Airbag Fault after Steering Wheel Module Upgrade
tehfalcon
C?ID=235987
I have upgraded my Feb, 2006 Built MK5 GTI's steering wheel controller to the CH version. This was to enable MFSW controls on my RNS-315. The MSFW works, as does the horn, but I now have an Airbag Light.
The Clockspring that is installed is: 1K0959653D
Here is my Autoscan
Saturday,11,February,2017,18:27:22:15363
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 17.1.3.0 (x64)
Data version: 20170203 DS267.2
VIN: WVWFV71K56W129684   License Plate:
Mileage: 156270km-97101mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56
VIN: WVWFV71K56W129684   Mileage: 156270km-97101miles
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 B    HW: 1K0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: --H14---    Serial number: VWZ7Z0F3317926
   Coding: 0403010A1C070160
   Shop #: WSC 02172 444 52255
   VCID: 256F0270ECDD0569BA-8071
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1115
   Revision: 04507000    Serial number: 00000512200806
   Shop #: WSC 01279 785 00200
   VCID: 14094FB437478CE15D-8041
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0021122
   VCID: 71C72620689519C916-8025
   Part No: 1K0 907 044 BE
   Component: ClimatronicPQ35 090 0808
   VCID: 6BFB34484AB9F3192C-803F
   Part No SW: 3C8 937 049 S    HW: 3C8 937 049 S
   Component: Bordnetz-SG     H53 3101
   Revision: 00H53000    Serial number: 00000009145138
   Coding: B78F8321400418005014000000140080805900000000801C000000000000
   VCID: 41A7B6E018B5C949A6-8015
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00063445
   Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
   Component: 5L AIRBAG VW8R  032 7900
   Revision: 03032000    Serial number: 0038FD04B6EV
   Coding: 0013644
   VCID: 3957DE0070659189EE-806D
   Subsystem 1 - Part No: 1K0 959 339 D
   Component: BF-Gewichtsens. 006 0006
   Subsystem 2 - Serial number: 6332MSME0D5C2365H
   Subsystem 3 - Serial number: 6342MSME0D5C1632E
   Subsystem 4 - Serial number: 6352QSME0848185BM
   Subsystem 5 - Serial number: 6362QSME09132F75K
   Subsystem 6 - Serial number: 63727SME087A084C9
   Subsystem 7 - Serial number: 63827SME09071E271
01587 - Igniter 2 for Airbag; Drivers Side (N250)
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Coding: 0001432
   Shop #: WSC 131071 102 209715
   VCID: 7AD5010C35E35A91A7-802F
   Component: E0221           007 0050
   Part No: 1K6 920 972 E
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0003203
   Shop #: WSC 02172 444 53795
   VCID: 3449EF3457076CE13D-8061
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K0851604B9
   Coding: ED811F064002020000
   Shop #: WSC 31890 001 104857
   VCID: 354FD2305C7D75E90A-8061
   Component: IMMO            VDD 4312
Address 37: Navigation
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2375
   Coding: 0001141
   VCID: 364DD53C417B7EF103-8063
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.0   D06 1701
   VCID: 334BEC2852096BD924-8067
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 AS    HW: 1K0 959 433 AS
   Component: 02 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 9A900E885103003F7F040F8FF0080A0480A040
   Shop #: WSC 12345 785 00200
   VCID: 012776E058350949E6-8055
   Part No: 1K0 959 702 K
   Coding: 0001141
   VCID: 3753D838467187F918-8063
   Part No: 1T0 907 357
   Coding: 0000003
   Shop #: WSC 01287 785 00200
   VCID: 74C92F3417872CE1FD-8021
Address 56: Radio
End-------------------------(Elapsed Time: 01:04)--------------------------
tehfalcon
C?ID=235987
Solved, turns out the CH only supports Single Igniter Airbags, you can solder two pins onto the CH to have it support the dual igniter, so i'll be attempting that later today.
golfi_vend
Tartu, Estonia
C?ID=195131
Be carefull with pins. Very fragile.
Danners74
C?ID=273244
Soldering of an airbag pins is strictly forbidden on VAG cars especially airbags. This could in turn deploy your air bag or FUBAR your control unit which I've seen countless times.
Be aware my friend.......................Regards Danners
golfi_vend
Tartu, Estonia
C?ID=195131
VAG has soldered pins himself on SWCM PCB. How else would you connect something on PCB?
Danners74
C?ID=273244
Yes that's in a factory environment. PCB's are soldered. I'm talking about any external repairs to wiring. Soldering pins yourself on a safety device......no thanks.
