
            Lichtfunktion D 21:
                nicht aktiv
            Dimmwert CD 21:
            Dimming Direction CD 21:
                minimize
            Lichtfunktion E 21:
            Lichtfunktion F 21:
                nicht aktiv
            Dimmwert EF 21:
                28
            Dimming Direction EF 21:
                maximize
            Lichtfunktion G 21:
                nicht aktiv
            Lichtfunktion H 21:
                nicht aktiv
            Dimmwert GH 21:
            Dimming Direction GH 21:
                maximize
        Leuchte22BR MA57:
            Lasttyp 22:
                42 - LED dritte Bremsleuchte
            Lampendefektbitposition 22:
                29
            Fehlerort mittleres Byte DTC-DFCC 22:
                2c
            Lichtfunktion A 22:
                Bremslicht
            Lichtfunktion B 22:
                nicht aktiv
            Dimmwert AB 22:
                100
            Lichtansteuerung HD AB 22:
                always
            Lichtfunktion C 22:
                nicht aktiv
            Lichtfunktion D 22:
                nicht aktiv
            Dimmwert CD 22:
            Dimming Direction CD 22:
                maximize
            Lichtfunktion E 22:
                nicht aktiv
            Lichtfunktion F 22:
                nicht aktiv
            Dimmwert EF 22:
            Dimming Direction EF 22:
                maximize
            Lichtfunktion G 22:
                nicht aktiv
            Lichtfunktion H 22:
                nicht aktiv
            Dimmwert GH 22:
            Dimming Direction GH 22:
                maximize
        Leuchte23SL HLC10:
            Lasttyp 23:
                9 - allgemeine Glühlampe 27W, auch H15
            Lampendefektbitposition 23:
                a
            Fehlerort mittleres Byte DTC-DFCC 23:
                29
            Lichtfunktion A 23:
            Lichtfunktion B 23:
                nicht aktiv
            Dimmwert AB 23:
                28
            Lichtansteuerung HD AB 23:
                always
            Lichtfunktion C 23:
                nicht aktiv
            Lichtfunktion D 23:
                nicht aktiv
            Dimmwert CD 23:
            Dimming Direction CD 23:
                maximize
            Lichtfunktion E 23:
                nicht aktiv
            Lichtfunktion F 23:
                nicht aktiv
            Dimmwert EF 23:
            Dimming Direction EF 23:
                maximize
            Lichtfunktion G 23:
                nicht aktiv
            Lichtfunktion H 23:
                nicht aktiv
            Dimmwert GH 23:
            Dimming Direction GH 23:
                maximize
        Leuchte24SL HRA65:
            Lasttyp 24:
            Lampendefektbitposition 24:
                1a
            Fehlerort mittleres Byte DTC-DFCC 24:
                2a
            Lichtfunktion A 24:
            Lichtfunktion B 24:
                nicht aktiv
            Dimmwert AB 24:
                28
            Lichtansteuerung HD AB 24:
                always
            Lichtfunktion C 24:
                nicht aktiv
            Lichtfunktion D 24:
                nicht aktiv
            Dimmwert CD 24:
            Dimming Direction CD 24:
                maximize
            Lichtfunktion E 24:
                nicht aktiv
            Lichtfunktion F 24:
                nicht aktiv
            Dimmwert EF 24:
            Dimming Direction EF 24:
                maximize
            Lichtfunktion G 24:
                nicht aktiv
            Lichtfunktion H 24:
                nicht aktiv
            Dimmwert GH 24:
            Dimming Direction GH 24:
                maximize
        Leuchte25KZL HA59:
            Lasttyp 25:
                18 - 2* 5W
            Lampendefektbitposition 25:
                28
            Fehlerort mittleres Byte DTC-DFCC 25:
                30
            Lichtfunktion A 25:
            Lichtfunktion B 25:
                nicht aktiv
            Dimmwert AB 25:
                100
            Lichtansteuerung HD AB 25:
                always
            Lichtfunktion C 25:
                nicht aktiv
            Lichtfunktion D 25:
                nicht aktiv
            Dimmwert CD 25:
            Dimming Direction CD 25:
                maximize
            Lichtfunktion E 25:
                nicht aktiv
            Lichtfunktion F 25:
                nicht aktiv
            Dimmwert EF 25:
            Dimming Direction EF 25:
                maximize
            Lichtfunktion G 25:
                nicht aktiv
            Lichtfunktion H 25:
                nicht aktiv
            Dimmwert GH 25:
            Dimming Direction GH 25:
                maximize
        Leuchte26NSL LA72:
            Lasttyp 26:
                not active
            Lampendefektbitposition 26:
            Fehlerort mittleres Byte DTC-DFCC 26:
            Lichtfunktion A 26:
                nicht aktiv
            Lichtfunktion B 26:
                nicht aktiv
            Dimmwert AB 26:
            Lichtansteuerung HD AB 26:
                always
            Lichtfunktion C 26:
                nicht aktiv
            Lichtfunktion D 26:
                nicht aktiv
            Dimmwert CD 26:
            Dimming Direction CD 26:
                maximize
            Lichtfunktion E 26:
                nicht aktiv
            Lichtfunktion F 26:
                nicht aktiv
            Dimmwert EF 26:
            Dimming Direction EF 26:
                maximize
            Lichtfunktion G 26:
                nicht aktiv
            Lichtfunktion H 26:
                nicht aktiv
            Dimmwert GH 26:
            Dimming Direction GH 26:
                maximize
        Leuchte27NSL RC6:
            Lasttyp 27:
            Lampendefektbitposition 27:
            Fehlerort mittleres Byte DTC-DFCC 27:
                47
            Lichtfunktion A 27:
            Lichtfunktion B 27:
                nicht aktiv
            Dimmwert AB 27:
                127
            Lichtansteuerung HD AB 27:
                always
            Lichtfunktion C 27:
                nicht aktiv
            Lichtfunktion D 27:
                nicht aktiv
            Dimmwert CD 27:
            Dimming Direction CD 27:
                maximize
            Lichtfunktion E 27:
                nicht aktiv
            Lichtfunktion F 27:
                nicht aktiv
            Dimmwert EF 27:
            Dimming Direction EF 27:
                maximize
            Lichtfunktion G 27:
                nicht aktiv
            Lichtfunktion H 27:
                nicht aktiv
            Dimmwert GH 27:
            Dimming Direction GH 27:
                maximize
        Leuchte28RFL LC11:
            Lasttyp 28:
            Lampendefektbitposition 28:
                b
            Fehlerort mittleres Byte DTC-DFCC 28:
                31
            Lichtfunktion A 28:
                Rueckfahrlicht
            Lichtfunktion B 28:
                nicht aktiv
            Dimmwert AB 28:
                100
            Lichtansteuerung HD AB 28:
                always
            Lichtfunktion C 28:
                nicht aktiv
            Lichtfunktion D 28:
                nicht aktiv
            Dimmwert CD 28:
            Dimming Direction CD 28:
                maximize
            Lichtfunktion E 28:
                nicht aktiv
            Lichtfunktion F 28:
                nicht aktiv
            Dimmwert EF 28:
            Dimming Direction EF 28:
                maximize
            Lichtfunktion G 28:
                nicht aktiv
            Lichtfunktion H 28:
                nicht aktiv
            Dimmwert GH 28:
            Dimming Direction GH 28:
                maximize
        Leuchte29RFL RA64:
            Lasttyp 29:
            Lampendefektbitposition 29:
                1b
            Fehlerort mittleres Byte DTC-DFCC 29:
                32
            Lichtfunktion A 29:
                Rueckfahrlicht
            Lichtfunktion B 29:
                nicht aktiv
            Dimmwert AB 29:
                100
            Lichtansteuerung HD AB 29:
                always
            Lichtfunktion C 29:
                nicht aktiv
            Lichtfunktion D 29:
                nicht aktiv
            Dimmwert CD 29:
            Dimming Direction CD 29:
                maximize
            Lichtfunktion E 29:
                nicht aktiv
            Lichtfunktion F 29:
                nicht aktiv
            Dimmwert EF 29:
            Dimming Direction EF 29:
                maximize
            Lichtfunktion G 29:
                nicht aktiv
            Lichtfunktion H 29:
                nicht aktiv
            Dimmwert GH 29:
            Dimming Direction GH 29:
                maximize
        Leuchte30FR LC72:
            Lasttyp 30:
            Lampendefektbitposition 30:
            Fehlerort mittleres Byte DTC-DFCC 30:
            Lichtfunktion A 30:
                Fussraumlicht
            Lichtfunktion B 30:
                nicht aktiv
            Dimmwert AB 30:
                100
            Lichtansteuerung HD AB 30:
                always
            Lichtfunktion C 30:
                nicht aktiv
            Lichtfunktion D 30:
                nicht aktiv
            Dimmwert CD 30:
            Dimming Direction CD 30:
                maximize
            Lichtfunktion E 30:
                nicht aktiv
            Lichtfunktion F 30:
                nicht aktiv
            Dimmwert EF 30:
            Dimming Direction EF 30:
                maximize
            Lichtfunktion G 30:
                nicht aktiv
            Lichtfunktion H 30:
                nicht aktiv
            Dimmwert GH 30:
            Dimming Direction GH 30:
                maximize
        Leuchte31AMBL 1C61:
            Lasttyp 31:
                not active
            Lampendefektbitposition 31:
            Fehlerort mittleres Byte DTC-DFCC 31:
            Lichtfunktion A 31:
                nicht aktiv
            Lichtfunktion B 31:
                nicht aktiv
            Dimmwert AB 31:
            Lichtansteuerung HD AB 31:
                always
            Lichtfunktion C 31:
                nicht aktiv
            Lichtfunktion D 31:
                nicht aktiv
            Dimmwert CD 31:
            Dimming Direction CD 31:
                maximize
            Lichtfunktion E 31:
                nicht aktiv
            Lichtfunktion F 31:
                nicht aktiv
