need coding abs vw passat 3C
scanboy83
Morocco
C?ID=197556
hi guys
the first time i post this thread
i need coding abs vw passat 3C the coding change after change parking brake ecu was damaged by water
any help please
thanks
Monday,27,February,2017,20:11:30:13545
VCDS Version: 16.8.4.2
VIN: WVWZZZ3CZ8P020401   License Plate: VW PASSAT ABS CODING
Mileage: 132870km-82561mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 5D 62 72 76
          77
VIN: WVWZZZ3CZ8P020401   Mileage: 132870km-82561miles
08-Auto HVAC -- Status: Sporadic communication error 1000
15-Airbags -- Status: Malfunction 1010
5D-Operations -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 FH    HW: 03G 906 018 FH
   Component: R4 2.0l PPD1.5 G    1605
   Revision: --H45---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00028 028 00001
   VCID: 70EF25D26397FAC239-8024
005685 - Powertrain Data Bus
               P1635 - 009 - Missing Message from A/C Controller - Intermittent
                    Reset counter: 38
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:19:09
                    RPM: 768 /min
                    Torque: 24.0 Nm
                        0.00 %
                    Voltage: 11.53 V
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
005686 - Powertrain Data Bus
               P1636 - 009 - Missing Message from Airbag Controller - Intermittent
                    Reset counter: 38
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:19:09
                    RPM: 768 /min
                    Torque: 24.0 Nm
                        0.00 %
                    Voltage: 11.53 V
                    Bin. Bits: 00001100
                    Torque: 0.0 Nm
049448 - No Communications with Parking Brake Control Module
               U0128 - 009 -  - Intermittent
                    Reset counter: 38
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:19:09
                    RPM: 768 /min
                    Torque: 24.0 Nm
                        0.00 %
                    Voltage: 13.90 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
Readiness: N/A
   Part No SW: 3C0 614 109 C    HW: 3C0 614 109 C
   Component: J104    C4 440 V1   0003
   Revision: --020---    Serial number: 00000775629621
   Coding: 0000279
   Shop #: WSC 00012 000 00000
   VCID: 1E332B6AC9833CB2DB-804A
            000 -  -
                    Reset counter: 200
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 00:58:18
                    Hex Value: 0x0000
                    Voltage: 14.25 V
                    Bin. Bits: 00011110
                    Count: 199
            000 -  -
                    Reset counter: 200
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011110
                    Count: 149
                    Reset counter: 200
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 CB    HW: 3C0 907 044 CB
   Component: ClimatronicPQ46 122 0707
   Revision: 00122021    Serial number: 00000000000000
   VCID: 63C55A9EA261515AB4-8036
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004970057
   Coding: E5808F0700041A00470A00000F00000000095D435C0001
   VCID: 6CD731A24FBF1E2205-8038
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 250507 003  0205
   Coding: 00046997
   Shop #: WSC 00028
   Component: RLS     290607 046  0204
   Coding: 00208933
   Shop #: WSC 00028
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 200
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:00
                    Voltage: 14.00 V
                    Reset counter: 238
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:00
                    Voltage: 14.00 V
                    Fault Frequency: 8
                    Reset counter: 238
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:00
                    Voltage: 14.00 V
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0B AIRBAG VW8   032 2522
   Revision: 12032000    Serial number: 003B1PCG50H4
   Coding: 0012354
   VCID: 306FE5D2A317BAC279-8064
   Subsystem 1 - Serial number: 6332MSME1C330014
   Subsystem 2 - Serial number: 6342MSME1C0D301C
   Subsystem 3 - Serial number: 6351HTS6D3KGK397
   Subsystem 4 - Serial number: 6361HTS6OFJSM696
01217 - Side Airbag Igniter; Driver Side (N199)
01218 - Side Airbag Igniter; Passenger Side (N200)
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
   Part No SW: 3C0 953 549 M    HW: 3C0 953 549 M
   Component: J0527               0015
   Revision: 00006000    Serial number: 3C5953507BJ
   Coding: 0000311
   VCID: 3663D3CA417394F223-8062
   Part No SW: 3C0 920 871 E    HW: 3C0 920 871 E
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 80093 222 69422
   VCID: 2643038A91D3E47293-8072
                    Reset counter: 238
