2017 Seat Ateca, 1.4 TSI CZEA
ConD
Oulu, Finland
C?ID=82663
Hi everyone! Brand new car and new model so there's couple of "missing" .rod files. CAN Gateway is newer than i've seen and engine is also unknown to VCDS. Some minor codings done, otherwise like from factory.
Friday,27,January,2017,21:14:50:60995
VCDS Version: 17.1.2.0 (x64)
Data version: 20170107 DS267.0
VIN: VSSZZZ5FZH6521780   License Plate:
Mileage: 3460km-2149mi   Repair Order: Ateca
Chassis Type  5F (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 42 44 52 5F 69
          A5
VIN: VSSZZZ5FZH6521780   Mileage: 3460km-2149miles
Address 01: Engine (J623-CZEA)       Labels: None
   Part No SW: 04E 906 027 KA    HW: 04E 907 309 BJ
   Component: R4 1.4l TFS   H23 3749
   Revision: R6H23---
   Coding: 011D003A247605083000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM14TFS01104E906027KA 001005
   ROD: N/A
   VCID: 6DDA2497BC7FBD2938-8038
No ASAM data for: "EV_ECM14TFS01104E906027KA" (SE37)
   Part No SW: 0D9 300 014 J    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5004
   Revision: 06454104    Serial number: TFK01609140638
   ROD: EV_TCMDQ250021.rod
   VCID: 1F460E5F06539FB9FA-804A
   Revision: 00000000    Serial number: 62686000001353
   Coding: 22EE6A923422246D877E070842C32844562C24E1E042147B38225074E223430000100212121212A635351919323200
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 77F606FFCE2307F9D2-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0419698784
   Coding: 032C0C0F03
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB_SE37.rod
   VCID: 3C7CD9D3B785E4A1FF-8068
133124 - Databus
                    Reset counter: 129
                    Mileage: 3292 km
                    Date: 2017.01.21
                    Time: 14:33:54
   Part No SW: 5F0 907 044 AH    HW: 5F0 907 044 AH
   Component: Climatronic   H05 1801
   Revision: 00001K09
   Coding: 06000204204111011105004000101020
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ACClimaBHBVW37X 006143
   VCID: 6CDC29938765B4212F-8038
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001628902444
   Shop #: WSC 33361 790 00109
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F06EEDFE6133FB99A-802A
   Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S5Y16M10D21H00M30S34
   Coding: 00996E
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616281
   Coding: 0271163151
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_009.rod
   VCID: 0D1A4417DCBF1D2998-8058
Address 13: Auto Dist. Reg (J428)       Labels: 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320047CB54FF8728749C8065804081
   Shop #: WSC 33361 790 00146
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_VW37.rod
   VCID: 3B7EDACFB28BE399F6-806E
   Part No SW: 3Q0 959 655 AK    HW: 3Q0 959 655 AK
   Component: Airbag VW21   004 0305
   Revision: --------    Serial number: 003R6PLM7Z3K
   Coding: 98CCC0C0000000005C5400CC000800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0716763FBEC37779A2-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 000 410 16
   Serial number: 35700000000E8391CE1Y
   Subsystem 2 - Part No SW: -----------    HW: 454 000 410 16
   Serial number: 3580000000021D344E1F
   Subsystem 3 - Part No SW: -----------    HW: 454 800 410 16
   Serial number: 3510090AE3C0D000000R
   Subsystem 4 - Part No SW: -----------    HW: 454 800 410 16
   Serial number: 3520087B03C0D000000L
   Subsystem 5 - Part No SW: -----------    HW: 454 802 609 16
   Serial number: 35500FB35890B000000W
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 EE    HW: 5Q0 953 569 A
   Revision: FF036036    Serial number: 20160928400609
   Coding: 6C14
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 5F0 920 750 D    HW: 5F0 920 750 D
   Component: KOMBI         306 8311
   Coding: 07A4201AEF84000800887A031001000000000000
   Shop #: WSC 73430 031 00063
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 26481BBB59094E71B9-8072
Address 18: Aux. Heat (J364)       Labels: 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 H    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0075
   Coding: 1309
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000130755
   Component: GW MQB High   512 5285
   Serial number: 09081610801154
   Coding: 030500F42F085700EB0022581E0F00010001050000000000000000000000
   ROD: N/A
   VCID: 2F66FE9F76F30F394A-807A
   Subsystem 2 - Part No SW: 5F0 959 537 A    HW: 5F0 959 537 A
   Serial number: 000000000B0372270816
   Coding: 012000
   Serial number: 75410803001610143043
No ASAM data for: "EV_GatewNF" (SE37)
8531970 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 122
                    Mileage: 2246 km
                    Date: 2017.01.18
                    Time: 13:23:37
   Serial number: HA1-00004.08.16
   Coding: 0001
   VCID: 4A908F0BED514A117D-801E
   Serial number: 16000237931003
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E238E7A04759C91C-8024
   Component: TSG FS        010 0032
   Serial number: 0000222415241
   Coding: 00311320D000040000001000
   VCID: 4796B63FFE43B77962-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000011826937
   Coding: 210000
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Revision: 00000000    Serial number: 0001073474
   Coding: 01010011004001
   ROD: EV_SteerAssisVWBSMQBA_SK37.rod
   VCID: 4084AD23DB6D8041A3-8014
   Component: TSG BFS       010 0032
   Serial number: 0000222934817
   Coding: 00311320DC00040000001000
