Passat B7 DSG Coasting missing in instruments
aus
Tartu, Estonia
C?ID=238046
Hi
VW Passat B7 2011 (DSG, 2.0 TDi) has coasting function in working, but I cannot turn it off from the instruments. :confused:
While moving in D and releasing gas pedal, car is moving in "coasting". Also it is shown on the MFA when current consumption number is replaced with "Coasting" sign.
I cannot see any menu when I can turn it off, also did not find it from the 02 Auto Trans. nor 17 Instruments.
Full autoscan:
Monday,30,January,2017,18:13:43:42366VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 17.1.2.0 (x64)  HEX-V2 CB: 0.4334.4
Data version: 20170107 DS267.0
VIN: WVWZZZ3CZCE******   License Plate:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4F 52 53 55 56 61
          62 69 72 77
VIN: WVWZZZ3CZCE******   Mileage: 190410km-118315miles
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BG    HW: 03L 907 309 N
   Component: R4 2,0L EDC   H24 8243
   Revision: 47H24---    Serial number: 00000000000000
   Coding: 001D0012043401080000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BG 003007
   ROD: EV_ECM20TDI01103L906018BG.rod
   VCID: 70BADA5D0A294467DD3-8025
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2707
   Revision: 05351113    Serial number: 00001107191608
   Shop #: WSC 05311 000 00000
   VCID: 1768C1C14387F35FFC9-8043
   Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
   Component: J104   C2 450M V49E 0022
   Revision: --H07---    Serial number: 00000004620598
   Coding: 0006579
   VCID: 6D84C329119BA98FF65-8039
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0004004803
   VCID: 005A8A9D3A8954E72D3-8055
9481988 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Fault Frequency: 19
                    Reset counter: 190
                    Mileage: 189808 km
                    Date: 2017.01.04
                    Time: 12:40:33
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 E    HW: 3AA 937 087 E
   Component: BCM PQ47 H+   413 0455
   Revision: BC413001
   Coding: 000800000000000000180080540029F423D50088626D8560E480C7240041
   VCID: 3C223E6D1661F00731B-8069
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 14071  10  0603
   Coding: 00B795
   Component: RLS 190811 05  54  0403
   Coding: 024D2A
00887 - Switch for Emergency Flasher (E229)
                    Fault Frequency: 12
                    Reset counter: 195
                    Mileage: 188812 km
                    Date: 2016.11.07
                    Time: 10:02:09
                        Term 15 Off
                    Voltage: 11.90 V
Address 10: Park/Steer Assist (J446)       Labels: 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 77631122902389
   Coding: 118102
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 7CA2FE6D5661300771B-8029
   Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
   Component: J234__10H VW10 HI   1918
   Revision: 22014000    Serial number: 003JZPHNQZCN
   Coding: 0012360
   VCID: 4BC06DB14FCF47BF881-801F
   Subsystem 1 - Serial number: 6332MTS687432181
   Subsystem 2 - Serial number: 6342MTS673212191
   Subsystem 3 - Serial number: 6351HTS6HSHQCAKR
   Subsystem 4 - Serial number: 6361HTS662G5DAKJ
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C9 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20110814100881
   Coding: 199A250000
   Shop #: WSC 00015 115 08193
   VCID: 6FB8D92117175B9FC49-803B
   Coding: E30000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 870 D    HW: 3AA 920 870 D
   Coding: 161F00
   Shop #: WSC 05314 115 00000
   VCID: 333015513BBF3F7FE01-8067
   Part No SW: 7N0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway H41 1620
   Revision:   H41       Serial number: 250811F1001552
   Coding: 462006
   Shop #: WSC 05314 000 00000
   VCID: 392C27791953C52F2AD-806D
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 76B6EC4564CD6A5707F-8023
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0003434405
   Coding: 0200B7
   Shop #: WSC 05311 115 00000
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 35342B4935CB214FCE5-8061
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000002391863
   Coding: 000090
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.310 1002
   Revision: 1AH03733    Serial number: 00112350089901
   Coding: 0000258
   VCID: 3C223E6D1A61F00731B-8069
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 043 0634
   Coding: 0091020052830E76300494157C084F0B607801
   Shop #: WSC 05311 000 08193
   Component: EZE_2         H41 1620
   Coding: 00000008
   VCID: 6FB8D92117975B9FC49-803B
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0003376852
   Coding: 0200B6
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 36362C4528CD2A57C7F-8063
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000002387525