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:17
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P0762003D0
   Coding: F9807F0E4026021002
   VCID: 23451A9EE2E1115AF4-8076
                    Reset counter: 238
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:18
                    Reset counter: 238
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:18
                    Reset counter: 198
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:22
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 3979D8F6706D7B8ACE-806C
   Subsystem 1 - Part No: 3C0 959 433 R
   Subsystem 2 - Part No: 3C0 905 861 G
   Component:    ELV          027 0380
   3C0 959 433 R      IMMO         042 03833C0905861G     ELV          027 0380
No Faults Found
Address 37: Navigation        Labels: 1K0-035-191.lbl
   Part No SW: 1K0 035 191 D    HW: 1K0 035 191 D
   Component: J401                0303
   Revision: 00018000    Serial number: VWZ1Z2G7267025
   Coding: 0043400
                    Reset counter: 198
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:16
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1131
   Revision: 31008001    Serial number: 00000539778530
   Coding: 0000247
   VCID: 3C77C1E27F5F4EA2D5-8068
                    Fault Status: 01100101
                    Reset counter: 200
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:18
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   VCID: 3561D4C65C759FEA2A-8060
02546 - Steering Limit Stop
                    Mileage: 132860 km
                    Temperature: 25.0°C
                    Voltage: 14.00 V
                    Voltage: 13.80 V
            000 -  -
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: 01910A0001860E763004941570084FCE707C00
   Component: LIN BACKUP HORN H07 9001
   Component: Neigungssensor  004 0611
                    Reset counter: 239
                    Reset counter: 238
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:20
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 239
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:14:14
                    Reset counter: 239
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:14:14
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1131
   Revision: 31008001    Serial number: 00000005278531
   Coding: 0000246
   VCID: 3D71CCE6644547AAE2-8068
                    Reset counter: 200
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:18
   Part No SW: 3C8 907 801 E    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-15417 0007
   Revision:   008       Serial number: 00000000063054
   Coding: 0000056
   VCID: 2C57F1A28F3FDE2245-8078
02433 - Supply Voltage for Right Parking Brake Motor (V283)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Reset counter: 200
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 00:56:28
                    Voltage: 14.10 V
                    Count: 31
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0404
            000 -  -  - MIL ON
                    Fault Status: 11110000
                    Reset counter: 0
                    Voltage: 5.00 V
                    Count: 43
                    Hex Value: 0x4040
                    Hex Value: 0x0082
                    Hex Value: 0x1010
Address 56: Radio        Labels: 1K0-035-191.lbl
   Component: R                   0303
   Coding: 0043400
                    Reset counter: 198
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:16
Address 5D: Operations        Labels: 3C0-035-151.lbl
   Part No SW: 3C0 035 151 C    HW: 3C0 035 151 C
   Component: J738            011 0019
   Revision: 00011000
   VCID: 183F3D722BA7428211-804C
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1118
   Revision: 11006001    Serial number: 00000001929675
   Coding: 0000208
00934 - Electric Window Motor; Rear Left (V26)
                    Reset counter: 200
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:18
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1118
   Revision: 11006001    Serial number: 00000001923892
   Coding: 0000208
   VCID: 3E73CBEA69435CB2FB-806A
00935 - Electric Window Motor; Rear Right (V27)
                    Reset counter: 200
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:18
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
   Component: Parkhilfe 8-Kan 004 0013
   Revision: 00004000    Serial number: 90630717214353
   Coding: 0000014
   VCID: 295908B680CDCB0ABE-807C
Address 77: Telephone
End-------------------------(Elapsed Time: 02:52)--------------------------
United States
This is one of those PPD TDIs with a C4 ABS controller so we may need some additional time to dig but I believe 0000282 is a good starting point for that 03-ABS coding.
