do i need a new ecu??
Cuprarog
LP/IP
Friday,17,February,2017,12:34:13:20229
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
VIN: VSSZZZ1MZ3R113757   License Plate:
Chassis Type: 1M (1M - Seat Leon (2000 > 2005))
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ3R113757   Mileage: 187470km-116488miles
   Part No: 1ML 906 032
   Component: 1.8l R4/5VT         0001
   Coding: 10510
   Shop #: WSC 33278
   VCID: 7EF275BF7AB870B19B-5140
   VSSZZZ1MZ3R113757     SEZ7Z0C1915415
17795 - Control Module Malfunction - Internal Altitude/Pressure Sensor
            P1387 - 35-00 -
17695 - Boost Pressure Control Valve (N249)
            P1287 - 35-00 - Open Circuit
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
            P0106 - 35-00 - Implausible Signal
Readiness: 0010 0000
Address 03: ABS Brakes        Labels: 8N0-907-379-MK60-F.lbl
   Part No: 8N0 907 379 G
   Coding: 0019469
   Shop #: WSC 00001 001 00001
   VCID: 408ECB4710CCC641A9-5122
Address 08: Auto HVAC        Labels: 1M0-820-043.lbl
   Part No: 1M0 820 043 E
   Component: 1M-CLIMATRONIC    X0702
   Coding: 00041
   Shop #: WSC 06402
   VCID: 244667D7B494FA61AD-257A
   Part No: 1C0 909 605 A
   Component: 39 AIRBAG VW51 0A   0008
   Coding: 13113
   Shop #: WSC 06441
   VCID: 224A61CFAE80F451DF-5122
Address 17: Instruments        Labels: 1M0-920-xx2-17.lbl
   Part No: 1M0 920 922 F
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 05424
   VCID: 2C568FF7DC44322165-5106
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 06402
   VCID: 70EE5B8730EC16C119-5106
   Part No: 1C0 959 799 F
   Component: A7 Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 06402
   VCID: 3A7AB9AF26109C91E7-4B00
   Subsystem 1 - Part No: 1C0959802B
   Component: A7 Tõrsteuer.FS KLO 0009
   Subsystem 2 - Part No: 1C0959801C
   Component: A7 Tõrsteuer.BF KLO 0009
   Component: A7 Tõrsteuer.HL KLO 0009
   Component: A7 Tõrsteuer.HR KLO 0009
            27-00 - Implausible Signal
End-------------------------(Elapsed Time: 02:58)--------------------------
sorry I'm still new to this
Bruce
Near Philadelphia, PA, USA
I don't see anything that indicates a failed ECU. I see failed sensors or improperly reporting sensors. Care to give more background? Such as how the car is acting and so on?
If it were my car, I'd go find the wiring diagrams and see what is in common to the three sensors that the ECU is barking about. Perhaps there is a common link among them and one could then look at that link to see why these are failing to report proper conditions. Implausible signal and open circuits usually lead to a wiring issue.
Could it be a bad ECU? Yep it could. But that is the most expensive item... start with basics and move toward that expensive item.
Gone But Not Forgotten
Cuprarog
LP/IP
Thank you for the replies, when I first start the car from cold I get the faults and I clear them and restart the car they don't come back while driving, its only when I have let it cooled down, the car runs fine apart from that.
Jef
HQ
17795 / P1387 - Control Module Malfunction - Internal Altitude/Pressure Sensor
Do you get this DTC without starting the engine, just ignition on?
On a cold start, fire the engine up, clear the DTC and exit out of the ECM quickly. Shut car down. Does the code come back on the next start up?
Cold start... temperature related? Could putting the ECM into the fridge next the beer effect the ECM? Does it have to run longer before it clears out? Note, be sure it isn't a Lucas refrigerator, that wouldn't be a valid test. :p
Cuprarog
LP/IP
I only get this DTC on a cold start, when I clear the DTC it doesn't come back until its cold again
Jef
HQ
My educated guess is you will need to replace the ECM. May as well open it up and take a look inside. Maybe you will get lucky and find a cracked solder joint or something.
Cuprarog
LP/IP
Would the map sensor cause the 17795 fault code or am i just not accepting its the ECM?
Jack how do I recode the module to default in simple terms?
Thank you all for your help it's much appreciated.
Cuprarog
LP/IP
think ive got it, I'm still trying to my head around all of this, would recoding the module to default does that return the ecu to factory stock or am I reading to much into it?
Cuprarog
LP/IP
Hi Jack, I followed the instructions on recoding module to default that you gave me, it was already showing 10510 in software coding so I pressed do it and the fault cleared, not sure if I was suppose to do this with the car running or not? I will let you know how it went on as it normally goes after I have cleared it then comes back when I restart when the engine is cold. thank you again for your support and being patient with me.
Cuprarog
LP/IP
its come back
Sunday,19,February,2017,14:13:16:20229
VIN: VSSZZZ1MZ3R113757   Mileage: 187510km-116513miles
   Coding: 10510
   Shop #: WSC 33278
            P1387 - 35-00 -
Readiness: 0110 0000
   Coding: 0019469
   VCID: 408ECB4710CCC641A9-5140
   Coding: 00041
   Shop #: WSC 06402
   VCID: 244667D7B494FA61AD-2580
00792 - A/C Pressure Switch (F129)
            31-00 - Open or Short to Ground
   Coding: 13113
   Shop #: WSC 06441
   VCID: 224A61CFAE80F451DF-5106
   Coding: 05424
   VCID: 2C568FF7DC44322165-5122
   Coding: 00006
   Shop #: WSC 06402
   Coding: 00258
   Shop #: WSC 06402
It gets done not running and you have not set a different WSC or VCDS config .....please do so in VCDS config and set the tester ID, WSC, and Importer #.
Coding: 10510
Shop #: WSC 33278 <<<<<<<<<<<<<<<
When you see that number get changed to the WSC code you input in config, it helps verify you actually recoded with 10150
P1387 - 35-00 -
If this fault fails to vacate you need a module.
FYI we have that module new and reman if needed.
Cuprarog
LP/IP
where do I find the vcds config and tester id? as I don't have that info
Cuprarog
LP/IP
thank you Jack, is the vcds config?
the info below is what I'm getting when I go into vcds
software coding (0 - 32761) 10510
workshop code (0 - 99999) 33278
importer code (0 - 999) ---
what information am I putting in there?
You need to set it in the config I aforementioned and do not use 33278............RTFB the link.
Cuprarog
LP/IP
ok am I recoding using 10150?
Cuprarog
LP/IP
it will not allow me to change the importer number
Yes but the WSC must be changed to show an alternate login of the WSC.......make it for example 12349 Importer # 888 and and tester # 36987 save it restart VCDS and when in the 07 screen you should see the new numbers and use 10510
