hi guys
the first time i post this thread
i need coding abs vw passat 3C the coding change after change parking brake ecu was damaged by water
any help please
thanks
any help please
thanks
Monday,27,February,2017,20:11:30:13545
VCDS Version: 16.8.4.2
VIN: WVWZZZ3CZ8P020401 License Plate: VW PASSAT ABS CODING
Mileage: 132870km-82561mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 5D 62 72 76
77
VIN: WVWZZZ3CZ8P020401 Mileage: 132870km-82561miles
15-Airbags -- Status: Malfunction 1010
5D-Operations -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 FH HW: 03G 906 018 FH
Component: R4 2.0l PPD1.5 G 1605
Revision: --H45--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00028 028 00001
VCID: 70EF25D26397FAC239-8024
005685 - Powertrain Data Bus
P1635 - 009 - Missing Message from A/C Controller - Intermittent
Reset counter: 38
Mileage: 132871 km
Date: 2017.02.25
Time: 02:19:09
RPM: 768 /min
Torque: 24.0 Nm
0.00 %
Voltage: 11.53 V
Bin. Bits: 00000000
Bin. Bits: 00000000
005686 - Powertrain Data Bus
P1636 - 009 - Missing Message from Airbag Controller - Intermittent
Reset counter: 38
Mileage: 132871 km
Date: 2017.02.25
Time: 02:19:09
RPM: 768 /min
Torque: 24.0 Nm
0.00 %
Voltage: 11.53 V
Bin. Bits: 00001100
Torque: 0.0 Nm
049448 - No Communications with Parking Brake Control Module
U0128 - 009 - - Intermittent
Reset counter: 38
Mileage: 132871 km
Date: 2017.02.25
Time: 02:19:09
RPM: 768 /min
Torque: 24.0 Nm
0.00 %
Voltage: 13.90 V
Bin. Bits: 11001100
Bin. Bits: 00000000
Readiness: N/A
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 C HW: 3C0 614 109 C
Component: J104 C4 440 V1 0003
Revision: --020--- Serial number: 00000775629621
Coding: 0000279
Shop #: WSC 00012 000 00000
VCID: 1E332B6AC9833CB2DB-804A
Reset counter: 200
Mileage: 132871 km
Date: 2017.02.25
Time: 00:58:18
Hex Value: 0x0000
Voltage: 14.25 V
Bin. Bits: 00011110
Count: 199
Reset counter: 200
Hex Value: 0x0000
Voltage: 12.25 V
Bin. Bits: 00011110
Count: 149
Reset counter: 200
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CB HW: 3C0 907 044 CB
Component: ClimatronicPQ46 122 0707
Revision: 00122021 Serial number: 00000000000000
VCID: 63C55A9EA261515AB4-8036
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004970057
Coding: E5808F0700041A00470A00000F00000000095D435C0001
VCID: 6CD731A24FBF1E2205-8038
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 250507 003 0205
Coding: 00046997
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 290607 046 0204
Coding: 00208933
Shop #: WSC 00028
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 200
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:00
Voltage: 14.00 V
Reset counter: 238
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:00
Voltage: 14.00 V
Fault Frequency: 8
Reset counter: 238
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:00
Voltage: 14.00 V
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 0B AIRBAG VW8 032 2522
Revision: 12032000 Serial number: 003B1PCG50H4
Coding: 0012354
VCID: 306FE5D2A317BAC279-8064
Subsystem 1 - Serial number: 6332MSME1C330014
Subsystem 2 - Serial number: 6342MSME1C0D301C
Subsystem 3 - Serial number: 6351HTS6D3KGK397
Subsystem 4 - Serial number: 6361HTS6OFJSM696
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 M HW: 3C0 953 549 M
Component: J0527 0015
Revision: 00006000 Serial number: 3C5953507BJ
Coding: 0000311
VCID: 3663D3CA417394F223-8062
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 80093 222 69422
VCID: 2643038A91D3E47293-8072
Reset counter: 238
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:17
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P0762003D0
Coding: F9807F0E4026021002
VCID: 23451A9EE2E1115AF4-8076
Reset counter: 238
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:18
Reset counter: 238
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:18
Reset counter: 198
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:22
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
VCID: 3979D8F6706D7B8ACE-806C
Subsystem 1 - Part No: 3C0 959 433 R
Subsystem 2 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0 959 433 R IMMO 042 03833C0905861G ELV 027 0380
No Faults Found
Address 37: Navigation Labels: 1K0-035-191.lbl
Part No SW: 1K0 035 191 D HW: 1K0 035 191 D
Component: J401 0303
Revision: 00018000 Serial number: VWZ1Z2G7267025
Coding: 0043400
Reset counter: 198
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:16
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1131
Revision: 31008001 Serial number: 00000539778530
Coding: 0000247
VCID: 3C77C1E27F5F4EA2D5-8068
Fault Status: 01100101
Reset counter: 200
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:18
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
VCID: 3561D4C65C759FEA2A-8060
02546 - Steering Limit Stop
Mileage: 132860 km
Temperature: 25.0°C
Voltage: 14.00 V
Voltage: 13.80 V
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Revision: 00042000 Serial number: VWZCZ000000000
Coding: 01910A0001860E763004941570084FCE707C00
Component: LIN BACKUP HORN H07 9001
Component: Neigungssensor 004 0611
Reset counter: 239
Reset counter: 238
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:20
Reset counter: 239
Mileage: 132871 km
Date: 2017.02.25
Time: 02:14:14
01134 - Alarm Horn (H12)
Reset counter: 239
Mileage: 132871 km
Date: 2017.02.25
Time: 02:14:14
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1131
Revision: 31008001 Serial number: 00000005278531
Coding: 0000246
VCID: 3D71CCE6644547AAE2-8068
Reset counter: 200
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:18
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C0 907 801 J
Component: J540 EPB3 VW-15417 0007
Revision: 008 Serial number: 00000000063054
Coding: 0000056
VCID: 2C57F1A28F3FDE2245-8078
02433 - Supply Voltage for Right Parking Brake Motor (V283)
011 - Open Circuit - MIL ON
Fault Status: 11101011
Reset counter: 200
Mileage: 132871 km
Date: 2017.02.25
Time: 00:56:28
Voltage: 14.10 V
Count: 31
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0404
000 - - - MIL ON
Fault Status: 11110000
Reset counter: 0
Voltage: 5.00 V
Count: 43
Hex Value: 0x4040
Hex Value: 0x0082
Hex Value: 0x1010
Address 56: Radio Labels: 1K0-035-191.lbl
Component: R 0303
Coding: 0043400
Reset counter: 198
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:16
Address 5D: Operations Labels: 3C0-035-151.lbl
Part No SW: 3C0 035 151 C HW: 3C0 035 151 C
Component: J738 011 0019
Revision: 00011000
VCID: 183F3D722BA7428211-804C
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1118
Revision: 11006001 Serial number: 00000001929675
Coding: 0000208
Reset counter: 200
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:18
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1118
Revision: 11006001 Serial number: 00000001923892
Coding: 0000208
VCID: 3E73CBEA69435CB2FB-806A
00935 - Electric Window Motor; Rear Right (V27)
Reset counter: 200
Mileage: 132871 km
Date: 2017.02.25
Time: 02:23:18
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 C HW: 3C0 919 283 C
Component: Parkhilfe 8-Kan 004 0013
Revision: 00004000 Serial number: 90630717214353
Coding: 0000014
VCID: 295908B680CDCB0ABE-807C
Address 77: Telephone
End-------------------------(Elapsed Time: 02:52)--------------------------