011A | 0000282
United States
PR Data:
Vehicle Identification No.	WVWZZZ3CZ8P020401
Model	passat sedan
PA
Date of production	04.07.2007
Year	2008
Sales type	3C2332
Engine Code	BMA
Transmission Code	KDN
G0K	6-speed manual transmission
MS9	4-cyl. turbo diesel engine 2.0 L/100 kW 16V (TDI) with pump-jet injection system Base engine is T9G/TB3/TQ0/TN0
TB3	4-cylinder diesel engine 2.0 L unit 03G.B
L0L	Left-hand drive vehicle
1SA	Without additional front underbody guard
8T2	Cruise control system (CCS) electronic
scanboy83
Morocco
C?ID=197556
i tested this code before but still error....
United States
OK, hopefully someone else has a suggestion. The dealer would code that module online via SVM and if you have to go that route we would highly appreciate the final Auto-Scan.
scanboy83
Morocco
C?ID=197556
thanks
ok how can do online ; you can do by vcds ...?
scanboy83
Morocco
C?ID=197556
i tried this 0000258- 0000267 and 0000309
0001291.............................................
but nothing
NostraJackAss
MODELMYENGINE-CODEPART#COMPONENTCODING
VW Passat Sedan2006BKC3C0 614 095 KESP 440 C2 H014 000113569
VW Passat Sedan2006BLF3C0 614 095 MESP 440 C2 H015 000113698
VW Passat Sedan2006BKC3C0 614 095 PESP 440 C2 H015 000313569
VW Passat Sedan2006BKP3C0 614 095 PESP 440 C2 H015 000329986
VW Passat Sedan2006BKP3C0 614 095 PESP 440 C2 H015 000313602
VW Passat Variant2006BKC3C0 614 095 PESP 440 C2 H015 000313569
VW Passat Sedan US2006BLV3C0 614 095 QESP 440 C2 H015 000346541
VW Passat Variant2006BKP3C0 614 095 PESP 440 C2 H015 000313602
VW Passat Variant2006BLR3C0 614 095 NESP 440 C2 H015 000130094
VW Passat Variant2006BKP3C0 614 095 QESP 440 C2 H015 000315650
VW Passat Sedan2006BKP3C0 614 095 MESP 440 C2 H015 000113602
VW Passat Sedan2006BKC3C0 614 095 MESP 440 C2 H015 000113569
VW Passat Variant2006BXE3C0 614 095 PESP 440 C2 H015 000313569
VW Passat Sedan2006BMR3C0 614 095 QESP 440 C2 H015 000313629
VW Passat Sedan2006BKP3C0 614 095 QESP 440 C2 H015 000329989
VW Passat Variant2007BXE3C0 614 095 PESP 440 C2 H015 000413569
VW Passat Variant2006BMR3C0 614 095 PESP 440 C2 H015 000413626
VW Passat Variant2007BMR3C0 614 095 SESP 440 C2 H015 000430013
VW Passat Sedan2007AXZ3C0 614 095 SESP 440 C2 H015 000446535
VW Passat Sedan2007BWA3C0 614 109ESP 440 C4 H018 000130112
VW Passat Variant2007AXZ3C0 614 109 AESP 440 C4 H018 000113767
VW Passat Sedan2005BMP3C0 614 095 PESP 440 C2 H015 000313602
VW Passat Sedan2007BMR3C0 614 109ESP 440 C4 H018 000113626
VW Passat Sedan2007BKP3C0 614 095 SESP 440 C2 H015 000413602
VW Passat Variant2008BMR3C0 614 109 DJ104 C4 440 V2 0003285
VW Passat Sedan2007BXE3C0 614 095 SESP 440 C2 H015 000413569
VW Passat Variant2006BMP3C0 614 095 QESP 440 C2 H015 000313605
VW Passat Var. BlueM2008BLS3C0 614 109 CJ104 C4 440 V1 0003258
VW Passat Variant2008BMP3C0 614 109 CJ104 C4 440 V1 0003267
VW Passat Variant2008BZB3C0 614 109 CJ104 C4 440 V1 0003309
VW Passat Sedan2007BMR3C0 614 095 PESP 440 C2 H015 000413626
VW Passat Variant2007BXE3C0 614 109ESP 440 C4 H018 000113569
VW Passat Variant2008BWS3C0 614 109 DJ104 C4 440 V2 0003381
VW Passat Sedan2008CBBB3C0 614 109 PJ104 C4 440 V2 0011301
VW Passat CC2009CAWB3C0 614 109 PJ104 C4 440 V2 00112412
VW Passat CC2009BWS3C0 614 109 PJ104 C4 440 V2 0011415
VW Passat CC2009CBAB3C0 614 109 PJ104 C4 440 V2 00112322
VW Passat2006BPY3C0 614 095 QESP 440 C2 H015 000313755
VW Passat Variant2009CBAB3C0 614 109 SJ104 C4 440 V1 0013274
VW Passat Var. BlueM2009CBDC3C0 614 109 MJ104 C4 440 V2 002133272
VW Passat Variant2008BMR3C0 614 109 EJ104 C4 440 V3 00032333
VW Passat Variant2008BMR3C0 614 109 KJ104 C4 440 V2 0005285
VW Passat Variant2006BVY3C0 614 095 PESP 440 C2 H015 000313710
VW Passat Variant2009CBBB3C0 614 109 RJ104 C4 440 V3 001326925
VW Passat Sedan2009CAXA3C0 614 109 SJ104 C4 440 V1 0013307
