Passat B6 2,0l CR TDI engine CBAB DPF and G450 procedures
MartinsX
Riga, Latvia
C?ID=268515
Some help needed here. This exact CBAB engine (ECU partnumbers Part No SW: 03L 997 384 H HW: 03L 907 309 ) does not have label file yet.
Need some assistance for G450 calibration and DPF service regeneration.
Scan and maps sent to RT support e-mail, too.
Wednesday,15,February,2017,14:45:17:32442
VCDS Version: 17.1.2.1
Data version: 20170131 DS267.1
VIN: WVWZZZ3CZ9E026223   License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 53 55 56 62 72
          77
VIN: WVWZZZ3CZ9E026223   Mileage: 213100km-132414miles
Address 01: Engine (CBA)       Labels: None
   Component: R4 2,0L EDC G001AG  0593
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 80093 222 71269
   VCID: 3F8D29C36E0306B9DB-806A
009315 - Diesel Particle Filter
               P2463 - 000 - Excessive Soot Accumulation - MIL ON
                    Fault Status: 11100000
                    Mileage: 213108 km
                    Date: 2017.02.13
                    Time: 13:58:42
                    Pressure: -44 mbar
                    Hex Value: 0xFF01
                    Temperature: 108.0°C
                    (no units): 0.0
                    Mileage: 2550 km
009754 - Coolant Pump 2
               P261A - 000 - Open circuit - Intermittent
                    Mileage: 213108 km
                    Date: 2017.02.13
                    Time: 14:31:22
                    RPM: 713 /min
                    Voltage: 13.60 V
                    Lambda: 79.7 %
                    Bin. Bits: 10011011
                    Bin. Bits: 00000000
                    Temperature: 19.8°C
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal
                    Mileage: 213108 km
                    Date: 2017.02.13
                    Time: 14:31:22
009299 - Diesel Particle Filter; Differential Pressure Sensor
               P2453 - 000 - Implausible Signal
                    Mileage: 213108 km
                    Date: 2017.02.13
                    Time: 14:39:55
                    Voltage: 13.38 V
                    Pressure: -44 mbar
                    Pressure: -41 mbar
                    (no units): 0.0
                    Temperature: 12.6°C
   Part No SW: 02E 300 051     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1818
   Revision: 04843012    Serial number: 00000806021471
   Shop #: WSC 05311 000 00000
   VCID: 50AF1A7FC39D89C132-8004
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000785800587
   Coding: 0000277
   VCID: 2B556D938A7B8A1967-807E
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 DC    HW: 3C0 907 044 DC
   Component: ClimatronicPQ46 132 0811
   Revision: 00132023    Serial number: 00000000000000
   VCID: 65C1DBABAC1F7C6971-8030
   Part No SW: 3C8 937 049 F    HW: 3C8 937 049 F
   Revision: 00H54000    Serial number: 00000008394191
   Coding: E38A8F0700041A00470A00000F000000000F5D435C000120000000000000
   Shop #: WSC 05124 000 00000
   VCID: 346776EF5745D5E136-8060
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 080508 003  0205
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     250608 054  0402
   Coding: 00208936
   Shop #: WSC 05124
                    Fault Status: 01101100
                    Reset counter: 4
                    Mileage: 213108 km
                    Date: 2017.02.13
                    Time: 14:38:00
                    Voltage: 13.10 V
                    Reset counter: 4
