On my 2006 Audi A8L 4.2... I replaced the Secondary Air Pump a couple of weeks ago, it seemed like it did the trick in getting rid of the "Insufficient Flow" DTC code from the previous pump. However about 500kms later, the same codes have come back. So I thought I should check to make sure that the replacement pump is actually working... I wanted to run an "output test" that will activate the pump?
If in fact the output test is under the 01 Engine Module (where the DTC code came from)... then I would guess that there are probably a ton of output tests for that system? Is there any way to skip over other tests to get to a specific output test?
Friday,03,March,2017,13:42:28:08168
VCDS Version: 17.1.3.0 HEX-V2 CB: 0.4334.4
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E8774746
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E0604104C16BBF78F5-807A
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Mileage: 204771 km
RPM: 660 /min
Load: 21.2 %
Temperature: 93.0°C
Temperature: 47.0°C
Absolute Pres.: 0.0 mbar
Voltage: 14.478 V
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow - MIL ON
Fault Status: 11100010
Mileage: 204944 km
RPM: 1647 /min
Load: 45.5 %
Speed: 23.0 km/h
Temperature: 60.0°C
Temperature: 32.0°C
Voltage: 13.970 V
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - MIL ON
Mileage: 204944 km
RPM: 1647 /min
Load: 45.5 %
Speed: 23.0 km/h
Temperature: 60.0°C
Temperature: 32.0°C
Voltage: 13.970 V
