Seat Alhambra MY16
pab567
Poland
C?ID=233680
Thursday,19,January,2017,21:54:59:12646
VCDS Version: 17.1.1.0
Data version: 20170106 DS267.0
Dealer/Shop Name:
Workshop Code:
VIN: VSSZZZ7NZHV705034   License Plate:
Mileage: 4410km-2740mi   Repair Order: 201701192155
Chassis Type: 7N (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 25 2B 42 44 46 4C 4F 52
          53 55 5F 61 62 6C 6D 72 BE BF
VIN: VSSZZZ7NZHV705034   Mileage: 4410km-2740miles
18-Aux. Heat -- Status: Malfunction 1010
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-DFLA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 016 HE    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1624
   Revision: 8AH20---
   Coding: 011D001A042411083000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TDI01104L906016HE 001003
   ROD: EV_ECM20TDI01104L906016HE.rod
   VCID: 73E5EEE6DA844ED9D8-8026
   Part No SW: 02E 300 063 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     540 4905
   Revision: 06354004    Serial number: 00001606130726
   Shop #: WSC 00020 790 00000
   VCID: 1521F07E3CB0F0E916-8040
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CF    HW: 5N0 614 109 CF
   Component: ESC-EBC460iV1 H10 0013
   Serial number: A0187V5
   Coding: 12F0449A0920C2710877480322C790431039170000014884
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 71E9E4EEA0987CC92A-8024
0763 - Tire Pressure Warning
          C102D 00 [136] -  -
                    Reset counter: 107
                    Mileage: 2376 km
                    Date: 2016.12.16
                    Time: 16:57:59
                    Additional_Codes: 38 56 00 0E E5 7F 00 48 02
                    DTC: 00 02 FB
                    Additional2: 00 08 01 08 05 22 5B 00 5B 00
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 G    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1305
   Revision: 00092000    Serial number: 0409476441
   Coding: 03300C
   Shop #: WSC 00020 999 39850
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: 39791CCEB868F489D2-806C
   Part No SW: 7N0 907 044 AT    HW: 7N0 907 044 AT
   Component: Clima-Sharan  H04 0606
   Revision: 00001K06
   Coding: 021010C549
   VCID: 020BBB22953E7751C3-8056
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Component: KBT-H  004 0103
   Serial number: 20160629000000065517
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0184
   Revision: BC122001
   Coding: 60590A3F8125E1C4508800C0B400897403D50008676D2DB26484C720A2C1
   VCID: 4581603ECC908069A6-8010
   Subsystem 1 - Part No SW: 7N1 955 119 B    HW: 7N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS428 270516  024 0644
   Serial number: 16052503038511
   Coding: 004DBD
   Component: RLHS  042 0105
   Serial number: S6Y16M06D30H18M30S20
   Coding: 0228DD
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331618701341
   Coding: 0031151011
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00.rod
   VCID: 377D1AF68E7CE2F924-8062
   Part No SW: 7N0 959 655 D    HW: 7N0 959 655 D
   Component: VW10Airbag108 H15 0016
   Serial number: 003PWPCS26KO
   Coding: 003038
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 408F712ADBB2A54195-8014
   Serial number: 3493ETS6071ABC51CDD9
   Serial number: 3503ETS60D6E7B11CDD7
   Serial number: 3513ETS60BDCEC51CDDN
   Serial number: 3523ETS60FAE7B11C9DB
   Serial number: 35540TS6066CFC41CDD2
   Part No SW: 5K0 953 501 DP    HW: 5K0 953 569 AP
   Revision: FF010042    Serial number: 20160627300322
   Coding: 1112240000
   VCID: 7BF5C6C6F2D4069980-802E
   Subsystem 1 - Part No SW: 7N5 919 719     HW: 7N5 919 719   Labels: 3C8-959-537.CLB
   Serial number: 000000000A1340020616
   Coding: 011000
   Part No SW: 7N5 920 880 D    HW: 7N5 920 880 D
   Component: KOMBI         H04 1104
   Coding: 110F010800
   Part No: 7N0 963 271 G
   Component: Zuheizer        051 3041
   Revision: 00051000    Serial number: 09028242000000
   Coding: 0000041
   VCID: 387F19CA4B62ED812D-806C
00664 - Fuel gauge
                    Reset counter: 145
                    Mileage: 3270 km
                    Date: 2017.01.04
                    Time: 08:34:13
   Part No SW: 7N0 907 530 BK    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1682
   Revision:   H55       Serial number: 260616F1002293
   Coding: 468232
   VCID: 7AFBC3C2F5EE3F919B-802E
                    Fault Status: 00110100
                    Reset counter: 142
                    Mileage: 3965 km
                    Date: 2017.01.12
                    Time: 07:32:57
   Component: IMMO          H04 1104
   Coding: 000007
   VCID: 6ADBF3828D4E8F116B-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000111424007
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 316924EE60183CC96A-8064
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H05 0561
   Revision:             Serial number: 0000206258782
   Coding: 01112F209000411011
   VCID: 49996C0EE088640942-801C
   Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
   Component: J500__APA-BS KL.325 1501
   Revision: 1BH04740    Serial number: 00161600059201
   Coding: 0000258
   VCID: 428B7B221DBEB75183-8016
   Component: EZE_2         H55 1682
   Coding: 050B0500
   VCID: 6FEDE296BEAC6A393C-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H05 0561
   Revision:             Serial number: 0000206276770
   Coding: 01112D209000411011
   VCID: 489F690AFB829D015D-801C
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H05 0111
   Coding: 068200000B000000
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3B0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3B0000
Address 5F: Information Electr. (J794)       Labels: User\7N5-035-680.clb
   Part No SW: 7N5 035 680 D    HW: 7N5 035 680 D
   Component: MU-S-N-ER     H30 0351
   Serial number: SEZAZ2S5012305
   Coding: 04240801FF00000011110001000808001F0103C400200100C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 34672DFA9F0A09E101-8060
   Subsystem 1 - Part No SW: 6P0 919 866 H    HW: -----------
   Component: ECE1 2016/17  --- 0635
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
   Component: Batt.regelung H55 1682
   Coding: 030F7873
   VCID: 71E9E4EEA8987CC92A-8024
   Subsystem 1 - Part No SW: 1K0 915 181 L    HW: 1K0 915 181 L
   Component: J367-BDM  H07 0270
   Serial number: 43179014225831302147
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-794.clb
   Part No SW: 7N0 959 794 L    HW: 7N0 959 794 H
   Component: TSG HL        H03 0561
   Revision:             Serial number: 0000204701716
   Coding: 01006D200000411001
   VCID: 4C97551AEFFA712179-8018
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 012408012201000700
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 306F21EA6B1235C165-8064
Address 6D: Trunk Elect. (J605)       Labels: 7N0-959-107.clb
   Part No SW: 7N0 959 107 G    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0250
   Revision: 41011001    Serial number: 160602204
   Coding: 0733334002
   ASAM Dataset: EV_HDSGVW428 201138
   ROD: EV_HDSGVW428_VW36.rod
   VCID: 3B7506C6B254C699C0-806E
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-794.clb
   Component: TSG HR        H03 0561
   Revision:             Serial number: 0000204701715
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Component: Schiebetuer_l 005 2414
   Serial number: 16238831
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
   VCID: 387F19CA8362ED812D-806C
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2414
   Serial number: 16238826
   ROD: EV_AST.rod
End-------------------------(Elapsed Time: 04:51)--------------------------