            Dimmwert EF 31:
            Dimming Direction EF 31:
                maximize
            Lichtfunktion G 31:
                nicht aktiv
            Lichtfunktion H 31:
                nicht aktiv
            Dimmwert GH 31:
            Dimming Direction GH 31:
                maximize
        Leuchte32AMBL 2C35:
            Lasttyp 32:
                not active
            Lampendefektbitposition 32:
            Fehlerort mittleres Byte DTC-DFCC 32:
            Lichtfunktion A 32:
                nicht aktiv
            Lichtfunktion B 32:
                nicht aktiv
            Dimmwert AB 32:
            Lichtansteuerung HD AB 32:
                always
            Lichtfunktion C 32:
                nicht aktiv
            Lichtfunktion D 32:
                nicht aktiv
            Dimmwert CD 32:
            Dimming Direction CD 32:
                maximize
            Lichtfunktion E 32:
                nicht aktiv
            Lichtfunktion F 32:
                nicht aktiv
            Dimmwert EF 32:
            Dimming Direction EF 32:
                maximize
            Lichtfunktion G 32:
                nicht aktiv
            Lichtfunktion H 32:
                nicht aktiv
            Dimmwert GH 32:
            Dimming Direction GH 32:
                maximize
        Leuchte33AMBL 3C36:
            Lasttyp 33:
                not active
            Lampendefektbitposition 33:
            Fehlerort mittleres Byte DTC-DFCC 33:
            Lichtfunktion A 33:
                nicht aktiv
            Lichtfunktion B 33:
                nicht aktiv
            Dimmwert AB 33:
            Lichtansteuerung HD AB 33:
                always
            Lichtfunktion C 33:
                nicht aktiv
            Lichtfunktion D 33:
                nicht aktiv
            Dimmwert CD 33:
            Dimming Direction CD 33:
                maximize
            Lichtfunktion E 33:
                nicht aktiv
            Lichtfunktion F 33:
                nicht aktiv
            Dimmwert EF 33:
            Dimming Direction EF 33:
                maximize
            Lichtfunktion G 33:
                nicht aktiv
            Lichtfunktion H 33:
                nicht aktiv
            Dimmwert GH 33:
            Dimming Direction GH 33:
                maximize
        Leuchte34AMBL 4C37:
            Lasttyp 34:
                not active
            Lampendefektbitposition 34:
            Fehlerort mittleres Byte DTC-DFCC 34:
            Lichtfunktion A 34:
                nicht aktiv
            Lichtfunktion B 34:
                nicht aktiv
            Dimmwert AB 34:
            Lichtansteuerung HD AB 34:
                always
            Lichtfunktion C 34:
                nicht aktiv
            Lichtfunktion D 34:
                nicht aktiv
            Dimmwert CD 34:
            Dimming Direction CD 34:
                maximize
            Lichtfunktion E 34:
                nicht aktiv
            Lichtfunktion F 34:
                nicht aktiv
            Dimmwert EF 34:
            Dimming Direction EF 34:
                maximize
            Lichtfunktion G 34:
                nicht aktiv
            Lichtfunktion H 34:
                nicht aktiv
            Dimmwert GH 34:
            Dimming Direction GH 34:
                maximize
        Vernetzung:
            Klimaelektronik:
                installed
            Anhaengeranschlussgeraet:
                not installed
            Bremsen_Steuergeraet:
                installed
            Getriebesteuergeraet:
                installed
            Kunden_spezifisches_Funktions_SG:
                not installed
            Kopfraumheizung:
                not installed
            UGDO:
                not installed
        HW_Verbau:
            Aussentemperatursensor:
                installed
            Brake pad wear:
                not installed
            PTC Zuheizer:
                not installed
            Insufficient brake fluid:
                installed
            Insufficient coolant:
                installed
            Insufficient washer fluid:
                installed
            Kontaktschalter_fuer_Motorhaube:
                installed
            Status_Tankdeckelverriegelung:
                not active
            Druckklappe:
                not installed
            Ladesteckerverriegelung:
                not installed
            Signalhorn ohne KL15:
                active
            Elektrische_Laderaumabdeckung:
                not installed
            Elektrische Laderaumabdeckung aktiv:
                not active
        Querschnitts_funktionen:
            Lenkungsanordnung:
                Left
            Verkehrsseite:
                Right
            Brand:
                VW
            Personalisierungsuebernahme:
                not_installed
            Bedien_und_Anzeigeprotokoll:
                active
            Schnittstelle_TrackingSystem:
                not active
            Codierungsabsicherung:
                not active
            CAN Wecken bei Softtouchbetaetigung:
                active
            Hardware_Eingang_Drucktankklappenstatus:
                Pin 31
            Klemmenfehler auf CAN ausgeben:
                active
            Fahrgeschwindigkeit_aus_ESP_21:
                active
        Aussenlicht_uebergreifend:
            Light_Control_Module:
                not installed
            Kontrollleuchte fuer Begrenzungslicht:
                integriert in Suchbeleuchtung
            Standlicht aus:
                active
            Parklicht ueber LSS aktiviert:
                not active
            Standlichtreduzierung mit beidseitigem Parklicht:
                not active
            Menueeinstellung CHO LHO:
                Menuesteuerung Zeit aktivieren
            Faktor fuer Verfügbarkeitstimer:
                Faktor fuer x5 Minuten
            Umfeldleuchte als Manoevrierleuchte:
                not active
            Fahrlichtwarnung_Hinweis_Konfig:
                kein_Hinweis
            Fahrlicht_Hinweis_mehrfach:
                not active
            Bedingungen zur Standlichtbegrenzung:
                begrenzen auf Mindestverfügbarkeit
            Standlicht-Verfügbarkeit:
                6 s
            bewusstes Standlicht:
                Aktive Begrenzung
            Bedingungen zur Parklichtbegrenzung:
            Lichtwarnungsverhalten:
                klemmenabhaengig
            Coming Home Verbaustatus:
                Not present
            Menuesteuerung Coming Home Werkseinstellung:
                not active
            Coming home Leuchten:
                Low beam
            Menueeinstellung Cominghome:
                not active
            Coming-home Einschaltereignis:
                ignition
            Helligkeitsschwelle Infrarot-Messung:
                0 lx
            Leaving-Home Verbausstatus:
                not enabled
            Menuesteuerung Leaving-home Freischaltung per BAP:
                not active
            LDS_mit_Nebellicht:
                No
            Lichtdrehschalter (LDS):
                discrete
            Menueeinstellung Leaving-home Zeit per BAP:
                not active
            Helligkeitsschwelle Forward-Messung:
                0 lx
            LDS_mit_Nebel_Schlusslicht:
                No
            LDS_mit_AFL:
                No
            LDS_mit_Standlichtstellung:
                Yes
            HVLM_Ladezustandsanzeige:
                No
            LCM_blinker:
                FALSCH
            Allwetterlicht:
                not installed
        Aussenlicht_Front:
            Abblendlicht_Leuchtentyp:
                GDL
            Zahl der aktiven Scheinwerfer auf 2 limitieren:
                limitieren
            Lichthupe bei Zuendung aus moeglich:
                active
            Allwetterlicht Einschaltgrenze:
                350 km/h
            Allwetterlicht Ausschaltgrenze:
                350 km/h
            Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht:
                not active
            Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich:
                not active
            Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge:
                active
            Standlicht aktiviert zusaetzlich Tagfahrlicht:
                active
            Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten:
                active
            Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht:
                not active
            Tagfahrlichtkontrollleuchte:
                not active
            Fahrlicht bei Tag:
                Daytime running lights
            Tagfahrlicht nur in Schalterstellung AUTO:
                not active
            Signaturlicht_verbaut:
                not installed
            Signaturlicht HMI-default Anzeige im Kombiinstrument:
                not active
            TFL_Abschaltung_ueber_Geschwindigkeit:
                not active
            Geschwindigkeitsabhaengiges TFL:
                5 km/h
        Aussenlicht_Heck:
            Bremslicht_ist_auch_Blinklicht:
                Yes
            Schlusslicht mit Bremslichtfunktion:
                not active
            Notbremsanzeige NBA:
                not active
            Umgreifende_Heckklappe:
                not installed
            Nebelschlusslicht Warngeschwindigkeit:
                0 km/h
        Aussenlicht_Blinker:
            Warnblinken_durch_Fahrerassistenz:
                not active
            Komfortblinken Blinkzyklen:
                3
            Abbruch Komfortblinken:
                active
            Komfortblinken:
                active
            Blinkkontrolleuchte fuer Anhaenger:
                separte
            Schluessel_Anlern_Blinken:
                not active
            UGDO_ Anlern_Blinken:
                not active
            ZV_Blinken_zu:
                not active
            ZV_Blinken_auf:
                not active
            Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken:
                not active
            DWA_Schaerfungsquittung:
                not active
            DWA_Alarm_Blinken:
                not active
            Taxialarmblinken:
                not active
            Panikblinken:
                not active
            Multi_kollisions_Blinken:
                not active
            Emergency_alert_blinken:
                not active
            Notwarn_blinken_NBA_Phase_2:
