2017 Passat GTE 1.4TSI
Ilu
Finland
HN1-008020
Seen a few probes and such, no active faults. Hopefully is good enough for a reference (y)
Friday,17,February,2017,17:24:26:11509
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 17.1.3.0 (x64)  HEX-NET CB: 0.4334.4
Data version: 20170203 DS267.2
VIN: WVWZZZ3CZHE051219   License Plate:
Chassis Type: 3C (5QE)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 55 5F
          6D 75 8C A9 BB BC C6
VIN: WVWZZZ3CZHE051219   Mileage: 7201km-4474miles
51-Electric Drive -- Status: Malfunction 0010
8C-Hybrid Battery -- Status: Malfunction 0010
Address 01: Engine (J623-CUKC)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AH    HW: 04E 907 309 F
   Component: 1.4l TFSI hy  H22 2881
   Revision: X3H22---
   Coding: 011D0012632405083000
   Shop #: WSC 05311 115 00305
   ASAM Dataset: EV_ECM14TFS01104E906023AH 006004
   ROD: EV_ECM14TFS01104E906023AH_006.rod
   VCID: 6680540F994B387173-8033
11 Faults Found:
26468 - Terminal 15 Voltage
          P151B 00 [032] - Implausible
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:38:47
                    Engine speed: 0.00 /min
                    Coolant temperature: 75 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 12.280 V
                    Unlearning counter according OBD: 32
                    Outside air temperature: 3 °C
                    Absolute intake pressure: 102 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 50.00 l
                    E-machine torque actual value: -0.3 Nm
                    Operating mode control expanded electrical driving: Correct result
                    Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 1
                    High-volt. battery: charge state: abs. value: 41.84 %
17167 - Databus
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:38:39
                    Voltage terminal 30: 12.260 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bit 0: 7
                    Cruise_control_shutoff_conditions_irreversible-Bit 0: 0
                    Cruise_control_shutoff_conditions_irreversible-Bit 8: 0
                    Cruise control system: temporary deactivation-Bit 0: 255
                    Cruise control switch actuation-Bit 0: 0
                    Cruise control switch actuation-Bit 8: 32
17158 - Databus
                    Mileage: 6238 km
                    Date: 2017.01.21
                    Time: 00:00:10
                    Coolant temperature: -6 °C
                    Intake air temperature: -6 °C
                    Voltage terminal 30: 9.240 V
                    Unlearning counter according OBD: 15
                    Cruise Control System (CCS): status-Bit 0: 6
                    Drivetrain coordinator: ACC fault status-Bit 0: 0
                    Drivetrain coordinator: ACC fault status-Bit 8: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 0: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 16: 128
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 24: 2
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 8: 136
                    Drivetrain coordinator: brake fault status-Bit 0: 5
15494 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [032] - -
                    Mileage: 6238 km
                    Date: 2017.01.25
                    Time: 11:29:20
                    Engine speed: 1592.50 /min
                    Normed load value: 19.2 %
                    Vehicle speed: 15 km/h
                    Coolant temperature: 78 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 14.960 V
                    Outside air temperature: -3 °C
                    Absolute intake pressure: 49 kPa abs
                    Engine torque: 34.3 Nm
                    Fuel level: 45.00 l
                    E-machine torque actual value: -22.5 Nm
                    Operating mode control expanded electrical driving: False result
                    Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 0
                    High-volt. battery: charge state: abs. value: 13.98 %
          U0428 00 [032] - -
                    Mileage: 6238 km
                    Date: 2017.01.21
                    Time: 00:00:09
                    Voltage terminal 30: 9.740 V
                    Outside air temperature: -4 °C
                    Absolute intake pressure: 103 kPa abs
                    Fuel level: 45.00 l
                    E-machine torque actual value: 0.2 Nm
                    High-volt. battery: charge state: abs. value: 10.33 %
23005 - No Communications with Control Module for Access/Start Authorization
          U100A 00 [032] - -
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:38:45
                    Fuel level: 50.00 l
18096 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [032] - -
                    Fault Frequency: 44
