Audi A4 B8 MY2008 park assistant/radio issue
MartinsX
Riga, Latvia
C?ID=268515
This Audi worked all fine until some small crash (nothing serious, airbags were not deployed). Bodywork was done by some another workshop. Customer noticed that after body repairs one feature he loved is lost - radio do not mute sound anymore, when reverse gear is engaged. In addition volume is not adjusted automatically anymore, when speed increases on highway.
I did an autoscan and nothing suspicious found. No parking assistant or radio/sound system related faults stored. I enabled visualization of park assistant by changing coding for park assistant module from 000003 to 100003. This works fine, display switches to parking assistance screen and shows distance to obstacles each time reverse is engaged.
Customer showed me some old printed diagnostic reports from times before crash and body repairs - I can't find any changes in any module coding when compared with today's autoscan. Other workshop climbed they didn't touch any single wire and nothing electrical/electronic at all. Only thing they did - they disconnected battery when started body repairs and connected it back after approx one week when finished their job.
Do anyone have any ideas, what could happen with volume auto-adjusting and muting feature and how to switch it back on?
Tuesday,07,February,2017,10:42:59:32442
VCDS Version: 17.1.2.1
Data version: 20170131 DS267.1
VIN: WAUZZZ8K48A011528   License Plate:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72
VIN: WAUZZZ8K48A011528   Mileage: 211590km-131475miles
Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 B    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H01 3210
   Revision: --H01---
   Coding: 0104002C18072118
   ASAM Dataset: EV_ECM20TDI03L906022B A01014
   ROD: EV_ECM20TDI03L906022B.rod
   VCID: 244786AF2FA54561A6-8070
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AQ    HW: 8K0 907 379 AQ
   Component: ESP8 front    H03 0210
   Coding: 160500
   Shop #: WSC 06325 000 00000
   VCID: 081FF21FBB4D8101AA-805C
   Part No SW: 8K0 907 064 L    HW: 8K0 907 064 L
   Component: BCM2 1.1      H70 0141
   Coding: 030100
   VCID: 397947DBB0272889E5-806C
   Subsystem 1 - Part No SW: 8T0 959 754     HW: 8T0 959 754
   Component: FBSAUDIB8 IDG  H35 0052
   Serial number: 0507000001248002
   Subsystem 2 - Part No SW: 8K0 905 852 C    HW: 8K0 905 852 C
   Component: ELVAUDIB8  H35 0039
   Serial number: 0207000003028002
   Part No SW: 8T1 820 043 R    HW: 8T1 820 043 R
   Component: KLIMA 3 ZONEN H05 0120
   Revision: C1000000    Serial number: 0118.12.070322
   Coding: 34000000
   VCID: 408F2A3FD3FD7941A2-8014
   Component: BCM1 1.0      H21 0253
   Revision: 05021001    Serial number: 00000000070191
   Coding: 2600D0914014AF010001000300001D0D001C030800010141000000
   VCID: 306F7AFF635DE9C152-8064
   Subsystem 1 - Part No SW: 8K1 955 119     HW: 8T1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 201207  H06 0060
   Serial number: SWFBIE 0000252
   Coding: 00FD11
   Component: RLS  H04 0002
   Serial number: 10033537
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 C    HW: 8K0 941 531 C
   Component: E1 - LDS  H07 0070
   Serial number: 00000000001812070527
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 B    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0010
   Revision: 11001001    Serial number: 75330736301076
   Coding: 000003
   VCID: 387F42DF8B2D31811A-806C
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD147WZ-
   Coding: 30363434363030303030554A3052384B3053
   VCID: 3C775ECFB7151DA1FE-8068
   Serial number: 6334MSME2C21213A6
   Serial number: 6344MSME2B042E54G
   Serial number: 6352QSME443C11057
   Serial number: 6362QSME4A581D23O
   Serial number: 63732SME4C0B4B2DD
   Serial number: 63832SME4C742129+
   Component: Lenks.Modul   H10 0012
   Revision: --------    Serial number: 90304GLL000CI
   Coding: 000016
   VCID: 3D7153CBA40F14A9C9-8068
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 900 C    HW: 8K0 920 900 C
   Component: KOMBIINSTR.   H14 0214
   Revision: 00000000    Serial number: 7VL1925D7
   Coding: 0F04080002000008010000
   VCID: 2A5B6897458193119C-807E
   Part No SW: 8T0 907 468 D    HW: 8T0 907 468 D
   Component: GW-BEM 5CAN   H04 0084
   Revision: GA801030    Serial number: 3000G07B1680A9
   Coding: 000003
   Shop #: WSC 00866 400 88369
   VCID: 428B2037DDF16B51B4-8016
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0150
   Serial number: 170018AD111207
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 C    HW: 8K0 959 793 A
   Component: TSG FA        H09 0170
   Revision:             Serial number: 0000006675464
   Coding: 011002204000410001
   Revision: 00002001    Serial number: 0108454634
   Coding: 011A062000390440012001
   Shop #: WSC 06342 000 00000
   Component: DWA-Sensor  H02 0030
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 J    HW: 8T0 035 223
   Component: DSP STD       H07 0210
   Revision: S1700000
   Coding: 0203010101
   VCID: 35614BEB9C3FCCE901-8060
   Part No SW: 8K0 959 792 C    HW: 8K0 959 792 A
   Component: TSG BF        H09 0170
   Revision:             Serial number: 0000006674223
   VCID: 3F8D29C3AE0306B9DB-806A
   Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
   Component: EPB Audi B8   H03 0040
   Revision: 00000003    Serial number: 00000000043100
   VCID: 2F6D79837E63F6394B-807A
   Part No: 8K0 907 357 A
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 336575F3524BD2D92F-8066
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 B    HW: 8T1 035 186 B
   Component: Concert3      H13 0310
   Revision: 00000514    Serial number: AUZ5Z6G1015711
   Coding: 0002008001010500035B070000
   VCID: 36634CE78139C7F108-8062
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000006698185
   Coding: 010002204000210001
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Part No SW: 8K0 959 794 A    HW: 8K0 959 795 A
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000006745597
                    Fault Status: 01101000
                    Reset counter: 193
                    Mileage: 211581 km
                    Date: 2017.01.31
                    Time: 15:31:09
End-------------------------(Elapsed Time: 03:19)--------------------------
