2004 Audi A3 ABS Coding Incorrect - Implausible Signal - Instrument Cluster Swap
poxxxy
C?ID=149927
Hi guys,
Having some trouble with my sisters car, its a 2004 Audi A3 8P with a 1.6 BGU.
The instrument cluster was crashing out and losing comms with a few units and draining the battery over night with lights left on the dash. I sourced an identical part number instrument cluster and swapped the immo over with car prog... Instruments no longer displayed safe and the car started... all good I thought.
Now I had a few errors with brake adaptations and steering assist stop adaptations which cleared up. But one code I couldn't get around was the 1104 Incorrect Module coding error - 008 Implausible Signal.
I'm not sure I took an autoscan before starting any work but on the scans I do have which I feel were before and after the cluster swapping ABS coding is 19077 which according to the coding tables is correct.
I've been advised that it may have some kind of VIN encrypted coding which is necessary...
Coding as per Rosstech wiki:
1zf +0000005
ua0 +0000640
7k0 +016384
Engine +2048
vin:
wauzzz8p25a032532
I was wondering if anyone could further advise on if the ABS does actually need encrypted coding or perhaps there is something in the IPC causing problems?
Tomorrow I will try replacing the old crashing dashboard back in there to check what the ABS states coding fault wise.
poxxxy
C?ID=149927
Hi Uwe, thanks for the reply. Please find attached most recent autoscan taken today. Note that adaptations are all done now and those codes are gone on the steering assist and the brake modules.
Tuesday,07,February,2017,14:37:51:59247
VCDS Version: 16.8.2.3 (x64)
Data version: 20160926 DS261.0
VIN: WAUZZZ8P25A032532   License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: WAUZZZ8P25A032532   Mileage: 246280km-153031miles
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
   Part No: 06A 906 033 DS
   Component: SIMOS71 1.6l 2V     5559
   Revision: --H03---    Serial number: AUX7Z0D6FNU0I9
   Coding: 0000071
   Shop #: WSC 06435 000 00000
   VCID: 73EFFF1F125247DAB9-8026
Readiness: 1110 1101
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0019077
   VCID: 3A71123B75B8F692BA-806E
   Part No SW: 8P0 820 043 D    HW: 8P0 820 043 D
   Component: KlimavollautomatH12 0150
   Revision: 079528      Serial number: 8P0820043D
   VCID: 2D5B2967B4F6512A2F-8078
                    Reset counter: 21
00716 - Air recirculation Flap Positioning Motor (V113)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 96
                    Reset counter: 237
                    Mileage: 245680 km
                    Date: 2016.10.07
                    Time: 20:16:31
                    Voltage: 13.80 V
                    Temperature: 14.0°C
                    (no units): 37.0
                    (no units): 33.0
                    Temperature: 9.5°C
                    Fault Status: 01101000
                    Reset counter: 237
                    Mileage: 246280 km
                    Date: 2015.12.31
                    Time: 00:03:47
Address 09: Cent. Elect.        Labels: 8P0-907-279-23-B.lbl
   Part No SW: 8P0 907 279     HW: 8P0 907 279 *
   Component: Bordnetz-SG 1.0 H30 0501
   Revision: 00030000    Serial number: 00000000935150
   Coding: 008C4F00A0141000000000000000000000
   VCID: 7AF1D23B35383692FA-802E
   Subsystem 1 - Part No: 8P2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 15: Airbags        Labels: 8P0-959-655-84.lbl
   Part No SW: 8P0 959 655 D    HW: 8P0 959 655 D
   Component: Airbag 8.4ED    H00 0140
   Coding: 0011602
   VCID: 438F6FDF0272B75AE9-8016
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 012 0030
   Coding: 0000002
   VCID: 6FE7F36F7E7A633A5D-803A
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 950 K    HW: 8P0 920 950 K
   Component: KOMBIINSTR. VDO H71 0210
   Revision: D02         Serial number: 1246DD02000640
   Coding: 0004408
   Shop #: WSC 77827 127 263172
   VCID: 3C7D14237F8CC8A2A8-8068
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 D    HW: 1K0 907 951
   Component: Gateway         H08 0100
   Revision: 08          Serial number: 250010472009BC
   Coding: 3D0F0342070101
   VCID: 2855D8739B147402DC-807C
   Revision: D02         Serial number: AUX7Z0D6FNG0BI
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 E
   Component: Tuersteuerger.  H10 0030
   Coding: 0000048
   VCID: 3D7B19276496C1AA9F-8068
   Part No: 1K2 909 144 G
   Component: EPS_ZFLS Kl.9       1301
   VCID: 30653013A3C43CC204-8064
02546 - Steering Limit Stop
                    Mileage: 6240 km
                    Temperature: 14.0°C
                    Voltage: 12.00 V
                    Voltage: 11.80 V
            000 -  -
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433
   Component:    KSG          H02 0040
   Coding: 008000186D288505489AC63000
   VCID: 79F3CD37303E3D8AF3-802C
   Subsystem 1 - Part No: 1K0 951 605 A
   Component: LIN BACKUP HORN H01 0101
   Subsystem 2 - Part No: 1K0 907 719
   Component: Neigungssensor  003 0003
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumueberw.H03 0010