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:16
4858 - Implausible Data Received from Body Control Module A (Central Electric 2)
          U0431 00 [032] - -
                    Fault Frequency: 34
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:17
                    Intake air temperature: 23 °C
23806 - Implausible Data Received from Steering Column Control Module
          U0429 00 [032] - -
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:38:45
                    Fuel level: 50.00 l
4459 - Implausible Data Received from Body Control Module A (Central Electric 2)
          U0431 00 [032] - -
                    Fault Frequency: 34
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:17
27705 - Implausible Data Received from Driver's Door Control Module
          U049A 00 [032] - -
                    Fault Frequency: 34
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:17
                    Outside air temperature: 1 °C
                    Fuel level: 50.00 l
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0DD 300 045 T    HW: 0DD 927 770 B
   Component: GSG DQ400E    H31 1124
   Revision: 00031033    Serial number: TFK01606030023
   Shop #: WSC 05311 115 00089
   ROD: EV_TCMDQ400021.rod
   VCID: 383CCA77837F7E8111-806D
19 Faults Found:
10779 - System Voltage
          P0562 00 [040] - Too Low
                    Mileage: 6238 km
                    Date: 2017.01.21
                    Time: 00:00:11
                    Engine speed: 6.25 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 35 km/h
                    Control Module temperature: 22 °C
                    CURRENT pressure: -9.5 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_5
                    Driving position: N
                    Accelerator position: 0.4 %
                    DTC memory status: 13824
32317 - Unknown Error Code
          U04B5 00 [002] - -
10893 - Implausible Data Received from Battery Energy Control Module 2
          U0413 00 [002] - -
60354 - ROD - Unknown Error Code
          - 00 [002]
60355 - ROD - Unknown Error Code
          - 00 [002]
60356 - ROD - Unknown Error Code
          - 00 [002]
60357 - ROD - Unknown Error Code
          - 00 [002]
60358 - ROD - Unknown Error Code
          - 00 [002]
60359 - ROD - Unknown Error Code
          - 00 [002]
60360 - ROD - Unknown Error Code
          - 00 [002]
60361 - ROD - Unknown Error Code
          - 00 [002]
60362 - ROD - Unknown Error Code
          - 00 [002]
60363 - ROD - Unknown Error Code
          - 00 [002]
60364 - ROD - Unknown Error Code
          - 00 [002]
60365 - ROD - Unknown Error Code
          - 00 [002]
60366 - ROD - Unknown Error Code
          - 00 [002]
60367 - ROD - Unknown Error Code
          - 00 [002]
60368 - ROD - Unknown Error Code
          - 00 [002]
60369 - ROD - Unknown Error Code
          - 00 [002]
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 62026000001669
   Coding: 0FEC408F3825236D4779060141CC49F0021CC4E26082927132A1F078C20202
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_SK37.rod
   VCID: 7CB41667F7C792A1B5-8029
0297 - Steering angle sensor
          B1168 16 [032] - Voltage Too Low
                    Mileage: 6238 km
                    Date: 2017.01.21
                    Time: 00:00:09
16412 - Display for Tire Pressure Monitoring
          C1146 02 [044] - Signal Failure
                    Mileage: 6238 km
                    Date: 2017.01.25
                    Time: 11:17:28
16413 - Display for Tire Pressure Monitoring
                    Mileage: 6238 km
                    Date: 2017.01.25
                    Time: 11:17:28
   Part No SW: 3Q0 959 435 D    HW: 3Q0 959 435 D
   Component: VWKESSYMQB    026 0811
   Revision: 00026000    Serial number: 0412456226
   Coding: 002F0F070F
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   VCID: 3B36D57BB2495599FC-806F
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 144
                    Mileage: 6238 km
                    Date: 2017.01.05
                    Time: 04:10:26
133124 - Databus
                    Fault Frequency: 52
                    Reset counter: 162
                    Mileage: 6246 km
                    Date: 2017.01.25
                    Time: 12:48:26
12718085 - Databus
                    Fault Frequency: 19
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:34:21
12786202 - Databus
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:16
12786210 - Databus
                    Fault Frequency: 24
                    Reset counter: 162
                    Mileage: 1048574 km
   Part No SW: 5GE 907 044 AK    HW: 5GE 907 044 AK
   Component: Climatronic   H04 1502
   Revision: 00001K07
   Coding: 1202100420011001081550000010182A
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   ROD: EV_ACClimaBHBVW37X_004_VW48.rod