                    Mileage: 213108 km
                    Date: 2017.02.13
                    Time: 14:38:00
                    Reset counter: 4
                    Mileage: 213108 km
                    Date: 2017.02.13
                    Time: 14:31:00
                    Voltage: 12.15 V
   Component: J234__005 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPALW2D%
   Coding: 0012341
   VCID: 3B755DD37A1B1A99F7-806E
   Subsystem 1 - Serial number: 6333FTS619771558
   Subsystem 2 - Serial number: 6343FTS610381578
   Subsystem 3 - Serial number: 6353ETS6EERMTVNH
   Subsystem 4 - Serial number: 6363ETS6RRGJTVNP
   Part No SW: 3C0 953 549 AC    HW: 3C0 953 549 AC
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507AR
   Coding: 0001112
   VCID: 6DD1A38B74EF442939-8038
   Part No SW: 3C0 920 871 E    HW: 3C0 920 871 E
   Component: KOMBIINSTRUMENT VD1 2416
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 00001 686 98110
   VCID: 26439CA79199B771B8-8072
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 H    HW: 3C0 907 951
   Component: J533__Gateway   H13 0142
   Revision:   H13       Serial number: 2600P08606069E
   Coding: FD817F064006022002
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 397947DB70272889E5-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Part No SW: 1T0 035 680 D    HW: 1T0 035 680 B
   Component: RNS-MID       H03 4020
   Revision: AB001001    Serial number: VWZ6Z7H8183041
   Coding: 04000400040000020000
   Shop #: WSC 05314 000 00000
   VCID: 2F6D79837E63F6394B-807A
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1517
   Revision: 72009005    Serial number: 00000539688620
   Coding: 0000181
   VCID: 6FEDB9837EE3B6390B-803A
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.082 0401
   Revision: 1AH02234    Serial number: 00080920157502
   Coding: 0000258
   VCID: 36634CE74139C7F108-8062
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: Long Coding
   Subsystem 1 - Part No: 3C0 959 433 R
   Subsystem 2 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Subsystem 3 - Component:       NGS n.mounted
   Subsystem 4 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.       Labels: 1K0-959-702-MIN3.lbl
   Control Module Part Number: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component and/or Version: J387  TUER-SG BT    1517
   Software Coding: 0000180
   Work Shop Code: WSC 05311 000 00000
   VCID: 70EFBAFF63DDA9C112-8024
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   008       Serial number: 00000000051009
   Coding: 0000057
   VCID: 285F929F9B8DA1018A-807C
   Component: AFS-Steuergeraet    0133
   Coding: 2311425
   Shop #: WSC 00871 461 181337
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000452752
   Coding: 0000144
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000474331
   Coding: 0000144
   VCID: 71E9BFFB68D7A0C91D-8024
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730     HW: 1K8 035 730
   Component: Telefon       H06 3100
   Revision: 00006000    Serial number: 20387920007064
   Coding: 012100
   VCID: 66C3DCA79119777178-8032
End-------------------------(Elapsed Time: 03:56)--------------------------
;SW:03L-997-384-H   HW:03L-907-309 ---  Engine
;Component:R4 2,0L EDC G001AG  0593, Coding:0000078
;Wednesday,15,February,2017,14:09:12:32442
;VCDS Version: Release 17.1.2  Data version: 20170131 DS267.1
;VCID: 3F8D29C36E0306B9DB-806A
Group,Field 1,Data type,Field 2,Data type,Field 3,Data type,Field 4,Data type,
