I have a 2006 Audi A8L 4.2, I discovered that my steering rack was leaking fluid about a week ago. Ordered a used rack from Wolf Auto. It arrived and my mechanic installed it on Thursday. Yesterday, they sent the car in for a four wheel alignment... and apparently they got that done... but it take quite a long time? But when I got the car back, the ESP was not working very well, as it engaging even while I drove the car straight ahead and very slowly? The ESP light flashed on and off applying brakes and reducing power from various wheels as if I was in a corner and sliding. Until eventually the ESP would fault out (only takes about 100-200 feet of driving straight ahead at 5kph) the center info panel on the cluster displayed "ESP Fault Found" and ESP disengaged completely (ESP light stayed on solid)... then the car drove normally.
This morning, I went over to the mechanics shop, spoke to the owner. I showed him the VCDS output and he thinks that it might be something that was not reconnected in the ABS system? He is not sure, but is going to have his top tech take a look on Monday.
I did my own google searching, specifically around the 18061 DTS code, and it appears that this code can pop up when the vehicles battery is disconnected or run down low. I know for sure that this happened, as I had alot of "low voltage" type codes when I first checked in VCDS... after a quick battery charge, and an All DTC Clear, all of those type of codes did not come back... But the Steering Angle Sensor fault in Module 03 ABS Brakes, always does come back. I have also, read that it might take a few code resets to get his one to clear? I have cleared the Module 03 fault about 3-4 times, and it always comes back... and the car drives the same as I described in the 1st paragraph.
It appears that the Steering Angle Sensor might be ok.... see VCDS Log output... the top line in the summary below for Module 00. Here is a clip of the important bits from the log file.
The symptoms from driving the car this morning are as follows: starts up nicely, no fault lights on the dash, however, when I pull away from a parked position, the ESP indicator light flashes on and off and the ESP system is engaging by applying brakes and removing power from various wheels as if I'm in a corner and sliding... but I am driving straight ahead going very slowly. It will do this for about 100-200 feet then the ESP will fault out (displaying ESP Fault Found on the center display), the ESP warning light will stay on... and the car will drive normally (pretty well the same as last night).
Any thoughts on what this could be? I'm wondering if the Steering Angle Sensor needs to be reset or aligned... I noticed in Module 03, under "Basic Settings" that there is a Steering Angle Sensor alignment entry... but since I didn't know exactly what it did, I didn't want to experiment with it.
Saturday,25,February,2017,08:10:53:08168
VCDS Version: 17.1.3.0 HEX-V2 CB: 0.4334.4
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E8774746
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E0604104C16BBF78F5-807A
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Mileage: 204669 km
RPM: 133 /min
Load: 72.1 %
Temperature: 101.0°C
Temperature: 54.0°C
Absolute Pres.: 0.0 mbar
Voltage: 10.795 V
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Mileage: 204669 km
RPM: 2179 /min
Load: 53.3 %
Speed: 17.0 km/h
Temperature: 21.0°C
Temperature: 13.0°C
Voltage: 14.097 V
Readiness: 0010 1101
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
Shop #: WSC 60462 000 00000
VCID: 221EE02008CE0F971BD-8076