                not active
            dynamisch_blinken_10:
                not active
            Richtungs_blinken_rechts:
                not active
            Richtungs_blinken_links:
                not active
            ABBA_Blinken:
                not active
            Crashblinken:
                not active
            Warnblinken_Zuendung_EIN:
                not active
            Warnblinken_Zuendung_AUS:
                not active
            Dynamische_Blink_Delay:
                50 ms
        Static AFS light:
            bei Rueckwaertsfahrt:
                both sides
            Zeitwert Einschaltzeit Abbiegelicht:
                15 min
            Vorschrift:
                ECE R119
            Untere Geschwindigkeitsschwelle:
                0.0 km/h
            Obere Geschwindigkeitsschwelle:
                40.0 km/h
            Steering wheel angle, offset:
                -63.8 °
            Unterer Lenkradwinkel:
                180 °
            Oberer Lenkradwinkel:
                120 °
            Abdimmgeschwindigkeit:
                50.0 %/s
            Maximaltemperatur:
                100.0 °C
            obere Grenztemperatur:
                95.0 °C
            untere Grenztemperatur:
                80.0 °C
        Sonderfunktionen:
            Sonderfunktionen 1:
                not installed
            Sonderfunktionen:
                not enabled
            Signalprioritaet fuer Blinker:
                MFG
        Fernlicht_assistent:
            Erweiterte_Fernlichtsteuerung:
                AFS, BCM-Fernlicht
            Menuesteuerung Fernlichtassistent:
                Not present
            Fernlichtassistent Reset:
                not active
            Menuesteuerung Fernlichtassistent Werkseinstellung:
                Present
            Assistenzfahrlicht, Empfindlichkeit per BAP einstellbar:
                Present
        Leuchtweitenregulierung:
            sensor_headlight_range_control_installed:
                not installed
            sLWR_verbaut:
                not installed
            1_Sensor_LWR:
                1-Sensor_LWR
            Fahrwerk_Variante:
                Verbundlenkerhinterachse
            sLWR_bei_Abblendlicht:
                not active
            Quelle_Hoehenwerte:
                BCM
            Aktivierung_LWR_Fehlerlampe:
                not active
            Logik_PWM_Signal:
                Negative
            Entprellung_Fehlerlampe:
                0.0 s
            Fail_Safe_sLWR:
                0.0 %
            Zyklus_sLWR:
                0.00 s
            sLWR_Touristenlicht:
                -100.0 %
            sLWR_SW_Grad:
                0.0 %/s
            sLWR_Hysterese:
                0.0 %
            diagnose_soll_toleranz:
                0 %
            Ansteuerung_untere_grenze:
                0.0 %
            Ansteuerung_obere_grenze:
                0.0 %
            Lineare_Abbildung:
            fac_Pwm_Zu_Hoehe_V_1:
                -8.00 mm/%
            fac_Pwm_Zu_Hoehe_H_1:
                -8.00 mm/%
            fac_Pwm_Zu_Hoehe_V_2:
                -8.00 mm/%
            fac_Pwm_Zu_Hoehe_H_2:
                -8.00 mm/%
            Achssensor_PWM_Wert_Einfederung_Sensor_vorn:
                -8.00 mm/%
            Achssensor_PWM_Wert_Einfederung_Sensor_H4:
                -8.00 mm/%
            Achsabstand_des_Fahrzeuges:
                0 mm
            lwr_lFzg_Sw_Abstand:
                0 mm
            lwr_lFzg_Sw_Hoehe:
                0 mm
            pa_fDynFiltStatLwr:
                0 Hz
            fFiltEinf:
                0.00 Hz
            pa_fFiltSwNeigung:
                0.00 Hz
            lwr_pwm_untere_schwelle:
                0.0 %
            lwr_pwm_obere_schwelle:
                0.0 %
            max_v_slwr:
                0 km/h
        lwr_ofs_RSw_Ah1S:
            x0:
                -5.00 %
            x1:
                -5.00 %
            x2:
                -5.00 %
            x3:
                -5.00 %
            x4:
                -5.00 %
            y0:
                -5.00
            y1:
                -5.00
            y2:
                -5.00
            y3:
                -5.00
            y4:
                -5.00
        Kennlinie_sLWR_Soll:
            x0:
                -5.00 %
            x1:
                -5.00 %
            x2:
                -5.00 %
            x3:
                -5.00 %
            x4:
                -5.00 %
            x5:
                -5.00 %
            x6:
                -5.00 %
            x7:
                -5.00
            x8:
                -5.00 %
            x9:
                -5.00 %
            y0:
                0.0 %
            y1:
                0.0 %
            y2:
                0.0 %
            y3:
                0.0 %
            y4:
                0.0 %
            y5:
                0.0 %
            y6:
                0.0 %
            y7:
                0.0 %
            y8:
                0.0 %
            y9:
                0.0 %
        Activate left/right hand drive switch-over:
                not active
        Assistance light functions:
            Regen_Lichtsensor:
                not installed
            Feuchtesensor:
                not installed
            Assistenzfahrlicht bei Regen:
                active
            Sonnensensor:
                not installed
            LS_Error_Ausgabe:
                not active
            Maskierung_Regenfunktion:
                not active
            Lichtsensorempfindlichkeit:
                normal
        Light sensor:
            Einschaltgrenze_CHO_LHO:
                0 lx
            Daemmerungsgrenze, Hysterese_obergrenze:
                0 lx
            Daemmerungsgrenze_Hysterese_untergrenze:
                0 lx
            Helligkeitsgrenze_sehr_hell:
                0 lx
            Helligkeitsgrenze_Licht__einschalten:
                0 lx
            Helligkeitsgrenze_Licht_ausschalten:
                0 lx
            Minimale_Beleuchtungsstaerke:
                0 lx
            Maximale_Beleuchtungsstaerke:
                0 lx
            Minimale_Ausgangsspannung:
                0 mV
            Maximale_Ausgangsspannung:
                0 mV
            Tunnel_einschalt_verzoegerung:
            ECE_Lichteinschaltschwelle:
                0 lx
            Helligkeitsgrenze_Licht_ausschalten_red:
            HMI_Wiper_Comfort_Rain_Sensor_OFF:
                not active
            HMI_Exterior_light_on_highway:
                not active
            HMI_Exterior_light_on_rain:
                not active
            LS_Error_Ausgabe:
                not active
            HMI_exterior_light_sensitivity:
                frueh
        LuB Lichtrouter Kennlinie 1:
            x0:
                0.0 %
            x1:
                5.0 %
            x2:
                50.0 %
            x3:
                75.0 %
            x4:
                110.0
            x5:
                126.5
            y0:
                0.0 %
            y1:
                6.0 %
            y2:
                16.0 %
            y3:
                30.0 %
            y4:
                60.0 %
            y5:
                100.0 %
        Light configuration:
                0C3400140200640000000000000000000C3E00150400640000000000000000000448004A14006406008008091A000000044C004C140064070080080A1A000000013A004914007F06008008097F0000000144004B14007F070080080A7F0000000336001A0B0F7F0000000000000000000340001B0C0F7F0000000000000000002435002608097F000000000000000000243F0027080A7F0000000000000000000237001E0D0F7F0000000000000000000241001F0E0F7F0000000000000000000000000000000000000000000000000000000000000000000000000000000000
        Leuchtenkonfiguration_Aussenlich_Heck:
                00000000000000000000000000000000000000000000000000000000000000000E13003D18026403008008001C0000000E23003E18046405008008001C0000002A29002C180064000000000000000000090A002908001C000000000000000000091A002A08001C00000000000000000012280030080064000000000000000000000000000000000000000000000000002400004708007F000000000000000000090B0031190064000000000000000000091B0032190064000000000000000000
        Leuchtenkonfiguration_Sonstiges:
                0000000000000000000000000000000000000000000000000000000000000000240000022B006400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000290000064C0064000000000000000000
        debug_light_function:
            Adresse:
            Bitmask:
            Offset:
            Divisor:
            Polaritaet:
            Aktivierung:
        Int. light, 2nd generation:
            Aufloesung Dimmzeit:
                0.10 s
            weicher Farbwechsel:
                not active
            Tuertafelbeleuchtung mehrfarbig:
                not active
            Instrumententafelbeleuchtung mehrfarbig:
                not active
            Cockpitbeleuchtung mehrfarbig:
                not active
            Lautsprecherbeleuchtung mehrfarbig:
                not active
            Mittelkonsolenbeleuchtung mehrfarbig:
                not active
            Dachbeleuchtung mehrfarbig:
                not active
            Panoramaschiebedachbeleuchtung mehrfarbig:
                not active
            Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren:
                not active
            BAP Farbwert Farbe 1:
            BAP Farbwert Farbe 2:
            BAP Farbwert Farbe 3:
            Defaultwert Ambienteprofil Mittelkonsole:
                80 %
            Defaultwert Ambienteprofil Dach:
                80 %
            Defaultwert Ambienteprofil Farbe:
            Defaultwert Ambienteprofil Fussraum:
                80 %
            Defaultwert Ambienteprofil Tuer:
                80 %
            Defaultwert Ambienteprofil Vorn:
                80 %
            Helligkeit_Tuertafelbeleuchtung_nicht_berechnen:
                not active
            Helligkeit Instrumententafelbeleuchtung nicht berechnen:
                active
            Helligkeit Cockpitbeleuchtung nicht berechnen:
                active
            Helligkeit Lautsprecherbeleuchtung nicht berechnen:
                active
            Helligkeit Mittelkonsolenbeleuchtung nicht berechnen:
                active
            Helligkeit Dachbeleuchtung nicht berechnen:
                active
            Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen:
                active
            Farbausgabe Tuertafelbeleuchtung nicht berechnen:
