[NMS Passat] Disable Turn Signals with Low Beam On
NoSpark
UC151243 (2nd hand?)
The North American B7 Passat has the turn signals illuminated (at a reduced brightness) when the low beams are on.
I'm wondering if there is a way to disable that, and I think there may be (the Chinese Passat does not have this situation). I still need the turn signals to function when the stalk is pressed.
In Byte 18, I have been able to achieve this, but it creates unwanted behavior with the tail lights.
Byte 18 = A0 (North American Region)
Byte 18 = 96 (China with Halogen)
I'm basically looking to have the headlight function from Byte 96 and tail light function from Byte A0.
Thanks in advance!
Change thread title from "B7" to "NMS" because the RDW B7 is quite different than the NAR/China NMS.
I'm not aware of a way to change that via single coding bits and believe you are on track with Byte 18. Don't hesitate to post another scan now that you have a new BCM in the car to see if you receive any additional suggestions.
ivagp
C?ID=95551
you are setting yourself up liability wise.
NoSpark
How so? My GTI does not have the indicators on with low beams on.
