Hi everyone,
I looked at an Audi A4 B8 2008 2,0 TDI Diesel during the week which had the EML light on. The log from the ECM is attached. I had a throttle body from the same type of car and engine so I changed them but the DTC remains. The throttle which is originally in the car is made by Continental and the replacement is made by Siemens. It appears one of the part numbers (starting with 03L) has been covered or not printed on the throttle body on the car, the date also is 08.06.2015 suggesting it has also been replaced in the past. I ran three new wires of the 5 which go to the throttle body (2 wires for the dc motor for the flap). Problem still there. I have also taken logs of the adv measuring blocks after trying something different.
I then looked at the adv measuring blocks of another Audi with the same engine, the value for throttle valve position sensor was ~2200 mV at idle compared to the ~4300 mV I'm getting on the car with the DTC. When I replaced the wire for the signal off the throttle I measured what voltage was on the old wire to see if it was shorting with the 12V however it was 0V. I also checked the voltage on the signal wire and it is the same as what the ECM is measuring
I can only hope the only solution is to get the identical replacement part as there must be an internal fault in the sensor.
Any suggestions ?
Logs with two different throttle Bodies:
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 17.1.2.1
Data version: 20170131 DS267.1
VIN: WAUZZZ8KX9A056345 License Plate: A4 CLON BLACK
Address 01: Engine (03L 906 022 JM)
12:03:21
IDE00083 Throttle valve position (absolute) 83.9 %
ENG109419 Throttle valve activation 0.00 %
ENG109415 Throttle valve feedback 0.13 %
ENG109422 Throttle valve offset closed -0.37 %
ENG109423 Throttle valve offset open 0.37 %
ENG109425 Throttle valve output stage 5.82 %
ENG109427 Throttle valve position sensor 4214.8 mV
Saturday,11,February,2017,15:03:03:28282
15:02:57
IDE00083 Throttle valve position (absolute) 84.3 %
ENG109415 Throttle valve feedback 0.16 %
ENG109422 Throttle valve offset closed -0.74 %
ENG109423 Throttle valve offset open 0.74 %
ENG109425 Throttle valve output stage 14.53 %
ENG109427 Throttle valve position sensor 4232.6 mV
Log off a similar car with no faults:
Saturday,11,February,2017,15:06:36:28282
VIN: WAUZZZ8K7BA110254 License Plate: A4
Address 01: Engine (03L 906 022 NN)
15:06:31
IDE00083 Throttle valve position (absolute) 42.7 %
ENG109419 Throttle valve activation 56.76 %
ENG109415 Throttle valve feedback 49.43 %
ENG109422 Throttle valve offset closed -0.77 %
ENG109423 Throttle valve offset open 0.77 %
ENG109425 Throttle valve output stage 32.15 %
ENG109427 Throttle valve position sensor 2099.4 mV
Last Auto-Scan:
Any suggestions ?
12:03:21
15:02:57
15:06:31
Last Auto-Scan:
Saturday,11,February,2017,17:30:49:28282
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72
VIN: WAUZZZ8KX9A056345 Mileage: 211640km-131506miles
Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 JM HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3173
Revision: 11H01---
Coding: 0104002C18072018
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TDI03L906022JM A01005
ROD: EV_ECM20TDI03L906022B.rod
VCID: 79F98650F8B72889A5-802C
7859 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 00 [039] - Implausible Signal
Mileage: 211641 km
Date: 2017.02.11
Time: 17:27:05
Engine speed: 836.00 /min
Normed load value: 22.4 %
Coolant temperature: 68 °C
Intake air temperature: 22 °C
Voltage terminal 30: 14.120 V
Crankshaft speed (RPM): 836.0 /min
Vehicle speed: 0.00 km/h
Accelerator position: 0.00 %
V Sw Vlv r Drft Opn mp: 11.98 %
V Sw Vlv r Drft Clsd mp: -1.81 %
V Sw Vlv u Raw: 319.4 mV
V Sw Vlv st Mon-Bit 0: 00000000
V Sw Vlv st Mon-Bit 16: 00000000
V Sw Vlv st Mon-Bit 24: 00000000
V Sw Vlv st Mon-Bit 8: 00000000
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AQ HW: 8K0 907 379 AQ
Component: ESP8 front H03 0210
Coding: 160500
VCID: 081FF394BB5D4101AA-805C
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 BC HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0252
Coding: 031100
VCID: 72EBB17CADC15BD1E4-8026
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000027298001
Component: ELVAUDIB8 H35 0039
Serial number: 0208000025683013
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0140
Revision: D0000000 Serial number: 0115.06.080159
Coding: 34040000
VCID: 428B21BCDDE1AB51B4-8016
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 207
Mileage: 211641 km
Date: 2017.02.11
Time: 17:27:04
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal
Reset counter: 207
Mileage: 211641 km
Date: 2017.02.11
Time: 17:27:04
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 E HW: 8K0 907 063
Component: BCM1 1.0 H22 0380
Revision: 01022001 Serial number: 00000000066113
Coding: 690040B10034A7000001000000005F5F001D020800000141000000
Shop #: WSC 00294 210 88150
VCID: 31697E70684720C95D-8064
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 180608 H05 0060
Serial number: SWFBIE 0000065
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10162374
Coding: 025028
Component: E1 - LDS H03 0031
Serial number: 00000000001503110505
Reset counter: 207
Mileage: 211641 km
Date: 2017.02.11
Time: 17:27:00
014 - Defective
Fault Status: 01101110
Reset counter: 207
Mileage: 211641 km
Date: 2017.02.11
Time: 17:27:00
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD16SGDL
Coding: 30363434363030303030554A3052384B3053
VCID: 3C775F44B705DDA1FE-8068
Serial number: 6334MSME32036E203
Serial number: 6344MSME3B032A1AE
Serial number: 6352QSME7017273BF
Serial number: 6362QSME73234B23D
Serial number: 63732SME7D23776DE
Serial number: 63832SME6A34210F+
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90304HFP0008V
Coding: 000012
VCID: 3D715240A41FD4A9C9-8068
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
Component: KOMBIINSTR. H16 0221
Revision: 00200000 Serial number: 995650V68
Coding: 2F05080002002600010000
Shop #: WSC 06325 123 12345
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G08612814D
Coding: 000303
VCID: 46833DACF1C9977198-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18026355040608
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 C HW: 8K0 959 793 A
Component: TSG FA H10 0170
Revision: Serial number: 0000007341027
Coding: 011002204001410001
VCID: 408F2BB4D3EDB941A2-8014
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0112114819
Coding: 011B0622003904400020010000000000
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S1900000
Coding: 0203010101
VCID: 6ED3A50CB9F97F3100-803A
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 C HW: 8K0 959 792 A
Component: TSG BF H10 0170
Revision: Serial number: 0000007374815
VCID: 3F8D2848AE13C6B9DB-806A
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000158852
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 C HW: 8T2 035 186 C
Component: Concert3 H02 0210
Revision: 00000004 Serial number: AUZ5Z6H1080895
Coding: 0502008001010D000359070000
VCID: 387F43548B3DF1811A-806C
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
Component: TSG HL H06 0170
Revision: Serial number: 0000100076759
Coding: 010002204001210001
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
Component: TSG HR H06 0170
Revision: Serial number: 0000100087983
End-------------------------(Elapsed Time: 02:53)--------------------------