   Coding: 000090
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000188479
   Coding: 0022167
   VCID: 35342B49394B214FCE5-8061
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0105
   Coding: 029200000B000200
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0011
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0011
   Coding: 230000
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 F    HW: 3C8 035 195 F
   Component: Radio RCD510  052 0208
   Revision: 00000001    Serial number: VWZ1Z3L1535703
   Coding: 05000400040011
   VCID: 2B000D31E30F67BFA81-807F
   Component: Batt.regelung H41 1620
   Coding: 030B185A
   VCID: 71BCDF5901A34D6FD2D-8025
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900241953
Address 69: Trailer (J345)       Labels: 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00000154657334
   Coding: 4106040000000000
   VCID: 73B0D5517BBF7F7F201-8027
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
   Component: Telefon       011 0723
   Revision: --------    Serial number: 35909603217474
   Coding: 020000000000000000000000
   ASAM Dataset: EV_UHVPremi A02003
   ROD: EV_UHVPremi_A02.rod
   VCID: 221EE0159445A6F71B7-8077
End-------------------------(Elapsed Time: 01:32)--------------------------
Any help is appreciated! ;)
stevecrk
Budapest, Hungary
C?ID=59799
Your car has an EPB (Electronic Parking Brake). Does it also have an Auto-Hold button?
If you have this button, just activate it, and it will keep the car in standstill, until you press the gas pedal again.
golfi_vend
Tartu, Estonia
C?ID=195131
Eh? Question is not about standstill. It is about coasting funcion in DSG where after releasing accelatot pedal the DSG disengages the clutch.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Coasting means that the DSG will disengage the current gear and shift to neutral instead of using the engine to brake/reduce speed - a better term might be free wheeling. The idea is that one will save fuel by doing so, depending on the driving scenario. If the menu to deactive/active does not exist, I don't see a direct way of enabling it. You might be able to reset the installation information in the DSG itself and see if that fixes things. Alternatively, you might want to check for a software update to the ECM and DSG module.
TBAx
C?ID=287144
I'm not really sure, but I read somewhere, that updating the TCM gave the menu to someone. However, as the internet is, I was not able to find it.
However the current dataset can be read in MWB 41. With this information you can check for possible updates on your transmission unit. Maybe there just is an update you could install (not via VCDS through) to gain free wheel/clutch.
aus
Tartu, Estonia
C?ID=238046
Thanks for the answers! I thought maybe coasting enable/disable comes with SW update, too.
As I have bit newer B7 myself (MY 2014, 4motion, DSG), I have "coasting" option in MFA, where I can enable/disable it - hence the question.
I guess I will try to update DSG SW, as there seems to be an update, as golfi_vend mentioned.
While driving, as the driver’s foot is taken off the accelerator pedal the engine is declutched, allowing the vehicle to coast and roll over a longer distance. The momentum of the vehicle is used to save fuel with a foresighted driving style. When the brake, accelerator pedal or the gear selector lever is operated, the clutch is re-engaged and engine braking / drive takes effect. Coasting Function can be selected or deselected via the multifunction display settings. The gear selector lever is required to be in the D position to be functional. The coasting function is only available with direct shift gearbox (DSG) transmissions in selected models.
aus
Tartu, Estonia
C?ID=238046
Hi
As DSG and Instruments SW upgrade did not help I am open to new suggestions. ;)
I'm thinking of replacing this B/W cluster from client's car with my premium cluster just to check if the Coasting menu appears. Then maybe I can deselect it and put back old cluster.
If that does not help, then my nex guess is that Coasting comes from ECU - maybe ECU SW upgrade helps?
And another guess is that maybe I can replace DSG SW with the one what does not have "coasting" function?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Mind posting a fresh scan? The type of cluster (Plus vs. Premium) is unrelated to the coasting option.
aus
Tartu, Estonia
C?ID=238046
Forgot to take a new scan yesterday after the update.
I can remember that DSG was v0698x07 and new is v0698x17.
nicknorman979
Aberdeen, UK
C?ID=35874
On my 2016 Skoda Superb DSG 4x4 (VAG MQB platform) coasting is activated when the drive mode is Eco. In the other modes (normal, sport) it doesn't do coasting/freewheeling. Maybe you just need to come out of Eco?
