- Jul 30, 2014
- 14
- 9
- Oulu, Finland
- C?ID=82663
Hi everyone! Brand new car and new model so there's couple of "missing" .rod files. CAN Gateway is newer than i've seen and engine is also unknown to VCDS. Some minor codings done, otherwise like from factory.
I Took debug from engine and i already took it from CAN GW with older version earlier:
Engine:
GW:
So... Thank you, and waiting for updates.
Friday,27,January,2017,21:14:50:60995
VCDS Version: 17.1.2.0 (x64)
Data version: 20170107 DS267.0
VIN: VSSZZZ5FZH6521780 License Plate:
Mileage: 3460km-2149mi Repair Order: Ateca
Chassis Type 5F (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 42 44 52 5F 69
A5
VIN: VSSZZZ5FZH6521780 Mileage: 3460km-2149miles
Address 01: Engine (J623-CZEA) Labels: None
Part No SW: 04E 906 027 KA HW: 04E 907 309 BJ
Component: R4 1.4l TFS H23 3749
Revision: R6H23---
Coding: 011D003A247605083000
Shop #: WSC 33361 790 00063
ASAM Dataset: EV_ECM14TFS01104E906027KA 001005
ROD: N/A
VCID: 6DDA2497BC7FBD2938-8038
No ASAM data for: "EV_ECM14TFS01104E906027KA" (SE37)
Part No SW: 0D9 300 014 J HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5004
Revision: 06454104 Serial number: TFK01609140638
ROD: EV_TCMDQ250021.rod
VCID: 1F460E5F06539FB9FA-804A
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 62686000001353
Coding: 22EE6A923422246D877E070842C32844562C24E1E042147B38225074E223430000100212121212A635351919323200
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 77F606FFCE2307F9D2-8022
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0419698784
Coding: 032C0C0F03
ROD: EV_KessyHellaMQBAB_SE37.rod
VCID: 3C7CD9D3B785E4A1FF-8068
133124 - Databus
Reset counter: 129
Mileage: 3292 km
Date: 2017.01.21
Time: 14:33:54
Part No SW: 5F0 907 044 AH HW: 5F0 907 044 AH
Component: Climatronic H05 1801
Revision: 00001K09
Coding: 06000204204111011105004000101020
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_ACClimaBHBVW37X 006143
VCID: 6CDC29938765B4212F-8038
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001628902444
Shop #: WSC 33361 790 00109
ROD: EV_BCMBOSCH_017.rod
VCID: 7F06EEDFE6133FB99A-802A
Subsystem 1 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S5Y16M10D21H00M30S34
Coding: 00996E
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616281
Coding: 0271163151
ASAM Dataset: EV_EPHVA2CAU3700000 009017
ROD: EV_EPHVA2CAU3700000_009.rod
VCID: 0D1A4417DCBF1D2998-8058
Address 13: Auto Dist. Reg (J428) Labels: 2Q0-907-572.clb
Part No SW: 2Q0 907 572 J HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0156
Coding: 320047CB54FF8728749C8065804081
Shop #: WSC 33361 790 00146
ASAM Dataset: EV_ACCMRRCONTIVW376 001011
ROD: EV_ACCMRRCONTIVW376_VW37.rod
VCID: 3B7EDACFB28BE399F6-806E
Part No SW: 3Q0 959 655 AK HW: 3Q0 959 655 AK
Component: Airbag VW21 004 0305
Revision: -------- Serial number: 003R6PLM7Z3K
Coding: 98CCC0C0000000005C5400CC000800000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0716763FBEC37779A2-8052
Subsystem 1 - Part No SW: ----------- HW: 454 000 410 16
Serial number: 35700000000E8391CE1Y
Subsystem 2 - Part No SW: ----------- HW: 454 000 410 16
Serial number: 3580000000021D344E1F
Subsystem 3 - Part No SW: ----------- HW: 454 800 410 16
Serial number: 3510090AE3C0D000000R
Subsystem 4 - Part No SW: ----------- HW: 454 800 410 16
Serial number: 3520087B03C0D000000L
Subsystem 5 - Part No SW: ----------- HW: 454 802 609 16
Serial number: 35500FB35890B000000W
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 EE HW: 5Q0 953 569 A
Revision: FF036036 Serial number: 20160928400609
Coding: 6C14
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 5F0 920 750 D HW: 5F0 920 750 D
Component: KOMBI 306 8311
Coding: 07A4201AEF84000800887A031001000000000000
Shop #: WSC 73430 031 00063
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 26481BBB59094E71B9-8072
Address 18: Aux. Heat (J364) Labels: 5Q0-963-272.clb
Part No SW: 5Q0 963 272 H HW: 5Q0 963 272 H
Component: STH-MQB 008 0075