   VCID: 05427383840DD369DA-8051
   Subsystem 3 - Part No SW: 3Q0 963 231 D    HW: 3Q0 963 231 D
   Serial number: -00102.9T.5B20340229
   Air quality sensor:
   Air Conditioning Compressor Sub:
H02 0007
          B10CD 00 [008] -  -
                    Reset counter: 147
                    Mileage: 6238 km
                    Date: 2016.12.28
                    Time: 13:32:44
                    Voltage terminal 30: 11.4 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up light: OFF
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0222
   Revision: --------    Serial number: 865823071601A7
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 014A67939025FF49E6-8055
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160713  042 0607
   Serial number:         160727033500
   Component: RLHS  042 0105
   Serial number: S4Y16M08D02H08M04S44
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 J    HW: 3G0 941 633 J
   Serial number: 02 06 2016  10000048
          U1400 00 [008] - -
                    Reset counter: 144
                    Mileage: 6238 km
                    Date: 2017.01.21
                    Time: 00:00:12
528662 - Databus
                    Fault Frequency: 56
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:16
544790 - Databus
                    Fault Frequency: 27
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:38:34
529174 - Databus
                    Fault Frequency: 21
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:16
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616204
   Coding: 1271061051
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_009.rod
   VCID: 0D524BA3DC7DAB2992-8059
13637426 - Databus
                    Reset counter: 144
                    Mileage: 6238 km
                    Date: 2017.01.21
                    Time: 00:00:13
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 5200608151FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3424FE479F179AE13D-8061
2055 - Databus
                    Reset counter: 144
                    Mileage: 6238 km
                    Date: 2017.01.21
                    Time: 00:00:14
                    Control Module temperature: -1 °C
                    Voltage terminal 15: 14.1 V
2101 - Databus
                    Reset counter: 144
                    Mileage: 6238 km
                    Date: 2017.01.21
                    Time: 00:00:13
                    Voltage terminal 15: 13.6 V
0836 - Databus
                    Fault Frequency: 88
                    Reset counter: 166
                    Mileage: 6237 km
                    Date: 2016.12.19
                    Time: 09:56:25
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 14.5 V
                    Status_ACC_System: ACC_Init
1086 - Databus
                    Fault Frequency: 45
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:16
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 11.9 V
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 144
                    Mileage: 6238 km
                    Date: 2017.01.21
                    Time: 00:00:10
                    Voltage terminal 15: 8.9 V
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    010 0870
   Serial number: 003MFR02BZWI
   Coding: 88CCC000002000005C5400CF004800000065
   Shop #: WSC 05314 000 00001
   VCID: 50EC92D70BCFC6C139-8005
   Subsystem 1 - Part No SW: -----------    HW: 480 002 207 16
   Serial number: 357000000004EC6DFC16
   Subsystem 2 - Part No SW: -----------    HW: 480 002 207 16
   Serial number: 35800000000ECAC8AC19
   Subsystem 3 - Part No SW: -----------    HW: 480 402 306 16
   Serial number: 3510002A520F1951524R
   Subsystem 4 - Part No SW: -----------    HW: 480 402 306 16
   Serial number: 3520002BD20FC4C1D0EN
   Subsystem 5 - Part No SW: -----------    HW: 480 402 306 16
   Serial number: 3550002BD20FC4C32148
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 DJ    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160803501224
   Coding: 0410
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7BB6157BF2C99599BC-802F
   Part No SW: 3G0 920 754 B    HW: 3G0 920 754 B
   Component: KOMBI         304 8315
   Coding: 07240B182BC0000801886B111201002000000000
   VCID: 271E190B5EC1E17988-8073
13 Faults Found:
16776960 - Databus
                    Fault Frequency: 65
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:16
16776961 - Databus
                    Fault Frequency: 77
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:16
16776962 - Databus
                    Fault Frequency: 24
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:16
16776968 - Databus
                    Fault Frequency: 41
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:16
16776978 - Databus
                    Fault Frequency: 39
