BCM PQ35 Cannot Pair Keys
NoSpark
UC151243 (2nd hand?)
I purchased a BCM out of a crash to replace the one I fried, but I am unable to pair the keys. I have followed the guide listed on the Ross-Tech Wiki, but have been unsuccessful.
I'd also like to clear fault codes if possible, but I'm unable to communicate with 09 Central Electronics to do so.
To the best of my knowledge, I have found the origninal coding from the previous BCM for the car (which is called out in the wiki for key pairing), but I still am unable to pair.
Original coding: 6F200E1B902B08D408880001160004480071008640A00D60648060000C70
The long coding in the auto-scan below is how the BCM arrived.
Saturday,04,February,2017,12:27:31:55020
VCDS Version: 17.1.2.0 (x64)
Data version: 20170127 DS267.1
VIN: 1VWBH7A34CC029827   License Plate:
Mileage: 86940km-54022mi   Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 46 4F 52 56 62 72 77
VIN: 1VWBH7A34CC029827   Mileage: 86940km-54022miles
09-Cent. Elect. -- Status: Malfunction 1010
46-Central Conv. -- Status: Sporadic communication error 1000
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 AN    HW: 07K 907 309 A
   Component: 2,5l R5/4V      G01 1102
   Revision: T6H02---    Serial number:
   Coding: 0000075
   Shop #: WSC 09003 957 00200
   VCID: 7AD53F203509B591AD-802E
   Part No SW: 09G 927 750 LH    HW: 09G 927 750 LH
   Component: AQ 250 6F           2043
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 022547C05DD9FD51F5-8056
   Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
   Revision: 00H31001
   Coding: C54BC0F549240803A31303E692201061A60000
   Shop #: WSC 42378 000 1048576
   VCID: 79D7202CF00FBE89A4-802C
   Part No SW: 561 907 044 D    HW: 561 907 044 D
   Component: Climatronic   H01 0102
   Revision: 00001001
   Coding: 0010001002
   VCID: 181105A8E34547813B-804C
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 59
                    Mileage: 86930 km
                    Date: 2017.01.31
                    Time: 17:53:06
   Part No SW: 5K0 937 085 P    HW: 5K0 937 085 P
   Component: BCM PQ35 B+   011 0048
   Revision: BH011001
   Coding: 6F200E1B902B08D408880001160004480071008640A00D60648060000C70
   VCID: 40A18DC8D3552F41A3-8014
   Component: RLS 281011 05  54  0403
   Coding: 06300A
23 Faults Found:
                    Fault Status: 00101011
                    Reset counter: 34
                        Term 15 Off
                    Voltage: 12.05 V
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Reset counter: 34
                    Fault Status: 00101001
                    Reset counter: 34
                        Term 15 Off
                    Voltage: 12.05 V
00927 - Terminal 30 (Right)
                    Reset counter: 34
                    Fault Status: 00101010
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.02.04
                    Time: 00:02:03
                    Voltage: 11.85 V
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.02.04
                    Time: 00:02:03
01259 - Fuel Pump Relay (J17)
                    Fault Status: 01101001
                    Reset counter: 249
                        Term 15 Off
                    Voltage: 12.10 V
                    Reset counter: 249
                    Reset counter: 34
                        Term 15 Off
                    Voltage: 12.05 V
                    Reset counter: 34
01495 - Bulb for High-Beams; Left (M30)
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.02.04
                    Time: 19:30:02
                    Voltage: 11.65 V
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.02.04
                    Time: 19:30:02
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.02.04
                    Time: 19:30:02
                    Voltage: 11.70 V
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.02.04
                    Time: 19:30:02
01800 - Light Switch (E1)
                    Reset counter: 59
                        Term 15 Off
                    Voltage: 12.05 V
                    Reset counter: 59
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.02.04
                    Time: 19:30:02
                        Term 15 Off
                    Voltage: 11.75 V
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.02.04
                    Time: 19:30:02
                    Reset counter: 34
                        Term 15 Off
                    Voltage: 12.05 V
02742 - Bulb for Brake/Turn Signal Light; Left
                    Reset counter: 34
02894 - Valet Parking Indicator Lamp (K159)
                    Reset counter: 34
                        Term 15 Off
                    Voltage: 12.10 V
03188 - Bulb for Side Marker Light; Front Left
                    Reset counter: 34
03189 - Bulb for Side Marker Light; Front Right
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.02.04
                    Time: 19:30:01
                    Voltage: 11.70 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM00BTW5
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FC31E74B64BE0390A-803A
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y11000087M60C
   Coding: 30324D
   Serial number: 3572MSME75663063ZZZT
   Serial number: 3582MSME1C561164ZZZU
   Serial number: 3516KSME41276F11ZZZQ
   Serial number: 3526KSME444A2811ZZZO
   Serial number: 3556LSME31161A14ZZZL
   Serial number: 3566LSME6E041A14ZZZZ
   Part No SW: 1K5 953 501 Q    HW: 5K0 953 569 H
   Revision: FF010040    Serial number: 20110914300292
   Coding: 098A140000
   VCID: 3957E02CB88F7E89E4-806C
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
   Part No SW: 561 920 970 B    HW: 561 920 970 B
   Component: KOMBI         H07 0507
   Coding: 231E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   VCID: 191700AC184F5E8904-804C
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.01.31
                    Time: 00:00:02
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.01.31
                    Time: 00:00:04
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 23101101291362
   Coding: 461000
   VCID: 3851E5288B8567811B-806C
00457 - Control Module for Network (J519)
                    Fault Status: 00110100
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.01.31
                    Time: 00:00:02
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.01.31
                    Time: 00:00:02
   Component: IMMO          H07 0507
   VCID: 6AF50F608DA905115D-803E
   Revision: A1001003    Serial number: 7660742743
   Coding: 020000
   VCID: 2977306C402FCE0994-807C
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.01.31
                    Time: 00:26:17
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H33 0265
   Serial number: VWZAZ2L8475509
   Coding: 0400042104000B0000008000
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 236B22442A031459DE-8076
   Component: NAR_V2  0002
1048669 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 68
                    Mileage: 69502 km
                    Date: 2015.04.20
                    Time: 16:11:44
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [009] - General memory failure
                    Mileage: 86930 km
                    Date: 2017.01.31
                    Time: 19:25:59
   Revision: 13110009    Serial number: 0003513669
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5B9B5AA452F36C99D6-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 19
68098 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.01.31
                    Time: 00:00:03
68100 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.01.31
                    Time: 00:00:03
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 19
   Component: EZE_2         H40 1620
   Coding: 01030108
   VCID: 6FC31E74BE4BE0390A-803A
   Serial number: 53388786011124100651
   Coding: 181100
   Component: Analoguhr  008 0002
   Revision: 15110009    Serial number: 0003540712
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5C9959B857FD6BA1DF-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
          U1111 00 [008] - -
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.01.31
                    Time: 00:00:03
          U1111 00 [008] - -
                    Reset counter: 59
                    Mileage: 86931 km
                    Date: 2017.01.31
                    Time: 00:00:03
                    Reset counter: 19
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660606199
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 277336545E3BF87982-8072
End-------------------------(Elapsed Time: 02:09)--------------------------
NoSpark
This has been resolved. The issue was using Up/Down to select the number of keys for adaptation 001. When doing this, the Test button was greyed out, and I was unable to select. Typing "2" allowed me to select "Test" and then "Save."
Oddly, I didn't get any confirmation from the lights/horn/turn signals that it worked.
This was the correct original coding:
2012 Passat SE, 2.5L, Sunroof, Nav
   Revision: BH011001