1,0 /min,RPM,0.0 mg/str,Inj. Quantity,8.0 bar,Pressure,52.2°C,Temperature,
2,0 /min,RPM,0.0 %,Load, 0 00  0,Bin. Bits,52.2°C,Temperature,
3,0 /min,RPM,650.0 mg/str,Mass Air / Rev.,0.0 mg/str,Mass Air / Rev.,100.0 %,Load,
4,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),8.0 bar,Pressure,
5,0 /min,RPM,0.0 mg/str,Inj. Quantity,1.0,(no units),52.2°C,Temperature,
6,0.0 km/h,Speed,00101100,Bin. Bits,0.0 km/h,Speed,10000001,Bin. Bits,
7,25.2°C,Temperature,43.2°C,Temperature,18.9°C,Temperature,52.2°C,Temperature,
8,0 /min,RPM,93.0 Nm,Torque,0.0 Nm,Torque,615.0 Nm,Torque,
9,0 /min,RPM,-1280.0 Nm,Torque,615.0 Nm,Torque,0.0 Nm,Torque,
10,0.0 mg/str,Mass Air / Rev.,1030.2 mbar,Absolute Pres.,1020.0 mbar,Absolute Pres.,0.0 %,Load,
11,0 /min,RPM,1020.0 mbar,Absolute Pres.,1020.0 mbar,Absolute Pres.,9.8 %,Load,
12,01010000,Bin. Bits,0.00 s,Time,12.01 V,Voltage,52.2°C,Temperature,
13,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,
15,0 /min,RPM,-150.0 Nm,Torque,0.00 l/h,Fuel Consump.,93.0 Nm,Torque,
16,0.0 %,Lambda,00011100,Bin. Bits,0.0,(no units),12.01 V,Voltage,
17,77.0,(no units),0.01,(no units), , , , ,
18,0 /min,RPM,25.2°C,Temperature,0.0,(no units), , ,
19,0 /min,RPM,226.95,(no units),0.0 bar,Pressure,15872.0, ,
20,0 /min,RPM,240.0 bar,Pressure,8.0 bar,Pressure,7.9 %,Lambda,
21,0 /min,RPM,240.0 bar,Pressure,8.0 bar,Pressure,15.0 %,Lambda,
22,0 /min,RPM, 0001000,Bin. Bits, 0000000,Bin. Bits, 0111000,Bin. Bits,
23,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),3.0,(no units),
24,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),8.0 bar,Pressure,
25,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),8.0 bar,Pressure,
26,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),8.0 bar,Pressure,
27,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),8.0 bar,Pressure,
28,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),8.0 bar,Pressure,
29,0 /min,RPM,0.0 °BTDC,Ign. Timing,0.0,(no units),8.0 bar,Pressure,
30,0.684 V,Voltage,0.304 V,Voltage, 0 00  0,Bin. Bits,0.0 %,Load,
31,EBD8,Voltage,
32,0 /min,RPM,1020.0 mbar,Absolute Pres.,1020.0 mbar,Absolute Pres.,4.7 %,Lambda,
33,0 /min,RPM,18.0°C,Temperature,1.00,(no units),1.00,(no units),
34,0 /min,RPM,9.8 %,Load,11.0 %,Lambda,4.7 %,Lambda,
35,0 /min,RPM,650.0 mg/str,Mass Air / Rev.,0.0 mg/str,Mass Air / Rev.,100.0 %,Load,
36,0 /min,RPM,100.0 %,Load,99.4 %,Lambda,0.0 %,Lambda,
38,0 /min,RPM,100.0 %,Load,98.6 %,Lambda,0.0 %,Lambda,
39,0 /min,RPM,0.0 mg/str,Mass Air / Rev.,18.9°C,Temperature,0.0 %,Lambda,
40,0 /min,RPM,100.0 %,Load,100.2 %,Lambda,0.0 %,Lambda,
41,200 ohms,Resistance,0.000 V,Voltage,0.01,(no units),0.0,(no units),
42,0.01,(no units),1.6 %,Lambda,3.300 V,Voltage,25.40,(no units),
43,0.0,(no units),0.0°C,Temperature,00000000,Bin. Bits,0.000 V,Voltage,
44,0 /min,RPM,11001000,Bin. Bits,0.0,(no units),0.0,(no units),
45,52.2°C,Temperature,0.0 %,Load,9.5 %,Lambda,0.0 %,Lambda,
46,0.0°C,Temperature,52.2°C,Temperature,18.0°C,Temperature,00000001,Bin. Bits,
47,94.5°C,Temperature,18.0°C,Temperature,0.0 %,Load,9.5 %,Lambda,
48,0 /min,RPM,5865 /min,RPM,       1,Bin. Bits,1270.0 Nm,Torque,
50,0 /min,RPM,0.0 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,      10,Bin. Bits,
51,0 /min,RPM,0 /min,RPM,1.0,(no units),0.0°KW,Idle Stabilization,
52,0 /min,RPM,0xFF00,Hex Value,0xFF00,Hex Value,21.6°C,Temperature,
53,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,00000100,Bin. Bits,
