Facelift A3 8V - Visual Parking display
dbdimma
C?ID=129931
Hi Everyone,
I'm new to the forum, but have been a home VCDS user for a good few years now.
I've done a search of the forum, but can't seem to find my answer so I though I'd better post my question.
On the pre-facelift A3 8V's (<2016), it's possible to turn on the rear visual parking display with a tick of a box, but the steer/park assist controller for my 2017 car doesn't have any labels. I've tried ticking the corresponding bit from the earlier cars, but it didn't do anything.
Has anyone been able to activate this on a fl car yet?
I've sent an autoscan to Ross-Tech and eagerly check each update, but so far there's not been any labels added. I've also read on the internet (so it must be true ;) ) that the fl cars have inherited the new way of being programmed from the new A4, A5, Q5 and Q7 cars, so programming some modules won't work. I'm not totally sure what that means.
Any help would be gratefully received.
Please post your Auto-Scan here as well.
pronet
Romania
C?ID=157414
First of all you have to use a security code access IOT to access the codding area - 07.
Try this:
Select STG 10 (parking aid)
STG Access authorization - Select function 16
Enter access code 71679
STG coding -> select function 07
Byte 2
Bit 0 - visualization of parking aid - activate
lala30
Croatia
C?ID=71949
on A3 FL is not possible !
you need install parameters from skoda or VW then you can enable visual PDC!
dbdimma
C?ID=129931
I'll have to admit I'm not 100% sure what installing parameters from skoda or VW entails, but it sounds like it's a bit beyond me.
It'll be quite annoying if I can't enable it though.
If you still need it, then here is my Auto-Scan.
Thursday,09,February,2017,18:43:46:35939
 VCDS Version: 17.1.3.0 (x64)
 Data version: 20170203 DS267.2
 Chassis Type: 8V (5Q0)
 Scan: 01 02 03 08 09 10 15 16 17 19 42 44 47 52 55 5F BB BC
   Mileage: 6499km-4038miles
 Address 01: Engine (J623-CZEA)       Labels: 04E-907-309-V1.clb
    Part No SW: 04E 906 027 HF    HW: 04E 907 309 BJ
    Component: R4 1.4l TFS   H23 2489
    Revision: R6H23---
    Coding: 02250032232401082000
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_ECM14TFS01104E906027HF 001005
    ROD: EV_ECM14TFS01104E906027HF_AU37.rod
    VCID: 6FE8473CB6116F3900-803A
    CAN Converter 01:
    Part No SW: 0CW 300 049 K    HW: 0AM 927 769 E
    Component: GSG DQ200G2_M H05 0905
    Revision: 00005026    Serial number: CU501608126668
    Shop #: WSC 17734 418 534600
    ROD: EV_TCMDQ200021.rod
    VCID: 4584C594C42D85699A-8010
    Part No SW: 5Q0 614 517 AR    HW: 5Q0 614 517 AG
    Component: ESC           H62 0642
    Revision: 00000000    Serial number: 61956000002263
    Coding:
 12F18AA22423227589790E0640C729485124449170029472022100748208420000000012121212B835351919323200
    ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
    VCID: 010C118490856949E6-8054
 Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
    Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
    Component: AC Automat    H03 0110
    Revision: 20001000    Serial number: 00000001001731
    Coding: 03100004000000011000000000001100
    ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
    VCID: 408AD480DB0FA041A9-8014
    Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
    Component: AQ_Hum_Sensor  H01 0005
    Serial number: BA19044800PAG0MUFU03
 Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
    Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
    Component: BCM MQBAB M+  H34 0236
    Serial number: 02001621702347
    ROD: EV_BCMBOSCH_017.rod
    VCID: 7EF66A78E17B16B19B-802A
    Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels:
 5QX-955-119-V1.CLB
    Component: WWS370 160803  043 0580
    Serial number:         160810143606
    Coding: 0A47F7
    Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels:
 8U0-955-559.CLB
    Serial number: 62140542
    Coding: 00006C
    Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
    Serial number: 29 05 2016  00000080
    Serial number: 000000000ZY162021218
    Component: Sirene, DWA  005 0313
    Serial number: 00000000000066800107
 Address 10: Park/Steer Assist (J446)       Labels: None
    Part No SW: 5QA 919 283     HW: 5QA 919 283
    Component: PDC 4 KanalH07 0031
