Probably been asked/discussed before but my S4 Avant has stop/start which can be switched off but needs to be done every time the engine is started otherwise it reverts to being on and I'm really not keen on it cutting out when I don't want it to.
I would prefer that I could switch it off and it stay off, or leave it on and it stay on i.e. 'remember' the last state but I understand that is probably not possible? If that is the case then I would rather it be permanently off than default to on, if possible.
There was mention in another thread about a different model that it can be permanently disabled with some adaptation? can anyone tell me how?
Here's a scan in case it helps;
Thanks in advance.
Tuesday,15,November,2016,12:38:47:24986
VCDS Version: 16.8.3.1
VIN: WAUZZZ8K7EA150192 License Plate:
Mileage: 27250km-16932mi Repair Order:
Chassis Type: 8K (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 30 36 42 44 46 47 52 53 56 5F
62 6D 72 A9
VIN: WAUZZZ8K7EA150192 Mileage: 27250km-16932miles
Address 01: Engine (J623-CGWC) Labels: 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 D HW: 4H0 907 551
Component: 3.0l V6 TFSIH07 0004
Revision: --H07---
Coding: 12250034052701020800
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218K5907551D 001004
ROD: EV_ECM30TFS0218K5907551D.rod
VCID: 377CA0AB8E2C1EFA4D-8062
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8K5 927 156 B HW: 0B5 927 156 K
Component: 0B5 30TFSIRdW H03 0003
Revision: --H03---
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021_VW51.rod
VCID: 387EA3978332118244-806C
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
Component: ESP8 quattro H09 0020
Coding: 291DCC01
Shop #: WSC 06335 000 00000
VCID: 09181653A058D80AEB-805C
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 JG HW: 8K0 907 064 JG
Component: BCM2 2.0 H14 0650
Coding: 01B24040000000000000
VCID: 7EF2758FE996EFB2CE-802A
Subsystem 1 - Part No SW: 8K0 959 754 BH HW: 8K0 959 754 BH
Serial number: 0514000046829005
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 0214000068278002
Part No SW: 8K2 820 043 AQ HW: 8K2 820 043 AQ
Revision: D1000000 Serial number: 01100420140302
Coding: 6624028000
VCID: 78FE6397CBB2D18284-802C
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000789946701
Coding: 260000108034AFC00081404300001D0D0F1D470A27090201000008004400030100000024000000
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 010414 H06 0080
Serial number: SWF14044015610
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 22487512
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000000104144832
Serial number: FA780227000000000001
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H48 0610
Serial number: 003KFDC0WUTP
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 60782 001 1048576
VCID: 489ED357F3D2610234-801C
Serial number: 6334MSME443A333AD
Serial number: 6344MSME443C6E75T
Serial number: 6352QSME1E400648E
Serial number: 6362QSME1A401B6EP
Serial number: 63732SME40404A66X
Serial number: 63832SME4F400F689
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NDE001IC
Coding: 000037
VCID: 489ED357FBD2610234-801C
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 982 T HW: 8K0 920 982 T
Component: KOMBIINSTR. H35 0564
Revision: 00100000 Serial number: ZAE62M34F
Coding: 33A7110003012600010000
VCID: 4580DA63CCC07C6ACF-8010
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0060
Revision: 1Y080030 Serial number: 3041Y143310158
Coding: 80CF07FF00
VCID: 4A9AE95FE5DE931222-801E
Serial number: 9802233103
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Serial number: 14099003849011200410
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 B HW: 8K0 907 440
Component: STS H04 0020
Revision: S0H04000 Serial number: 00000000084090
Coding: 01010101000000000001000102
VCID: 2D5082C37470A42A27-8078
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0077
Revision: AA000000 Serial number: 00000097259421
Coding: 01781300000000000000
VCID: 3B74BC9BBA043A9AA9-806E
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000098884238
Coding: 011C02205E21410001
VCID: 4FACF84B1EBCB63A75-801A
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8K0 909 144 G HW: 8K0 909 144 B
Component: RCEPS H40 0508
Revision: 00001000 Serial number: 0003457337
Coding: 100000000001
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008015
ROD: EV_RCEPSAU48X_008.rod
VCID: 3560AAA39420ECEA5F-8060
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0332027708
Coding: 013B0622A0B938948330023680000047
Subsystem 3 - Part No SW: 8K0 959 591 C HW: 8K0 959 591
Component: J245 PS151 H08 0043
Subsystem 4 - Part No SW: 8K0 959 591 C HW: 8K0 959 591
Component: J394 PS240 H08 0043
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813028507104
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000098720192
VCID: 4E92E54F19B6BF327E-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H01 0005
Revision: -------- Serial number: 20000000431915
ROD: EV_ParkiBrake_VW51.rod
VCID: 3A7AB99FBD3E0392B2-806E
Part No SW: 4G0 035 061 N HW: 4G0 035 061
Component: Radio U DAB H60 0139
Revision: AB001007 Serial number: 109D20E7915856
Coding: 010103010000000001
VCID: 285E73D75B928102D4-807C
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 666 E HW: 8R2 035 666 C
Component: H-BN-EU H47 0793
Revision: -------- Serial number: 206DZ0E7560780
Coding: 110101010206A1ED41808B5E00000403E40100020000000000
Subsystem 1 - Part No: 8R0 060 884 BK
Component: EUR 2014 1703
Component: DU7 High H42 0104
Serial number: A130DI0E3000809
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Serial number: 00000001824649
Component: CD-Database 5571
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000098922402
Coding: 010C02204021210001
VCID: 4682DD6FF1C67772C6-8012
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8K9 827 851 C HW: 8K9 827 851 C
Component: J605 Master H53 0330
Revision: -------- Serial number: 8K9827851C
VCID: 3E72B58FA9162FB28E-806A
Subsystem 1 - Part No SW: 8K9 827 852 C HW: 8K9 827 852 C
Component: J756 Slave H53 0330
Serial number: 8K9827852C
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000098919842
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 140301200807
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X_002.rod
VCID: 72EA51BFA5CEBBD2BA-8026
End-------------------------(Elapsed Time: 04:42)--------------------------
Thanks in advance.
