- Feb 5, 2017
- 1
- 3
- Palm Springs California
- phil@koken.org
Saturday,04,February,2017,17:30:39:48999
VCDS Version: 17.1.2.1 (x64) HEX-V2 CB: 0.4334.4
Data version: 20170131 DS267.1
VIN: WVWVF7AU8HW101729 License Plate: BLKMMTH
Mileage: 1972km-1225mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
55 5F 75 A5 A9
VIN: WVWVF7AU8HW101729 Mileage: 1972km-1225miles
Address 01: Engine (J623-CYFB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 K HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 091D00122466000E3004
ASAM Dataset: EV_ECM20TFS0208V0906259K 001003
ROD: EV_ECM20TFS0208V0906259E.rod
VCID: 48CA52FA32380D37A52-801C
17178 - Databus
U1123 00 [040] - Received Error Message
Mileage: 1862 km
Date: 2017.02.03
Time: 00:00:48
Engine speed: 0.00 /min
Coolant temperature: 30 °C
Intake air temperature: 29 °C
Voltage terminal 30: 12.343 V
Drivetrain coordinator: ACC fault status-ACC: Not active: although TSK passive
Drivetrain coordinator: ACC fault status-Start and stop request: Set at stopping speed
Drivetrain coordinator: ACC fault status-Bit 2: Not transmitted simultaneously
Drivetrain coordinator: ACC fault status-Bit 3: Does not reactivate after DTC-induced shutdown
Drivetrain coordinator: ACC fault status-Bit 4: Not active when limiter active
Drivetrain coordinator: ACC fault status-Bit 5: Transmits no undefined signals
Drivetrain coordinator: ACC fault status-Bit 6: Not active when main switch off
Drivetrain coordinator: ACC fault status-Bit 7: Not active when driver braking
Drivetrain coordinator: ACC fault status-Bit 8: Not active during the EPB emer. braking
Drivetrain coordinator: brake fault status-ESP: no error
Drivetrain coordinator: brake fault status-Deceleration controller: Available
Drivetrain coordinator: brake fault status-TSK/ESP handshake: no error
Drivetrain coordinator: brake fault status-Bit 1: no error
Drivetrain coordinator: brake fault status-Bit 3: Not malfunction due to inaccurate engine torque
Drivetrain coordinator: brake fault status-Bit 4: No indication of TSK message consistency error
Drivetrain coordinator: brake fault status-Bit 6: Automatic engagement OK
Drivetrain coordinator: brake fault status: 5
Drivetrain coordinator: brake function status-Parking Brake: not active
Drivetrain coordinator: brake function status-ACC: Not braking
Drivetrain coordinator: brake function status-ESP: Not invoking TSK braking
Drivetrain coordinator: brake function status-Driver: Not braking
Drivetrain coordinator: brake function status-Hill descent control: passive
Drivetrain coordinator: brake function status-ASR: no intervention
Drivetrain coordinator: brake function status-MSR: no intervention
Drivetrain coordinator: brake function status-ADS: no intervention
Drivetrain coordinator: brake function status-ABS: no intervention
Drivetrain coordinator: brake function status-EDL: no intervention
Drivetrain coordinator: brake function status-ASP: no intervention
Drivetrain coordinator: brake function status-AWV2: No warning pressure
Drivetrain coordinator: brake function status-Bit 4: no intervention
Drivetrain coordinator: brake function status-Bit 11: not passively cycled
Drivetrain coordinator: brake function status-Bit 12: not passively cycled
Drivetrain coordinator: brake function status-Bit 13: Standstill not detected
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H54 4937
Revision: 06354004 Serial number: TFK01608310095
ROD: EV_TCMDQ250021.rod
VCID: 53F07596FB7EBEEFC00-8006
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 62636000000544
Coding: 01FA6BA15420096D457E030241CC6980D62A90A2C0829637184050D8C2A803
VCID: 7BA0FD36336E96AF780-802E
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 79
Mileage: 1862 km
Date: 2017.02.03
Time: 00:01:26
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 49
Mileage: 47 km
Date: 2017.01.12
Time: 02:53:25
16412 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Reset counter: 78
Mileage: 1862 km
Date: 2017.02.03
Time: 00:01:36
16413 - Display for Tire Pressure Monitoring
Reset counter: 78
Mileage: 1862 km
Date: 2017.02.03
Time: 00:01:36
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0417610276
Coding: 032C0C
VCID: 3B203D3673EE56AF380-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BL HW: 5G0 907 044 BL
Component: Climatronic H04 1601
Revision: 00001K08
Coding: 00020004200100000105000012111402
ASAM Dataset: EV_ACClimaBHBVW37X 006142
VCID: 72BED0126424D7E72B6-8026
Air quality sensor:
B10CD 00 [008] - -
Reset counter: 46
Mileage: 9 km
Date: 2016.10.18
Time: 05:19:45
Voltage terminal 30: 12.4 V
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
CAN input signal(s) status-Back-up light: OFF
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 BL HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061625800277
Coding: 00011B46C041A2E169E44000091C07201800000000000000000000000000
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 045286CA4E90E95709A-8050
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160907 043 0551
Serial number: 160919042733
Component: RLHS 042 0105
Serial number: S5Y16M10D09H22M33S13
Coding: 00A8DD
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331628203987
Coding: 0071155011
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 43D045D60B1E2E6F700-8016
13637426 - Databus
Reset counter: 78
Mileage: 1862 km
Date: 2017.02.03
Time: 00:01:26
13688835 - Databus
Reset counter: 79
Mileage: 1862 km
Date: 2017.02.04
Time: 08:36:17
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: 350000C151FFC428949C8045000016
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: N/A
No ASAM data for: "EV_ACCBOSCHVW416" (VW37)
