VW Polo 9N IPC adaptions/login
MartinsX
Riga, Latvia
C?ID=268515
This one Polo, I'm working with tonight, along with other problems is displaying warning for missing signal from oil level/temperature sensor. But sensor is not present at all :D So I would like to disable it. Unfortunately IPC does not allow me to change ADP CH 39 from 1 to 0 and login 13861 offered by pop-up window results with dropped comms to IPC and FAIL displayed in right side LCD of IPC below odometer reading.
Any suggestions, colleagues?
Autoscan:
Thursday,09,February,2017,20:31:14:32442
VCDS Version: 17.1.2.1
Data version: 20170131 DS267.1
VIN: WVWZZZ9NZ6Y149970   License Plate:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ6Y149970   Mileage: 227620km-141436miles
   Part No: 045 906 019 CA
   Component: 1,4l R3 EDC G000SG  7537
   Coding: 00002
   Shop #: WSC 00788
   VCID: 56A3EC67B279E7F1E8-4AE8
   WVWZZZ9NZ6Y149970     VWZ7Z0E2938242
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 35-10 -  - Intermittent
18061 - Please check DTC Memory of ABS Controller
            P1653 - 35-10 -  - Intermittent
Readiness: 1 1 0 0 0
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.lbl
   Part No SW: 6Q0 907 379 AF    HW: 6Q0 907 379 AF
   Component: ABS 8.0 front   H05 0002
   Coding: 0002190
   Shop #: WSC 00788 785 00200
   VCID: 0109EF3B5B77B049ED-5122
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Q0 820 045
   Component: Klimaanlage        X0840
   VCID: 6ADBA897160153115C-5122
01596 - Motor for Outside/Recirculated Air Flap (V154)
            30-00 - Open or Short to Plus
            07-00 - Signal too Low
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 00BK BN-SG.         1S34
   Coding: 09870
   Shop #: WSC 00788
   VCID: 3C775ECF2C151DA1FE-5140
01024 - Rain Sensor (G213)
            03-00 - No Signal
            49-00 - No Communications
   Part No: 1C0 909 605 K
   Component: 19 AIRBAG VW51 0P   0008
   Coding: 12601
   Shop #: WSC 00788
   VCID: 2C576E8FDC758D216E-5122
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            25-10 - Unknown Switch Condition - Intermittent
01218 - Side Airbag Igniter; Passenger Side (N200)
            32-10 - Resistance Too High - Intermittent
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 823 E
   Coding: 02132
   VCID: 346776EF0445D5E136-5122
   Part No: 6N0 909 901
   Component: 0B7L GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 00788
   VCID: 70EFBAFF30DDA9C112-5122
   Part No: 6Q0 423 156 Q
   Component: LenkhilfeTRW        V250
   Coding: 10111
   Shop #: WSC 20550
   VCID: 3D7153CB370F14A9C9-5140
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 E
   Component: 3F Komfortgerбt     0002
   Coding: 00019
   Shop #: WSC 00788
   VCID: 3D7153CB370F14A9C9-4B00
   Part No SW: 6Q0 035 152     HW: 6Q0 035 152
   Component: Radio BVX       006 0010
   Revision: 00006000    Serial number: VWZ1Z5E4690602
   Coding: 0020200
   VCID: 67DDD1A355136E7943-5140
End-------------------------(Elapsed Time: 03:36)--------------------------
Admap:
;SW:6Q0-920-823-E   HW: ---  Instruments
;Component:KOMBI+WEGFAHRSP VDO V02, Coding:02132
;Thursday,09,February,2017,22:06:11:32442
;VCDS Version: Release 17.1.2  Data version: 20170131 DS267.1
;VCID: 346776EF0445D5E136-5140
Channel,,Field 1,Field 2,Field 3,Field 4,
01,,ERROR:,Channel 01,Not,Available,
02,0,,,,,
03,,ERROR:,Channel 03,Not,Available,
