A4/B9 Reverse Mirror Tilt coding
JST1963
Belgium
C?ID=295302
Hey guys,
I'm still searching for the correct coding to make the passengers side mirror tilt when I'm in reverse.
I've seen lots of coding (mod 52...byte 4...bit 2 & 3) but this is the coding for a B8, I assume. However I have a B9 and guess what: that is n't working on a B9.
So, my question is simple: has anyone figured out yet how to do it on a A4/B9?
BTW: I don't have memory seats and I don't have foldable mirrors...
Thx!
JST
I don't have the answer to your question, but it might be helpful if you would post an Auto-Scan so people can see exactly what control modules are installed in your car and how they are configured.
Mrclopec
Nipomo, CA
C?ID=149231
I thought all you had to do was:
1. Mirror selector switch to right mirror.
2. Place foot on brake, shift to reverse.
3. Use mirror adjuster to put mirror into desired tilt position.
4. Shift back into park.
Previously that used to store the desired tilt position within the door control module. Does that process not work anymore for the new B9?
Dukedesmo
C?ID=288946
That's how it is on my B8 A4 (although left not right as it's a RHD model) and also on my Son's Golf and whilst my A4 has both memory seats and auto-folding mirrors, the Golf has neither.
DJAlix
London, United Kingdom
C?ID=238277
This is done via a combination of Long Coding and TXT Coding, so not possible via VCDS. You could try the following in the hope that the needed TXT Coding setting might be set from the factory:
Module 52 - Pass Door
Long Coding
Byte 4
Activate Bit 2
Activate Bit 3
*No Memory seats or folding mirrors needed for this to work on MQB and MLBevo platforms
TBAx
C?ID=287144
Uhh, well, speaking for MQB: when you want to set a specific "dipping location", you have to wire the mirror accordingly (with memory seats this wire is always present). Else it will only dip to a sort of hardcoded location.
JST1963
Belgium
C?ID=295302
Long Coding
Byte 4
Activate Bit 2
Activate Bit 3
I've tried this before but it won't work. When I set these bits in VCDS I can't move the mirror at all. It's locked into the position at that time and won't move again until I put these bits back to "0".
Below you can find the log of my car:
Thursday,09,February,2017,19:48:24:59652
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4334.4
Data version: 20170203 DS267.2
Chassis Type: F4 (4M1)
Scan: 01 02 03 08 09 15 16 17 19 42 44 46 52 5F 81 A5 AC BB BC
VIN: WAUZZZF44GA035931
Address 01: Engine (J623-DETA)       Labels: None
   Part No SW: 04L 906 026 AG    HW: 04L 907 309 L
   Component: R4 2.0l TDI   H33 1969
   Revision: B1H33---
   Coding: 0A254032232605083408
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TDI01104L906026AG 001006
   ROD: EV_ECM20TDI01104L906026AG.rod
   VCID: 6FB8D9CD37139C3FC43-803A
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 8W0 927 155 K    HW: 0CK 927 156 S
   Component: 0CL 20TDIRdWH06 0002
   Revision: --H06---    Serial number: 0000001463
   ASAM Dataset: EV_TCMDL382021 002021
   ROD: EV_TCMDL382021_VW51.rod
   VCID: 47C8516D7F23647FAC3-8012
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  HB1 0572
   Serial number: 75117051150348000842
   Part No SW: 8W0 907 379 E    HW: 8W0 907 379 J
   Component: ESP9 Plus     H06 0593
   Coding: 0CAA489928A50A9B15A74894007E5292E6A59230121450A812004A4967A549
   Shop #: WSC 58530 002 1048576
   ASAM Dataset: EV_ESP9BOSCHAU49X 012014
   ROD: EV_ESP9BOSCHAU49X_012.rod
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 8W0 820 043 L    HW: 8W0 820 043 L
   Component: Klima Zone 1  H40 0055
   Coding: 141800285140000500000100000000000000000000000000000000000000
   Shop #: WSC 06325 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 3C223E8136E537A7311-8068
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000693052
   Subsystem 2 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
   Component: Humidity_Sens  H01 0003
   Serial number: D7280DD7000000000001
   Part No SW: 8W0 907 063 AC    HW: 8W0 907 063 C
   Component: BCM1 MLBevo   H12 0228
   Coding: 80453342451800CD01445118182C00B911031100000000000000000020001A2000410023025601
   ASAM Dataset: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_015.rod
   VCID: 7CA2FE817665F7A7711-8028
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A
   Component: WWS491 151022  043 0813
   Serial number: 894353?0301529500282
   Coding: 5BC7F7
   Serial number: 61063111
   Coding: 03005D
   Subsystem 3 - Part No SW: 4M0 941 531 N    HW: 4M0 941 531 N
   Component: E1 - LDS  H06 0008
   Serial number: 07 10 2015  00124853
   Interior Light Module:
   Subsystem 4 - Part No SW: 8W0 947 135 D    HW: 8W0 947 135
   Component: J528-Dachele  H13 0082
   Serial number: Q00038549
   Subsystem 5 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H15 0010
   Serial number: 2615000121581007
Address 15: Airbags (J234)       Labels: None
