Hello all , i'm trying to help my cousin with her jetta I believe this all to be from a bad ground or major wiring harness fault as all fuses are good and no sign of coolant mitigation.
there is a brake switch fault that dings while driving , yes e-brake is off pulled the harness of the e-bake switch and no change , don't know if the switch is normally open or closed haven't tried putting a jumper in the harness .
using measuring blocks it shows that the switch is working when pressing the brake pedal.
brake light and air bag light on both illuminated on the dash.
anything else to check before its up for sale ?
Wednesday,22,February,2017,19:14:15:10983
VCDS Version: 17.1.1.2
Data version: 20170107 DS267.0
VIN: 3VWSE69M33M024410 License Plate: NYA
Mileage: 385160km-239327mi Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWSE69M33M024410 Mileage: 385160km-239327miles
Address 01: Engine Labels: 06A-906-032-AWP.lbl
Part No: 06A 906 032 LP
Component: 1.8L R4/5VT G 0005
Coding: 07500
Shop #: WSC 00066
VCID: 77FD52BB55E7A3F9EA-5122
3VWSE69M33M024410 VWZ7Z0B5306709
16955 - Brake Switch (F)
P0571 - 35-00 - Implausible Signal
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0018945
Shop #: WSC 00066 000 00000
VCID: 326BA3AFAE0586D11D-5122
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0001
Coding: 12340
Shop #: WSC 00066
VCID: 275D42FBC5C7F379BA-5106
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 J
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 05232
Shop #: WSC 08070
VCID: 2F6DAADBED37AB3972-5106
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00066
VCID: 70EF69A73089F4C12B-5106
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 377D92BB156763F92A-4AEA
Component: 1H Tõrsteuer.FS KLO 0004
Component: 1H Tõrsteuer.BF KLO 0004
Component: 1H Tõrsteuer.HL KLO 0004
Component: 1H Tõrsteuer.HR KLO 0004
27-00 - Implausible Signal
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180
Component: RADIO 3CP 0001
Coding: 00031
Shop #: WSC 00066
VCID: 5DB12013D71B69A990-5106
00856 - Radio Antenna
36-00 - Open Circuit
00849 - S-contact at Ignition/Starter Switch (D)
78-10 - Missing Messages - Intermittent
01064 - Terminal 58d; Interior Dimming
00625 - Vehicle Speed Signal
End-------------------------(Elapsed Time: 05:49)--------------------------