54,1.0,(no units),1311 /min,RPM,25.8 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,
57,0 /min,RPM,0.0 km/h,Speed,0.0 %,Duty Cycle, , ,
59,0 /min,RPM,-150.0 Nm,Torque,33.0 Nm,Torque,0.0 Nm,Torque,
60,33.0 Nm,Torque,-36.0 Nm,Torque,0.0 Nm,Torque,0.0 %,Lambda,
61,0 /min,RPM,43.2°C,Temperature,0.0 mm,Content,51.0 mm,Content,
62,0 /min,RPM,0.0 mg/str,Inj. Quantity,0.0,(no units),0.0,(no units),
63,0 /min,RPM,0 /min,RPM,0 /min,RPM,0 /min,RPM,
69,01011010,Bin. Bits,00000011,Bin. Bits,01011010,Bin. Bits,00000011,Bin. Bits,
70,01011010,Bin. Bits,00000011,Bin. Bits, , , , ,
71,11111111,Bin. Bits, , , , , , ,
72,4.00,(no units),1.00,(no units),8.00,(no units), , ,
73,7.00,(no units),2.00,(no units),10.00,(no units), , ,
74,-4.00,(no units),-3.00,(no units),-2.00,(no units), , ,
75,7.00,(no units),3.00,(no units),3.00,(no units), , ,
80,BPG-810 20.06.08 13H01--- 1312 0246, ,
81,WVWZZZ3CZ9E026223 VWZCZ000000000        , ,
82,8133746100817 10.12.12 78       79  <>  , ,
85,213100 km,Mileage,18,Count,3708,Count,14131,Count,
86,11110000,Bin. Bits,10110110,Bin. Bits,11100000,Bin. Bits,11111111,Bin. Bits,
87,11111111,Bin. Bits,11111111,Bin. Bits,11111111,Bin. Bits, , ,
89,00000000,Bin. Bits,00001110,Bin. Bits,10100000,Bin. Bits,10100000,Bin. Bits,
90,0 /min,RPM,0.0 mg/str,Inj. Quantity,650.0 mg/str,Mass Air / Rev.,00000000,Bin. Bits,
91,323.85,(no units),-326.40,(no units),650.0 mg/str,Mass Air / Rev.,323.85,(no units),
93,00000000,Bin. Bits,3.97,(no units),0.0,(no units),0.0,(no units),
95,00000000,Bin. Bits,00000001,Bin. Bits,0.0,(no units), , ,
96,00000000,Bin. Bits,      00,Bin. Bits,00000000,Bin. Bits,12.01 V,Voltage,
97,-41 mbar,Pressure,-41 mbar,Pressure, , , , ,
99,0 /min,RPM,18.0°C,Temperature, , , , ,
100,90.0°C,Temperature,30.0°C,Temperature,-44 mbar,Pressure,-41 mbar,Pressure,
101,0 /min,RPM,0.0,(no units),0.0,(no units),0.0,(no units),
102,00000000,Bin. Bits,00000001,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,
103,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,
104,0xFF01,Hex Value,0xFF10,Hex Value,00001000,Bin. Bits,00000000,Bin. Bits,
105,00000000,Bin. Bits,9.0,(no units),78.0°C,Temperature,0.0,(no units),
106, , ,68.9 l,Tank Cont.,2550 km,Mileage,3060.0,(no units),
107,45.0, ,39.9, ,24.0, , , ,
108,0 ml,milliliters,50.1, ,0.0, , , ,
110, , ,00000110,Bin. Bits,0.0 km/h,Speed, , ,
111,0 /min,RPM,0.0 km/h,Speed,0.00,(no units),0.0,(no units),
112,0.00,(no units),850.0 Nm,Torque,-1280.0 Nm,Torque,0.0 Nm,Torque,
113,00000110,Bin. Bits,0.0,(no units),0.0,(no units),0.0,(no units),
114,255.0,(no units),255.0,(no units),0.00,(no units),0.00,(no units),
117,0.0 %,Lambda,18.0°C,Temperature,10011110,Bin. Bits,00000000,Bin. Bits,
120,-3.9 %,Lambda,3.2 %,Lambda,00000000,Bin. Bits,3.800 V,Voltage,
121,7.1 %,Lambda,-5.5 %,Lambda,00000100,Bin. Bits,0.988 V,Voltage,
123,0.8 %,Lambda,00000100,Bin. Bits,00000010,Bin. Bits,0.684 V,Voltage,
124,-0.8 %,Lambda,0.0 %,Lambda,00000100,Bin. Bits,4.560 V,Voltage,
125,Transm. 1, ,ABS 1, ,Instruments 1, ,Airbag 1, ,
126,HVAC 1, , , , , , , ,
127, , , , , , ,St. Wheel 1, ,
128,Gateway 1, , , , , ,Park Brake 1, ,
166,4.06,(no units),4.03,(no units),4.19,(no units),4.13,(no units),
214,-6.0°C,Temperature,-6.0°C,Temperature,-6.0°C,Temperature, , ,
225,0.0,(no units),0.0,(no units),0.0,(no units),5.0,(no units),
226,0.0,(no units), , ,0.0,(no units),0.0,(no units),
227,0.0,(no units),0.0,(no units),0.0,(no units),0.0,(no units),
228,0.0,(no units),0.0,(no units),0.0,(no units),0.0,(no units),
