2012 Audi A6 C7 S-Line
MartinsX
Riga, Latvia
C?ID=268515
This is not broken anymore, so scan from this car fits here. Unfortunately I had no possibility to make any maps as car came from neighbour workshop just for diagnostics.
Monday,20,February,2017,12:07:03:32442
VCDS Version: 17.1.2.1
Data version: 20170131 DS267.1
VIN: WAUZZZ4G2CN127782   License Plate:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 28 34 3B 3C 42 44 46
          47 52 53 55 56 5F 62 69 72 82 85 8B 8E 8F 90
VIN: WAUZZZ4G2CN127782   Mileage: 205886km-127931miles
Address 01: Engine (J623-CLAA)       Labels: None
   Part No SW: 4G0 907 311 E    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0001
   Revision: 53H37---
   Coding: 12254012057601020000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907311E 001001
   ROD: EV_ECM30TDI0114G0907311E.rod
   VCID: 25419BAB249FBC69B1-8070
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G1 927 156 C    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0001
   Revision: --H10---    Serial number: 0000001963
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 2D51638B7C6F842979-8078
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 07A6C701E065E380EB00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 387F42DF832D31811A-806C
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Component: BCM2 2.0      H31 0333
   Coding: 01A93006000000000000
   VCID: 76E38CE7C1B987F1C8-8022
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-4Z.clb
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H12 0064
   Serial number: 02021200040867
   Coding: 3602007834
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 275D91A35E93AE7983-8072
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 BP    HW: 4H0 907 063
   Component: BCM1 2.0      H12 BCM1 2.0      H12 01110111
   Revision: 11012002    Serial number: 00000001390250
   Coding: 0907201009749FE28981008320001800CF9CE7082E080101000108542F01
   VCID: 77FD81E3C6B3FEF9D3-8022
   Subsystem 1 - Part No: 4G1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS57X 120107
   Coding: 0045F7
   Subsystem 2 - Part No: 8K0 955 559   Labels: 8K0-955-559.CLB
   Component: RLS
   Coding: 02512B
   Subsystem 3 - Part No: 4G0 941 531 G
   Component: E1 - LDS
   Subsystem 4 - Part No: 4H0 907 472 B
   Component: A31 LED Mod1L
   Coding: 110000
   Subsystem 5 - Part No: 4H0 907 472 B
   Component: A27 LED Mod1R
   Coding: 110000
   Subsystem 6 - Part No: 4H0 907 658
   Component: AQ_Hum_Sensor
Address 10: Park/Steer Assist (J791)       Labels: 4H0-919-475-7X5.clb
   Part No SW: 4H0 919 475 R    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0045
   Revision: --------    Serial number: 56261203000983
   Coding: 992B07
   ASAM Dataset: EV_EPHVA2CAU57X0000 002011
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 41892F3BD0F77049AD-8014
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H17 0400
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 285F929F538DA1018A-807C
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 Airbag10.43   H43 00400040
   Revision: --------    Serial number: 003JG006P02S
   Coding: 30323436313330303339554A304C34473053
   ROD: N/A
   VCID: 36634CE78939C7F108-8062
   Serial number: 3575HRB405L131GQCH7G
   Serial number: 3585HRB405J131GUB1JE
   Serial number: 3515JRB4067134DMKP7B
   Serial number: 3525JRB4067134DM806H
   Serial number: 3554VRB40511138COGUJ
   Serial number: 3564VRB40511138CD1BI
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: --------    Serial number: 90372LAU000K8
   Coding: 0000DD
   VCID: 377D41E386333EF913-8062
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H08 0009
   Serial number: 22 11 2011  B0090904
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 931 R    HW: 4G8 920 931 R
   Component: TDieRdwAcc    H79 0416
   Revision: 28460177    Serial number: 658110112591019
   Coding: 138611001F150008000000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K.rod
   VCID: 3D7153CBAC0F14A9C9-8068
   Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000383209
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 346776EF9F45D5E136-8060
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790797773
   Voltage stabilizer:
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 04018264747464545425363E
   VCID: 336575F3924BD2D92F-8066
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0064
   Serial number: 01021200040913
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 2F6D79837663F6394B-807A
Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
   Part No SW: 4G0 907 553 E    HW: 4G0 907 553
   Component: LUFE-DAEMPFER H17 0781
   Coding: 008003
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0009
   Revision: --------    Serial number: EJ1BPA4203LX5J0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0020
   Revision: 00H02000    Serial number: 6PZ 010 287-03
   Coding: 0010102
   VCID: 306F7AFFA35DE9C152-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H02 0020
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F26.01.1200H020003CF27831˙
   Subsystem 4 - Serial number: F27831˙
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F16205000628002080013
   VCID: 41892F3BD8F77049AD-8014
Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0020321327
   Coding: 101101010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326B70F76551DBD124-8066
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0169634807
   Coding: 0100062020B90480832009842C0104000000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00000785771
   Revision: CJ007001    Serial number: 00000000023759
   Coding: 030000
   VCID: 1D31B34B04CF74A9E9-8048
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F16205000628002080002
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000242559
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2A5B68974D8193119C-807E
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 120202-0001-114
   Coding: 11226F601002A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C576E8F47758D216E-8078
   Part No SW: 4G1 035 053 E    HW: 4G1 035 053
   Component: Radio U Basic H41 0093
   Revision: AB001007    Serial number: 227BU0C7531742
   Coding: 010003010000000001
   VCID: 21498FBB38B75049CD-8074
   Part No SW: 4G0 035 666 G    HW: 4G0 035 666 A
   Component: H-BN-EU       H48 0484
   Revision: --------    Serial number: 426AQ0C7635203
   Coding: 050100010003FDED3D30EB3E00000003E80101020000000000
   VCID: 2C576E8F4F758D216E-8078
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB9400KM3S
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LB3000TZ
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F14204000628002080002
   VCID: 4487262FC7E5656186-8010
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Revision: 5G001001    Serial number: 00000168814966
   Coding: 0109080000000000
   VCID: 71E9BFFBA8D7A0C91D-8024
   Component: TSG HR        H04 0212
Address 82: Heads Up Display (J898)       Labels: 4G0-919-604.clb
   Part No SW: 4G0 919 604 G    HW: 4G0 919 604 G
   Component: HeadUpDisplay 005 0106
   Coding: 470000
   ASAM Dataset: EV_HUDContiC7 001020
   ROD: EV_HUDContiC7.rod
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H25 0036
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 65C1DBAB641F7C6971-8030
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   VCID: 26439CA75999B771B8-8072
Address 8E: Image Processing (J851)       Labels: 4H0-907-107-V2.clb
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000050302127
   Coding: 04C0BB1C1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 31697FFB6057E0C95D-8064
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 06:47)--------------------------