   Part No SW: 8W0 959 655     HW: 8W0 959 655
   Component: Airbag10.44   H52 0084
   Serial number: 003M6001243+
   Coding: AECCF0C00C800000585400F3C00C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_AU49.rod
   VCID: 06569C6938A9BD77175-8052
   Subsystem 1 - Part No SW: -----------    HW: 442 062 811 15
   Serial number: 3577Y00B71A828835291
   Subsystem 2 - Part No SW: -----------    HW: 442 062 811 15
   Serial number: 3587Y00A51AF3D1233B5
   Subsystem 3 - Part No SW: -----------    HW: 442 0B0 911 15
   Serial number: 35177009D1C81BB691DW
   Subsystem 4 - Part No SW: -----------    HW: 442 0B0 911 15
   Serial number: 3527700B31E2DF0371DL
   Subsystem 5 - Part No SW: -----------    HW: 442 0C3 011 15
   Serial number: 3557500AF1E0EEC2E372
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C3 011 15
   Serial number: 3567500AF1E0EEC181F2
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 711 15
   Serial number: 2307500C11DEB202A175
   Subsystem 8 - Part No SW: -----------    HW: 442 430 412 15
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00C71AF3CF473B%
   Subsystem 9 - Part No SW: -----------    HW: 442 430 412 15
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00C11A8288260EF
   Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76B6ECA94849ADF7075-8022
Address 17: Instruments (J285)       Labels: None
   Part No SW: 8W5 920 741     HW: 8W5 920 741
   Component: MM--M--DSLRW- H06 0265
   Revision: 0251v1      Serial number:    NASI0C9CR
   Coding: 00A551C0688000080D0369601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736.rod
   VCID: 7BA0FD9D736BF09F78B-802E
   Part No SW: 4M1 907 468 A    HW: 4M1 907 468 A
   Component: Gateway       H13 4079
   Revision: 3B040053    Serial number: 5343B01A815C11
   Coding: 0301000100000F404400000000590012C8100007000000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002.rod
   VCID: 35342BA515CFE6EFCEF-8060
   Subsystem 1 - Part No SW: 8W0 951 523 D    HW: 8W0 951 523 D
   Component: J453 MFL  H02 0002
   Serial number: 20151121015047 RD157
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 4951208603
   Part No SW: 8W0 959 593 G    HW: 8W0 959 593
   Component: TSG FS        005 0052
   Serial number: 0000178624610
   Coding: 001D0B214000000000001080
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   VCID: 4EC664499059B537EF5-801A
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 8W0 909 144 D    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0405
   Coding: 09008080008000
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_EPSZFAU49X 002015
   ROD: EV_EPSZFAU49X.rod
   VCID: 3E26348920F925B71F5-806A
Address 46: Central Conv. (J393)       Labels: None
   Part No SW: 8W0 907 064 AA    HW: 8W0 907 064 A
   Component: BCM2 MLBevo   016 0307
   Coding: 01340000400000A0638180000600000033020000004300502F04000000040030001F0000000000
   ASAM Dataset: EV_BCM2HellaAU736 010010
   ROD: EV_BCM2HellaAU736_010.rod
   Part No SW: 8W0 959 592 A    HW: 8W0 959 592
   Component: TSG BFS       005 0050
   Serial number: 0000178311063
   ROD: EV_DCU2PasseSideMAXHCONT.rod
   Part No SW: 8W0 035 193     HW: 8W0 035 193
   Component: MU-HS-LN-EU   042 0102
   Coding: 01940101FF0A000013110001000A00102F00024401700100CE
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 74B2D6A15E35BFE7391-8020
   Subsystem 1 - Part No SW: 8W0 919 866 C    HW: -----------
   Component: ECE 2016  --- 0009
   Subsystem 2 - Part No SW: 8W0 919 604     HW: 8W0 919 604
   Component: AU49x_DU_STD  H40 0008
   Serial number: AUZ8Z9FBG00C37
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 N    HW: 8W0 919 614 N
   Component: ControlUnit_B  H22 0134
   Serial number: C1000021101500050080
   Part No SW: 8W1 713 041 E    HW: 8W1 713 041 E
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20151123003267
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU49.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 8W0 907 217 A    HW: 8W0 907 217
   Component: BVS           H13 0030
   Coding: 0404090100000401022023A0AD0000FC80F0C010C000
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 3A2E38993CD1099723D-806E
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736.rod
   VCID: 6E86C4C930199537CF5-803A
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 8W0 959 595 A    HW: 8W0 959 595
   Component: TSG HFS       005 0050
   Serial number: 0000178628925
   Coding: 000D09200000000000001080
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 4ACE68596C319917B3D-801E
Address BC: Door Rear Pass (J389)       Labels: None
   Component: TSG HBFS      005 0050
   Serial number: 0000178628924
   ROD: EV_DCU2RearPasseMAXHCONT.rod
End----------(Elapsed Time: 01:21, VBatt start/end: 12.1V/12.2V)-----------
DJAlix
C?ID=238277
I have had passenger mirror dip on my pre facelift A3 8V, also have it on my Facelift A3 8V with no memory seats. In fact memory seats are not a factory option on the A3 8V's.