229, , , , ,0.0,(no units),0.0,(no units),
;Wednesday,15,February,2017,14:09:46:32442
Channel,,Field 1,Field 2,Field 3,Field 4,
01,,ERROR:,Security,access,required,
02,,ERROR:,Security,access,required,
03,,ERROR:,Security,access,required,
04,,ERROR:,Security,access,required,
05,,ERROR:,Security,access,required,
06,,ERROR:,Security,access,required,
07,,ERROR:,Security,access,required,
08,,ERROR:,Channel 08,Not,Available,
09,,ERROR:,Channel 09,Not,Available,
10,,ERROR:,Channel 10,Not,Available,
11,,ERROR:,Channel 11,Not,Available,
12,,ERROR:,Channel 12,Not,Available,
13,,ERROR:,Security,access,required,
14,,ERROR:,Security,access,required,
15,,ERROR:,Security,access,required,
16,,ERROR:,Security,access,required,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,300, , , , ,
21,300, , , , ,
22,300, , , , ,
23,200, , , , ,
24,200, , , , ,
25,0, , , , ,
26,0, , , , ,
27,,ERROR:,Channel 27,Not,Available,
28,,ERROR:,Channel 28,Not,Available,
29,,ERROR:,Channel 29,Not,Available,
30,,ERROR:,Channel 30,Not,Available,
31,,ERROR:,Channel 31,Not,Available,
32,,ERROR:,Channel 32,Not,Available,
33,,ERROR:,Channel 33,Not,Available,
34,,ERROR:,Channel 34,Not,Available,
35,,ERROR:,Channel 35,Not,Available,
36,,ERROR:,Channel 36,Not,Available,
37,,ERROR:,Channel 37,Not,Available,
38,,ERROR:,Channel 38,Not,Available,
39,,ERROR:,Channel 39,Not,Available,
40,,ERROR:,Channel 40,Not,Available,
41,,ERROR:,Channel 41,Not,Available,
42,,ERROR:,Channel 42,Not,Available,
43,,ERROR:,Channel 43,Not,Available,
44,,ERROR:,Channel 44,Not,Available,
45,,ERROR:,Channel 45,Not,Available,
46,,ERROR:,Channel 46,Not,Available,
47,,ERROR:,Channel 47,Not,Available,
48,,ERROR:,Channel 48,Not,Available,
49,,ERROR:,Channel 49,Not,Available,
50,,ERROR:,Security,access,required,
51,,ERROR:,Channel 51,Not,Available,
52,,ERROR:,Channel 52,Not,Available,
53,,ERROR:,Channel 53,Not,Available,
54,,ERROR:,Channel 54,Not,Available,
55,,ERROR:,Channel 55,Not,Available,
56,,ERROR:,Channel 56,Not,Available,
57,,ERROR:,Channel 57,Not,Available,
58,,ERROR:,Channel 58,Not,Available,
59,,ERROR:,Channel 59,Not,Available,
60,,ERROR:,Channel 60,Not,Available,
61,,ERROR:,Channel 61,Not,Available,
62,,ERROR:,Channel 62,Not,Available,
63,,ERROR:,Channel 63,Not,Available,
64,,ERROR:,Channel 64,Not,Available,
65,,ERROR:,Channel 65,Not,Available,
66,,ERROR:,Channel 66,Not,Available,
67,,ERROR:,Channel 67,Not,Available,
68,,ERROR:,Channel 68,Not,Available,
69,,ERROR:,Channel 69,Not,Available,
70,,ERROR:,Channel 70,Not,Available,
71,8SZR6SH, , , , ,
72,81HZ7II, , , , ,
73,8AHX6IG, , , , ,
74,AAAEDSI, , , , ,
75,,ERROR:,Channel 75,Not,Available,
76,,ERROR:,Channel 76,Not,Available,
77,,ERROR:,Channel 77,Not,Available,
78,,ERROR:,Channel 78,Not,Available,
79,,ERROR:,Channel 79,Not,Available,
80,,ERROR:,Channel 80,Not,Available,
81,,ERROR:,Channel 81,Not,Available,
82,,ERROR:,Channel 82,Not,Available,
83,,ERROR:,Channel 83,Not,Available,
84,,ERROR:,Channel 84,Not,Available,
85,,ERROR:,Channel 85,Not,Available,
86,,ERROR:,Channel 86,Not,Available,
87,,ERROR:,Channel 87,Not,Available,
88,,ERROR:,Channel 88,Not,Available,
89,,ERROR:,Channel 89,Not,Available,
90,,ERROR:,Channel 90,Not,Available,
91,4, , , , ,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,,ERROR:,Channel 99,Not,Available,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
102,,ERROR:,Channel 102,Not,Available,
103,,ERROR:,Channel 103,Not,Available,
104,,ERROR:,Channel 104,Not,Available,
