Today I was able to get the w/Hex-V2 to communicate w/ two modules - Address 25
Immobilizer) and 05
Access/Start Authority) located under the "electronics 1" section of OPEN CONTROLLERS. AUTO SCAN would fail and never complete. Looks like its a KESSY module issue, anyone??? Does anyone have the security code? Or does anyone know what the correct settings are?
In addition to whats below:
Incorrect synch byte: $0
VBat 12.4v/and VLGN 0.001v w/ no jumper
VBat 09.5v/and VLGN 09.4v w/ jumper cables attached.
Hope this might help me narrow down my troubleshooting!!!
Friday,17,February,2017,13:14:02:02409
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 17.1.3.0 HEX-V2 : 0.4334.4
Data version: 20170203 DS267.2
VIN: WVGPT77L57D009872 License Plate:
Mileage: 146662 Repair Order:
Address 25: Immobilizer Labels: None
Control Module Part Number: 7L0 909 135 A HW: 5WK 485 01
Component and/or Version: Kessy 6700
Software Coding: 0000232
Work Shop Code: 31414 000 00000
Additional Info: 4E0905852E ELV 1940
Additional Info: Geraet 00000
VCID: 2F38193CFB0DDAEF843-5160
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
00164 - Battery Monitoring Control Module (J367) in Emergency Mode
00087 - Terminal 30 for Starting Relevant Consumers
002 - Lower Limit Exceeded
Address 25: DTCs cleared
Address 05: /Start Auth. Labels: None
Advanced Identification
Serial number: VWZ3Z0F2502801
Identification: RBG-SME
Revision: 67006015
Date: 26.06.06
Test stand number: 0001
Manufacturer number: 0156
Software
A04.24
K02.57
Misc.
Hardware number: 5WK 485 01
Car Info
Chassis Number: WVGPT77L57D009872
Info:
Labels: None
Address 05,7L0 909 135 A,recoded (Short coding),from,0000232,to,0000232,(31414/000/00000),
