A4 8W Right Headlight problems
tomyn18
Hrenova, Slovenia
C?ID=291351
Hi All!!
I'm new on the forum. I have HEX-NET for few months now and I am facing some problems, which I do not know how to solve. I have replaced LCM (light control module) on friend's A4 8W and now I cannot get it working. The number of the old one was the same like number of the new module (4M0907397AC). I can normally connect to address 39 - Right Light, but I cannot do/change anything and only low (dipped) beam is working.
There is also one error present:
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0022
ASAM Dataset: EV_LCMRightHELLAAU736 001011
ROD: EV_LCMLeftHELLAAU736.rod
VCID: 78BC25A5C3D6B981E3-802C
0019 - Headlamp Type
C119F 00 [009] - Implausible
Reset counter: 184
Mileage: 23972 km
Date: 2017.02.26
Time: 18:40:11
Here is AUTO-SCAN:
Sunday,26,February,2017,18:44:35:01522
VCDS Version: 17.1.1.2 (x64)  HEX-NET CB: 0.4334.4
Data version: 20170107 DS267.0
Workshop Code: 123 07149 007149
VIN: WAUZZZF43GA074834   License Plate:
Chassis Type: F4 (4M1)
Scan: 01 02 03 08 09 15 16 17 19 29 39 3C 42 44 46 52 5F 6C 6D 81
          A5 AC BB BC CA CF D6 D7
39-Right Light -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DETA)       Labels: None
   Part No SW: 04L 906 026 AD    HW: 04L 907 309 L
   Component: R4 2.0l TDI   H33 1970
   Revision: B1H33---
   Coding: 0A254032232405083428
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TDI01104L906026AD 001006
   ROD: EV_ECM20TDI011_AU49.rod
   VCID: 6C9409F5878E052117-8038
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 8W0 927 155 G    HW: 0CK 927 156 S
   Component: 0CK 20TDI RdW H06 0006
   Revision: --H06---    Serial number: 0000001024
   ASAM Dataset: EV_TCMDL382021 002021
   ROD: EV_TCMDL382021_VW51.rod
   VCID: 43C68249CA902A5986-8016
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071160054001640
   Part No SW: 8W0 907 379 J    HW: 8W0 907 379 J
   Component: ESP9 Plus     H06 0579
   Coding: 0CAA489910A90A9A15A648940081529266A59A30120850A812004A4966A559
   Shop #: WSC 06334 790 00001
   ASAM Dataset: EV_ESP9BOSCHAU49X 011009
   ROD: EV_ESP9BOSCHAU49X_011.rod
   VCID: 4CD4A975E7CEE52177-8018
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
   Component: Klima Zone 3  H32 0052
   Coding: 241808285544400D02000100800000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 373EE6998E4876F92A-8062
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000772896
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: 3D284618000000000001
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: Klima Heck  H34 0050
   Part No SW: 8W0 907 063 AG    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0228
   Coding: 07501143E17900CD01458714582E00B911033100000000000000000020001A810A450122025705
   ASAM Dataset: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_015.rod
   VCID: 004C4D459B06F141DB-8054
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A
   Component: WWS491 160212  043 0813
   Serial number: 894353?0401604304555
   Coding: 5BC7F7
   Serial number: 61447298
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 21 12 2015  00188532
   Serial number: GX1CE123121511520664
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 AT    HW: 8W0 947 135
   Component: J528-Dachele  H13 0082
   Serial number: B00083298
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H15 0010
   Serial number: 2615000143737001
66679 - Databus
                    Reset counter: 184
                    Mileage: 23972 km
                    Date: 2017.02.26
                    Time: 18:40:13
                    average_Voltage_terminals: 14.30 V
                    Outside air temperature sensor-Resistance: 0.00 KOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 11.50 °C
                    interior_temperature: 13.50 °C
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: On
                    Terminal control-Terminal 15 status signal: On
                    Terminal control-Terminal 15 via CAN: On
                    Terminal control-Term 75: qualification: OFF
66964 - Databus
                    Reset counter: 184
                    Mileage: 23972 km
                    Date: 2017.02.26
                    Time: 18:40:13
                    average_Voltage_terminals: 14.20 V
Address 15: Airbags (J234)       Labels: None
   Part No SW: 8W0 959 655     HW: 8W0 959 655
   Component: Airbag10.44   H52 0084
   Serial number: 003M60028FBO
   Coding: AECCF0C00C800000585400F3C00C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_AU49.rod
   VCID: 06405B5DB922DF71E1-8052
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 8W0857705A0063Q01597
   Coding: 88001B
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 8W0857706A0065Q01244
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 063 001 16
   Serial number: 3577Y00A91DE13E27135
   Subsystem 4 - Part No SW: -----------    HW: 442 060 302 16
   Serial number: 3587Y00A91DE13E23121
   Subsystem 5 - Part No SW: -----------    HW: 442 0B1 002 16
   Serial number: 3517700A51FA3415C26B
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 502 16
   Serial number: 3527700C91FB2C61941L
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 902 16
   Serial number: 3567500C31EA9BB292D.