                active
            Farbausgabe Instrumententafelbeleuchtung nicht berechnen:
                active
            Farbausgabe Cockpitbeleuchtung nicht berechnen:
                active
            Farbausgabe Lautsprecherbeleuchtung nicht berechnen:
                active
            Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen:
                active
            Farbausgabe Dachbeleuchtung nicht berechnen:
                active
            Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen:
                active
            Innenlicht bei offenem Heckdeckel einschalten:
                active
            KL30G ohne PWM:
                not active
            Weckfaehigkeit_klemme_30G:
                installed
            LIN-Dachkonsole mit Flaechenlicht:
                not installed
            Tuerinnengriffbeleuchtung mit I-Tafel:
                not installed
            Tuerinnengriff mit Tuertafel:
                not installed
        Interior light, light configuration:
            Ambiente_Applikationsleisten_in_Tuertafel:
                installed
            Ambiente_Lautsprecher:
                not installed
            Ambiente_Applikationsleisten_in_Instrumententafel:
                not installed
            Cockpitbeleuchtung:
                not installed
            Mittelkonsolenbeleuchtung:
                not installed
            Dachbeleuchtung:
                not installed
            Panoramaschiebedachbeleuchtung:
                not installed
            Fussraumbeleuchtung:
                installed
            Farbwahl ueber HMI:
                not installed
            Farbwahl ueber Fahrprofil:
                not installed
            LIN-Dachkonsole lokal aktivierbar:
                not active
            Ambientemenue mit globalem aus:
                not active
            Ambientemenue mit alle Zonen:
                not active
            Ambient_Farbliste_HMI:
                not active
            Frei_Farbwahl_ueber_HMI:
                not active
        Interior lighting, parameter:
            p_t_verzoegerung_einstieg_innenlicht:
                0.0 s
            p_t_verzoegerung_ausstieg_innenlicht:
                0.0 s
            p_t_verzoegerung_oeffnen_innenlicht:
                0.0 s
            p_t_verzoegerung_entriegelt_innenlicht:
                0.0 s
            p_t_verzoegerung_schliessen_innenlicht:
                0.0 s
            p_t_verzoegerung_schluessel_ab_innenlicht:
                0.0 s
            p_t_verzoegerung_verriegelt_innenlicht:
                0.0 s
            p_t_verzoegerung_einstieg_tueren:
                0.5 s
            p_t_verzoegerung_ausstieg_tueren:
                0.0 s
            p_t_verzoegerung_oeffnen_tueren:
                0.0 s
            p_t_verzoegerung_entriegelt_tueren:
                0.0 s
            p_t_verzoegerung_schliessen_tueren:
                0.0 s
            p_t_verzoegerung_schluessel_ab_tueren:
                0.0 s
            p_t_verzoegerung_verriegelt_tueren:
                0.0 s
            p_t_verzoegerung_einstieg_fussraum:
                2.0 s
            p_t_verzoegerung_ausstieg_fussraum:
                0.0 s
            p_t_verzoegerung_oeffnen_fussraum:
                0.0 s
            p_t_verzoegerung_entriegelt_fussraum:
                0.0 s
            p_t_verzoegerung_schliessen_fussraum:
                0.0 s
            p_t_verzoegerung_schluessel_ab_fussraum:
                0.0 s
            p_t_verzoegerung_verriegelt_fussraum:
                0.0 s
            p_t_verzoegerung_einstieg_cockpit:
                0.0 s
            p_t_verzoegerung_ausstieg_cockpit:
                0.0 s
            p_t_verzoegerung_oeffnen_cockpit:
                0.0 s
            p_t_verzoegerung_entriegelt_cockpit:
                0.0 s
            p_t_verzoegerung_schliessen_cockpit:
                0.0 s
            p_t_verzoegerung_schluessel_ab_cockpit:
                0.0 s
            p_t_verzoegerung_verriegelt_cockpit:
                0.0 s
            p_t_verzoegerung_einstieg_miko:
                0.0 s
            p_t_verzoegerung_ausstieg_miko:
                0.0 s
            p_t_verzoegerung_oeffnen_miko:
                0.0 s
            p_t_verzoegerung_entriegelt_miko:
                0.0 s
            p_t_verzoegerung_schliessen_miko:
                0.0 s
            p_t_verzoegerung_schluessel_ab_miko:
                0.0 s
            p_t_verzoegerung_verriegelt_miko:
                0.0 s
            p_t_verzoegerung_einstieg_dach:
                0.0 s
            p_t_verzoegerung_ausstieg_dach:
                0.0 s
            p_t_verzoegerung_oeffnen_dach:
                0.0 s
            p_t_verzoegerung_entriegelt_dach:
                0.0 s
            p_t_verzoegerung_schliessen_dach:
                0.0 s
            p_t_verzoegerung_schluessel_ab_dach:
                0.0 s
            p_t_verzoegerung_verriegelt_dach:
                0.0 s
            p_helligkeit_entriegelt_innenlicht:
                100 %
            p_helligkeit_max_innenlicht:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_innenlicht:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_innenlicht:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht:
                0 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht:
                100 %
            p_helligkeit_einausstieg_innenlicht:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht:
                100 %
            p_adaption_kundenwunsch_tuer:
                0.60
            p_helligkeit_entriegelt_tueren:
                0 %
            p_helligkeit_max_tueren:
                96 %
            p_helligkeit_HD_auf_zuendung_ein_tueren:
                126 %
            p_helligkeit_HD_auf_zuendung_aus_tueren:
                127 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_tueren:
                96 %
            p_helligkeit_andereTuer_auf_zuendung_ein_tueren:
                96 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_tueren:
                96 %
            p_helligkeit_andereTuer_auf_zuendung_aus_tueren:
                96 %
            p_helligkeit_einausstieg_tueren:
                96 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren:
                127 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren:
                96 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren:
                96 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren:
                96 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren:
                96 %
            p_adaption_kundenwunsch_fussraum:
                0.20
            p_helligkeit_entriegelt_fussraum:
                0 %
            p_helligkeit_max_fussraum:
                70 %
            p_helligkeit_HD_auf_zuendung_ein_fussraum:
                126 %
            p_helligkeit_HD_auf_zuendung_aus_fussraum:
                127 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum:
                70 %
            p_helligkeit_andereTuer_auf_zuendung_ein_fussraum:
                70 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum:
                70 %
            p_helligkeit_andereTuer_auf_zuendung_aus_fussraum:
                70 %
            p_helligkeit_einausstieg_fussraum:
                70 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum:
                127 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum:
                70 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum:
                70 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum:
                70 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum:
                70 %
            p_adaption_kundenwunsch_lautsprecher:
                1.00
            p_helligkeit_entriegelt_lautsprecher:
                100 %
            p_helligkeit_max_lautsprecher:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_lautsprecher:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_lautsprecher:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher:
                100 %
            p_helligkeit_einausstieg_lautsprecher:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher:
                100 %
            p_adaption_kundenwunsch_itafel:
                1.00
            p_helligkeit_entriegelt_itafel:
                100 %
            p_helligkeit_max_itafel:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_itafel:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_itafel:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_itafel:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_itafel:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_itafel:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_itafel:
                100 %
            p_helligkeit_einausstieg_itafel:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel:
                100 %
            p_adaption_kundenwunsch_cockpit:
                1.00
            p_helligkeit_entriegelt_cockpit:
                100 %
            p_helligkeit_max_cockpit:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_cockpit:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_cockpit:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_cockpit:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_cockpit:
                100 %
            p_helligkeit_einausstieg_cockpit:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit:
                100 %
            p_adaption_kundenwunsch_miko:
                1.00
            p_helligkeit_entriegelt_miko:
                100 %
            p_helligkeit_max_miko:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_miko:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_miko:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_miko:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_miko:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_miko:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_miko:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_miko:
                100 %
            p_helligkeit_einausstieg_miko:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_miko:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_miko:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_miko:
                100 %
            p_adaption_kundenwunsch_dach:
                1.00
            p_helligkeit_entriegelt_dach:
                100 %
