MY 2011 Skoda Octavia 1,6l CR TDI CAYC faults
MartinsX
Riga, Latvia
C?ID=268515
This Skoda has intermittent starting problems.
The only fault stored is for terminal 30 power supply. Constant battery power is supplied to ECU pin 92, (tested with load), but fault code comes back immediately after clearing it and measurement at channel IDE00019 shows 0V.
Second thing I have found is, that glow plugs are not switched on when needed. Power (30 and 15) is supplied to glow module, ground is ok, control wires from glow module to ECU has continuity. Glow plugs are ok, too. Strange thing is, that ECU does not show faults for disconnected glow plugs, nor for disconnected glow module. Output test can be activated, but nothing happens and no glow plug related faults stored.
Probably something is wrong with ECU itself.
Has anyone experienced something similar and how this was repaired?
Wednesday,22,February,2017,17:32:37:32442
VCDS Version: 17.1.3.0
VIN: TMBGT61Z7B2127504   License Plate:
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: TMBGT61Z7B2127504   Mileage: 282040km-175251miles
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LP    HW: 03L 906 023 JH
   Component: 1,6l R4 CR td H43 9645
   Revision: --H43---    Serial number:
   Coding: 00114016032400080000
   Shop #: WSC 00004 686 122714
   ASAM Dataset: EV_ECM16TDI02103L906023LP 003007
   ROD: EV_ECM16TDI02103L997557.rod
   VCID: 7F0D69C3E683C6B990-802A
6551 - System Voltage
          P0562 00 [039] - Too Low
                    Mileage: 282043 km
                    Date: 2017.02.22
                    Time: 00:03:12
                    Engine speed: 0.00 /min
                    Coolant temperature: 34 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 0.000 V
                    Sensor for engine block temperature: raw value-Coolant temperature: 33 °C
                    Engine torque-TQI_SP: 54.88 Nm
                    Accelerator position: normalized-Accelerator position: 0.00 %
                    selected gear-DRI: 0
Readiness: 0100 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0105
   Revision: 00H35001
   Coding: 0017665
   Shop #: WSC 73430 790 00088
   VCID: 7BF59DD33A9BDA99BC-802E
   Part No SW: 3T0 907 044 BE    HW: 3T0 907 044 BE
   Component: Climatronic   H16 0402
   Revision: 00006001
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 76E38CE7C9B987F1C3-8022
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 46000AB8A05BF1C040080080110001E4430000AE524D85605C8540000040
   Shop #: WSC 00001 686 70659
   VCID: 387F42DF8B2D318111-806C
   Subsystem 2 - Part No: 5J0 951 172
   Component: DWA-Sensor 03   03 1109
   Subsystem 3 - Part No: 1K8 951 605 B
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 242
                    Mileage: 282042 km
                    Date: 2011.07.16
                    Time: 21:44:58
                    Voltage: 12.15 V
                        Term 50 Off
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 242
                    Mileage: 282042 km
                    Date: 2011.07.16
                    Time: 21:44:58
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC242PA5
   Coding: 0020790
   VCID: 3D7153CB640F14A9C2-8068
   Subsystem 1 - Serial number: 6332MSME5C1214376
   Subsystem 2 - Serial number: 6342MSME5D106F32H
   Subsystem 3 - Serial number: 6351HSME265644442
   Subsystem 4 - Serial number: 6361HSME2656486EJ
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20110301100629
   Coding: 108A140000
   ROD: EV_SMLSNGVOLWSXS.rod
   VCID: 79F987DBF8A7E889AE-802C
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
   Part No SW: 1Z0 920 843 M    HW: 1Z0 920 843 M
   Coding: 110A00
   Shop #: WSC 73430 031 00088
   VCID: 428B2037D5F16B51BF-8016
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 270211F1000904
   Coding: 352302
   VCID: 306F7AFF635DE9C159-8064
   Component: IMMO          H20 0420
   VCID: 6ADBA8978D01531157-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.clb
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2119
   Coding: 0000246
   VCID: 76E38CE701B987F1C3-8022
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 346776EF5745D5E13D-8060
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.5 V
                        PD
                    Temperature: 14.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.clb
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0000246
   VCID: 489F321F3BCD410161-801C
   Part No SW: 1Z0 035 161 N    HW: 1Z0 035 161 N
   Component: Radio-SWING   012 0036
   Revision: -----16S    Serial number: SKZ4Z2L1157833
   Coding: 050004000001
   VCID: 397947DBB0272889EE-806C
00856 - Radio Antenna
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 242
                    Mileage: 282042 km
                    Date: 2011.07.16
                    Time: 19:03:41
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012568
   VCID: 326B70F7AD51DBD12F-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 336575F3524BD2D924-8066
   Part No SW: 5K0 035 730     HW: 5K0 035 730
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669447755
   Coding: 0B00000000010110
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 62CBC0B775310B519F-8036
End-------------------------(Elapsed Time: 02:46)--------------------------
Hmm, I found the VW RoW TPI # 2022687/3 but that was talking about a voltage drop on the wire to pin 92 and you already load tested it. I'll keep searching and report back if I fond something else.. but if the powers and grounds are OK it sounds like the controller might be flaky as you suspected.
MartinsX
Riga, Latvia
C?ID=268515
Thanks, Dana!
This case ends with diagnosing so far - customer is not ready to invest in new ECU. He will drive his car "as it is" until it stops completely...
BTW do anyone knows do any tested and reliable way is found how to clone these Siemens/Continental ECU's? Or how to adapt used ones to car? Or at last immo off?
Gone But Not Forgotten
Component: 1,6l R4 CR td H43 9645 <<<<<<<<<< Beware of FOD and do your updates!
My Favorite Martian Martin needs JPPSG!
Stop Stack Abuse for FOD!
MartinsX
Riga, Latvia
C?ID=268515
Can't catch idea what exactly You wanted to say, Jack?
Do You think SW update will solve problem that ECU doesn't measure power supply voltage and is not controlling glow plug module at all?
Theoretically it is possible, if some part of SW code is damaged by some reason and reflashing even with the same version could solve problem. But if there is some HW problem in MCU or on PCB then reflashing may result with completely dead ECU... As customer is not ready to invest in new ECU, I don't want to try it on my own responsibility.
MartinsX
Riga, Latvia
C?ID=268515
Why are You posting those stupid videos and pictures, Jack?
If You have any information according that exact type of ECU, please share it. If You have not or You want to keep it in secret, maybe better say (post) nothing...
Yes I think a firmware update would possibly be a help and is the first thing you do as per the repair manual.
For someone as smart as you, you should know that checking, verifying firmware or TSB's is a given.
Don't get pissy at my poor sense of humor but just handle the process.
It's like me coming up to you while you are blowing bubbles with chewing gum and me asking is that chewing gum you are chewing.
Check all fuses but I hope you did already and ground points.
I apologize if I insulted you......but I can be an asshole and will go stand in corner until milk time.
Oh a ecu supply or terminal relay can hide this or ignition switch and in rare cases a BCM.
MartinsX
Riga, Latvia
C?ID=268515
Your apologize received, everything ok, Jack! :)
This exact case is closed, as customer has no money for any further tests with ECU. And I do not want to kill ECU on my own risk and expense.
Theoretical question for future cases left open: how to clone another used ECU or how to adapt to car another used ECU of this type?
03L 906 023 LP
CR
Easy ....swap eeprom data and flash MAC derivative if supported for CP with calculation or Immo defeat or do a GeKo transfer session