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:16
16776988 - Databus
                    Fault Frequency: 37
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:16
12858141 - Databus
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:35:33
12858136 - Databus
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:41:33
12858138 - Databus
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:35:33
12858137 - Databus
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:47:30
16776990 - Databus
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:38:46
16776992 - Databus
                    Fault Frequency: 33
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:16
12858145 - Databus
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:38:33
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5QE 907 530 F    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3265
   Revision: --------    Serial number: 01071610520442
   Coding: 020300172EF21000FB00526A5C1D00000001070100010000000300000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013.rod
   VCID: 49DABFB3E895F7097E-801D
   Subsystem 1 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29160001413930116284
   Coding: 29FFFF
   Subsystem 2 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Serial number: 0277770904
   Analog clock:
   Subsystem 3 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
8531970 - Quiescent Current
          U1406 00 [008] - Too High
                    Fault Frequency: 24
                    Reset counter: 168
                    Mileage: 6238 km
                    Date: 2016.12.20
                    Time: 06:11:58
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: OFF
8526356 - Autonomous Post-Charging Active
          P30F2 00 [008] - -
                    Fault Frequency: 14
                    Reset counter: 147
                    Mileage: 6238 km
                    Date: 2016.12.28
                    Time: 13:32:45
                    Supply voltage: Terminal 30: 11.4 V
                    Terminal 15: OFF
8526359 - Autonomous Post-Charging Play-Protection Active
          P30F3 00 [008] - -
                    Fault Frequency: 15
                    Reset counter: 147
                    Mileage: 6238 km
                    Date: 2016.12.28
                    Time: 13:52:40
                    Supply voltage: Terminal 30: 13.1 V
                    Terminal 15: OFF
   Part No SW: 5QE 909 059 E    HW: 5QE 909 059 B
   Component: EBKV          H14 0200
   Serial number:   085430010354
   Coding: 05720100431900020002060500
   Shop #: WSC 05311 115 00314
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
   ROD: EV_BrakeBoostBoschMQBOMG_001_VW48.rod
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861130716163655
173568 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
                    Mileage: 6238 km
                    Date: 2017.01.21
                    Time: 00:00:09
87296 - Databus
          U1121 00 [040] - Missing Message
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:37:17
   Serial number: 16000163941014
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AA3753A085EFC916-8025
13637381 - Databus
                    Fault Frequency: 38
                    Reset counter: 162
                    Mileage: 6660 km
                    Date: 2017.02.12
                    Time: 17:38:33
                    Result lock conditions: invalid
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Lock sensor: not activated
                    Unlock sensor: operated
                    Error mode 1: not active
                    Error mode 2: not active
                    Clamp S: On
                    Clamp 15: On
                    Clamp 15 Status: valid
                    Remotestart: not active
                    Driver door: closed
                    Central locking locked external: unlocked
                    Central locking safed external: Vehicle not secured
                    Clamp Request: No
                    Request highside lock: No
                    HW highside lock: OFF
                    Highside unlock: No
                    Motor break: not active
                    Activation lowside unlock: OFF
                    Activation lowside lock: OFF
                    I2C overflow: No
                    I2C error pathflags: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C length failure: No
                    I2C error sda: No
                    I2C communication failure: i2c no comm failure
                    I2C state esp 10: i2c e2e failure
                    I2C cnd haco message: valid
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: Yes
                    Signature IMS OK: Yes
                    IMS responded: Yes