VW Passat CC2009CAWB3C0 614 109 TJ104 C4 440 V2 00132415
VW Passat Variant2006BMP3C0 614 095 PESP 440 C2 H015 000313602
VW Passat Variant2007BKP3C0 614 109ESP 440 C4 H018 000129998
VW Passat Var. BlueM2010CBDC3C0 614 109 AHJ104 C4 440 V2 002433272
VW Passat2010CBBB3C0 614 109 AEJ104 C4 440 V1 0015293
VW Passat2010CAXA3C0 614 109 AHJ104 C4 440 V2 002433269
VW Passat2007BKP3C0 614 109 AESP 440 C4 H018 000115653
NostraJackAss
Revision: --020--- Serial number: 00000775973613
Coding: 0001282
scanboy83
Morocco
C?ID=197556
thanks
for your coding
i was testing coding From 0000300 until 0000399
and 0000270 until 0000299
NostraJackAss
Revision: --020--- Serial number: 00000776042709
Coding: 0001306
scanboy83
Morocco
C?ID=197556
thanks tomorrow i will try the last codes and i report....
scanboy83
Morocco
C?ID=197556
Thanks for help i test all your code but don't work finally i try many times and i find the coding is :0000261
Tuesday,28,February,2017,11:40:14:13545
VIN: WVWZZZ3CZ8P020401   License Plate: LAST PASSAT 3C ABS
          77
   Coding: 0000072
Readiness: N/A
   Coding: 0000261
   Coding: 00046997
   Shop #: WSC 00028
   Coding: 00208933
   Shop #: WSC 00028
                    Reset counter: 201
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:00
                    Voltage: 14.00 V
                    Reset counter: 238
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:00
                    Voltage: 14.00 V
                    Fault Frequency: 8
                    Reset counter: 238
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:00
                    Voltage: 14.00 V
   Coding: 0012354
   Coding: 0000311
   Coding: 0007105
                    Reset counter: 238
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:17
                    Reset counter: 238
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:18
                    Reset counter: 238
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:18
                    Reset counter: 198
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:22
   Coding: 0043400
                    Reset counter: 198
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:16
   Coding: 0000247
                    Fault Status: 00100101
                    Reset counter: 240
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:18
                    Reset counter: 239
                    Reset counter: 238
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:20
                    Reset counter: 239
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:14:14
                    Reset counter: 239
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:14:14
   Coding: 0000246
                    Reset counter: 201
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:18
   Coding: 0000056
                    Reset counter: 201
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 00:49:20
                    Voltage: 12.30 V
                    Count: 31
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0404
            000 -  -  - MIL ON
                    Reset counter: 0
                    Voltage: 5.00 V
                    Count: 43
                    Hex Value: 0x4040
                    Hex Value: 0x0082
                    Hex Value: 0x1010
   Component: R                   0303
   Coding: 0043400
                    Reset counter: 198
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:16
   Revision: 00011000
   Coding: 0000208
                    Reset counter: 201
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:18
   Coding: 0000208
                    Reset counter: 201
                    Mileage: 132871 km
                    Date: 2017.02.25
                    Time: 02:23:18
   Coding: 0000014
End-------------------------(Elapsed Time: 02:36)--------------------------
