RNS 510 and Gateway Canbus upgrade gone wrong.
DISCOSTU29
Hello there
I bought a RNS510 (1T0 035 680 B) and a Gateway (7N0 907 530AM) to upgrade my Golf Mk5.
1-I took note of the Gateway Installation list. I forgot to take note of the long coding.
2-I installed the new gateway and selected correct modules and added the 37 Navigation then hit save.
3-I got the message Re-code Invalid. ' This appears to be an uninitialized control module' I wasn't expecting this and selected yes.
4-The RNS510 unit appear to be working.
5-I then updated the firmware which failed as it started installing Gateway.
6-I used ISO-Fix to get it going again.
7-I then put the original Gateway module back in.
8-I ran a VCDS scan and the results are below
I'm getting these errors now:
37-Navigation -- Status: Cannot be reached 1100
Any ideas why?
Tuesday,21,February,2017,21:57:29:49422
VCDS Version: 16.8.2.3
Data version: 20160926 DS261.0
VIN: WVWZZZ1KZ7W210418   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ7W210418   Mileage: 138020km-85761miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 DP    HW: Hardware No
   Component: MED9.5.10       G00 9029
   Revision: 66H09---    Serial number: VWZ7Z0G8063050
   Coding: 0000072
   Shop #: WSC 01279 785 00200
   VCID: 74E1E256177A21E2A0-8020
   Revision: 00H11001
   Coding: 0019073
   VCID: 73E3E14A127426DAB9-8026
   Part No: 1K0 820 047 GK
   Component: Climatic PQ35   120 0606
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006725215
   Coding: E48D0F2700041500471400001400000000087B075C0001
   Shop #: WSC 01287 785 00200
   VCID: 6CD1FA364F4AF92278-8038
   Component: Wischer 140207 020  0501
   Coding: 00038805
   Shop #: WSC 01287
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     230207 020  0105
   Coding: 00208933
   Shop #: WSC 01287
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD123JYM
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D77077264B0A0AA9F-8068
   Subsystem 1 - Serial number: 6332MSME175E4427F
   Subsystem 2 - Serial number: 6342MSME16753875E
   Subsystem 3 - Serial number: 6352QSME1D68483DX
   Subsystem 4 - Serial number: 6362QSME222C0727C
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
   Part No SW: 1K0 953 549 BD    HW: 1K0 953 549 BD
   Coding: 0002022
   VCID: 75E7DF521C0038EA97-8020
   Part No SW: 1K0 920 973 A    HW: 1K0 920 973 A
   Revision: V0003000    Serial number: VWZ7Z0G8063050
   Coding: 0003403
   Shop #: WSC 00581 210 64475
   VCID: 2B53392A8AC43E1A31-807E
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 210207F1000396
   Coding: 3D3F034807000003
   VCID: 2F6B2D3ABEDC423A1D-807A
                    Fault Frequency: 14
                    Reset counter: 4
                    Mileage: 137921 km
                    Time: 21:44:31
                    Reset counter: 218
                    Mileage: 137921 km
                    Time: 21:40:00
01304 - Radio
                    Fault Status: 00110100
                    Reset counter: 3
                    Mileage: 137921 km
                    Time: 06:13:08
   Component: IMMO            VDD 1610
Address 37: Navigation        Labels: None
   VCID: 55A7BFD2BCC058EAB7-8000
No Faults Found
   Component: Tuer-SG         005 0980
   Coding: 0000692
   VCID: 387916664B9285824C-806C
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.068 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 35671F525C8078EA57-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Component:    KSG PQ35 G2  020 0203
   Coding: 819002005103085B2D04840570085FC690FC00
   Shop #: WSC 00365 210 88132
   VCID: 0303B18A42D4165AA9-8056
   Subsystem 2 - Part No: 1K0 951 178
   Component: Neigungssensor  001 0101
   Subsystem 3 - Part No: 1K0 951 178
   Component: Innenraumueberw.001 0101
   Coding: 0000692
   VCID: 397F136270989C8AB3-806C
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Address 56: Radio        Labels: None
No Faults Found
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         005 0913
   Coding: 0000144
   Shop #: WSC 01279 785 1012552
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
End-------------------------(Elapsed Time: 02:07)--------------------------
Due to the fault code in your airbag module:
CAN Gateway has 3 faults. Two of them are flagged "Intermittent", meaning the fault condition that set the code did not exist or could not be detected at the time the scan was performed. Those should clear. The last one is because your RNS is being flaky.
Look at the detailed scan results on both of these (same module, two addresses). It's not happy.
PS: Please Get Verified so we can move this to the Retrofits section of the forum.
DISCOSTU29
I have run serveral scans and cleared the faults each time but always come back.
Are the Radio and Navigation fault both supposed to be on the same module with different addresses. Sorry I'm new to this and not sure.
DISCOSTU29
Is there anything i missed when installing the RNS510 unit ? Anything should have used VCDS for coding?
I used iso fix to get the RNS510 back to switching on but i cant update the firmware because of the gateway problem. The only thing that currently works on the unit is the radio. The touch screen, hard disc, CD, maps don't work so i need to be able to update the firmware.
golfi_vend
Tartu, Estonia
C?ID=195131
Version B RNS510 suffered from bad can-bus communication. Is Communication working? Radio shuts off when key removed etc... ?
DISCOSTU29
It shuts off if remove the key, wont switch off if you push the off button on the unit.
United States
DISCOSTU29
So do i need to recode the RNS510? If so how, if i cant talk to it the VCDS?
I dont understand the original canbus gateway didnt have any faults on it when last scanned. I put the new one upgraded one in and it can up with these three faults so i put the original one back in and still have the same faults.
Obviously the radio and navigation ones go if i put the original radio back in and take off the navigation code but stilll left with the canbus gateway fault.