                    Positive authentification in current KL15 cycle: Yes
                    Lifestate: Immobilizer download obtained
                    Authentication valid (T1): No
                    State of authentication state machine: WFS_AUTH_INIT_e
                    Vehicle speed: 0.00 km/h
                    UBat internal: 11.5 V
                    UMotorBridge: 6.3 V
                    Lock condition engine speed: Condition met
                    Lock condition clamp S: Condition not met
                    Lock condition clamp 15: Condition not met
                    Lock condition E2E clamp status: Condition not met
                    Lock condition timeout clamp status: Condition met
                    Lock condition vehicle speed: Condition met
                    Lock condition E2E vehicle speed: Condition not met
                    Lock condition timeout vehicle speed: Condition met
                    Lock condition Mode1: Condition met
                    Lock condition drive readiness: Condition not met
                    Lock condition selector lever position parking: Condition met
                    Clamp enable ESCL: not enabled
                    Lock condition timeout distance pulse: Condition met
                    Lock condition E2E distance pulse: Condition not met
                    Lock condition difference distance pulse: Condition not met
13637383 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Fault Frequency: 27
                    Reset counter: 159
                    Mileage: 6246 km
                    ESCL locked: Yes
                    ESCL unlocked: No
                    Lock sensor: operated
                    Unlock sensor: not activated
                    Clamp S: OFF
                    Clamp 15: OFF
                    Driver door: closed
                    Clamp Request: Yes
                    Highside unlock: No
                    I2C overflow: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C error sda: No
                    I2C state esp 10: i2c timeout
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: No
                    Signature IMS OK: No
                    IMS responded: No
                    Positive authentification in current KL15 cycle: No
                    Vehicle speed: 655.35 km/h
                    UBat internal: 11.9 V
                    UMotorBridge: 6.5 V
                    Lock condition clamp S: Condition met
                    Lock condition clamp 15: Condition met
                    Lock condition vehicle speed: Condition not met
                    Lock condition timeout vehicle speed: Condition not met
                    Lock condition drive readiness: Condition met
                    Lock condition timeout distance pulse: Condition not met
   Serial number: 120716EGA22453
   Coding: 003F0F208000020000001000
   VCID: 43C6AD9BCAB92D59B4-8017
65621 - Locking Module for Central Locking
          B122F 29 [008] - Signal Implausible
                    Reset counter: 144
                    Mileage: 6238 km
                    Date: 2017.01.25
                    Time: 11:18:08
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000958285
   Coding: 01010010005101
   Shop #: WSC 00015 115 00305
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_SK37.rod
   VCID: 3D32DB63AC5D5BA9C2-8069
5262656 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 144
                    Mileage: 6238 km
                    Date: 2017.01.21
                    Time: 00:00:08
                    valid
   Part No SW: 3G0 907 080 C    HW: 3G0 907 080 C
   Component: LE Gen 3.3H09 0060
   Revision: 00H09000
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM12030113G0907080C 001015
   ROD: EV_DMCM12030113G0907080B.rod
   VCID: 2502130324CDF369BA-8071
31789 - System Voltage
          P0562 00 [032] - Too Low
                    Mileage: 6238 km
                    Date: 2017.01.21
                    Time: 00:00:10
                    Voltage terminal 30: 8.802 V
                    Drive control condition: Standby
                    Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE: 2
   Serial number: 070716EG625047
   Coding: 003F01208000020000001000
   VCID: 42C8A89FD5A32451BF-8017
   Component: AFS-ECU       H01 0120
   Coding: 039A00000F200200
   Shop #: WSC 05311 000 08193
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3FCEA16BA65149B9D0-806B
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
13706046 - Databus
                    Reset counter: 162
                    Mileage: 6358 km
                    Date: 2017.02.09
                    Time: 14:07:06
13706047 - Databus
                    Reset counter: 162
                    Mileage: 6358 km
                    Date: 2017.02.09
                    Time: 14:07:06
