Saturday,04,February,2017,19:27:37:29062
VCDS Version: 16.8.3.1
VIN: WVWZZZ3CZGE104332 License Plate: 65 PASSAT 2.0
Mileage: 57357km-35639mi Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F 65 BB BC
VIN: WVWZZZ3CZGE104332 Mileage: 57357km-35639miles
Address 01: Engine (J623-CRLB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 026 ES HW: 04L 907 309 R
Component: R4 2,0L EDC H22 1342
Revision: B5H22---
Coding: 0119001203451D083000
Shop #: WSC 05311 115 00302
ASAM Dataset: EV_ECM20TDI01104L906026ES 002001
ROD: EV_ECM20TDI01104L906026ES_002.rod
VCID: 7F088F5FE68CFABAC5-802A
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 62735000001175
Coding: 0EEC928F34200B70077A060341C54970492CD0E0608292F11460F0084002
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 79FC6147F8A8D48AFB-802C
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0382834887
Coding: 000F0F0E03
VCID: 397CA147B828148ABB-806C
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5G0 907 426 AG HW: 5G0 907 426 AG
Component: AC Manuell H03 1202
Revision: 00001K06
Coding: 11120104202100001000400200000002
ASAM Dataset: EV_ACManueBHBVW37X 003129
ROD: EV_ACManueBHBVW37X_SK48.rod
VCID: 70EA5C63ABD295C24C-8024
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 AJ HW: 5Q0 937 086 AJ
Revision: -------- Serial number: 86580210151758
Coding: 03010866C2C1027F07804094B11007281880000000000000000000000000
Shop #: WSC 05311 115 00316
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 020E06AB957E9752AA-8056
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150730 043 0607
Serial number: 150919002847
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S3Y15M10D13H23M24S35
Coding: 90A8DD
Subsystem 3 - Part No SW: 3G0 941 633 HW: 3G0 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 27 06 2015 10000619
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY152292S83
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000033571428
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39331528003766
Coding: 0071051801
Shop #: WSC 05311 115 00080
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 4482C0B3CFEA5962D8-8010
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Coding: 2A00608251FFC428949C804D
ROD: EV_ACCBOSCHVW48X.rod
VCID: 346290739F4AE9E268-8060
Part No SW: 3Q0 959 655 BA HW: 3Q0 959 655 BA
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003SSPJHQMSO
Coding: 98FCC0C0000000005C5400CC008800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7EF6725BE186F3B2CE-802A
Belt Pretensioner left:
Serial number: 3G2857705E0279P01524
Coding: 80000D
Belt Pretensioner right:
Serial number: 3G2857706E0278P01575
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 002 909 15
Serial number: 3576U0000009C698761N
Subsystem 4 - Part No SW: ----------- HW: 454 002 909 15
Serial number: 3586U000000F6DB8761X
Subsystem 5 - Part No SW: ----------- HW: 454 802 609 15
Serial number: 3516RDC9A8508000000L
Subsystem 6 - Part No SW: ----------- HW: 454 802 709 15
Serial number: 3526R19268108000000Z
Subsystem 7 - Part No SW: ----------- HW: 454 802 209 15
Serial number: 3556VA3E69D08000000R
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151013500224
Coding: 0000
Shop #: WSC 00015 115 00001
ROD: EV_SMLSVALEOMQB.rod
VCID: 6DD44517BCE0782A67-8038
Part No SW: 3G0 920 951 A HW: 3G0 920 951 A
Component: KOMBI 301 6421
Coding: 27A401902680260001886B051000000000000000
VCID: 25447D372490806AEF-8070
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2227
Revision: -------- Serial number: 04101510802582
Coding: 0B0300045F087300FB00005C080F00010001070000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 75E46D77D4B0B0EA9F-8020
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
Component: E221__MFL-DC1 H16 0040
Serial number: 29150001914030115402
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 9764577803
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H56 0033
Serial number: 0139062
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000082764014
Coding: 0000000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71EC5967A0D89CCA43-8024
Component: TSG FS 020 0041
Serial number: 220915BIL06845
Coding: 003F0A20D001028000001000
VCID: 4380C3AFCAE45E5AE1-8016
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: 8103
Shop #: WSC 00015 115 00302
Component: TSG BFS 020 0041
Serial number: 250915BIO14741
Coding: 003F0020D001028000001000
VCID: 428EC6ABD5FE5752EA-8016
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 A HW: 3Q0 035 874 A
Component: MU-S-ND-ER 820 0622
Coding: 02840101FF00000051111101008808001F0100C601200100CF
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 306A9C636B52D5C20C-8064
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H52 1028
Serial number: VWZ8Z9REN00F63
Subsystem 2 - Part No SW: 3G0 919 866 H HW: -----------
Component: ECE 2015/16 --- 0430
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000009413
ROD: EV_RDKBERU30_006.rod
Address BB: Door Rear Drv (J388) Labels: None
Component: TSG HFS 020 0041
Serial number: 260915BIO2009C
Coding: 000E00200101028000001000
VCID: 4584DDB7C4D0606ACF-8010
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 020 0041
Serial number: 260915BIO20097
End-------------------------(Elapsed Time: 04:38)-----------------------
