V10 doesn't start
   #61
Larry Manton
C?ID=112505
You got burned once by that garage, were you expecting any different this time? Pushing this issue for an immediate fix won't happen as it requires digging and perseverance, its not a common issue so you are your own saviour here.
Then this 23 year old (30 years experience) confessed
Feel your pain as have been following this, but the 30 years exp was the 'BEST" I'm not laughing @ you but you have to make the best of that line.:banghead:
Larrymore
   #62
NostraJackAss
Nope sorry this is a routine issue with TOW-RIG and Q7 taking on water ingress........
"Customer states" line is equally important to observe.
Vehicle drove through car wash twice and then died........hmmmm
This is why JPPSG!
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
   #63
tuningbyamg
Canada
C?ID=230173
I get what you're trying to say Jack, i'm on my 4th Touareg and currently own 3. None of them failed to start after a car wash but the facts are presented to us and we can only make educated guesses with the info provided.
   #64
NostraJackAss
   #65
tuningbyamg
Canada
C?ID=230173
Better spoken than me Jack :thanks:
   #66
Harris
North Carolina, USA
C?ID=296109
Here is some of the dialog i've had outside forum but feel it's pertinent to the thread. Hello Jack I've got a V10 Touareg and was interested in how your services might help?
Helpful Tip guide and gathering of information to help you!
Jacks Professional Problem Solver Guide. "JPPSG"
Make/ Model/ Year/ Edition
Step 1 Tag of PR-Build data picture posted ???? This is located in trunk/spare tire area and in first page of service book.
Step 2 Status of car stock or modified in any way? If so list! ????
Step 3 VAS/ODIS OEM or "VCDS" COMPLETE Auto-Scan in code tags!
Step 4 Describe recent repairs or services, problem at hand, & attempts at repair.?????
Step 5 Are parts OEM or AFT? If so, "what", and what origin?????
Step 6 Identify specific issues to be addressed/concerned about, or say ALL?
Step 7 Verify if campaigns for recall, TSB, Service Action exist for any conditions related to problem.
Step 8 Now that you jumped through the first few hoops of fire, did you check the FUSES/Battery connections?
Good Information Guideline.
1 Focus discussion on symptom description!
2 Ask questions that clarify what, when, where, & frequency.
3 Summarize your understanding & get agreement from colleagues.
4 Explain what you will do to proceed, & get my acknowledgement.
5 Do you have a proper repair manual? If not get one! www.erwin.vw.com or www.erwin.audi.com
6 Do you know how to read a schematic? If not see "How to read WD section in...... RTFB! "
7 Check part numbers are accurate, & firmware versions of OEM scanner----VCDS + respective controllers are of latest firmware release.
8 Did you check CHARGING SYSTEM HEALTH, BATTERY & FUSES "YET"?
Diagnosing, Brain storming, & the Final Solution!
1 Describe problem ( List known symptoms ) Nix opinions or disguised solutions
2 Verify & Analyze ( Duplicate if possible, & list possible causes...... RTFB! the trouble tree, TSB's & for FOD is an MIL ON or pending?
Further..... FOD for hardware, & or electronically modified firmware/software/emissions defeat/delete devices is essential now...... "do not negate this"!
Look for any discrepancies in codification when compared to other modules.
Actually review Time Stamps Miles and the information made available in a DTC, ......such as a G or N destinations and use as a search criteria in WD for familiarization!
3 Locate the problem ( Prioritize and identify work times + safety limits, or the use of chemicals & tool requirements )
4 Repair the Problem ( Determine the cause & not just treat an effect! )
5 Conduct a quality Check of your work and verify you fixed it!
IF ANY OF THE ABOVE IS TOO MUCH TO COMPLY WITH, YOU SHOULD CONSIDER SEEKING A PROFESSIONAL SHOP VISIT.
Computer repair and or swaps:Cores are required in advance, even if flooded for CP transfer and config verification.
