06 treg v10 tdi
ivagp
C?ID=95551
hi i just purchased a 06 treg with a v10 tdi. im trying to figure out what i stepped on. it has a coolant leak maybe from the water pump. only leaks while the engine is running. next its leaking oil, mostly dripping down the left front of the engine. cant really tell. last i have a exhuast leak on both sides. i think its coming from the manifolds. any suggestions please let me know
Gone But Not Forgotten
Remove engine .........completely inspect, service, use factory parts, RTFB!......... reinstall engine.
You have stepped into & entered the Twilight TDI v10 zone .........
ivagp
C?ID=95551
hey nerd take the dic and some pop and go see a movie. go piss on someone else's post
ivagp
C?ID=95551
Okay finally got to work Onnit replace the oil filter adapter gasket the oil cooler seals button up everything back together and now I have water leaking out of the weep hole on the oil cooler adapter. Does anyone know if that weep hole leads to the water pump. The whole is on the left side of the oil filter adapter somewhere in the middle, a little bit above the base
ivagp
C?ID=95551
hi guys dose any one know on this v10 water pump sealing cap part# 07Z103189, can you buy the seal by it self. in the manual it says nothing about not reusing the seal or my other thought was to discard the seal and just use sealant. anyone has experience with this? thanks again
mddlfngz
Finland
You cannot buy the seal by itself. I would use sealant.
