How to calculate my HP ? (or how to log RPM and FTLB)
killep2
C?ID=214777
Hi,
I would like to know how to calculate my HP
I know it is PRM*LBFT/5252
What the correct checkbox on the Log for both FTLB and RPM log ?
DrPeter
16.4905° S, 151.7375° W
Hi,
There are lots of ways to calculate horsepower and there are different types of horsepower, Nominal, Indicated, Brake, Shaft or Effective horsepower, it is generally it is expressed like this:
- Horsepower is equal to the weight of the vehicle times (Speed in Miles per hour, divided by 234) raised to the third power.
HP = (Weight X ((MPH / 234)^3))
Andy here at Ross-Tech has touched this subject in the past:
http://forums.audiworld.com/showthread.php?p=22358766
More on Horse Power:
http://en.wikipedia.org/wiki/Horsepower
drpeter
killep2
C?ID=214777
Hi,
thank you but not this answer I expect.
How I can find the relevant information on the VCDS to convert then tis to Graph or something
NEtech
Denmark
C?ID=56995
killep2
C?ID=214777
Thanks !
Some one can now explain this ?":-) "Do at least a test run and log engine speed and velocity with VAG-COM / VCDS to a log file."
Which parameters exactly should I log ? There is so much !!!
killep2
C?ID=214777
That what I Did
Module 1 >> 8 >> on the first line 138 on the second 120 and on the third 113
Then The nM * 0.738 which will give me me ftlb and then RPM * the ftlb and /5252 which provides me 245hp :)
Thanks to all!