I supply a forensic examination report of the old unit, which in some cases, could help aid a tech with a repair before install of a new, or reconditioned unit.
ECU's fail usually for an underlined condition, such as short, flood, ground condition, or supply voltage issue.
If not corrected beforehand, you will ultimately damage a new unit.
Jack Shapiro E.P.E.
VAS>Geko ASE Extern 7076062 NYS DMV SAE>NASTF
European Parts Emporium
Immobilizer Solutions
1001 State Route 17K
Montgomery New York 12549 USA
vwemporium@aol.com
845-457-9808 TEL/FAX
845-784-0335 Net
   #67
NostraJackAss
I am following up scenario's on this and what I see in the J518.....+ what was not discussed.
   #68
tuningbyamg
Canada
C?ID=230173
Get it started yet? How bad is the damage on the ECM?
   #69
ivagp
C?ID=95551
   #75
NostraJackAss
Did you isolate the trucks ecus after correction of the terminal 15 fault and other shorted consumers?
I have been waiting myself to hear about this.
   #76
ivagp
C?ID=95551
I replaced a block if it makes you happy :D
the hell with replacing a block if u can just drop the motor with out killing yourself ill take my hat off. great job amg
   #78
Harris
North Carolina, USA
C?ID=296109
Here is my latest autoscan. Vehicle still not starting. Current tally $6000 sunk
Wednesday,03,May,2017,17:06:47:02409
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
VIN: WVGPT77L57D009872   License Plate: HARRIS
Mileage: 146662mi   Repair Order: 0000001
Chassis Type: XX (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
   Part No SW: 070 906 016 CQ    HW: 028 101 196 2
   Component: V10 5,0L EDCG001AGMª9805
   Revision: --H02---    Serial number: XXXXXXXXXXXXXX
   Coding: 0060575
   Shop #: WSC 03738 444 38140
   VCID: 619CAF04FD593C9F427-5160
8 Faults Found:
001540 - Internal Control Module
               P0604 - 000 - RAM Error - MIL ON
013111 - Engine-Engine Databus
               P3337 - 000 - Implausible Message - MIL ON
006407 - Engine Databus
               P1907 - 000 - ECU<->ECU Communications Fault
004373 - Oxygen (Lambda) Sensor Heating: B1 S1
               P1115 - 000 - Short to Ground
005696 - Internal Control Module
               P1640 - 000 - EEPROM Error
005377 - Fuel Pump Relay (J17)
               P1501 - 000 - Short to Ground
012547 - Motor for Intake Manifold Flap (V157)
               P3103 - 000 - Malfunction - MIL ON
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
   Component: AL 750 6A           0856
   Revision: 00H51000    Serial number:
   Coding: 0004216
   Shop #: WSC 31414 000 00000
   VCID: 7F58097C6BEDEA6F543-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   VCID: 3D2433742161387F06F-5160
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 135 A    HW: 5WK 485 01
   Component:    Kessy            6700
   Revision: 67006015    Serial number: VWZ3Z0F2502801
   Coding: 0000232
   VCID: 2F38193CFB0DDAEF843-5160
Address 08: Auto HVAC        Labels: 7L6-907-044.clb
   Part No: 7L6 907 044 AB
   Component: CLIMAtronic 2+2     4325
   Coding: 0020030
   Shop #: WSC 25807 128 68113
   VCID: 74B2D65052ABB937391-5160
   Subsystem 1 - Part No: 7L6 907 049 E
   Component: CLIMAtronic FOND    0400
02599 - Rear Left Temperature Flap Motor (V313)
00362 - Rear Left Air Flap Motor (V239)
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3002
   Coding: 0110815
   VCID: 47C8519C73BD62AFAC3-5160
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG001AGSª9805
   Coding: 0060575
000151 - Intake Air Temperature Sensor 2 (G299)
               P0097 - 000 - Signal too Low
   Part No: 3D0 909 601 L
   Component: 03 Airbag 8.4E++H02 0662
   Revision: BB62060     Serial number: 0000199>
   Coding: 0012339
   Shop #: WSC 06485 444 10329
   VCID: 2C020E30CA1BA1F7A11-5160
   Subsystem 1 - Part No: 7L0 959 339 C
   Component: BF-Gewichtsens. 006 0008
