2013 VW Caddy 1.6 CR TDI Fan Running Constantly.. Fault Stored..
Gaz-M
C?ID=242079
Hi, I have a 2013 VW Caddy 1.6 CR TDI with fan running from the minute the ignition is switched on, during running then for upto a minute after switching off.
Fault logged and scanned below:
Saturday,28,January,2017,14:31:34:41009
VCDS Version: 17.1.0.0 (x64)
Data version: 20170106 DS267.0
VIN: WV1ZZZ2KZDX094159   License Plate:
Chassis Type: 2K (7N0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZDX094159   Mileage: 112910km-70159miles
Address 01: Engine (J623-CAYD)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 PC    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 4256
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114010030500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023PC 003006
   ROD: EV_ECM16TDI02103L906023DB.rod
   VCID: 76E3DA50C9670CF1E5-8022
6139 - Fan 1 Control Circuit
          P0692 00 [045] - Short to Plus
                    Fault Frequency: 8
                    Mileage: 112602 km
                    Date: 2017.01.04
                    Time: 18:10:32
                    Engine speed: 981.25 /min
                    Normed load value: 20.4 %
                    Coolant temperature: 61 °C
                    Intake air temperature: 4 °C
                    Voltage terminal 30: 14.456 V
                    Engine speed: 0 /min
                    Sensor for temp after charge air cooler: raw value-TBA_MES: 8 °C
                    Sensor for engine block temperature: raw value-Coolant temperature: 16 °C
                    Outside air temperature-Ambient temperature: 1.50 °C
                    Coolant fan 1: activation-Radiator fan 1: activation: 9.8 %
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   Coding: 433C400D092B03FEC20C02E99022C081300000
   Shop #: WSC 35110 377 00144
   VCID: 7CF7C878FF4B56A193-8028
   Part No SW: 5K0 937 085 R    HW: 5K0 937 085 R
   Component: BCM PQ35 B+   021 0068
   Revision: BB021001
   Coding: 411A583A8025186A08800082900000640301728852020060648000000040
   VCID: 428B7680DD2FE05199-8016
   Subsystem 1 - Part No: 1T2 955 119 A
   Component: Wischer 16011  26  0512
   Coding: 009795
   Component: VW10Airbag02A H07 0013
   Revision: --------    Serial number: 003HL00FSBHQ
   Coding: 000000000000000000000000000000003241
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 35611D5C94E147E92C-8060
   Part No SW: 1K5 953 507 M    HW: 5K0 953 549
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440MAN0003M
   Coding: 0080060000
   ROD: EV_SMLSNGKUDS_VW32.rod
   VCID: 3B750B64B2C59199DA-806E
   Part No SW: 2K0 920 965 G    HW: 2K0 920 965 G
   Component: KOMBI         H06 0705
   Coding: 480001
   ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
   VCID: 336523449A9559D902-8066
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 210113F6000638
   Coding: 357401
   VCID: 74E7E058D71B1EE1DB-8020
   Component: IMMO          H06 0705
   VCID: 6ADBFE208DDFD81171-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 489F64A83B13CA0147-801C
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 140    3305
   Revision: 00H22000
   VCID: 377D175446EDB5F93E-8062
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 479D6794360DC5794E-8012
   Part No SW: 5K0 035 156 A    HW: 5K0 035 156 A
   Component: Radio         H52 0106
   Revision: R0000000    Serial number: VWZAZ1M5213270
   Coding: 0500020001
   VCID: 2541CD1C2C4137699C-8070
End-------------------------(Elapsed Time: 01:44)--------------------------