04,,ERROR:,Channel 04,Not,Available,
05,,ERROR:,Channel 05,Not,Available,
06,,ERROR:,Channel 06,Not,Available,
07,,ERROR:,Channel 07,Not,Available,
08,,ERROR:,Channel 08,Not,Available,
09,22762,Kilometer,in 10,km, - ,
10,,ERROR:,Channel 10,Not,Available,
11,,ERROR:,Channel 11,Not,Available,
12,,ERROR:,Channel 12,Not,Available,
13,,ERROR:,Channel 13,Not,Available,
14,,ERROR:,Channel 14,Not,Available,
15,,ERROR:,Channel 15,Not,Available,
16,,ERROR:,Channel 16,Not,Available,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,,ERROR:,Channel 20,Not,Available,
21,2,Old Key,Count,2.0, - ,
22,,ERROR:,Channel 22,Not,Available,
23,,ERROR:,Channel 23,Not,Available,
24,,ERROR:,Channel 24,Not,Available,
25,,ERROR:,Channel 25,Not,Available,
26,,ERROR:,Channel 26,Not,Available,
27,,ERROR:,Channel 27,Not,Available,
28,,ERROR:,Channel 28,Not,Available,
29,,ERROR:,Channel 29,Not,Available,
30,128,Actual Value, , , - ,
31,,ERROR:,Channel 31,Not,Available,
32,,ERROR:,Channel 32,Not,Available,
33,,ERROR:,Channel 33,Not,Available,
34,,ERROR:,Channel 34,Not,Available,
35,0,,,,,
36,,ERROR:,Channel 36,Not,Available,
37,,ERROR:,Channel 37,Not,Available,
38,,ERROR:,Channel 38,Not,Available,
39,1,,,,,
40,50,Actual Value,Insp. in 1,00 km, - ,
41,110,Actual Value,Insp. in 1,Days, - ,
42,150,Min. Value,Oil in 1,00 km, - ,
43,150,Max. Value,Oil in 1,00 km, - ,
44,365,Max. Value,Insp. in 1,Days, - ,
45,1,Oil,Quality, , - ,
46,,ERROR:,Channel 46,Not,Available,
47,61,Soot,Qty. in 1,00 km, - ,
48,55,Thermal Load,in 1,00 km, - ,
49,365,Min. Value,Insp. in 1,Days, - ,
50,32000,Disabled, ,N/A,N/A,
51,,ERROR:,Channel 51,Not,Available,
52,,ERROR:,Channel 52,Not,Available,
53,,ERROR:,Channel 53,Not,Available,
54,,ERROR:,Channel 54,Not,Available,
55,,ERROR:,Channel 55,Not,Available,
56,,ERROR:,Channel 56,Not,Available,
57,,ERROR:,Channel 57,Not,Available,
58,,ERROR:,Channel 58,Not,Available,
59,,ERROR:,Channel 59,Not,Available,
60,,ERROR:,Channel 60,Not,Available,
61,,ERROR:,Channel 61,Not,Available,
62,,ERROR:,Channel 62,Not,Available,
63,,ERROR:,Channel 63,Not,Available,
64,,ERROR:,Channel 64,Not,Available,
65,,ERROR:,Channel 65,Not,Available,
66,,ERROR:,Channel 66,Not,Available,
67,,ERROR:,Channel 67,Not,Available,
68,,ERROR:,Channel 68,Not,Available,
69,,ERROR:,Channel 69,Not,Available,
70,,ERROR:,Channel 70,Not,Available,
71,,ERROR:,Channel 71,Not,Available,
72,,ERROR:,Channel 72,Not,Available,
73,,ERROR:,Channel 73,Not,Available,
74,,ERROR:,Channel 74,Not,Available,
75,,ERROR:,Channel 75,Not,Available,
76,,ERROR:,Channel 76,Not,Available,
77,,ERROR:,Channel 77,Not,Available,
78,,ERROR:,Channel 78,Not,Available,
79,,ERROR:,Channel 79,Not,Available,
80,,ERROR:,Channel 80,Not,Available,
81,,ERROR:,Channel 81,Not,Available,
82,,ERROR:,Channel 82,Not,Available,
83,,ERROR:,Channel 83,Not,Available,
84,,ERROR:,Channel 84,Not,Available,
85,,ERROR:,Channel 85,Not,Available,
86,,ERROR:,Channel 86,Not,Available,
87,,ERROR:,Channel 87,Not,Available,
88,,ERROR:,Channel 88,Not,Available,
89,,,,,,
90,,,,,,
91,,,,,,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,,ERROR:,Channel 99,Not,Available,
Andy
Sector 7G
HC424490
I believe the Login of 13861 only applies to entering the odometer reading in Adaptation channel 09 on a brand new cluster. Other changes shouldn't require a Login. Try Adp 04 to change the language for example. I'm not familiar with Adp 39 ... it's possible that could require a different Login?