105,,ERROR:,Channel 105,Not,Available,
106,,ERROR:,Channel 106,Not,Available,
107,,ERROR:,Channel 107,Not,Available,
108,,ERROR:,Channel 108,Not,Available,
109,,ERROR:,Channel 109,Not,Available,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,0, , , , ,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,0,-3.9 %,3.2 %,00000000,3.800 V,
121,0,7.1 %,-5.5 %,00000100,0.912 V,
122,,ERROR:,Channel 122,Not,Available,
123,0,0.8 %,00000100,00000010,0.684 V,
124,0,-0.8 %,0.0 %,00000100,4.560 V,
125,,ERROR:,Channel 125,Not,Available,
126,,ERROR:,Channel 126,Not,Available,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Security,access,required,
129,,ERROR:,Security,access,required,
130,,ERROR:,Security,access,required,
131,,ERROR:,Security,access,required,
132,,ERROR:,Security,access,required,
133,,ERROR:,Security,access,required,
134,,ERROR:,Security,access,required,
135,,ERROR:,Security,access,required,
136,,ERROR:,Security,access,required,
137,,ERROR:,Security,access,required,
138,,ERROR:,Security,access,required,
139,,ERROR:,Security,access,required,
140,,ERROR:,Security,access,required,
141,,ERROR:,Security,access,required,
142,,ERROR:,Security,access,required,
143,,ERROR:,Security,access,required,
144,,ERROR:,Security,access,required,
145,,ERROR:,Security,access,required,
146,,ERROR:,Security,access,required,
147,,ERROR:,Security,access,required,
148,,ERROR:,Security,access,required,
149,,ERROR:,Security,access,required,
150,,ERROR:,Security,access,required,
151,,ERROR:,Security,access,required,
152,,ERROR:,Security,access,required,
153,,ERROR:,Security,access,required,
154,,ERROR:,Security,access,required,
155,,ERROR:,Security,access,required,
156,,ERROR:,Security,access,required,
157,,ERROR:,Security,access,required,
158,,ERROR:,Security,access,required,
159,,ERROR:,Security,access,required,
160,,ERROR:,Security,access,required,
161,,ERROR:,Security,access,required,
162,,ERROR:,Security,access,required,
163,,ERROR:,Security,access,required,
164,,ERROR:,Security,access,required,
165,,ERROR:,Security,access,required,
166,,ERROR:,Security,access,required,
167,,ERROR:,Security,access,required,
168,,ERROR:,Security,access,required,
169,,ERROR:,Security,access,required,
170,,ERROR:,Security,access,required,
171,,ERROR:,Security,access,required,
172,,ERROR:,Security,access,required,
173,,ERROR:,Security,access,required,
174,,ERROR:,Security,access,required,
175,,ERROR:,Security,access,required,
176,,ERROR:,Security,access,required,
177,,ERROR:,Security,access,required,
178,,ERROR:,Security,access,required,
179,,ERROR:,Security,access,required,
180,,ERROR:,Security,access,required,
181,,ERROR:,Security,access,required,
182,,ERROR:,Security,access,required,
183,,ERROR:,Security,access,required,
184,,ERROR:,Channel 184,Not,Available,
185,,ERROR:,Channel 185,Not,Available,
186,,ERROR:,Channel 186,Not,Available,
187,,ERROR:,Channel 187,Not,Available,
188,,ERROR:,Channel 188,Not,Available,
189,,ERROR:,Channel 189,Not,Available,
190,,ERROR:,Channel 190,Not,Available,
191,,ERROR:,Security,access,required,
192,,ERROR:,Security,access,required,
193,,ERROR:,Security,access,required,
194,,ERROR:,Security,access,required,
195,,ERROR:,Security,access,required,
196,,ERROR:,Security,access,required,
197,,ERROR:,Security,access,required,
198,,ERROR:,Security,access,required,
199,,ERROR:,Security,access,required,
200,,ERROR:,Security,access,required,
201,,ERROR:,Channel 201,Not,Available,
202,,ERROR:,Security,access,required,