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 846 A    HW: 3Q0 035 846 A
   Component: MU-S-N-ER     H30 0356
   Serial number: VWZAZ2S0408575
   Coding: 02840201FF0000005111000100080A001F0209C401200100CF
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 2F2EF12B7631B93940-807B
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9S2070744
   Subsystem 2 - Part No SW: 3G0 919 866 S    HW: -----------
   Component: ECE1 2016/17  --- 0635
5688 - Control Head for Mulimedia System
          B13C9 F2 [008] - On/Off Switch
                    Reset counter: 162
                    Mileage: 6652 km
                    Date: 2017.02.12
                    Time: 16:27:11
                    Voltage terminal 30: 14.9 V
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30813994300000
   Coding: 0200
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
   Component: OCULowMQBEU   012 0717
   Coding: 0284720110829A0300F800000000
   ROD: EV_OCULowMQB.rod
   VCID: 44C4AE87CFB72A618D-8011
Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 3Q0 915 227 K    HW: 3Q0 915 227 K
   Component: K8C           H05 0430
   Serial number: 22071616010149
   ASAM Dataset: EV_BECM09620213Q0915227K 002006
   ROD: EV_BECM09620213Q0915227K.rod
   VCID: 393ACF73B8756789EE-806D
   Battery Junction Box:
   Subsystem 1 - Part No SW: 3Q0 915 227 J    HW: 3Q0 915 227 J
   Component: A2 HVSMBJBECU  H08 0410
   Serial number: 00000027071616010109
   Cell Module Controller 1:
   Subsystem 2 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC1  H04 0430
   Serial number: 16430ZKK311A01040562
   Cell Module Controller 2:
   Subsystem 3 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC2  H04 0430
   Serial number: 16430ZKK311A01040347
   Cell Module Controller 3:
   Subsystem 4 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC3  H04 0430
   Serial number: 16430ZKK311A01040466
   Cell Module Controller 4:
   Subsystem 5 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC4  H04 0430
   Serial number: 16430ZKK311A01040373
   Cell Module Controller 5:
   Subsystem 6 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC5  H04 0430
   Serial number: 16502ZKK311A01040038
   Cell Module Controller 6:
   Subsystem 7 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC6  H04 0430
   Serial number: 16424ZKK311A01040525
   Cell Module Controller 7:
   Subsystem 8 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC7  H04 0430
   Serial number: 16426ZKK311A01040862
   Cell Module Controller 8:
   Subsystem 9 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC8  H04 0430
   Serial number: 16426ZKK311A01040781
28796 - 14V Power System Voltage
          P0A8D 00 [032] - too Low
                    Mileage: 6238 km
                    Current of high-voltage / hybrid battery: Initializing
                    Voltage terminal 30: 8.250 V
28809 - System Voltage
                    Mileage: 6238 km
                    Voltage terminal 30C: 8.300 V
28558 - Invalid Data Received from Diagnostic Gateway Module
          U0447 00 [032] - -
                    Fault Frequency: 192
                    Mileage: 6320 km
                    Date: 2017.02.06
                    Time: 11:35:50
                    Current of high-voltage / hybrid battery: -2.750 A
28559 - Invalid Data Received from Diagnostic Gateway Module
          U0447 00 [032] - -
                    Fault Frequency: 16
                    Mileage: 6320 km
                    Date: 2017.02.06
                    Time: 11:35:38
                    Current of high-voltage / hybrid battery: -16.750 A
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 3G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 160713201272
   VCID: 699A5F33885517095E-803D
Address BB: Door Rear Drv (J388)       Labels: None
   Serial number: 200716EGD08931
   Coding: 000E01200100020000001000
   VCID: 45C2B383C48D13699A-8011
Address BC: Door Rear Pass (J389)       Labels: None
   Serial number: 200716EGD09201
65593 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Reset counter: 149
                    Mileage: 6307 km
                    Date: 2017.02.04
                    Time: 11:51:15
Address C6: Batt. Chrg. (J1050)       Labels: None
   Part No SW: 5QE 915 682 M    HW: 5QE 915 682 M
   Component: OBC KOSTAL    H31 4006
   Revision: --------    Serial number: 0607160G40002O
   Coding: 115068222000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB11P 004001
   ROD: EV_OBCSinglPhaseKLOMQB11P.rod
   VCID: 57FE69CB2E2191F9F8-8003
          U1400 00 [008] - -
                    Reset counter: 144
13705540 - Databus
                    Reset counter: 170
                    Mileage: 6237 km
                    Date: 2016.12.19
                    Time: 10:03:01
End----------(Elapsed Time: 02:11, VBatt start/end: 13.2V/13.2V)-----------