Have activated this on many 8V's without power adjustable folding mirrors without issue however for a small number, 3 or 4, the mirror would never return to its exact normal driving position.
DJAlix
C?ID=238277
   Revision: B1H33---
   Coding: 5BC7F7
   Coding: 03005D
That would be because there is another parameter which needs activating in addition to the long coding, which unfortunately VCDS is unable to access.
JST1963
Belgium
C?ID=295302
Can you access it with ODB11?
DJAlix
C?ID=238277
Have fixed a load of cars destroyed by that application but never coded with it, so have no idea to be honest. If it is possible I would imagine its only via their credit "apps".
hadez16
C?ID=289891
It is not true that it is a mixture of TXT coding and long code. The according TXT coding which can be found in the interweb is just an equivalent to Bit 2 in Byte 4 of unit 52.
In the meantime we should all know that TXT coding of a specific other piece of software is just the experimental labeling without Byte/Bit combination addressed.
Besides, this issue is still not solved. There are a few things in the BCM2 (unit 46) regarding dipping mirrors:
Byte 9 Bit 6 active (dipping_mirrors installed)
Byte 34 Bit 4 active (bap mirror lowering at reverse gear default value = active)
Anyone would like to try if this triggers the MMI menue entry?
By the way, perhaps someone with mirror dipping from factory could post an Auto-Scan??
Fatal EDIT: If really every B9 in the US has this option by factory, then my suggestions will propably not work as these bits are also not set in US cars....
hadez16
C?ID=289891
I really did some deep investigations as I have detailed information from two B9 where one has the dipping mirrors and the other does not. (confirmed by the persons who own them)
I cannot find any bit or channel that differs and points to this function, besides the obvious bits in Unit 52.
Can this still be a hidden adaptation channel because of some ASAM yingyang?
rlarsen
Copenhagen, Denmark
C?ID=78998
Has this been tried (German site): http://vagdata.de/8w-a4/beifahrerspiegelabsenkung-bei-rueckwaertsfahrt-8w/ ??
[52 - Door Elect, Pass.]
[Coding - 07] -> [Long Coding Helper] -> Byte 4
Bit 2 - activate
Bit 3 - activate
[09 – Cent. Elect.]
[Security Access - 16] - Code: 31347
[Adaptation - 10]
(17) Zugangskontrolle 2-Spiegelabsenkung bei Rueckwaertsfahrt  - activate
rod_vw
C?ID=30904
Any progress on this? Son has an A4 B9 (UK 2018 model) looking to activate mirror tilt.
Rod
hadez16
C?ID=289891
Bit 2 - activate
Bit 3 - activate
[09 – Cent. Elect.]
[Adaptation - 10]
This adaptation channel does not exist! It is copied from B8 platform!
Yet no progress. My hope is that this is caused by missing adaptation channels that might occur on later VCDS Versions.
Again, I compared two B9, one with tilt and one without, and found no clue.
hadez16
C?ID=289891
In a german forum there are people who just changed the door units or even just the driver door unit (I'm not sure) in order to get this to work.
Of course from a car who has it by stock.
This would confirm that this feature only resides in software of the door units.
jpaudioa4
Greece
C?ID=265430
Good morning. Update: my car has folding mirrors and I tried to recode in order to have this feature based on info I found in several Audi enthousiast sites. BUT, I realized that this feature can only work if the mirror selecton in driver's door is in passenger's mirror possition! If it is in center one, "0", nothing happens. I don't know if this feature was embeded already in my car and I don't remember if I let the new coding or reverted back either, sorry. I will check next week and come back. I just report this finding for all to check. Also there is an official video at youtube that describe how this can be set. Worth to try.
Note: my car is a European one.
Regards,
John
South Molton, UK
I realized that this feature can only work if the mirror selection in driver's door is in passenger's mirror position!
This is one of what I think are two silly "features" regarding the mirrors on my MQB platform Skoda Octavia 5E -
1) as you have found, the mirror dip only works if the mirror switch is in the passenger position. AND if you don't have memory seats the mirror will NOT return to the same position so all need adjusting every time you use it - how crazy is that!
2) the mirror heating is a separate latching position on the switch (which appears NOT to have a timer so can be left on) instead if being combined with the heated rear window (like on my B7 Audi, which had a timer so cannot be left on). At the very least this should be timer controlled and not a latching position on the switch IMHO.