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH25 0160
   Revision: 00003       Serial number: 10000001142003
   VCID: 70E5F01363447CC244-8024
                    Reset counter: 22
                    Mileage: 246280 km
                    Date: 2015.12.31
                    Time: 00:00:35
                    Temperature: 8.0°C
                    Raw, Form. N/A: 000 000 000
                    Reset counter: 22
                    Time Indication: 1
                    Temperature: 8.0°C
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
   Part No: 8P0 959 802 E
   Coding: 0000048
   VCID: 3E791E2B6990DAB286-806A
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 152 A    HW: 8P0 035 152 A
   Component: chorus II       H51 0100
   Revision:      01S    Serial number: AUZ2Z2D1009851
   Coding: 0001000
   VCID: 2953DD77801E4D0AC3-807C
                    Reset counter: 22
                    Time Indication: 15
                    Reset counter: 22
                    Bin. Bits:       10
End-------------------------(Elapsed Time: 01:22)--------------------------
poxxxy
C?ID=149927
Not sure if of any use but found an old log from the same car
Thursday,02,August,2012,21:05:21:59247
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Chassis Type: 1K0
VIN: WAUZZZ8P25A032532   Mileage: 177560km/110330miles
   Coding: 0000071
   VCID: 73EFFF1F12AE091
   Coding: 0019077
   VCID: 3A71123B7544B89
   VCID: 2D5B2967B40A1F1
   VCID: FAF1523BB5C4F89
   Coding: 00062736
   Coding: 0011602
   VCID: 438F6FDF028EF91
   Coding: 0000002
   VCID: EFE7736FFE86AD1
   Revision: D02         Serial number: 1246DD02000546
   Coding: 0004408
   Shop #: WSC 00505 210 80779
   VCID: 3C7D14237F70869
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   VCID: 2855D8739BE83A9
   Revision: D02         Serial number: AUX7Z0D6FNU0I9
01176 - Key
   Coding: 0000048
   VCID: 3D7B1927646A8F1
   VCID: 30653013A338729
   VCID: F9F34D37B0C2F31
   Component: LIN BACKUP HORN H01 1201
   VCID: F0E57013E3B8B29
   Coding: 0000048
   VCID: 3E791E2B696C949
   Coding: 0001000
   VCID: 2953DD7780E2031
Address 25: DTCs cleared
Address 09: DTCs cleared
So your ABS coding hasn't been changed, it's identically the same as it was with the old cluster, which has exactly the same part number as the new cluster, but the ABS now thinks it's incorrectly coded.
That makes no dang sense to me. Hopefully someone else knows something I don't.
poxxxy
C?ID=149927
I would suggest:
Enter some numbers Workshop Identifications in Options > Save > Exit > Start VCDS
Use the same coding (0019077) in [03-ABS] and [Do It!].
Then do the Basic settings.
I did try manually entering some non 00 values during the coding procedure but not as you mentioned, they were accepted but the fault remained. Its a little puzzling to say the least, I was scratching my head for a long time! I am wondering if car prog has not transferred something and the abs is looking for a certain string or such from the instrument cluster that is mismatching. I will try your method just to be sure.
poxxxy
C?ID=149927
So... in the depths of the internet, I have found someone that has the same problem as me... and also used carprog also to change immo cluster information. Immo ID is not being transferred and perhaps there is some kind of encryption in the can communication between abs and dash? I am not sure what tool to invest in next to try and repair or whether to just find someone with AVDI that can do it for me!
piehole1983
Belfast, Northern Ireland
C?ID=295335
It was likely to be me that you had found. I'm still having the same problem and a few people have assured me that the problem lies with the ABS unit. I got a newer one really cheap so I'm going to try to fit it soon. What I did notice, when I fitted my full DIS cluster, I was able to go in to the service menu to see the VIN number which appeared as YYYYYYYYYYYYYYYYY and not the actual VIN. The VIN shows up as normal in VCDS and Carprog, I don't know why it's doing that in the cluster on board menu though. Could be one for the Ross Tech guys to look at? Is the VIN stored in the Fujitsu MCU in my case as well as the EEPROM?
NostraJackAss
That's because you are looking in the wrong controller sections and it's an encrypted block.
0x17 verse 0x25
piehole1983
C?ID=295335
I mean viewing it with the red DIS screen inside the car, not VCDS. I can see it fine in VCDS. I was just browsing the menus in the car and stumbled across the VIN number, well what was supposed to be the VIN anyway!
piehole1983
C?ID=295335
It shows WAUZZZ8P45A146497 which matches the actual number of the car itself.
Hmm...... :confused:
NostraJackAss
You will never sort ABS controller coding unless repairing the Cluster/Immobilizer to display the correct VIN # for the correct PC & to broadcast as a needed precondition.
piehole1983
C?ID=295335
Hey Jack,
That's the thing though, the ECU, IMMO and cluster all show the same VIN. It's a strange one
South Molton, UK
Hey Jack,
Yet....
so something VIN related isn't right.
If the cluster is showing this then maybe it's sending "scrambled" VIN data to the ABS?
