I have a new to me 2010 Audi A5 Cabriolet. I'm in the process of sorting things out and I'm confused to whether or not this car has a telephone BT or not. Radio will show "Please wait, then Telephone not available" PR code on sticker is 9Q2, no other PR code with a "9". The scan comes up with 01303 code. So if telephone BT module is not installed, why would the scan pick this up? The rear A/C code is because I had console out cleaning coke/coffee out. The passenger seat code is because its dead as a door nail. There's power to the circuit breaker at drivers A pillar. No power at red plug under passenger seat. Probably corroded wire or connector under carpet. Now I have to figure how to get seat out (Seat is all the way back). Thats why I want to find out about the telephone BT module. As long as I have the seat / carpet out to fix seat problem, if BT module is bad Ill replace it at this time.
Tuesday,14,February,2017,21:30:06:01376
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
VIN: WAUJFAFH3AN011663 License Plate:
Chassis Type: FH (8T0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 26 2E 36 42 46 47 52 53 55
56 62 72 77
VIN: WAUJFAFH3AN011663 Mileage: 139180km-86482miles
06-Seat Mem. Pass -- Status: Cannot be reached 1100
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H15 0001
Revision: E1H15---
Coding: 011C010A02070160
Shop #: WSC 03236 001 1048576
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79F864E5F8DC3289AE-802C
Readiness: 0000 0100
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K1 927 155 J HW: 0AW 927 156 H
Component: 0AW 20TAVSUSA H02 0003
Revision: --H02--- Serial number: 0000001085
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMVL381 A02017
ROD: EV_TCMVL381_AU57.rod
VCID: 3B74BEEDB260C099FC-806E
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BT HW: 8K0 907 379 BT
Component: ESP8 front H04 0010
Coding: 080D18
Shop #: WSC 02391 823 56573
VCID: 0C162D31AF4E372185-8058
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DF HW: 8K0 907 064 DF
Component: BCM2 1.1 H02 0324
Coding: 090300
Shop #: WSC 02399 823 56573
VCID: 77FC62DDC6C824F9D8-8022
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000049939020
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000062964003
Address 06: Seat Mem. Pass
Part No SW: 8T1 820 043 AL HW: 8T1 820 043 AL
Component: KLIMA 3 ZONEN H08 0171
Revision: C3000000 Serial number: 01080920091331
Coding: 6403200E
VCID: 7BF47EEDFAE00099BC-802E
00461 - Control Module for Seat Memory; Passenger (J521)
Reset counter: 146
Mileage: 139061 km
Date: 2017.03.08
Time: 19:26:34
03037 - Rear Temperature Selection Potentiometer (G538)
010 - Open or Short to Plus
Reset counter: 146
Mileage: 139061 km
Date: 2017.03.08
Time: 19:26:34
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000455439
Coding: 26001091063CAF010000080000003D3D0F1C528800010161000003
VCID: 3C76BDF1BF6EC7A1F5-8068
Subsystem 1 - Part No SW: 8F1 955 119 HW: 8K1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 200809 H06 0021
Serial number: SWF09080205343
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10591523
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN
Component: E1 - LDS H08 0090
Serial number: 00000000000508090992
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
03456 - Control Module for Left Cabin Heater
Reset counter: 146
Mileage: 139183 km
Date: 2017.03.14
Time: 21:15:00
03457 - Control Module for Right Cabin Heater
Reset counter: 146
Mileage: 139183 km
Date: 2017.03.14
Time: 21:15:00
Address 15: Airbags (J234) Labels: 8F0-959-655.clb
Part No SW: 8F0 959 655 A HW: 8F0 959 655 A
Component: AirbagVW-AU10 H09 0430
Serial number: 003A5D051DY+
Coding: 303737353631303030304A55304C38463053
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 3662AFD989421DF103-8062
Subsystem 1 - Part No SW: 8K0 959 339 HW: 8K0 959 339
Component: BF-Gewichtss. H01 0050
Serial number: 5810000R09000042KF
Serial number: 6334MSME4B537735I
Serial number: 6344MSME4B702428C
Serial number: 6352QSME1A3C102CI
Serial number: 6362QSME7B3B113CR
Serial number: 63732SME4A380D341
Serial number: 63832SME4E38031A0
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315IIE00055
Coding: 000016
VCID: 3D70B0F5A474CEA9C2-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 950 Q HW: 8T0 920 950 Q
Component: KOMBIINSTR. H33 0255
Revision: 00000000 Serial number: CHU32U299
Coding: 8B1619000300D705020000
VCID: 4682DF19F1A28D7193-8012
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G09901827A
Coding: 00C303
VCID: 50AEF94103E653C139-8004
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Serial number: 1908E1C2020909
Reset counter: 146
Mileage: 139183 km
Date: 2017.03.14
Time: 21:16:00
Bin. Bits: 10111
Voltage: 11.60 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 146
Mileage: 139183 km
Date: 2017.03.14
Time: 21:16:00
Address 26: Auto Roof (J256) Labels: 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H12 0190
Coding: 030000
Shop #: WSC 25615 210 01865
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: 71E85CC5A0AC7AC916-8024
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0280
Revision: 00000000
Coding: 020302
VCID: 3978A4E5B05CF289EE-806C
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Part No SW: 8T0 959 760 D HW: 8T0 959 760 D
Component: MEM-FS H10 0073
Revision: AA000000 Serial number: 00001001278888
Coding: C80170250D2400001000
VCID: 4486C511C79EBF618D-8010
Reset counter: 143
Mileage: 139061 km
Date: 2017.03.06
Time: 20:23:10
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009285684
Coding: 011C43724008332C03
VCID: 4580D815CCA486699A-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0121249906
Coding: 010602BA007A442000B0030000000000
Subsystem 1 - Part No SW: 8F0 959 719 HW: 8F0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000159840
Component: LIN BACKUP HO H03 1301
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2200000
Coding: 0203010102
VCID: 74E655D1D7BE4FE1FD-8020
Reset counter: 143
Mileage: 139061 km
Date: 2017.03.08
Time: 19:28:27
Voltage: 11.60 V
Temperature: 33.0°C
Bin. Bits: 00000000
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009290021
Coding: 011C43324008332C03
Reset counter: 183
Mileage: 139061 km
Date: 2017.03.11
Time: 15:56:50
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000448299
VCID: 346695D1973E0FE13D-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Coding: 0000001
VCID: 77FC62DD06C824F9D8-8022
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H04 0351
Revision: 00000006 Serial number: AUZ5Z6I1269501
Coding: 04020002010385004359070800
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Reset counter: 143
Mileage: 139061 km
Date: 2017.03.09
Time: 18:54:24
Reset counter: 143
Mileage: 139061 km
Date: 2017.03.09
Time: 18:54:28
Reset counter: 143
Mileage: 139061 km
Date: 2017.03.09
Time: 18:54:28
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 E HW: 4F0 959 795 L
Component: TSG HL H10 0306
Revision: Serial number: 0000101866992
Coding: 010C03324008372C03
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101866972
Address 77: Telephone
End-------------------------(Elapsed Time: 03:35)--------------------------