    Serial number: 000308419616217
    Coding: 0700040011
    ASAM Dataset: EV_EPHVA14AU3700000 009027
    ROD: EV_EPHVA14AU3700000_AU37.rod
    VCID: 07180F9CBEA15779A8-8052
    Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
    Component: AirbagVW21    003 0315
    Serial number: 003TDR21HWVQ
    Coding: 98CCC0000C0000005C5400CA00C800000065
    VCID: 102A24C0CBEF10C179-8044
    Subsystem 1 - Part No SW: -----------    HW: 480 001 708 16
    Serial number: 35700000000D6D31CD1Y
    Subsystem 2 - Part No SW: -----------    HW: 480 001 708 16
    Serial number: 3580000000084CA4BD1-
    Subsystem 3 - Part No SW: -----------    HW: 480 401 708 16
    Serial number: 3510001B92205C31B58-
    Subsystem 4 - Part No SW: -----------    HW: 480 401 708 16
    Serial number: 3520001B92205C34C33Y
    Subsystem 5 - Part No SW: -----------    HW: 480 402 507 16
    Serial number: 3550002AB211FA36320-
    Pedestrian Protection Driver:
    Subsystem 6 - Part No SW: -----------    HW: 480 401 908 16
    Component: PedP_Sensor_D  000 6149
    Serial number: 2280001A520F2B26240T
    Subsystem 7 - Part No SW: -----------    HW: 480 401 908 16
    Component: PedP_Sensor_P  000 6149
    Serial number: 2290001AB20F2B2296CA
    Subsystem 8 - Part No SW: -----------    HW: 480 002 807 16
    Serial number: I0M00000000E5054EC19
    Subsystem 9 - Part No SW: -----------    HW: 480 002 807 16
    Serial number: I0N000000009FB955D1N
    Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
    Revision: --------    Serial number: 13081604400331
    Coding: A418
    ROD: EV_SMLSKLOMQB_SK48.rod
    Part No SW: 8V0 920 972 J    HW: 8V0 920 972 J
    Component: KOMBI         H04 8316
    Coding: 27A509082B8026000100EE001001000000000000
    ASAM Dataset: EV_DashBoardVDDMQBAB 009054
    ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
 16777022 - Function Restricted due to Interrupted Communications
           U1110 00 [008] - -
                     Reset counter: 150
                     Mileage: 5861 km
                     Date: 2017.01.26
                     Time: 20:54:24
    Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
    Component: GW MQB High   128 1265
    Revision: --------    Serial number: 0005250159
    Coding: 030100043F0857005B0002481C0B00000001010000000000000000000000
    ROD: EV_GatewLear_013.rod
    VCID: 7CF26070F76704A1B5-8028
    Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
    Component: J453 MFL  H04 0003
    Serial number: 20160727043851 00638
    Serial number: 75410803001608132904
    Serial number: 080816EH724916
    Coding: 005D8A205C01040000001002
    VCID: 4380DB8CCA19BB59B4-8016
    Component: EPS_MQB_ZFLS  128 1072
    Coding: 8107
    ROD: EV_SteerAssisMQB_013.rod
    Part No SW: 81A 035 466     HW: 81A 035 466
    Component: MIB2_amp_P_A3 H10 0100
    Revision: 00000001    Serial number: AUZ8ZAGHX00517Z
    Coding: 0173030000AAAA2AAA0000010000
    ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
    ROD: EV_AMPMst16C8Gen2ALPI.rod
    VCID: 62CE3E0875C3D2519F-8036
    Serial number: 150716EGE35591
    Coding: 005D82205E01040000001002
    VCID: 428EDE88D503B251BF-8016
 Address 55: Headlight Range (J745)       Labels: None
    Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
    Component: MxB-ECU       001 0230
    Coding: 0EDE00102B230200
    ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
    VCID: 3E76AA78A1FBD6B1DB-806A
    Part No SW: 81A 035 192     HW: 81A 035 192
    Component: MU-HS-LND-EU  045 0148
    Coding: 017303010000000011111102000A00102F002AE601F00100CE
    ROD: EV_MUHigScl6C3DELP.rod
    VCID: 5EB60AF841BBF6B1BB-800A
    Subsystem 1 - Part No SW: 8W0 919 866 C    HW: -----------
    Component: ECE 2016  --- 0009
    Component: DU High  H49 0014
    Serial number: AUZ8Z9GY2072Q1
    Multimedia Operating Unit:
    Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
    Component: ControlUnit_B  H50 0103
    Serial number: ALJAL128061600010714
 Address BB: Door Rear Drv (J388)       Labels: None
    Serial number: 070816DH609734
    Coding: 000C82204001040000001002
 Address BC: Door Rear Pass (J389)       Labels: None
    Serial number: 070816DH609657
 End
pronet
Romania
C?ID=157414
What parameters are taking about? It's the same procedure for 8k. According to you the solution is to re-write the module?
