[2012 Passat] 09 Central Electronics - Byte 18=FF - Cannot Communicate
NoSpark
UC151243 (2nd hand?)
Hi there,
First time poster, so hopefully this is as proper as I can make it. *I can post an autoscan, but I cannot communicate with 09 Central Electronics, and Autoscan hangs at that module*
I was adjusting Byte 18 in the Central Electronics module to see if I could find a code that worked with some aftermarket headlights for my 2012 Passat SE (2.5L, North American Region). By default, the turn signals are on (at a reduced brightness) with the low beams, and ultimately, I'm trying turn them off completely (but still function when I activate the turn signal).
After trying numerous different values for Byte 18, I entered FF, which turned my car into a total light show (exterior lights, interior lights). Now I cannot start the car (tries to turn over but doesn't start), or access Central Electronics again. Battery voltage is approximately 11.2V.
Does anyone have any idea how I can revert back to the factory settings without currently having access to 09 Central Electronics?
Thank you in advance!
11.2V? I would start by connecting a battery charger. ;)
NoSpark
Ok, I don't think the battery voltage was the issue. I put it on the charger (got up to about 12.8V) and did not fix the problem.
With ignition on, door lights, low beams, interior lights, etc all flash twice per second. Battery drain is pretty substantial (estimated 0.25V/min), and still cannot communicate with 09 Central Electronics (auto-scan hung on that module). I also cannot lock/unlock the doors with the fob or buttons inside the car. Auto-scan below:
Sunday,29,January,2017,11:25:47:55020
VCDS Version: 17.1.2.0 (x64)
Data version: 20170127 DS267.1
VIN: 1VWBH7A34CC029827   License Plate:
Mileage: 86930km-54015mi   Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 46 4F 52 56 62 72 77
VIN: 1VWBH7A34CC029827   Mileage: 86930km-54015miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 AN    HW: 07K 907 309 A
   Component: 2,5l R5/4V      G01 1102
   Revision: T6H02---    Serial number:
   Coding: 0000075
   Shop #: WSC 09003 957 00200
   VCID: 7AD53F203509B591AD-802E
   Part No SW: 09G 927 750 LH    HW: 09G 927 750 LH
   Component: AQ 250 6F           2043
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 022547C05DD9FD51F5-8056
   Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
   Revision: 00H31001
   Coding: C54BC0F549240803A31303E692201061A60000
   Shop #: WSC 42378 000 1048576
   VCID: 79D7202CF00FBE89A4-802C
   Part No SW: 561 907 044 D    HW: 561 907 044 D
   Component: Climatronic   H01 0102
   Revision: 00001001
   Coding: 0010001002
   VCID: 181105A8E34547813B-804C
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 59
                    Mileage: 86930 km
                    Date: 2017.01.29
                    Time: 17:53:06
Address 09: Cent. Elect.        Labels: None
   VCID: 558F4C9CBCD7BAE9E0-8000
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM00BTW5
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FC31E74B64BE0390A-803A
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y11000087M60C
   Coding: 30324D
   Serial number: 3572MSME75663063ZZZT
   Serial number: 3582MSME1C561164ZZZU
   Serial number: 3516KSME41276F11ZZZQ
   Serial number: 3526KSME444A2811ZZZO
   Serial number: 3556LSME31161A14ZZZL
   Serial number: 3566LSME6E041A14ZZZZ
   Part No SW: 1K5 953 501 Q    HW: 5K0 953 569 H
   Revision: FF010040    Serial number: 20110914300292
   Coding: 098A140000
   VCID: 3957E02CB88F7E89E4-806C
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
   Part No SW: 561 920 970 B    HW: 561 920 970 B
   Component: KOMBI         H07 0507
   Coding: 231E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   VCID: 191700AC184F5E8904-804C
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 23101101291362
   Coding: 461000
   VCID: 3851E5288B8567811B-806C
   Component: IMMO          H07 0507
   VCID: 6AF50F608DA905115D-803E
   Revision: A1001003    Serial number: 7660742743
   Coding: 020000
   VCID: 2977306C402FCE0994-807C
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H33 0265
   Serial number: VWZAZ2L8475509
   Coding: 0400042104000B0000008000
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 236B22442A031459DE-8076
   Component: NAR_V2  0002
1048669 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 68
                    Mileage: 69502 km
                    Date: 2015.04.18
                    Time: 16:11:44
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [009] - General memory failure
                    Mileage: 86930 km
                    Date: 2017.01.29
                    Time: 19:25:59
   Revision: 13110009    Serial number: 0003513669
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5B9B5AA452F36C99D6-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 19
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 19
Address 46: Central Conv.
   Component: EZE_2         H40 1620
   Coding: 01030108
   VCID: 6FC31E74BE4BE0390A-803A
   Serial number: 53388786011124100651
   Coding: 181100
   Component: Analoguhr  008 0002
   Revision: 15110009    Serial number: 0003540712
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5C9959B857FD6BA1DF-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
                    Reset counter: 19
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660606199
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 277336545E3BF87982-8072
End-------------------------(Elapsed Time: 03:56)--------------------------
Changing codings in a module with battery voltage down in the mud could very well cause problems.
Next thing I would try is cold-booting the BCM. Either disconnect it from the car's harness for a while or disconnect the battery for a while. No guarantees that this will fix anything, but it costs less to try than a new BCM. ;)
NoSpark
Thanks for the quick replies Uwe! I disconnected the battery overnight (just positive terminal). Is there a fuse tied to the BCM? Any other ideas?
NoSpark
So I guess I will order a new BCM?
Personally, I don't have any other ideas.
VCDS does warn you that fiddling with byte 18 may cause malfunctions that in some
cases cannot be fixed except by replacing the module.
NoSpark
Any idea if making changes in the BCM can affect other modules in the car? For example, could it affect the CAN gateway, or ECM, or some other electrical control module?
NoSpark
Update:
For those looking at this in the future, it was just the BCM that was fried. Replaced that, and all was mostly good. I am having issues pairing keys, but I think there is lots on the forum to troubleshoot that.
Does anyone have the stock 09 Central Electronics long coding for a 2012 2.5L Passat SE?
Look in your Scans sub-folder, perhaps you did an Auto-Scan before you bricked the module?
Or look for for the CodingLog.txt file; it will likely have some, if not all of what you're looking for.
If you don't have either of those, the closest data I have handy is:
2012 Poverty Spec 6MT TDI:
   Part No SW: 5K0 937 085 P    HW: 5K0 937 085 P
   Component: BCM PQ35 B+   011 0047
   Revision: BH011001
   Coding: 6F200EB8F82B28D408880001360004C84071008E50A00560648060000C70
2013 TDI SE with Sunroof & Nav:
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200E1B802B2AD408880001160085480071008640A00560648060000C70
   Shop #: WSC 07807 444 103846
NoSpark
Thanks for the help Uwe! From what I can tell, this is the original coding:
2012 Passat SE 2.5L w/Nav and sunroof
5K0 937 087 P
6F200E1B902B08D408880001160004480071008640A00D60648060000C70