Coding: 1309
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000130755
Component: GW MQB High 512 5285
Serial number: 09081610801154
Coding: 030500F42F085700EB0022581E0F00010001050000000000000000000000
ROD: N/A
VCID: 2F66FE9F76F30F394A-807A
Subsystem 2 - Part No SW: 5F0 959 537 A HW: 5F0 959 537 A
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B0372270816
Coding: 012000
Serial number: 75410803001610143043
No ASAM data for: "EV_GatewNF" (SE37)
8531970 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 122
Mileage: 2246 km
Date: 2017.01.18
Time: 13:23:37
Serial number: HA1-00004.08.16
Coding: 0001
VCID: 4A908F0BED514A117D-801E
Component: ELV-MQBB H05 0032
Serial number: 16000237931003
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E238E7A04759C91C-8024
Component: TSG FS 010 0032
Serial number: 0000222415241
Coding: 00311320D000040000001000
VCID: 4796B63FFE43B77962-8012
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000011826937
Coding: 210000
Address 44: Steering Assist (J500) Labels: 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0001073474
Coding: 01010011004001
ROD: EV_SteerAssisVWBSMQBA_SK37.rod
VCID: 4084AD23DB6D8041A3-8014
Component: TSG BFS 010 0032
Serial number: 0000222934817
Coding: 00311320DC00040000001000
VCID: 4688BB3BF949AE7199-8012
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000011601100
Coding: 390000
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 5QA 035 846 A HW: 5QA 035 846 A
Component: MU-S-N-ER H30 0359
Serial number: SEZAZ2S0177325
Coding: 04230601FF0A000011110001000808002F0100D40120010086
Shop #: WSC 33361 790 00140
ASAM Dataset: EV_MUStd6C3TSAT 001015
ROD: EV_MUStd6C3TSAT_SE26.rod
VCID: 4280A72BD5619251B5-8016
Subsystem 1 - Part No SW: 575 919 606 HW: 575 919 606
Component: ABT_High-2_N H41 1041
Serial number: SEZ8Z9SCB00D0P
Subsystem 2 - Part No SW: 6P0 919 866 M HW: -----------
Component: ECE1 2017 --- 0730
Address 69: Trailer (J345) Labels: 5Q0-907-383.clb
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0204
Revision: 8A001003 Serial number: 0418537982
Coding: 0100000202000000
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 10101611P12456
Coding: 030307060000040000221345C050A90098000E230020
ROD: EV_MFKBoschMQBB.rod
End-------------------------(Elapsed Time: 05:20)--------------------------
Engine:
Friday,27,January,2017,21:19:27:60995
Mileage: 3460km-2149mi Repair Order: Ateca_CZEA
Address 01: Engine
Control Module Part Number: 04E 906 027 KA
Component and/or Version: R4 1.4l TFS H23 3749
Software Coding: 011D003A247605083000
Work Shop Code: WSC 33361
Advanced Identification/FAZIT
Identification: BXJ-531
Revision: R6H23---
Date: 02.10.16
Manufacturer number: 9438
Test stand number: 1471
Flash Status
Programming Attempts(application): 1/1/1
Successful Attempts(application): 1/1/1
Flash Date: 16.10.26
Misc.
Hardware number: 04E 907 309 BJ
Workshop System Name: J623
ASAM Dataset Revision: 001005
Car Info
Chassis Number: VSSZZZ5FZH6521780
Engine code: CZEA
VCDS Info:
Labels: None
Readiness: No script available
ROD: ERROR - EV_ECM14TFS01104E906027KA 001005 (SE37)
GW:
Wednesday,11,January,2017,17:50:15:60995
VCDS Version: 17.1.0.0 (x64)
Data version: 20170106 DS267.0
VIN: VSSZZZ5FZH6521780 License Plate: Ateca_GW
Control Module Part Number: 3Q0 907 530 C
Component and/or Version: GW MQB High 512 5285
Software Coding: 030500F42F085700EB0022581E0F00010001050000000000000000000000
VCID: 2F66FE9F76F30F3966-807A
Identification: SJ8-FST
Date: 09.08.16
Manufacturer number: 1080
Test stand number: 1154
Flash Status
Programming Attempts(application): 0/0
Programming Attempts(data): 3
Successful Attempts(data): 3
Flash Date: 00.00.00
Flash Tool Code(data): 00109 790 33361
Misc.
Hardware number: 3Q0 907 530 C
Workshop System Name: J533
Equipment/PR Code: 00000000000527BD
Dataset Number: V03935232PC
Dataset Version: 0009
ASAM Dataset Revision: 013020
VCDS Info:
Labels: None
ROD: ERROR - EV_GatewNF 013020 (SE37)
