7859 - Intake Manifold Flap Position Sensor, replaced throttle Body & wiring
Alan_Harrington
Ireland
C?ID=268223
Hi everyone,
I looked at an Audi A4 B8 2008 2,0 TDI Diesel during the week which had the EML light on. The log from the ECM is attached. I had a throttle body from the same type of car and engine so I changed them but the DTC remains. The throttle which is originally in the car is made by Continental and the replacement is made by Siemens. It appears one of the part numbers (starting with 03L) has been covered or not printed on the throttle body on the car, the date also is 08.06.2015 suggesting it has also been replaced in the past. I ran three new wires of the 5 which go to the throttle body (2 wires for the dc motor for the flap). Problem still there. I have also taken logs of the adv measuring blocks after trying something different.
I then looked at the adv measuring blocks of another Audi with the same engine, the value for throttle valve position sensor was ~2200 mV at idle compared to the ~4300 mV I'm getting on the car with the DTC. When I replaced the wire for the signal off the throttle I measured what voltage was on the old wire to see if it was shorting with the 12V however it was 0V. I also checked the voltage on the signal wire and it is the same as what the ECM is measuring
I can only hope the only solution is to get the identical replacement part as there must be an internal fault in the sensor.
Any suggestions ?
Logs with two different throttle Bodies:
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 17.1.2.1
Data version: 20170131 DS267.1
VIN: WAUZZZ8KX9A056345 License Plate: A4 CLON BLACK
Address 01: Engine (03L 906 022 JM)
12:03:21
IDE00083 Throttle valve position (absolute) 83.9 %
ENG109419 Throttle valve activation 0.00 %
ENG109415 Throttle valve feedback 0.13 %
ENG109422 Throttle valve offset closed -0.37 %
ENG109423 Throttle valve offset open 0.37 %
ENG109425 Throttle valve output stage 5.82 %
ENG109427 Throttle valve position sensor 4214.8 mV
Saturday,11,February,2017,15:03:03:28282
15:02:57
IDE00083 Throttle valve position (absolute) 84.3 %
ENG109415 Throttle valve feedback 0.16 %
ENG109422 Throttle valve offset closed -0.74 %
ENG109423 Throttle valve offset open 0.74 %
ENG109425 Throttle valve output stage 14.53 %
ENG109427 Throttle valve position sensor 4232.6 mV
Log off a similar car with no faults
Saturday,11,February,2017,15:06:36:28282
VIN: WAUZZZ8K7BA110254 License Plate: A4
Address 01: Engine (03L 906 022 NN)
15:06:31
IDE00083 Throttle valve position (absolute) 42.7 %
ENG109419 Throttle valve activation 56.76 %
ENG109415 Throttle valve feedback 49.43 %
ENG109422 Throttle valve offset closed -0.77 %
ENG109423 Throttle valve offset open 0.77 %
ENG109425 Throttle valve output stage 32.15 %
ENG109427 Throttle valve position sensor 2099.4 mV
Last Auto-Scan:
Saturday,11,February,2017,17:30:49:28282
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72
VIN: WAUZZZ8KX9A056345   Mileage: 211640km-131506miles
Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 JM    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H01 3173
   Revision: 11H01---
   Coding: 0104002C18072018
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM20TDI03L906022JM A01005
   ROD: EV_ECM20TDI03L906022B.rod
   VCID: 79F98650F8B72889A5-802C
7859 - Intake Manifold Flap Position Sensor (Bank 1)
          P2015 00 [039] - Implausible Signal
                    Mileage: 211641 km
                    Date: 2017.02.11
                    Time: 17:27:05
                    Engine speed: 836.00 /min
                    Normed load value: 22.4 %
                    Coolant temperature: 68 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 14.120 V
                    Crankshaft speed (RPM): 836.0 /min
                    Vehicle speed: 0.00 km/h
                    Accelerator position: 0.00 %
                    V Sw Vlv r Drft Opn mp: 11.98 %
                    V Sw Vlv r Drft Clsd mp: -1.81 %
                    V Sw Vlv u Raw: 319.4 mV
                    V Sw Vlv st Mon-Bit 0: 00000000
                    V Sw Vlv st Mon-Bit 16: 00000000
                    V Sw Vlv st Mon-Bit 24: 00000000
                    V Sw Vlv st Mon-Bit 8: 00000000
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AQ    HW: 8K0 907 379 AQ
   Component: ESP8 front    H03 0210
   Coding: 160500
   VCID: 081FF394BB5D4101AA-805C
   Part No SW: 8K0 907 064 BC    HW: 8K0 907 064 C
   Component: BCM2 1.1      H70 0252
   Coding: 031100
   VCID: 72EBB17CADC15BD1E4-8026
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0508000027298001
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000025683013
   Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
   Component: KLIMA 3 ZONEN H06 0140
   Revision: D0000000    Serial number: 0115.06.080159
   Coding: 34040000
   VCID: 428B21BCDDE1AB51B4-8016
00457 - Control Module for Network (J519)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 207
                    Mileage: 211641 km
                    Date: 2017.02.11
                    Time: 17:27:04
                    Reset counter: 207
                    Mileage: 211641 km
                    Date: 2017.02.11
                    Time: 17:27:04
   Part No SW: 8K0 907 063 E    HW: 8K0 907 063
   Component: BCM1 1.0      H22 0380
   Revision: 01022001    Serial number: 00000000066113
   Coding: 690040B10034A7000001000000005F5F001D020800000141000000
   Shop #: WSC 00294 210 88150
   VCID: 31697E70684720C95D-8064
   Subsystem 1 - Part No SW: 8K2 955 119     HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 180608  H05 0060
