Audi TT ABS coding
stefano82
Italy
C?ID=297173
Hi All,
just mounted on my TT 2015 a couple of 340 mm front brakes from TTS model. Original was 312 mm.
I was wondering if an ABS recoding is necessary to update the brakes size.
The issue is that coding has no long coding helper. Any hint to update this ECU coding ?
Here autoscan, please help me.
Stefano
Tuesday,14,February,2017,14:14:45:58654
VCDS Version: 17.1.3.0  HEX-V2 CB: 0.4334.4
Data version: 20170203 DS267.2
VIN: TRUZZZFV1F100xxxx   License Plate: xxxxxxx
Mileage: xxxxx   Repair Order:
Chassis Type: FV (8S0)
Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A5 A9
Address 01: Engine (J623-CHHC)       Labels: 06K-907-425-V1.clb
   Part No SW: 8S0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 0A1900322424050B3002
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208S0906259 001006
   ROD: EV_ECM20TFS0208S0906259.rod
   VCID: 7AAEF860DC51083763D-802E
Readiness: 1110 0001
   Part No SW: 8S0 907 379 B    HW: 8S0 907 379 B
   Component: ESC           H31 0504
   Revision: 00000000    Serial number: 63094000000178
   Coding: 32AA108D0A9915AF40990067C299930EC44C0850A8020043C97023
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
   ROD: EV_Brake1UDSContiMK100IPB_052.rod
   VCID: 40DA4A88FA0D92E76D9-8014
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0351661254
   Coding: 000F0F1620
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   VCID: 77A8E154EF43155F1C3-8022
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0020
   Revision: 20008000    Serial number: 14070000009000
   Coding: 400040000011101000
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6C82CE38A605A687E11-8038
   Serial number: AD598C57000000000001
   Operating and display unit 2 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H06 0010
   Serial number: 00000000000000002095
   Operating and display unit 3 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H06 0010
   Operating and display unit 4 for air conditioning:
   Subsystem 4 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H06 0010
   Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0136
   Serial number: 01011431504022
   Coding: 04054C42C20106FD43044004001807A80080000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 094C97AC89B713AF7A7-805C
   Subsystem 1 - Part No SW: 8S1 955 119 A    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 140619  032 0371
   Serial number: 00000001406170701496
   Coding: 1BC7F7
   Serial number: 23452498
   Coding: 00005D
   Serial number: 26 09 2014  00001508
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39211432204542
   Coding: 0000040001
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: 3B203D6493EBF13F38B-806E
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    009 0870
   Serial number: 003M7R005EYQ
   Coding: 88CCF0000C8000005C5000CFC04800000065
   VCID: 4DC463BC3D5F4F8F96F-8018
   Subsystem 1 - Part No SW: -----------    HW: 480 001 411 14
   Serial number: 3570000000048BA4B11M
   Subsystem 2 - Part No SW: -----------    HW: 480 001 411 14
   Serial number: 35800000000BFAA4B11-
   Subsystem 3 - Part No SW: -----------    HW: 480 012 909 14
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A01DD52E021F66
   Subsystem 4 - Part No SW: -----------    HW: 480 400 910 14
   Serial number: 3550002AD18166A572B9
   Front Sensor Passenger:
   Subsystem 5 - Part No SW: -----------    HW: 480 400 910 14
   Serial number: 3560002AD18166A3D2BE
   Pedestrian Protection Center:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 411 14
   Component: PedP_Sensor_C  001 6149
   Serial number: 2300002BD1860BC421B1
   Subsystem 7 - Part No SW: -----------    HW: 480 000 210 14
   Serial number: I0M000000006B485311-
   Subsystem 8 - Part No SW: -----------    HW: 480 000 210 14
   Serial number: I0N00000000A4485311Y
   Part No SW: 8S0 907 129 AC    HW: 8S0 907 129 AC
   Component: Lenks. Modul  H06 0140
   Revision: --------    Serial number: 91335NKJ00197
   Coding: 280C
   ASAM Dataset: EV_SMLSKLOMQB 019002
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 7BA0FD64D36B313F78B-802E
Address 17: Instruments (J285)       Labels: Redir Fail!
   Part No SW: 8S0 920 790     HW: 8S0 920 790
   Component: FBenRDW       H32 0221
   Coding: 04250110698000080420E8C09000800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001013
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 76B6EC50E8496C57075-8022
   Part No SW: 8S0 907 468 A    HW: 8S0 907 468
   Component: GW MQB TT3    012 0203
   Revision: --------    Serial number: 24091410800543
   Coding: 030100042F025A004B000268080000000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 011002
   ROD: EV_GatewContiAU33X.rod
   VCID: 3E26347080F9E4171F5-806A
   Subsystem 2 - Part No SW: 8S0 951 523 B    HW: 8S0 951 523 B
   Component: J453 MFL  H06 0001
   Serial number: 20140924161427 RD862
   Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
   Serial number: 5917184503
   Serial number: 14000192704011
   Coding: 0100000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BCDF4C81274B6FD27-8024
   Serial number: 09111403111295
   Coding: 001E47225C00040100001402
   VCID: 42DE4080F40180F77BD-8016
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5061
   Coding: 9103
   VCID: 37282154AFC3D55FDC3-8062
   Serial number: 08111403111192
   Coding: 001E47225E00040100001402
   VCID: 41DC4F8CF1079BEF627-8014
Address 55: Headlight Range (J745)       Labels: 4H4-907-357-V2.clb
   Coding: 03DA00102B230200
   Shop #: WSC 47824 001 1048576
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005010
   VCID: 34321658BEB53E47F91-8060
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 8S0 035 044     HW: 8S0 035 044
   Component: MU-H-LN-EU    H33 0117
   Serial number: A258K0E7503640
   Coding: 01330401FF00000011110001000800102F0000E100700000DE
   ASAM Dataset: EV_MUHig4CGen2HBAS 001115
   VCID: 6B80CD24A30BA1BFE8B-803E
   Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
   Component: ECE 2017  --- 0157
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8S0 919 614 A    HW: 8S0 919 614 A
   Component: ControlUnit_H  H21 0124
   Serial number: C1000015101400010237
   Compact Disc Database:
   Component: Gracenote  --- 1010
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3AA-980-654.clb
   Part No SW: 8S0 980 653     HW: 5Q0 980 653
   Component: MQB_MFK       H06 0002
   Serial number: 10000156378
   Coding: 0100000001010305000501000000000100
   ROD: EV_MFKBoschAU370.rod
   Part No SW: 8S0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0002
   Serial number: 141015200336
End-------------------------(Elapsed Time: 01:15)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
Theoretically in MY2015 (and a lot earlier already) ABS is not anymore just a system detecting blocked wheel and releasing it, keeping on the edge of slipping to achieve maximum braking efficiency. It is complicate system for road safety helping driver to control his car in several situations. For correct work of this system ABS/ESP electronics should know all the mechanical parameters of brake system parts to divide brake force between wheels correctly. That's why coding should be changed when retrofitting mechanical parts with different parameters. ABS/ESP long coding has complicate calculation including a lot of parameters and a VIN code of vehicle. At this time how far I know, it is possible only with dealers ODIS online for this type of ABS/ESP control modules, but I'm not sure will it work with retrofitted different parts.
stefano82
Italy
C?ID=297173
Thanks for the answer.
So you're telling me that recoding is a must in this case, since brakes diameter is greater, but you don't know if the dealer can do it too ..
You're thinking also that stability of the vehicle is compromised ?
Is it correct ?