NEtech
Denmark
C?ID=56995
Is the button [Security Access-16] maybe visible ?
MartinsX
Riga, Latvia
C?ID=268515
Ch 04 is not available
I can change Ch 45 (regular or longlife service) from 1 to 2 and back, without any login.
MartinsX
Riga, Latvia
C?ID=268515
I guess this IPC is not original for this car. Or some other components/modules are changed. IPC has ABS and ESP warning lights on, but brake electronics module installed is classic ABS 8.0, without ESP. I'm working on repairing damaged wiring to front wheel sensors right now.
Will have to check with PL24 tomorrow (I haven't PL available from place I'm working right now). Or someone could check it tonight for me, please?
P.S. VIN in autoscan is correct for this car, the same VIN on car's body.
NEtech
Denmark
C?ID=56995
Maybe, is channel 45 on 1 or 2 (Adaptation) ?
I think the cluster is correct. I don't want to post a massive pic so the link is:
http://ft.trillian.im/7a467daf2651281430c9375002268189594cfb6d/6O9PSEaX8W18BsN5hkGayWAQwSARq.jpg
Edit:
ECM # 045 906 019 CA is correct per PL24
ABS shows 6Q0 614 117 T to be used for 6Q0 614 117 S. 6Q0 614 117 T supers to 6Q0 614 117 AK (not AF) so something might be wrong in that area.
MartinsX
Riga, Latvia
C?ID=268515
I could be all off here but this page has some dated info:
http://www.ross-tech.com/vag-com/cars/vw_sri.html
This is all SRI information.
I'm searching for the way how to disable oil level/temperature sensor as it does not exist on this car. Probably it is Adp Ch 39, but this IPC does not allow to change value 1 to 0. If typing 0 into New Value field, it jumps back to 1 in Test field.
Right, but the the service scheme and reset info usually overlaps.
MartinsX
Riga, Latvia
C?ID=268515
Edit:
Thanks, Dana!
Ok, cluster is correct, ABS isn't. But then there should be some way how to disable oil level/temperature sensor in cluster.
This engine even don't have opening for sensor in oil sump. 045103601D
MartinsX
Riga, Latvia
C?ID=268515
How I understand, longlife service scheme may require oil level/temperature sensor in some cases, but fixed intervals can live without it. In my case Ch 45 is set to 1 (Fixed Intervals), but I can't set Ch 39 to 0 (no oil level/temperature sensor)...
MartinsX
Riga, Latvia
C?ID=268515
Edit:
Can You look at 927-000 (ABS control module) for me, please? Numbers above are from 614-012 (ABS unit)
MartinsX
Riga, Latvia
C?ID=268515
One mystery solved - this engine should have different oil level/temperature sensor, mounted in front end flange, not in oil sump like classic ones. 045907660D
In my case connector is broken and wires are just hanging in air ... And sensor can't be located on engine. Two different types of front end flanges exists - with opening for sensor and without. 045103153 and 045103153A
Probably presence of this sensor is hardcoded in cluster - e.g. I can see value 1 in Adp Ch 39, but I can't change it, at lest by regular way of changing adaption parameters.
NEtech
Denmark
C?ID=56995
You found the G266 problem, but I am also puzzled about Adp channel 39.
The Instrument is configured for "fixed service" (Sorry about the question, forgot to look at you posted channel map #8), channel 42, 43, 44, 45.
But the Engine is still Coded for Variable Service (WIV), 00005
If you want, try: 00102
MartinsX
Riga, Latvia
C?ID=268515
Probably I'll not have possibility to test it anymore. As main problem was ABS and I found out last night that incorrect module is fitted, wiring and brake pipes are rebuild and warning lamps in IPC covered with black tape etc. G85 removed from car and so on... :D In short words car was prepared for sale using worst practice ever seen... Customer is not ready right now to invest in parts and labour to revert things in order they should be with all correct parts installed and so on. So thank You everyone for Your help! Special thanks to Dana! :)
I realize this car is fixed well enough for now but I like NEtech's suggestion if it returns.
I can't post the entire thing for privacy reasons but we had a scan with these details using xxxx2 in the Engine:
VIN: WVWZZZ9NZ6Y??????
> Component: 1,4l R3 EDC 0000SG 7537
> Coding: 00002
> Component: ABS 8.0 front H03 0002
> Coding: 0002190
> Part No: 6Q0 920 903 D
> Coding: 01432
> Coding: 00014
Both cars used QG1 Service interval prolongation