203,,ERROR:,Security,access,required,
204,,ERROR:,Security,access,required,
205,,ERROR:,Security,access,required,
206,,ERROR:,Security,access,required,
207,,ERROR:,Security,access,required,
208,,ERROR:,Security,access,required,
209,,ERROR:,Security,access,required,
210,,ERROR:,Security,access,required,
211,,ERROR:,Security,access,required,
212,,ERROR:,Security,access,required,
213,,ERROR:,Security,access,required,
214,,ERROR:,Security,access,required,
215,,ERROR:,Security,access,required,
216,,ERROR:,Security,access,required,
217,,ERROR:,Security,access,required,
218,,ERROR:,Channel 218,Not,Available,
219,,ERROR:,Security,access,required,
220,,ERROR:,Security,access,required,
221,,ERROR:,Security,access,required,
222,,ERROR:,Security,access,required,
223,,ERROR:,Security,access,required,
224,,ERROR:,Security,access,required,
225,,ERROR:,Security,access,required,
226,,ERROR:,Security,access,required,
227,,ERROR:,Security,access,required,
228,,ERROR:,Security,access,required,
229,,ERROR:,Security,access,required,
230,,ERROR:,Security,access,required,
231,,ERROR:,Security,access,required,
232,,ERROR:,Security,access,required,
233,,ERROR:,Security,access,required,
234,,ERROR:,Security,access,required,
235,,ERROR:,Security,access,required,
236,,ERROR:,Security,access,required,
237,,ERROR:,Security,access,required,
238,,ERROR:,Security,access,required,
239,,ERROR:,Security,access,required,
240,,ERROR:,Security,access,required,
241,,ERROR:,Security,access,required,
242,,ERROR:,Security,access,required,
243,,ERROR:,Security,access,required,
244,,ERROR:,Security,access,required,
245,,ERROR:,Security,access,required,
246,,ERROR:,Security,access,required,
247,,ERROR:,Security,access,required,
248,,ERROR:,Security,access,required,
249,,ERROR:,Security,access,required,
250,,ERROR:,Security,access,required,
251,,ERROR:,Security,access,required,
252,,ERROR:,Security,access,required,
253,,ERROR:,Security,access,required,
254,,ERROR:,Security,access,required,
255,,ERROR:,Security,access,required,
I think that was 03L-906-022-CL before the VW flash to 03L-997-384-H
REDIRECT,03L-906-022-CBA.LBL,03L-906-022-CL ; CBAB (35/3C) Current
REDIRECT,03L-906-022-CBA.LBL,03L-997-384-H ; CBAB (35/3C) Proposed
We should be able to redirect that to the CBA lbl for you. Ref to FS#1312
In the meanwhile the G450 proceed is here
http://wiki.ross-tech.com/wiki/index.php/2.0L_CR_TDI
and you'd use Login code 30605 = Exhaust Gas Differential Pressure Sensor (G450) Adaptation.
I don't think the DPF will regen with that Intake Manifold Flap Position Sensor DTC but Security Access code 12233 = Adaptation Enabling (e.g. DPF/NOx Regeneration while Driving) is used in conjunction with Adp channel 013. SA code 27971 = Basic Setting Enabling (e.g. Regeneration while Standing) is used in conjunction with BS 226.
MartinsX
Riga, Latvia
C?ID=268515
Hi, Dana!
Thanks for quick response!
How can I redirect VCDS to use another label file for this ECU? Or You will send some modified *.clb file to me?
I have already replaced G450 and adapted the new one with Bosch KTS, now it shows -3mbar/-3mbar in MVB 100/3 and 100/4 @ condition ignition on/engine off.
I guess I will be able to run DPF regeneration as the Intake Manifold Flap Position Sensor DTC is intermittent and does not come back, at least while idling.
Do You know, may the DTC 009754 - Coolant Pump 2 P261A - 000 - Open circuit - Intermittent prevent the DPF regeneration, too? This fault is present all the time.