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 H
   Coding: 0010031
   VCID: 44D24690428B49B7491-5160
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 981 R
   Component: KOMBIINSTRUMENT RB8 3211
   Coding: 0007231
   VCID: 48CA52A07EA36DD7A59-5160
Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
   Part No: 7L6 815 071 D
   Component: Standheizung E1MAC
   Coding: 0000100
   VCID: 3330154C1725FE0FE0B-5160
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70BADA4026B38517DD9-5160
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   VCID: 45D45B9449B170BF5EF-5160
00926 - Terminal 30
   Part No: 0AD 927 755 AT
   Component: TRANSFERCASE        0114
   VCID: 0D44A3B45141C8FF56F-5160
Address 32: Differential Locks        Labels: None
   Part No: 0AC 927 771 C
   Component: SG-Quersperre       5020
   VCID: 382A22600E431D57D59-5160
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 H
   Component: LUFTFDR.-CDC- 3C3P1 3099
   Coding: 0015521
   Part No: 7L0 959 760
   Component: Sitzverstellung     0702
   VCID: 77A8E15C43DDD22F1C3-5160
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 H
   Component: YM HSG              0400
   Coding: 0000085
   VCID: 41DC4F845D995C9F627-4B1E
   Subsystem 1 - Part No: 7L0 959 701 G
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 G
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 C
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 C
   Component: Tuersteuergeraet HR 0201
7 Faults Found:
00330 - Signal Rear Wiper Interval
            009 - Open or Short to Ground
Address 47: Sound System        Labels:
   VCID: 55F48BD4BC01C03F2EF-5160
   Note: Excessive Comm Errors
Address 55: Headlight Range        Labels: 7L6-907-357.lbl
   Part No SW: 7L6 907 357     HW: 7L6 907 357
   Component: AFS-Steuergeraet    0003
   Revision:   H09       Serial number:
   Coding: 0000009
   VCID: 78AAE2604EC3DD57159-5160
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000034
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000034
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000341
   Shop #: WSC 31414 000 376832
   VCID: 3C223E703A7B3177311-5160
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     071006 020  0105
   Coding: 00208933
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   Coding: 0000002
   Part No SW: 7L6 907 441     HW: 7L6 907 441
   Component: J772__Rearview      0051
   Revision: 00H07000    Serial number:    PA8 J640552
   Coding: 0000101
   VCID: 72BED04828BFB7072BD-5160
03005 - Video change-over
            013 - Check DTC Memory
02203 - Audio / Video Input 1
Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
   Part No SW: 7L6 959 107     HW: 7L6 959 107
   Component: J605  HECKKLAPPE    1110
   Revision: --H05---    Serial number: --------004007
   Coding: 0022110
03074 - Rear Lid Inclination Sensor (G549)
03277 - Functionality Limited due to Missing Stand-Time Data
            000 -  -
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 T
   Component: DACHDISPLAY         0539
   Revision: 00900539    Serial number: 2009289.07
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 392C27643549045F2A7-5160
End----------(Elapsed Time: 10:26, VBatt start/end: 12.4V/12.3V)-----------
   #79
Harris
North Carolina, USA
C?ID=296109
Not sure what isolate ECUs means? I've tested everything you mentioned before and everything tests good. Currently have the drivers seat removed, back seats removed, rear compartment removed, rear HVAC exposed, rear lid harness removed, there were many broken wires found so i ordered new harness. Old harness removed which explains some of the faults codes in last scan.
   #80
Harris
North Carolina, USA
C?ID=296109
I give up. The second ECU is now showing the same faults as the first ECU. Both units had been recently refurbished.
