Hello everyone.
VW did cluster exchange online from LowLine to HighLine .
All good , expect one error
TPMS on DiscoverMedia show - Not Available
Before cluster swap all was good.
I am able reset TPMS from ABS adaptation and VCDS show "correct ", but SET button on Discover media no longer work
All adaptation was re-write from old cluster to new,
Any suggestion where / what to look ?
I did some reserch and seems this error come from Trailer module, but cant find where to decode it , in a fact only cluster can contain Trailer info, because my car dont have that
Thursday,02,March,2017,21:20:31:25051
VCDS Version: 17.1.3.0
Dealer/Shop Name: Spacewalker
Workshop Code: 020 01342 012345
VIN: WVWZZZAUZFW205302 License Plate:
Mileage: 8510km-5287mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZFW205302 Mileage: 8510km-5287miles
Address 01: Engine (J623-CXSA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 DE HW: 04E 907 309 A
Component: 1,4l R4 TSI H10 7774
Revision: WAH10---
Coding: 01190032232405082000
Shop #: WSC 01342 020 12345
ASAM Dataset: EV_ECM14TFS01104E906016DE 002006
ROD: EV_ECM14TFS01104E906016DE_VW37.rod
VCID: 68D5BA339312000141-803C
Part No SW: 3Q0 907 379 F HW: 3Q0 907 379 F
Component: ESC H42 0609
Revision: 00000000 Serial number: 63374000000767
Coding: 01FA6AA124202971077A060041C52980562494E0608294F300200078C002
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 3D7B3B67AC1075A9C2-8068
8299 - Databus
Reset counter: 4
Date: 2017.03.01
Time: 18:27:47
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5G0 907 426 T HW: 5G0 907 426 T
Component: AC Manuell H02 1001
Revision: 00001K06
Coding: 00020004200100001000000000000000
ROD: EV_ACManueBHBVW37X_SK48.rod
VCID: 3C7D3663B70A7CA1F5-8068
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011433701787
Coding: 00000A42C24122730BA44080B10C07081000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 000582939B62D841E9-8054
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140719 043 0551
Serial number: 140726190131
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y14M12D10H17M35S39
Coding: 05A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY143212GFC
Serial number: 00000000000061173199
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391433514013
Coding: 0031051001
ROD: EV_EPHVA18AU3700000_VW37.rod
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R0E3NTY
VCID: 41834797D0E81149A6-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 212 14
Serial number: 35767000000D2B74321S
Subsystem 2 - Part No SW: ----------- HW: 480 000 412 14
Serial number: 35867000000B5BE0321X
Subsystem 3 - Part No SW: ----------- HW: 480 402 811 14
Serial number: 3516502A7188FC24917K
Subsystem 4 - Part No SW: ----------- HW: 480 402 811 14
Serial number: 3526502B318B3A71E22A
Subsystem 5 - Part No SW: ----------- HW: 480 402 811 14
Serial number: 3556502A118B3AB393AK
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AA HW: 5Q0 953 549
Revision: -------- Serial number: 05121408490885
Coding: 0400
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 75EBE347D4A0EDE9CA-8020
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.lbl
Part No SW: 517 920 750 HW: 517 920 750
Component: KOMBI 301 4260
Coding: 07A502002B80000807087E001400000000000000
Shop #: WSC 111246 001 1048576
ASAM Dataset: EV_DashBoardVDDMQBAB 009036
VCID: 54AD7EC33F9A94E11D-8000
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW MQB High 128 1204
Revision: -------- Serial number: 0002818375
Coding: 030100042F085700EF000048080F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 72E1D85BA5CEFAD1EF-8026
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0038
Serial number: 29140002727390084496
Coding: 28FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 1945735203
Part No SW: 5Q0 959 393 D HW: 5Q0 959 393 B
Component: TSG FS 020 0028
Serial number: 071214BL615153
Coding: 003002208000040000001000
VCID: 40854293DBE21841A9-8014
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004643923
Coding: 110000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
VCID: 438F4D9FCAF40359B4-8016
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 021214BL211212
Coding: 003000208E00040000801000
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004670226
Coding: 090000
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 029A000001000000
ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-HGH1.clb
Part No SW: 5G0 035 043 C HW: 5G0 035 043
Component: MU-H-N-EU H40 0290
Serial number: A457D0E7514135
Coding: 02730001FF00000011110001000B00001F020794010001017F
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 1E39DCEB01D60EB1FB-804A
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0032
Serial number: VWZ8Z9RU304L3X
Subsystem 2 - Part No SW: V03 959 801 DG HW: -----------
Component: ECE 2016/2017 --- 0153
Compact Disc Database:
Component: Gracenote --- 1008
End-------------------------(Elapsed Time: 03:47)--------------------------