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 902 16
   Serial number: 2307500A31EA9BB6229J
   Subsystem 10 - Part No SW: -----------    HW: 442 432 211 15
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00A31A82884C30B
   Subsystem 11 - Part No SW: -----------    HW: 442 432 211 15
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00A51A828827026
   Part No SW: 4M0 907 129 HD    HW: 4M0 907 129 HD
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 79BA20A1F8DCA0899C-802C
Address 17: Instruments (J285)       Labels: None
   Part No SW: 8W5 920 790 B    HW: 8W5 920 790 B
   Component: FBenRDW       H12 0275
   Coding: 04A468C0288800080020E9601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   ROD: EV_DashBoardAU736.rod
   VCID: 41CA8841D08C384994-8014
   Part No SW: 4M1 907 468 A    HW: 4M1 907 468 A
   Component: Gateway       H13 1079
   Revision: 3B060055    Serial number: 5543B031F16222
   Coding: 0301000100000F4044000000005900124C100007000000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002.rod
   VCID: 3522EC91944484E938-8060
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20160223150621 01570
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 8803469403
   Component: LCM_MLBevoH05 0023
                    Reset counter: 184
                    Mileage: 23972 km
                    Date: 2017.02.26
                    Time: 18:40:11
Address 3C: Lane Change (J769)       Labels: None
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   VCID: 3424D1959F3E9DE10F-8060
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000189524207
   Coding: 001F9B2150000080000010B0
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   VCID: 42C8874DD58A23518D-8016
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0407
   Coding: 09000080008000
   ASAM Dataset: EV_EPSZFAU49X 002015
   ROD: EV_EPSZFAU49X.rod
   VCID: 40CC8D45DB8631419B-8014
Address 46: Central Conv. (J393)       Labels: None
   Part No SW: 8W0 907 064 AC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   016 0307
   Coding: 01340000000000E0630980006E00080031024000004B02502F0400000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 010010
   ROD: EV_BCM2HellaAU736_010.rod
   VCID: 7DB234B1ECF49CA9B0-8028
   Subsystem 1 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94076279
   Part No SW: 4M0 959 792 G    HW: 4M0 959 792 C
   Component: TSG BFS       009 0052
   Serial number: 0000189771541
   Coding: 001F9B215C000080000010B0
   ROD: EV_DCU2PasseSideMAXHCONT.rod
   Part No SW: 8W0 035 036 D    HW: 8W0 035 036 A
   Component: MU-P-LN-EU    051 0442
   Serial number: A667C0GB013535
   Coding: 01940201FF0A000013110001000A00332F0022E501700100DE
   Subsystem 1 - Part No SW: V03 959 801 FA    HW: -----------
   Component: ECE 2016  --- 0134
   Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
   Component: DU High AU49x  H31 0160
   Serial number: TPO00128011600820060
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 P    HW: 8W0 919 614 P
   Component: ControlUnit_H  H22 0139
   Serial number: APVAK116011600030018
   Compact Disc Database:
   Component: Gracenote2  --- 1011
Address 6C: Back-up Cam. (J772)       Labels: None
   Part No SW: 4M0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H10 0130
   Coding: 0294020102002001000040
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
   ROD: EV_CamSysRVRVCPANAMLBEv_AU49.rod
   VCID: 72A8178DA5AAD3D1DD-8026
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 4M0 959 107     HW: 4M0 959 107
   Component: HDSG-Modul    H12 0143
   Revision: --------    Serial number: 30557117300000
   Coding: 0570
   ASAM Dataset: EV_DeckLidCONTIAU736 001010
   VCID: 70AC1D85ABA6E1C12B-8024
   Part No SW: 8W1 713 041 E    HW: 8W1 713 041 E
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20160303001611
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU49.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 8W0 907 217 A    HW: 8W0 907 217
   Component: BVS           H14 0030
   Coding: 0404090200000403022023A2A50000FC00F0C020C020
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 3A38FFADBD5A6B91D5-806E
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736.rod
   VCID: 6E9003FDB192F73139-803A
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 4M0 959 795 G    HW: 4M0 959 795 C
   Component: TSG HFS       009 0052
   Serial number: 0000189798554
   Coding: 000F992000000080000010A0
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 44C48155CF9E2D61BF-8010
Address BC: Door Rear Pass (J389)       Labels: None
   Component: TSG HBFS      009 0052
   Serial number: 0000189794868
   ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof (J245)       Labels: None
   Part No SW: 4M0 907 594     HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 608000049202
   ROD: EV_SunRoofCONTIAU736_VW37.rod
   VCID: 73A61289DAB0DAD9D6-8026
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 B    HW: 4M0 907 590
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
   VCID: 312AD881602CA8C964-8064
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   ROD: EV_LEDModLeftMELCOAU736_AU49.rod
   VCID: 16600B1DE9826FF111-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 01:47, VBatt start/end: 14.5V/14.5V)-----------
If someone know how to clear 09 - Cent. Elect. errors, I would also be happy to hear it. :)
Thank you!
Kind regards,
tomyn18
Your new right light module has different (older) software in it than the left. I wonder if that is the source of some of the unhappiness between it and the 09 module?
tomyn18
Hrenova, Slovenia
C?ID=291351
Hi @Uwe, thank you for the answer!
So, you thing that it is worth to upgrade software on right light module? I don't have VAS-PC, but maybe I can find someone in Slovenia or I can ask Audi dealer to upgrade it.
Kind regards,
tomyn18
tomyn18
Hrenova, Slovenia
C?ID=291351
So, after upgrading module firmware, right light is working without any problems.
Thank you for your help!
Kind regards,
tomyn18
milkatrek
Poland
C?ID=147536
how you upgrade this module?
what tool you use.
thx