@dbdimma: try the codding using security access code provided by vcds.
lala30
Croatia
C?ID=71949
hello
8K ? :-)
did you tray to coding a3 8V facelift?
please first tray to code then write!!!!
lala30
Croatia
C?ID=71949
Audi a3 8V , Golf 7 , seat leon and skoda facelift
use same unit for PDC , and only in Audi is not possible to enable PDC on screen if you have only rear sensors,
parameters....
this is same rear camera and same car
first photo Audi parameters
second photo VW parameters
windows 7 screen shot
and this PLA in Audi
skoda, seat and vw have in instrument cluster and this you get with parameters
screen capture software
DiagnosticFr3ak
Israel
C?ID=285257
try going to 10- Adaptions and serach for pdc.
lala30
Croatia
C?ID=71949
IDE00001-Production mode,Deactivating
IDE00820-ENG118120-Activating and deactivating all development messages-Dev_Id_High_Nibble,not activated
IDE00820-ENG118119-Activating and deactivating all development messages-Dev_Id_Low_Nibble,not activated
IDE01165-Park assist activation tone,On
IDE01167-Convertible offset for volume level 1,255
IDE01168-Increment for convertible volume levels,255
IDE01169-Audio reduction request,On
IDE02332-Deactivate production mode,0
IDE03782-Switch-off speed for parking assist,10 km/h
IDE05274-Acoustic warning for rear lid assistant,not active
MAS01426-Speaker volume for rear park assist,Stage 4
MAS01427-Speaker frequency for rear park assist,Stage 6
MAS01428-Speaker volume for front park assist,Stage 4
MAS01429-Speaker frequency for front park assist,Stage 4
dbdimma
C?ID=129931
I tried those steps again, this time using the security code, but still no luck.
The security code was accepted, the long coding was accepted, but when I exited everything and tried putting it in reverse there's still no visual display.
I don't understand why just the FL Audi's are different. Is it likely to be in there somewhere, but we just don't know which bits need changing, or is it never going to be possible?
lala30
Croatia
C?ID=71949
Before FL use pDC unit 5Q0
Facelift use 5QA
And what you don't understand!
dbdimma
C?ID=129931
I'm not an expert on any of this. I just meant I don't know why they'd change the unit.
So there's definitely no way it can be done with the 5QA then?
lala30
Croatia
C?ID=71949
For now , is not possible
Tutuco
Brazil - Sao Paulo
C?ID=312382
Hey Guys. Any news about this? I'm in the same situation. Thanks
hadez16
C?ID=289891
What I've read about that topic is that MIB2 is the cause that it doesn't work anymore.
All the Audi 8W plattform guys are also struggeling with it, not only A3 FL.
Yet no solution on this afaik.
South Molton, UK
Not just Audi 8W - all MQB platform cars from whole of VAG.
hadez16
C?ID=289891
For me it sounds some kind of unlogic that MIB2 does not respond to 4-Channel PDC signal regarding the OPS but to 8-Channel PDC?
Someone will dig into it...unfortunately I have no MQB-FL or MLBevo car in access.
Frankyshiu
Hong Kong
C?ID=245708
Any update ? My friend experienced as the same.