TBAx
C?ID=287144
As far as I know cars prior to MQB/MLBevo didn't have this "bonding" to the driving profile. This is why there is a checkbox in the cluster. However it's worth testing.
golfi_vend
Tartu, Estonia
C?ID=195131
I would most certantly like to try it, but WHERE THE HELL should i choose driving profile on Passat B7? ;)
aus
Tartu, Estonia
C?ID=238046
Is it something to do with my right leg? :D
golfi_vend
Tartu, Estonia
C?ID=195131
I swapped a colour cluster that had coasting tick-box available at original car to this car. Coasting tick-box didn't appear. I didn't swap other way round.
So this issue is ECU/DSG related, not cluster related.
golfi_vend
Tartu, Estonia
C?ID=195131
Well, it seems everything is up to date know, but still no coasting menu.
I think i have to find different SW for DSG. - Quite hard given the way how DSG updates are labeled.
Autoscan:
Tuesday,14,February,2017,18:15:22:36026
VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4334.4
Data version: 20170203 DS267.2
Workshop Code: 456 45632 032456
VIN: WVWZZZ3CZCE   License Plate: ALLAN LÕPP
Mileage: 190730km-118514mi   Repair Order:
          62 69 72 77
VIN: WVWZZZ3CZCE   Mileage: 190730km-118514miles
   Component: R4 2,0L EDC   H24 9936
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BG 003008
   VCID: F0AC9B8C2B2F29C199-80A4
   Component: GSG DSG AG6     511 2717
   Shop #: WSC 44551 111 44551
   VCID: 977E8010A6019EF9B8-80C2
Address 03: ABS Brakes        Labels: User\3AA-614-109.lbl
   Component: J104   C2 450M V4A3 0022
   Coding: 0006579
   VCID: ED9282F8F41DC429B2-80B8
   Revision: 00001003
   Coding: 0004004803
   VCID: 804CCB4C1B8F394169-80D4
Address 09: Cent. Elect. (J519)       Labels: User\3AA-937-087.lbl
   Revision: BC413001
   Coding: 0008000000000000001800805500A9F423F5008862218560E480C7240041
   Shop #: WSC 05311 123 12345
   VCID: BC347FBC3FE79DA175-80E8
   Coding: 00B795
   Coding: 024D2A
   Coding: 118102
   VCID: FCB4BFBC77675DA135-80A8
   Coding: 0012360
   VCID: CBD62C60AA492A19CC-809E
   Coding: 199A250000
   VCID: EFAE98F03611363980-80BA
   Coding: E30000
   Component: KOMBI         H03 0610
   Coding: 161F00
   Shop #: WSC 45632 456 32456
   VCID: B32654801AB952D9A4-80E6
   Coding: 462006
   VCID: B93A66A830D5A8896E-80EC
   VCID: F6A0AD94814B07F143-80A2
   Coding: 0200B7
   VCID: B5226A9814CD4CE98A-80E0
   Slave Driver:
   Coding: 000090
   Coding: 0000258
   VCID: BC347FBCFFE79DA175-80E8
Address 46: Central Conv.        Labels: User\3C0-959-433-46.lbl
   Coding: 00000008
   VCID: EFAE98F03E11363980-80BA
   Coding: 0200B6
   VCID: B6206D9409CB47F183-80E2
   Slave Passenger:
   Coding: 000090
   Coding: 0022167
   VCID: B5226A98DCCD4CE98A-80E0
   Coding: 230000
   Coding: 230000
   VCID: AB164CE0CA890A19EC-80FE
   Coding: 030B185A
   VCID: F1AA9E88282520C996-80A4
   VCID: F3A69480523912D964-80A6
   VCID: A208A1C4B543CB515F-80F6
End-------------------------(Elapsed Time: 01:39)--------------------------
karldietmann
C?ID=339222
Any update on this? Just successfully retrofitted DSG7 (DQ200) and no coasting feature available :-(
golfi_vend
Tartu, Estonia
C?ID=195131
I flashed different flash file that didn't have coasting.
No Coasting menu available with this gearbox it seems.
  • Informative