7 Faults Found:
2055 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 78
Mileage: 1862 km
Date: 2017.02.03
Time: 00:01:27
0803 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 78
Mileage: 1862 km
Date: 2017.02.03
Time: 00:01:27
0822 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 64
Mileage: 838 km
Date: 2017.01.18
Time: 08:03:58
2101 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 78
Mileage: 1862 km
Date: 2017.02.03
Time: 00:01:26
0836 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 72
Mileage: 16 km
Date: 2016.12.28
Time: 18:44:40
0110 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 46
Mileage: 9 km
Date: 2016.10.18
Time: 05:06:06
2068 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 79
Mileage: 1862 km
Date: 2017.02.03
Time: 00:01:26
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 16091641350035
ROD: EV_DRCONTITEMIC.rod
VCID: 382A223A42D87DB7D52-806C
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR05NHDU
VCID: 47C851C63F26024FAC8-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000005U5Y7+
Coding: 30324E
Subsystem 2 - Part No SW: ----------- HW: 480 003 009 16
Serial number: 35700000000B02491E1E
Subsystem 3 - Part No SW: ----------- HW: 480 003 009 16
Serial number: 35800000000E40B01E1I
Subsystem 4 - Part No SW: ----------- HW: 480 401 609 16
Serial number: 3510002B721A372321BS
Subsystem 5 - Part No SW: ----------- HW: 480 401 609 16
Serial number: 3520002AB229A2E1212Z
Subsystem 6 - Part No SW: ----------- HW: 480 401 809 16
Serial number: 3550002AF21A3721F083
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 809 16
Component: FrontSensor_P 001 6149
Serial number: 3560002AF21A3720618
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 04091608490366
Coding: 0C10
ROD: EV_SMLSKLOMQB_SK48.rod
VCID: 094C97FE69B2B43F7AC-805C
Part No SW: 5G1 920 858 B HW: 5G1 920 858 B
Component: KOMBI 304 8311
Coding: 0BAD081A7F88CF0502886B0B5400000000000000
VCID: 2F381966B796BA0F848-807A
U1110 00 [008] - -
Reset counter: 80
Mileage: 290 km
Date: 2017.01.13
Time: 09:25:46
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005389876
Coding: 0101000838085900FB00023A9C0F00000001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 7CA2FE2A3660919771A-8028
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160001788460106373
Coding: 35FFFF
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Serial number: HA1-00030.08.16
Coding: 0001
VCID: 4ACE68F22C34FF27B36-801E
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000158528006
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 3432160A5EB099D7F9A-8060
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0416670919
Coding: 02011103
ROD: EV_HREntryHella.rod
VCID: 3C223E2A76E0519731A-8068
Lane Change Assistant 2:
338048 - Databus
Reset counter: 79
Mileage: 1862 km
Date: 2017.02.04
Time: 08:36:16
Component: TSG FS 020 0041
Serial number: 200916EIK01157
Coding: 003E13208000040000000000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000011636261
Coding: 111000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9102
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2E38327CD46FA7236-806E
16275 - Steering Angle Sensor
B1168 F2 [008] - Not Initialized
Reset counter: 43
Motor status: 00
System status: Reset
Supply voltage: 12.50 V
Temperature: 23.0 °C
KFC: 3F
KFA: 00 93
Environmental conditions: 21
uioUdNotFilt_xdu16: 12.66 V
uAdSensI_SwitchedKl30_xdu16: 12.66 V
NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
NoInitCause_RackPos_Rohwert: 01 C0
RP_VALCNTSAV: activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: activated
RP_CNTERR: activated
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Revision: 00000001 Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6D84C36E7D1A081FF64-8038
Component: TSG BFS 020 0041
Serial number: 270816EHQ20809
Coding: 003E13208000040000800000
VCID: 42DE40D2140427677B6-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000011837256
Coding: 091000
589843 - Window Regulator; Front Passenger Side
B1320 54 [008] - Missing Calibration / Basic Setting
Reset counter: 44
Mileage: 9 km
Date: 2016.10.18
Time: 05:04:20
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 022202010B000400
VCID: 40DA4ADA1A0835776D2-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0751
Coding: 027300020000000051220002001808009F0207F401200105C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 323E1012A4A497E7EB6-8066
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJX007S2
Subsystem 2 - Part No SW: 3G0 919 866 AC HW: -----------
Component: NAR 2016/17 --- 0445
6669 - Optical Data Bus for Digital Sound System
U10CC 00 [008] - Intermittent Disruption
Reset counter: 72
Mileage: 175 km
Date: 2017.01.12
Time: 15:50:41
Voltage terminal 30: 14.3 V
System_Temperature_Sensor_6-Maximum value: -50 °C
System_Temperature_Sensor_6-Minimum value: 0 °C
System_Temperature_Sensor_6-Current: 42 °C
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730002C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 04101611P12014
Coding: 0003070000000201002213548040490084000E100020
ROD: EV_MFKBoschMQBB.rod
1123173 - Databus
Reset counter: 78
Mileage: 1862 km
Date: 2017.02.03
Time: 00:01:28
Control Module temperature: 26 °C
Outside air temperature: 22.5 °C
Vehicle speed: 0.00 km/h
System run time: 3.3 s (second)
Voltage terminal 15: 12.3 V
mid: 02 E0
Camera_state: operational
Engine_Running_Info: 0
Software_Info_4: 1
Software_Info_3: 3
Software_Info_2: 2
Software_Info_1: 0
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 160723200910
End----------(Elapsed Time: 01:43, VBatt start/end: 12.4V/12.4V)-----------