            p_helligkeit_max_dach:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_dach:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_dach:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_dach:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_dach:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_dach:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_dach:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_dach:
                100 %
            p_helligkeit_einausstieg_dach:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_dach:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_dach:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_dach:
                100 %
            p_adaption_kundenwunsch_psd:
                1.00
            p_helligkeit_entriegelt_psd:
                100 %
            p_helligkeit_max_psd:
                100 %
            p_helligkeit_HD_auf_zuendung_ein_psd:
                100 %
            p_helligkeit_HD_auf_zuendung_aus_psd:
                100 %
            p_helligkeit_dieseTuer_auf_zuendung_ein_psd:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_ein_psd:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_ein_psd:
                126 %
            p_helligkeit_dieseTuer_auf_zuendung_aus_psd:
                100 %
            p_helligkeit_andereTuer_auf_zuendung_aus_psd:
                100 %
            p_helligkeit_einausstieg_psd:
                100 %
            p_helligkeit_Fzg_geschlossen_zuendung_aus_psd:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd:
                100 %
            p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd:
                100 %
            p_helligkeit_Tueren_geschlossen_schluessel_ab_psd:
                100 %
            p_helligkeit_Fzg_geschlossen_schluessel_ab_psd:
                100 %
            p_dimmfaktor_farbwechsel_auf:
            p_dimmfaktor_farbwechsel_ab:
            p_farbwechsel_delay:
            p_farbauswahl_HMI:
            p_ambienteumfang_mehrfarbig_HMI:
            p_ambienteumfang_mehrfarbig_HMI_2:
            p_ambienteumfang_mehrfarbig_HMI_3:
            p_ambienteumfang_mehrfarbig_HMI_4:
            p_ambientelicht_verbauinformation_HMI:
            p_ambientelicht_verbauinformation_HMI_2:
            p_ambientelicht_verbauinformation_HMI_3:
            p_ambientelicht_verbauinformation_HMI_4:
            p_verzoegerung_berechnen:
            p_t_HMI_verzoegerung_helligkeitswerte:
                200 ms
        Ambientelicht Farbliste:
            Rotwert Farbe 1:
                225
            Gruenwert Farbe 1:
                225
            Blauwert Farbe 1:
                225
            Rotwert Farbe 2:
                225
            Gruenwert Farbe 2:
                225
            Blauwert Farbe 2:
                225
            Rotwert Farbe 3:
                225
            Gruenwert Farbe 3:
                225
            Blauwert Farbe 3:
                225
            Rotwert Farbe 4:
            Gruenwert Farbe 4:
            Blauwert Farbe 4:
            Rotwert Farbe 5:
            Gruenwert Farbe 5:
            Blauwert Farbe 5:
            Rotwert Farbe 6:
            Gruenwert Farbe 6:
            Blauwert Farbe 6:
            Rotwert Farbe 7:
            Gruenwert Farbe 7:
            Blauwert Farbe 7:
            Rotwert Farbe 8:
            Gruenwert Farbe 8:
            Blauwert Farbe 8:
            Rotwert Farbe 9:
            Gruenwert Farbe 9:
            Blauwert Farbe 9:
            Rotwert Farbe 10:
            Gruenwert Farbe 10:
            Blauwert Farbe 10:
        ambient_lighting_lin_slaves_modules:
            pa_einzeladresse_slave_1:
            pa_verbauinfo_slave_1:
                not installed
            pa_fehlerort_slave_1:
            pa_einzeladresse_slave_2:
            pa_verbauinfo_slave_2:
                not installed
            pa_fehlerort_slave_2:
            pa_einzeladresse_slave_3:
            pa_verbauinfo_slave_3:
                not installed
            pa_fehlerort_slave_3:
            pa_einzeladresse_slave_4:
            pa_verbauinfo_slave_4:
                not installed
            pa_fehlerort_slave_4:
            pa_einzeladresse_slave_5:
            pa_verbauinfo_slave_5:
                not installed
            pa_fehlerort_slave_5:
            pa_einzeladresse_slave_6:
            pa_verbauinfo_slave_6:
                not installed
            pa_fehlerort_slave_6:
            pa_einzeladresse_slave_7:
            pa_verbauinfo_slave_7:
                not installed
            pa_fehlerort_slave_7:
            pa_einzeladresse_slave_8:
            pa_verbauinfo_slave8:
                not installed
            pa_fehlerort_slave8:
            pa_einzeladresse_slave_9:
            pa_verbauinfo_slave_9:
                not installed
            pa_fehlerort_slave_9:
            pa_einzeladresse_slave_10:
            pa_verbauinfo_slave_10:
                not installed
            pa_fehlerort_slave_10:
            pa_einzeladresse_slave_11:
            pa_verbauinfo_slave_11:
                not installed
            pa_fehlerort_slave_11:
            pa_einzeladresse_slave_:12:
            pa_verbauinfo_slave_12:
                not installed
            pa_fehlerort_slave_12:
            pa_einzeladresse_slave_13:
            pa_verbauinfo_slave_13:
                not installed
            pa_fehlerort_slave_13:
            pa_einzeladresse_slave_14:
            pa_verbauinfo_slave_14:
                not installed
            pa_fehlerort_slave_14:
            pa_einzeladresse_slave_15:
            pa_verbauinfo_slave_15:
                not installed
            pa_fehlerort_slave_15:
            pa_einzeladresse_slave_16:
            pa_verbauinfo_slave_16:
                not installed
            pa_fehlerort_slave_16:
            pa_einzeladresse_slave_17:
            pa_verbauinfo_slave_17:
                not installed
            pa_fehlerort_slave_17:
            pa_einzeladresse_slave_18:
            pa_verbauinfo_slave_18:
                not installed
            pa_fehlerort_slave_18:
            pa_einzeladresse_slave_19:
            pa_verbauinfo_slave_19:
                not installed
            pa_fehlerort_slave_19:
            pa_einzeladresse_slave_20:
            pa_verbauinfo_slave_20:
                not installed
            pa_fehlerort_slave_20:
        ambient_lighting_lin_slaves_groups:
            pa_verbauinfo_gruppe_1:
                not installed
            pa_lichtfunktion_gruppe_1:
                Door
            pa_korrekturfaktor_gruppe_1:
                1.00
            pa_verbauinfo_gruppe_2:
                not installed
            pa_lichtfunktion_gruppe_2:
                Door
            pa_korrekturfaktor_gruppe_2:
                1.00
            pa_verbauinfo_gruppe_3:
                not installed
            pa_lichtfunktion_gruppe_3:
                Door
            pa_korrekturfaktor_gruppe_3:
                1.00
            pa_verbauinfo_gruppe_4:
                not installed
            pa_lichtfunktion_gruppe_4:
                Door
            pa_korrekturfaktor_gruppe_4:
                1.00
            pa_verbauinfo_gruppe_5:
                not installed
            pa_lichtfunktion_gruppe_5:
                Door
            pa_korrekturfaktor_gruppe_5:
                1.00
            pa_verbauinfo_gruppe_6:
                not installed
            pa_lichtfunktion_gruppe_6:
                Door
            pa_korrekturfaktor_gruppe_6:
                1.00
            pa_verbauinfo_gruppe_7:
                not installed
            pa_lichtfunktion_gruppe_7:
                Door
            pa_korrekturfaktor_gruppe_7:
                1.00
            pa_verbauinfo_gruppe_8:
                not installed
            pa_lichtfunktion_gruppe_8:
                Door
            pa_korrekturfaktor_gruppe_8:
                1.00
            pa_verbauinfo_gruppe_9:
                not installed
            pa_lichtfunktion_gruppe_9:
                Door
            pa_korrekturfaktor_gruppe_9:
                1.00
            pa_verbauinfo_gruppe_10:
                not installed
            pa_lichtfunktion_gruppe_10:
                Door
            pa_korrekturfaktor_gruppe_10:
                1.00
            pa_verbauinfo_gruppe_11:
                not installed
            pa_lichtfunktion_gruppe_11:
                Door
            pa_korrekturfaktor_gruppe_11:
                1.00
            pa_verbauinfo_gruppe_12:
                not installed
            pa_lichtfunktion_gruppe_12:
                Door
            pa_korrekturfaktor_gruppe_12:
                1.00
            pa_verbauinfo_gruppe_13:
                not installed
            pa_lichtfunktion_gruppe_13:
                Door
            pa_korrekturfaktor_gruppe_13:
                1.00
            pa_verbauinfo_gruppe_14:
                not installed
            pa_lichtfunktion_gruppe_14:
                Door
            pa_korrekturfaktor_gruppe_14:
                1.00
            pa_verbauinfo_gruppe_15:
                not installed
            pa_lichtfunktion_gruppe_15:
                Door
            pa_korrekturfaktor_gruppe_15:
                1.00
        Suchbeleuchtung_allgemein:
            Warnblinktastersuchbeleuchtung Aktivierung:
                always active
            Eingabemedium_Suchbeleuchtung:
                potentiometer
            Umgebungs_helligkeit_auswahl:
                Fotosensor_Kombi
            Warnblinktastersuchbeleuchtung Grundwert:
                10.0 %
            Warnblinktastersuchbeleuchtung Faktor:
                0.100
            KL58 Einschalten mit Rampe:
                not active
            KL58 Verriegelungsausschalten:
                not_active
            Lichtsensor wirkt auf Suchbeleuchtung:
                active
            Suchbeleuchtung Festwert:
                100 %
            PWM Daempfung Aufdimmen KL58xs PWM:
                0.00 s
            Daempfung Abdimmen KL 58xs PWM:
                0.00 s
            Daempfung Aufdimmen KL 58xt PWM:
                0.00 s
            Daempfung Abdimmen KL 58xt PWM:
                0.00 s
            Daempfung Aufdimmen KL 58xd PWM:
                0.00 s
            Daempfung Abdimmen KL 58xd PWM:
                0.00 s
            Helligkeit_RLS_Daempfung_Aufdimmen:
                3.0 s
            Helligkeit_RLS_Daempfung_Abdimmen:
