Hi, could not get a steering angle calibration. Entering login 40168, OK, then go for calibration, start do it (write RUN) and after the second goes out with a fault (Aborted, safety reason). The car came to me with corrupted long coding, was all zeros, have coded by the sample of similar ABS unit, changed VIN bytes, coding was successfully changed, but not sure is it right, because don't have any info about ESP9.0i long coding. Any advice? Thank's
Log file attached
Log file attached
Wednesday,22,February,2017,12:49:44:38319
VCDS Version: 17.1.3.0
VIN: WAUZZZ8X4EB123201 License Plate:
Chassis Type: 8X (8U0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 62 72
VIN: WAUZZZ8X4EB123201 Mileage: 17980km-11172miles
Address 01: Engine (J623-CBZA) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GN HW: 03F 907 309 AC
Component: SIMOS10.24AH10 5468
Revision: --H10--- Serial number:
Coding: 001100B6230401080000
Shop #: WSC 00046 412 00000
ASAM Dataset: EV_ECM12TFS02103F906070GN 004007
ROD: EV_ECM12TFS02103F906070FS.rod
VCID: 74EC2750DF2E80E1FD-8020
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 BR HW: 6R0 907 379 BA
Component: ESP9.0i front H03 0003
Serial number: --------------
Coding: 33DF488B432502C3CC161269C25240961109
Shop #: WSC 00046 412 12345
ASAM Dataset: EV_Brake1ESP90iBOSCH 003031
ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
VCID: 0F2648BCD6C8C33960-805A
0993 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 36
Mileage: 17983 km
Date: 2017.02.21
Time: 19:52:19
Address 08: Auto HVAC Labels: None
Part No SW: 8X0 820 045 A HW: 8X0 820 045 A
Component: J255 Klima Manuell 0150
Revision: 0000708S Serial number: 00303003377371
Shop #: WSC 00046 000 00000
VCID: 346CE75057AEC0E13D-8060
Address 09: Cent. Elect. (J519) Labels: 8X0-907-063.clb
Part No SW: 8X0 907 063 R HW: 8X0 907 063 R
Component: BCM PQ35 M 113 0811
Revision: AD113811
Coding: 0E000A2CA805F1C0201841E000040154438B6C0A00CF4922DC0087830041
Shop #: WSC 09550 758 180955
VCID: 4B9E9CACEA50BF194C-801E
Subsystem 1 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
Address 10: Park/Steer Assist (J446) Labels: 8X0-919-475.clb
Part No SW: 8X0 919 475 Q HW: 8X0 919 475
Component: PARKHILFE 4K H03 0070
Revision: 11001001 Serial number: 37031413901416
ASAM Dataset: EV_EPHVA14AU21X0000 003006
ROD: EV_EPHVA14AU21X0000.rod
VCID: 54AC87D03F6EE0E11D-8000
Address 15: Airbags (J234) Labels: 8X0-959-655.clb
Part No SW: 8X0 959 655 B HW: 8X0 959 655 B
Component: Airbag10.41 H06 0009
Revision: -------- Serial number: 003KZ008Z2DU
Coding: 30323236303230303232554A305238583053
ASAM Dataset: EV_Airba1041BPAAU210 001018
ROD: EV_Airba1041BPAAU210.rod
VCID: 4992A6A4E82CAD097E-801C
Serial number: 3554VRB40651NOT2FPGL
Serial number: 3575HRB400E4UOB898L-
Serial number: 3585HRB405F2BJ1KEOT5
Rear Impact Crash Sensor:
Serial number: 3515ZRB400M50VKOI0FB
Address 16: Steering wheel (J527) Labels: 8X0-953-569.clb
Part No SW: 8X0 953 501 B HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0140
Revision: FF010018 Serial number: 20140522200128
Coding: 1184004000
VCID: 3972D664B8CC3D89EE-806C
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
1140738 - Steering angle sensor
Reset counter: 36
Mileage: 17983 km
Date: 2017.02.21
Time: 19:52:38
UBat: 14.80 V
MC1 interner Fehlercode: 0
MC2 interner Fehlercode: 0
Address 17: Instruments (J285) Labels: 8X0-920-xxx-17.clb
Part No SW: 8X0 920 980 L HW: 8X0 920 980 L
Component: KOMBI_MEDIUM H01 0340
Coding: 41CE01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
VCID: 4894A3A0F326540161-801C
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 AC HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0072
Revision: 1P130039 Serial number: 3941P1450206AD
Coding: FBCF7A64000100010353
VCID: 030E748C8280B759F4-8056
Subsystem 1 - Part No SW: 6R0 915 181 E HW: 6R0 915 181 E
Component: J367-BDM H08 0181
Serial number: 51113704172031119115
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 140215000000000002EE
Component: IMMO H01 0340
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 F HW: 8X0 959 793 F
Component: TSG FA H10 0415
Coding: 011802200001000000
VCID: 50A48BC003769CC139-8004
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11251
Shop #: WSC 00046
VCID: 3064EB40F7B6FCC159-8064
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 F HW: 8X0 959 792 F
Component: TSG BF H10 0415
VCID: 4FA688BC1E48833920-801A
Part No SW: 8X0 035 188 F HW: 8X0 035 188 D
Component: RMC Cnct P DR H55 0801
Coding: 01010400000053070023020103010000010000
VCID: 3F86B87CAEE813B9D0-806A
Subsystem 1 - Part No SW: 8X0 919 603 B HW: 8X0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9462I 0E2826514
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 8X0 959 795 D HW: 8X0 959 795 D
Component: TSG HL H07 0415
Coding: 010002200001000000
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H07 0415
End-------------------------(Elapsed Time: 02:45)--------------------------