   Serial number: SWFBIE 0000065
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10162374
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001503110505
                    Reset counter: 207
                    Mileage: 211641 km
                    Date: 2017.02.11
                    Time: 17:27:00
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 207
                    Mileage: 211641 km
                    Date: 2017.02.11
                    Time: 17:27:00
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD16SGDL
   Coding: 30363434363030303030554A3052384B3053
   VCID: 3C775F44B705DDA1FE-8068
   Serial number: 6334MSME32036E203
   Serial number: 6344MSME3B032A1AE
   Serial number: 6352QSME7017273BF
   Serial number: 6362QSME73234B23D
   Serial number: 63732SME7D23776DE
   Serial number: 63832SME6A34210F+
   Component: Lenks.Modul   H12 0013
   Revision: --------    Serial number: 90304HFP0008V
   Coding: 000012
   VCID: 3D715240A41FD4A9C9-8068
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 980 B    HW: 8K0 920 980 B
   Component: KOMBIINSTR.   H16 0221
   Revision: 00200000    Serial number: 995650V68
   Coding: 2F05080002002600010000
   Shop #: WSC 06325 123 12345
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0091
   Revision: GB102039    Serial number: 3900G08612814D
   Coding: 000303
   VCID: 46833DACF1C9977198-8012
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 18026355040608
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 C    HW: 8K0 959 793 A
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007341027
   Coding: 011002204001410001
   VCID: 408F2BB4D3EDB941A2-8014
   Revision: 00002001    Serial number: 0112114819
   Coding: 011B0622003904400020010000000000
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S1900000
   Coding: 0203010101
   VCID: 6ED3A50CB9F97F3100-803A
   Part No SW: 8K0 959 792 C    HW: 8K0 959 792 A
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007374815
   VCID: 3F8D2848AE13C6B9DB-806A
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000158852
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 C    HW: 8T2 035 186 C
   Component: Concert3      H02 0210
   Revision: 00000004    Serial number: AUZ5Z6H1080895
   Coding: 0502008001010D000359070000
   VCID: 387F43548B3DF1811A-806C
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000100076759
   Coding: 010002204001210001
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Part No SW: 8K0 959 794 A    HW: 8K0 959 795 A
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000100087983
End-------------------------(Elapsed Time: 02:53)--------------------------
Alan_Harrington
Ireland
C?ID=268223
I meant to add I also tried carrying out a throttle body adapdation on each body but made no difference
MartinsX
Riga, Latvia
C?ID=268515
Leave the TB alone, everything is ok with it :)
Problem is with intake manifold flap (swirl flap). Flap mechanism in manifold upper part is worn and flap motor drives it outside allowed range, position sensor detects it and fault is stored.
Official solution is to replace complete upper part of intake manifold with flaps and motor (not a very cheap part). I've just replaced couple of those last month, part costed approx 400eur at our local dealer.
MartinsX
Riga, Latvia
C?ID=268515
There is only one thing people have to remember - if this or similar limiter is installed, and flap mechanism is very badly worn, limiter will limit range where lever moves (no fault code stored), but it will not keep flaps fixed tightly at end position, when they are not moved. This means, flaps may vibrate when air flow passes and may crack and some debris may get into cylinders causing serious mechanical damage...
For 2,0 CR TDI this is just theoretical thoughts. Haven't seen broken flaps myself. But for 3,0 V6 CR TDI I have seen broken flaps and damaged valves/pistons several times.
If customer don't want repair this with complete new original intake manifold/flap/motor unit, I suggest to install limiter and remove flaps from manifold. Or program this feature off and remove flaps from manifold. Or disconnect lever arm and fix flaps tightly with spring as a quick temporary solution.
rhinopower
C?ID=58979
Mine has been perfect since fitting the limiting bracket.
Alan_Harrington
Ireland
C?ID=268223
Thanks for the replies guys will give update :)
vodonnell
Ireland
C?ID=5525
Would you have a photo or drawing of that fix Jack? regards Vinnie
NostraJackAss
I don't because I never documented since everyone watches the diesel geek video.
I have even just installed a roll/solid pin in the hole as a press fit & on the flapper side.
Additionally I have done this inside the unit getting the same result.
All you're doing is limiting the motion of the flap motor.
If I get time maybe I will take one apart and makes some photos.
A similar result can be had in 10 seconds with a very weak spring added to the arm & that the motor can move to create the seating resistance.
Alan_Harrington
Ireland
C?ID=268223
Thanks for the replies in the end I fixed this easily with that bracket had to do another lately as well, never thought of that Jack, actually easier than waiting on a bracket to arrive
NostraJackAss
Cheaper too.......& with adjustability to calibrate.
NostraJackAss
I have to add to this post and advise, that if you retime the gear or intermediate gear preloaded to the stop position; beneath the cover on the servo side & "installed" in the car disconnecting "NOTHING" by taking the cover off to access............ there is no need to drill or add a dam thing!
You advance it a tooth and you are DONE!