                20.0 s
            pa_Hysterese_RLS:
        Suchbeleuchtung_Tasterdimmung:
            tasterdimmung x0:
                0 ms
            tasterdimmung x1:
                100 ms
            tasterdimmung x2:
                160 ms
            tasterdimmung x3:
                200 ms
            tasterdimmung x4:
                260 ms
            tasterdimmung y0:
                1.0 %
            tasterdimmung y1:
                5.0
            tasterdimmung y2:
                15.0
            tasterdimmung y3:
                10.0
            tasterdimmung y4:
                100.0
        Suchbeleuchtung_Hochdimmen:
            x0:
                0 ms
            x1:
                200 ms
            x2:
                400 ms
            x3:
                600 ms
            x4:
                800 ms
            x5:
                1000 ms
            x6:
                1200 ms
            x7:
                1400 ms
            x8:
                1600 ms
            x9:
                1800 ms
            x10:
                2000 ms
            y0:
                0.0 %
            y1:
                1.0 %
            y2:
                3.0 %
            y3:
                5.0 %
            y4:
                11.0 %
            y5:
                22.0 %
            y6:
                40.0 %
            y7:
                80.0 %
            y8:
                95.0 %
            y9:
                100.0 %
            y10:
                100.0 %
        Suchbeleuchtung_Abdimmen:
            x0:
                0 ms
            x1:
                200 ms
            x2:
                400 ms
            x3:
                600 ms
            x4:
                800 ms
            x5:
                1000 ms
            x6:
                1200 ms
            x7:
                1400 ms
            x8:
                1600 ms
            x9:
                1800 ms
            x10:
                2000 ms
            y0:
                100.0 %
            y1:
                72.0 %
            y2:
                48.0 %
            y3:
                33.0 %
            y4:
                18.0 %
            y5:
                12.0 %
            y6:
                8.0 %
            y7:
                6.0 %
            y8:
                4.0 %
            y9:
                2.0 %
            y10:
                0.0 %
        Suchbeleuchtung_Fotosensor:
            x0:
            x1:
                50
            x2:
                100
            x3:
                200
            x4:
                253
            x5:
            x6:
            x7:
            x8:
            x9:
            x10:
            y0:
                0 lx
            y1:
                50 lx
            y2:
                100 lx
            y3:
                200
            y4:
                500
            y5:
            y6:
                0 lx
            y7:
                0 lx
            y8:
                0 lx
            y9:
                0 lx
            y10:
                0 lx
        Suchbeleuchtung_KL 58xs min:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                6.0
            y1:
                6.0
            y2:
                100.0
            y3:
                100.0
        Suchbeleuchtung_KL 58xs max:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                100.0
            y1:
                100.0
            y2:
                100.0
            y3:
                100.0
        Suchbeleuchtung_KL_58xt min:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                6.0
            y1:
                6.0
            y2:
                100.0
            y3:
                100.0
        Suchbeleuchtung_KL_58xt_max:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                100.0
            y1:
                100.0
            y2:
                100.0
            y3:
                100.0
        Suchbeleuchtung_KL_58xd_min:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                220 lx
            x3:
                300 lx
            x4:
                500 lx
            y0:
                6.0
            y1:
                6.0
            y2:
                100.0
            y3:
                100.0
            y4:
                100.0
        Suchbeleuchtung_KL_58xd_max:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                200 lx
            x3:
                300 lx
            x4:
                500 lx
            y0:
                16.0
            y1:
                16.0
            y2:
                100.0
            y3:
                100.0
            y4:
                100.0
        Suchbeleuchtung_KL_58xd_log_Bus:
            x0:
                0.0 %
            x1:
                6.0 %
            x2:
                16.0 %
            x3:
                30.0 %
            x4:
                60.0 %
            x5:
                100.0 %
            y0:
                10
            y1:
                10
            y2:
                100
            y3:
                150
            y4:
                220
            y5:
                253
        Dimmunt_KL_58xs_PWM:
            x0:
                0.0 %
            x1:
                50.0 %
            x2:
                100.0 %
            y0:
                0.0 %
            y1:
                50.0 %
            y2:
                100.0 %
        Suchbeleuchtung_KL_58xt_PWM:
            x0:
                0.0 %
            x1:
                50.0 %
            x2:
                100.0 %
            y0:
                0.0 %
            y1:
                50.0 %
            y2:
                100.0 %
        Suchbeleuchtung_KL_58xd_PWM:
            x0:
            x1:
                10
            x2:
                50
            x3:
                100
            x4:
                220
            x5:
                253
            y0:
                2.0 %
            y1:
                2.0 %
            y2:
                6.0 %
            y3:
                10.0 %
            y4:
                80.0 %
            y5:
                100.0 %
        Suchbeleuchtung_58_xs_Bus_Kennlinie:
            x0:
                0.0 lx
            x1:
                8.0 lx
            x2:
                50.0 lx
            x3:
                80.0 lx
            x4:
                100.0 lx
            y0:
                6.0
            y1:
                6.0
            y2:
                20.0
            y3:
                50.0
            y4:
                100.0
        Suchbeleuchtung_58xt_Bus_Kennlinie:
            x0:
                0.0 lx
            x1:
                8.0 lx
            x2:
                50.0 lx
            x3:
                80.0 lx
            x4:
                100.0 lx
            y0:
                6.0
            y1:
                6.0
            y2:
                20.0
            y3:
                50.0
            y4:
                100.0
        Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie:
            x0:
                0 lx
            x1:
                200 lx
            x2:
                400 lx
            x3:
                600 lx
            x4:
                800 lx
            x5:
                1020 lx
            y0:
            y1:
                84
            y2:
                166
            y3:
                250
            y4:
                370
            y5:
                500
        ZV allgemein:
            Notschliessfunktion:
                active
            Funkfrequenz:
                315MHz
            Funk bei Klemme 15 ein:
                not active
            ZV_ohne_Safe_Funktion:
                installed
            Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster:
                active
            Entsafen mit autorisierte Klemme 15 Ein:
                not active
            Bewusstes Safe mit 2. Betaetigung der FFB:
                not active
            Lock_Unlock_Taster_direkt:
                not installed
            Lock_Unlock_Toggle_Taster:
                not installed
            ZV Tuerentriegelung:
                Einzeltuerentriegelung
            Menuesteuerung Tuerentriegelung:
                active
            LS_Taster_Togglefunktion:
                not active
            Deaktivierung_Laderaumschliessung_extern:
                not active
            Nutzfahrzeug_Schliessung:
                not active
            Wiederverriegelung_Laderaum:
                Freigabe_Softtouch
            Tankschloss:
                bidirectional
        ZV Türkonfiguration:
            Viertuerer:
                Yes
            Fond_Schloss:
                2-Motorenschloesser
            Schlosstyp_NAR:
                Yes
            Schiebetueren_Crafter:
                not installed
            Schiebetuerschloss_direkt_BCM:
                Driver side
            Schiebetuer_Kontaktmodul_Fahrerseite:
                not installed
            Schiebetuer_Kontaktmodul_Beifahrerseite:
                not installed
            Schiebetuer_links:
                No
            Schiebetuer_rechts:
                No
            Schliessung der Schiebetuer bei geoeffneter Tankklappe:
                not active
            HFT_Invertierung_Drehfallensignal:
                nicht invertiert
        ZV Heck:
            Tausch_Tank_Hecktreiberausgang:
                No
            ZV_Heck_Schlosstyp:
                1- oder 2-Rasten-Hecksteller
            Heckschloss_mit_Vorraste:
                Yes
            Heckschloss_Steuerung:
                Kontaktsteuerung
            Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang:
                not active
            Heckdeckelentriegelung_HDF_Innentaster:
                not installed
            ZV entriegelt auch Heckdeckel:
                active
            Direkter Auswurf des Heckdeckels:
                not active
            Heckfreigabe_Ohne_Verzoegerung:
                active
            ZV Heck nur direkt auswerfen:
                not active
            Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster:
                not active
            Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt:
                not active
            Mindestbetaetigung_HDF_Innentaster:
                0.0 s
            Heckoeffnung_ueber_2_Bedienhandlungen:
                not active
        Acknowledgement signals:
            Optical feedback during locking:
                Decelerate
            Optische Rueckmeldung Komfortschliessen:
                active
            Optische Rueckmeldung 3.Bremsleuchte:
                not active
            Akustische Rueckmeldung global:
                active
            Akustische Rueckmeldung entriegeln:
                not active
            Quittierton bei zweitem ZV-AUF-Befehl:
                not active
            Akustische Rueckmeldung verriegeln:
                active
            Quittierton bei zweitem ZV-ZU-Befehl:
                active
            Menuesteuerung akustische Rueckmeldung:
                active
            Dauer der Akustischen Rueckmeldung vom Einfachhorn:
                kurz
            Akustische Rueckmeldung Signalhorn:
                active
            ZV-Blinken_Hellzeit:
                200 ms
            ZV-Blinken_Dunkelzeit:
                200 ms
            ZV-Blinken_Abschluss_Dunkelzeit:
                200 ms
        ZV Komfort:
            Freigabenachlauf FH bei Kl 15 aus:
                active
            Freigabenachlauf FH bei Tueroeffnen abbrechen:
                active
            Komfortbedienung global:
                active
            Comfort opening:
                not active
            Komfortoeffnen nur FH Fahrertuer:
                not active
            Schliesszylinder Komfort oeffnen:
                not active
            Funk Komfort oeffnen:
                not active
            Fahrertuerbedienung Fensterheber oeffnen:
                active
            FH SAD Kl15Aus Freigabezeit:
                600 s
            Comfort closing:
                active
            Schliesszylinder Komfort schliessen:
                not active
            Funk Komfort schliessen:
                not active
            Fahrertuerbedienung Fensterheber schliessen:
                not active
            Menuesteuerung Komfortbedienung einstellbar:
                adjustable
            Regenschliessen_ein_aus:
                not active
            Regenschliessen_art:
                once
            Menuesteuerung Regenschliessen:
                not active
            elektrischer_Fensterheber_hinten:
                Yes
        ZV Autolock:
            Automatisches Verriegeln bei Geschwindigkeit:
                active
            automatisches Entriegeln:
                active
            Autounlock NAR:
                active
            Autolock Autounlock wirkt auf Heck:
                active
            Geschwindigkeitsabhaengige Tankdeckelverriegelung:
                not active
            Menuesteuerung ZV Autolock-Unlock:
                adjustable
        Schiebedach:
            SAD Richtung Komfortoeffnen:
                tilting
            SAD Komfort schliessen:
                not active
            SAD Komfort oeffnen:
                not active
            Schiebedachmodul_MD_1:
                not installed
            Schiebedachmodul_MD_3:
                not installed
            Schiebedachmodul_MD_Rollo:
                not installed
            Verortung Schiebedachmodule:
                LIN
        Spiegelverstellung:
            Spiegelabsenkung bei Rueckwaertsfahrt:
                not active
            Spiegelverstellung Synchron:
                not active
            Menuesteuerung Spiegelabsenkung:
                not active
            Funk Spiegelanklappen:
                not active
            Funk Spiegelanklappung Modus:
                by convenience operation via remote control key
            Menuesteuerung synchrone Spiegelverstellung:
                not active
            Menuesteuerung Funk Spiegel anklappen:
                not active
            Profilfunktion fuer Anklappung der Aussenspiegel:
                active
            Signalisierung_Spiegelanklappung:
                active
            Spiegelanklappen_bei_Wiederverriegelung:
                not active
        ZV Crash:
            Heckdeckel-Bedienstellen nachCrash temporaer sperren:
                active
            ZV-Entriegelung nach Seitencrash:
                not active
            SAD PreCrash Konturschliessen:
                not active
        Anti-theft device:
            Alarmsignal:
                frequency modulated
            Verzoegerung Panikalarm:
                keine verzoegerung
            DWA Alarmverzoegerung:
                not active
            DWA Camper Modus:
                not active
            Ueberwachung Innenentriegelungshebel:
                not active
            Sirenen Alarmzahl:
                1 Alarm
            Akustischer Alarm Signalhorn:
                active
            IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet:
                No
            Diebstahlwarnanlage:
                not active
            Heckscheibenbruchsensor:
                not installed
            DWA_Einfachhorn_oder_Sounder:
                not installed
            tilt_sensor:
                No
            Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv):
                No
            Sensor_fuer_Innenraumueberwachung:
                No
            Parking heater:
                not installed
            OBD Alarm:
                not_active
        After-run for park light:
            Bedingungen zur Beendigung des Standlichtnachlaufs:
                abschalten nach der Nachlaufzeit
            ZV verriegeln bei Klemme 15 Ein:
                not active
            Standlicht-Nachlaufzeit:
                30 min
        Front_wiper:
            Frontwischertyp:
                LIN
            Frontwischer Referenzlauf:
                active
            Variable Regensensoraktivierung:
                not active
            Wischer stop bei KL15 aus:
                not active
            Wischer abparken bei Oeffnen der Motorhaube:
                not active
            Regensensor aktivieren:
                Not deactivated
            Menuesteuerung Frontwischer:
                not active
            Frontwischer Notlaufprogramm:
                active
            Tippwischen mit erhoehter Wischfrequenz:
                active
            Geschwindigkeitsabhaengige Wischstufenrueckschaltung:
                active
            Traenenwischen Front Status:
                not active
            Washer_Tipwiping_Variant:
                not active
            Adaptives Nachwischen bei SRA:
                not active
            Wischer Stopp bei Oeffnen der Motorhaube:
                not active
            Frontwischer_Abtauposition:
                not active
            Anfahrzeit_servicestellung:
                800 ms
        Rear Window Wiper:
            Heckwischer:
                logikgesteuert
            Komfortwischen Heck:
                active
            Menuesteuerung Komfortwischen HW:
                active
            Automatisches Heckwischen:
                not active
            Traenenwischen Heck:
                active
            Heckwischer Weiterlauf:
                not active
            Komofortwischen Heck Intervallpausenzeit Stufe Intervall:
                7 s
            Komofortwischen Heck Intervallpausenzeit Stufe Automatik:
                7 s
            Komofortwischen Heck Intervallpausenzeit Stufe 1:
                5 s
            Komofortwischen Heck Intervallpausenzeit Stufe 2:
                3 s
            Einzelansteuerung Heckintervallwischen Zeitintervall 1:
                8 s
            Einzelansteuerung Heckintervallwischen Zeitintervall 2:
                16 s
            Einzelansteuerung Heckintervallwischen:
                not active
        Scheinwerferreinigung:
            Scheinwerferreinigungsanlage:
                not installed
            SRA bei Waschwassermangel:
                not active
            Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung:
            SRA Verzoegerungszeit:
                0 ms
            SRA Waschzeit:
                0 ms
            SRA Einweichpausenzeit:
                0 ms
            SRA Nachwaschzeit:
                0 ms
            SRA Pausenzeit:
                0 ms
        Button in center console:
            Funktion Taster 1:
                not coded/not installed
            Funktion Taster 2:
            Funktion Taster 3:
                Driving program
            Funktion Taster 4:
            Zusatzcodierung Fahrprofiltaster hat keine LED:
                LED installed
        Seat heater level current consumption allocation:
            Sitzheizung Filterkonstante fuer Waermefluss:
                1 s
            Sitzheizung Regeltemperaturkorrektur bei Waermefluss:
                0.00 °C
            Sitzheizung Stufe 1 untere Schaltschwelle:
                21.50 °C
            Sitzheizung Stufe 1 obere Schaltschwelle:
                22.50 °C
            Sitzheizung Stufe 2 untere Schaltschwelle:
                21.50 °C
            Sitzheizung Stufe 2 obere Schaltschwelle:
                22.50 °C
            Sitzheizung Stufe 3 untere Schaltschwelle:
                33.00 °C
            Sitzheizung Stufe 3 obere Schaltschwelle:
                35.00 °C
            Sitzheizung Stufe 4 untere Schaltschwelle:
                33.00 °C
            Sitzheizung Stufe 4 obere Schaltschwelle:
                35.00 °C
            Sitzheizung Stufe 5 untere Schaltschwelle:
                50.00 °C
            Sitzheizung Stufe 5 obere Schaltschwelle:
                51.00 °C
            Sitzheizung Stufe 6 untere Schaltschwelle:
                50.00 °C
            Sitzheizung Stufe 6 obere Schaltschwelle:
                51.00 °C
            Sitzheitzung_CAN:
                Heizmatten am BCM
            Sitzheizungsfreigabe:
                not installed
        Seat fan charac. curve:
            Level_1_Sitz:
                25 %
            Level_1_Lehne:
                30 %
            Level_2_Sitz:
                25 %
            Level_2_Lehne:
                30 %
            Level_3_Sitz:
                53 %
            Level_3_Lehne:
                58 %
            Level_4_Sitz:
                53 %
            Level_4_Lehne:
                58 %
            Level_5_Sitz:
                80 %
            Level_5_Lehne:
                85 %
            Level_6_Sitz:
                80 %
            Level_6_Lehne:
                85 %
            Sitzlueftung:
                not installed
            Sitzlueftung_reduzierbar:
                installed
            Sitzpneumatik:
                not installed
        Window heater:
            Heizbare_Frontscheibe:
                not installed
            Heizbare Heckscheibe:
                installed
            Waschduesenheizung:
                installed
            Frontscheibenheizung_LED_direkt:
                not installed
            Frontscheibenheizungsansteuerung direkt von externem Algorithmus:
                not installed
            Temperaturabhaengige Einschaltzeit HSH:
                active
            Temperaturabhaengige Einschaltzeit FSH:
                active
            FSH Automatik:
                active
            Heckscheibenheizung Zeitwert:
                320 s
            Running time of heated front window:
                240 s
            Abschalttemperatur fuer Heckscheibenheizung:
                35.0 °C
            Abschalttemperatur fuer Frontscheibenheizung:
                35.0 °C
            Frontscheibenheizung _maximale_Dauer:
                0 s
            window heating front activation time:
                240 s
        A/C heater function via remote control:
            Remotestart:
                not installed
            Rueckmeldung_bei_Aktivierung:
                active
            Kombi_Fahrerhinweis_m_Uebernahme_RSt:
                active
            Abbruch_Hupen_RSt:
                not active
            Abbruch_d_Warnblinker_moeglich:
                active
            Kombi_Fahrerhinweis_m_Akustik:
                active
            Aktivierung_Drehzahlanzeige:
                active
        Characteristics in production mode:
            Headlamp washer system:
                2000 ms
        Roller test bench mode, functional:
                not active
        Transport mode:
                active
        Production mode:
                not active
            Heckwischer:
                not active
            Innenbeleuchtung:
                not active
            Aussenbeleuchtung:
                not active
            Zugangskontrolle:
                not active
            Virtuel_pedal:
                not active
        Deactivate production mode:
                not active
        Schlüssellose Zugang- und Startberechtigung:
            Kessy:
                installed
            Elektische_Lenkradverriegelung:
                installed
            Kessy Komfort oeffnen:
                not active
            Kessy Komfort schliessen:
                active
            Oeffnung Heckdeckel bei Wiederentriegelung:
                not active
            Kessy Komfortbedienung Reichweitenbegrenzung:
                not active
        Writing parameter:
            Parameter address:
                fe0000
            value:
                130
        Read parameter address:
            Parameter address:
                fe0000
        Vernetzungs- Diagnosefunktionen:
            can msg 1:
            can msg 2:
            can msg 3:
            can msg 4:
            lin msg 1:
            lin msg 2:
            lin msg 3:
            lin msg 4:
            lin msg 5:
            lin msg 6:
        LIN-Mirrormode:
            mirror_mode_typ:
                not active
            Data bus LIN 1:
                not active
            Data bus LIN 2:
                not active
            Data bus LIN 3:
                not active
            Data bus LIN 4:
                not active
            Data bus LIN 5:
                not active
            Data bus LIN 6:
                not active
        Activating and deactivating all development messages:
                not active
        Energy management:
            Hybridfahrzeug:
                No
            Recuperation:
                not active
            Energiemanagement Abschaltung:
                active
            Zweitbatterie:
                not installed
            Energy_Management_Adaptation:
                Energy management active
            Praediktives_Energiemanagement:
                not active
            Hochvoltfahrzeug:
                not installed
        Personalisierung:
            Personalisierung_Profilfunkion:
                profiles_inactive
            Profil_Variante:
                Schluessel
            Personalisierung_aktiv:
                not active
            Aktivierungsoption_im_HMI-Menue_sichtbar:
                active
            Benutzerkontenverwaltung_in_HMI-Menue_sichtbar:
                active
            Personalisierungsfunktionen_in_HMI-Menue_sichtbar:
                active
            Anzahl_Benutzerkonten:
                4
            Automatische_ Schluesselzuordnung:
                not active
            PSO_FSG_Setup2_Bit_1:
                active
            PSO_FSG_Setup2_Bit_2:
                active
            PSO_FSG_Setup2_Bit_3:
                not active
            PSO_FSG_Setup2_Bit_4:
                not active
        Verdecksteuergeraet:
            Nachsaven_nach_Verdecklauf:
                not active
            Komfortbedienung Verdeck global:
                active
            Komfortbedienung Verdeck oeffnen:
                active
            Komfortbedienung Verdeck schliessen:
                active
            Verdeck oeffnen via Schliesszylinder:
                active
            Verdeck schliessen via Schliesszylinder:
                active
            Verdeck oeffnen via Funkfernbedienung:
                active
            Verdeck schliessen via Funkfernbedienung:
                active
            Verdeck oeffnen via Kessy:
                active
            Verdeck schliessen via Kessy:
                active
            Doppelpuls nur Verdeck:
                active
            Verdeck mit Schiebedach:
                not active
            Heckdeckel sperren bei Verdeckbetrieb:
                not active
            Softtouch-Betaetigung senden:
                immer
            Servoheck Schlossansteuerung:
                immer
            Reichweitenbegrenzung fuer Servoheck schliessen:
                not active
            Cabrio_Verdeck:
                not_installed
            trunk_lid_conrol_unit:
                not installed
            Virtuelles_Pedal_Verbau:
                not installed
            Virtuelles_Pedal:
                not active
            Virtuelles_Pedal_HMI_einstellba:
                not active
            easycloselight_aktiv:
                not active
            Kick_and_close:
                not installed
        OCU:
            OCU:
                installed
            DWA_push:
                active
            Remote_Unlock_Lock:
                Via ZV-Absicherung Light
            Honk DWA_Ausgabe_Fanfare:
                active
            Remote Lock Unlock Timer s3:
                20.0 ms
            Remote Lock Unlock Timer s1:
                80 s
            Remote HuF Abbruch:
                20 km/h
            Remote HuF Hupfrequenz:
        Allwetterlicht_Spoiler:
            tt_spoiler:
                not installed
            Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT:
                not active
            Spoiler Einfahrunterdrueckung nach manuellem Ausfahren:
                not active
        Slave_systems_identification:
                Not available
                Not available
            Light Switch:
                Not available
            Garage Door Opener Control Module:
                Not available
            Garage Door Opener Operating Unit:
                Not available
                Not available
            Alarm Horn:
                Not available
            Sun Roof:
                Not available
            Ceiling Light Module:
                Not available
            Roof Blind:
                Not available
                Not available
            Neck Heating Left:
                Not available
            Neck Heating Right:
                Not available
            Seat Backrest Fan 1 Front Left:
                Not available
            Seat Cushion Fan 1 Front Left:
                Not available
            Seat Backrest Fan 1 Front Right:
                Not available
            Seat Cushion Fan 1 Front Right:
                Not available
        upper turn position:
                170.494335 °
        lower turn position:
                31.494474 °
        Position during interval mode:
                31.494474 °
        Alternating park position 1:
                7.494498 °
        Alternating park position 2:
                29.494476 °
        Service position:
                170.494335 °
        Kopfraumheizung:
            blower_speed:
            temperature:
                -2
    Mileage: 535 km
    Date: 2017-03-02 19:41
Notwithstanding the different format of the report from the "other" diagnostic device -there is a significant change in the structure of the adaption channels in the list and there is a re-assignment of Parent-Child associations.
Here's an example - Dana's admap for the 5Q0-937-087-AA BCM reports the adaptation channel:
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich - So, ignoring the new RT tags for the moment, the Parent identifier for this channel is clearly Daytime running lights
The "other" diagnostic cable for the 5Q0-937-087-AN BCM reports the same adaptation channel Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich, but instead of associating this with the DRL Parent name, it now is associated to the entirely new parent name Aussenlicht_Front (i.e. Outdoor lighting_Front, in English). This change is more than just substituting "DRL" for its German equivalent name "Tagfahrlicht"! There is also a new Parent name Aussenlicht_Heck, which has not previously appeared in these BCMs - and many more like examples!!
So, -if anyone has a VCDS admap for a BCM with these weird new re-structured channels (clearly from a PN/SW like 5Q0-937-087-AN)- I'd welcome a copy - please
Hi Don,
I can't offer scans/maps but I did search for those strings and can confirm the exact text exists in files such as:
EV_BodyContrModul1UDSBosc_017.ROD
EV_BodyContrModul1UDSCont_017.ROD
Using ROD files in a search isn't always accurate (because they may change) but the ASAM Dataset won't because that comes from the module. In this case I would search for the entire string like my example:
I think his would read something more like this if it was scanned with VCDS:
EV_BodyContrModul1UDSBosc 017002
.. and 017002 is way newer than my 015002 version.