One more question - is this ECU supporting DPF regeneration while standing, too? Or only driving type regeneration is possible?
Edit: Just noticed edited Dana's post, last question is answered already :)
I don't know if Seb's available today for a custom redirect but I can make you one. I'll send it off via e-mail shortly.
I'm not sure about that coolant pump DTC. Sometime those don't trigger a MIL at all (like brake vacuum booster elect pump DTCs) and if that's the case you may be OK avoiding repairs. If it won't cooperate I would be tempted to locate the coolant motor connector and make sure coolant didn't migrate into the wiring before sourcing another pump.
MartinsX
Riga, Latvia
C?ID=268515
27971 is accepted, after Brake/Accelerator pedal combination VCDS shows Basic setting is on, but nothing happens (rpm are like idle, group 226 shows values 226/1 = 120 degrees, 226/2 = 114 degrees, 226/3 = 0.0, 226/4 = 00000010
No changes for almost 10 minutes.
Stored faults at the moment:
Wednesday,15,February,2017,17:44:13:32442
VCDS Version: Release 17.1.2 Running on Windows XP x86
                Address 01: Engine       Labels: NONE
Control Module Part Number: 03L 997 384 H    HW: 03L 907 309
  Component and/or Version: R4 2,0L EDC G001AG  0593
           Software Coding: 0000078
            Work Shop Code: WSC 00011 888 181093
                    Mileage: 213108 km
                    Date: 2017.02.13
                    Time: 17:34:59
                    RPM: 782 /min
                    Pressure: 5 mbar
                    Hex Value: 0xFF04
                    Temperature: 132.0°C
                    (no units): 51.0
                    Mileage: 2550 km
               P261A - 000 - Open circuit - MIL ON
                    Mileage: 213108 km
                    Date: 2017.02.13
                    Time: 17:34:59
Readiness: 1 2 0 0 1
Check your e-mail please.
I would try a forced regen while driving since the standing isn't working out. MVBs 099-108 should include DPF data while logging/driving.
MartinsX
Riga, Latvia
C?ID=268515
Thanks!
Got mod for label redirect, it works.
Regen while standing probably is not starting because of too big soot amount (calculated/measured). Will try driving cycle tomorrow, today it is too late - it's getting dark on the street and traffic jams are starting as everyone drives home from work at this time.
P.S. Do anyone has explanation of zero's and one's at 226/4 = 00000010 in basic settings mode?
MartinsX
Riga, Latvia
C?ID=268515
On third attempt regeneration while driving was successful, DPF warning lamp went off, DTC cleared.
Representative of workshop, who brought this car to me, is warned, that intake manifold flaps and electric coolant pump must be repaired to make engine work normally.
Thursday,16,February,2017,14:35:09:32442
          77
VIN: WVWZZZ3CZ9E026223   Mileage: 213210km-132482miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Coding: 0000078
                    Mileage: 213212 km
                    Date: 2017.02.14
                    Time: 14:31:12
                    RPM: 759 /min
                    Voltage: 13.98 V
                    Lambda: 78.9 %
                    Bin. Bits: 10010111
                    Bin. Bits: 00000000
                    Temperature: 65.7°C
                    Fault Status: 10100000
                    Mileage: 213212 km
                    Date: 2017.02.14
                    Time: 14:31:12
Readiness: 1 1 0 0 1
   Coding: 0000277
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 00208936
   Shop #: WSC 05124
                    Reset counter: 6
                    Mileage: 213108 km
                    Date: 2017.02.13
                    Time: 14:38:00
                    Voltage: 13.10 V
                    Reset counter: 6
                    Mileage: 213108 km
                    Date: 2017.02.13
                    Time: 14:38:00
                    Reset counter: 6
                    Mileage: 213108 km
                    Date: 2017.02.13
                    Time: 14:31:00
                    Voltage: 12.15 V
   Coding: 0012341
   Coding: 0001112
   Coding: 0007105
   Coding: 0000181
   Coding: 0000258
   Coding: 0091020051030E763004941570084F0E707801
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1517
   Revision: 72009005    Serial number: 00000520588614
   Coding: 0000180
   Coding: 0000057
   Coding: 2311425
   Coding: 00000035
   Coding: 00000035
   Coding: 0000144
   Coding: 0000144
   Coding: 012100
End-------------------------(Elapsed Time: 02:37)--------------------------