   VCID: 4688BB3BF949AE7199-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000011601100
   Coding: 390000
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 5QA 035 846 A    HW: 5QA 035 846 A
   Component: MU-S-N-ER     H30 0359
   Serial number: SEZAZ2S0177325
   Coding: 04230601FF0A000011110001000808002F0100D40120010086
   Shop #: WSC 33361 790 00140
   ASAM Dataset: EV_MUStd6C3TSAT 001015
   ROD: EV_MUStd6C3TSAT_SE26.rod
   VCID: 4280A72BD5619251B5-8016
   Subsystem 1 - Part No SW: 575 919 606     HW: 575 919 606
   Component: ABT_High-2_N  H41 1041
   Serial number: SEZ8Z9SCB00D0P
   Subsystem 2 - Part No SW: 6P0 919 866 M    HW: -----------
   Component: ECE1 2017  --- 0730
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0204
   Revision: 8A001003    Serial number: 0418537982
   Coding: 0100000202000000
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Serial number: 10101611P12456
   Coding: 030307060000040000221345C050A90098000E230020
   ROD: EV_MFKBoschMQBB.rod
End-------------------------(Elapsed Time: 05:20)--------------------------
I Took debug from engine and i already took it from CAN GW with older version earlier:
Engine:
Friday,27,January,2017,21:19:27:60995
Mileage: 3460km-2149mi   Repair Order: Ateca_CZEA
                Address 01: Engine
Control Module Part Number: 04E 906 027 KA
  Component and/or Version: R4 1.4l TFS   H23 3749
           Software Coding: 011D003A247605083000
            Work Shop Code: WSC 33361
Advanced Identification/FAZIT
     Identification: BXJ-531
     Revision: R6H23---
     Date: 02.10.16
     Manufacturer number: 9438
     Test stand number: 1471
Flash Status
     Programming Attempts(application): 1/1/1
     Successful Attempts(application): 1/1/1
     Flash Date: 16.10.26
Misc.
     Hardware number: 04E 907 309 BJ
     Workshop System Name: J623
     ASAM Dataset Revision: 001005
Car Info
     Chassis Number: VSSZZZ5FZH6521780
     Engine code: CZEA
VCDS Info:
       Labels: None
       Readiness: No script available
       ROD: ERROR - EV_ECM14TFS01104E906027KA 001005 (SE37)
GW:
Wednesday,11,January,2017,17:50:15:60995
VCDS Version: 17.1.0.0 (x64)
Data version: 20170106 DS267.0
VIN: VSSZZZ5FZH6521780   License Plate: Ateca_GW
Control Module Part Number: 3Q0 907 530 C
  Component and/or Version: GW MQB High   512 5285
           Software Coding: 030500F42F085700EB0022581E0F00010001050000000000000000000000
                      VCID: 2F66FE9F76F30F3966-807A
     Identification: SJ8-FST
     Date: 09.08.16
     Manufacturer number: 1080
     Test stand number: 1154
Flash Status
     Programming Attempts(application): 0/0
     Programming Attempts(data): 3
     Successful Attempts(data): 3
     Flash Date: 00.00.00
     Flash Tool Code(data): 00109 790 33361
Misc.
     Hardware number: 3Q0 907 530 C
     Workshop System Name: J533
     Equipment/PR Code: 00000000000527BD
     Dataset Number: V03935232PC
     Dataset Version: 0009
     ASAM Dataset Revision: 013020
VCDS Info:
       Labels: None
       ROD: ERROR - EV_GatewNF 013020 (SE37)
So... Thank you, and waiting for updates. :)
We published a Data Version update today. Assuming your PC has an internet connection when you start VCDS, VCDS should find it within a day or so. If you'd like to install the update manually, you can grab it here.
I'm not certain whether it fixes either or both of those "No ASAM data" problems. Let us know please. ;)
ConD
Oulu, Finland
C?ID=82663
I've waited couple of weeks with my car to see if you happen to update data versions, and my laptop didn't push me any updates earlier today. :)
I'll install new version and try tomorrow if it helps...
ConD
Oulu, Finland
C?ID=82663
Here you go, CAN GW is now supported but engine is not:
Saturday,28,January,2017,13:40:24:60995
Data version: 20170127 DS267.1
Mileage: 3525km-2190mi   Repair Order: Ateca_2
          A5
VIN: VSSZZZ5FZH6521780   Mileage: 3525km-2190miles
   Revision: R6H23---
   ROD: N/A
   Coding: 032C0C0F03
133124 - Databus
                    Reset counter: 129
                    Mileage: 3292 km
                    Date: 2017.01.21
                    Time: 14:33:54
   Revision: 00001K09
   Air quality sensor:
   Coding: 00996E
   Coding: 0271163151
   Coding: 6C14
   Coding: 1309
   ROD: EV_GatewConti_013.rod
   Coding: 012000
8531970 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 122
                    Mileage: 2246 km
                    Date: 2017.01.18
                    Time: 13:23:37
                    Supply voltage: Terminal 30: 12.6 V
                    Terminal 15: OFF
   Coding: 0001
   Coding: 210000
   Coding: 390000
End--------------------(Elapsed Time: 05:16, Deb=1024)---------------------
Half of "unknowns" is now dealt. Happy to help if possible... :D
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The ASAM data for #01 should be addressed in data version 20170131+ and some of the remaining labels are also covered now while the rest is on the todo list. ;)
automech
Poland
C?ID=14925
Wait... what??
Dear VW Aktiengesellschaft, why do you need as much as 46 bytes to code ABS? Why? :facepalm:
That's like asking them why they needed all this:
To handle cars that had two K-lines. :D
ConD
Oulu, Finland
C?ID=82663
Wait... what??
IDK about the VW engineer answer, but 5 pre-selected driving modes+individual (via selector knob), offroad features, haldex controls and DSG controls may have something to do with this. Each pre-selected driving modes has a little different way of handling ESP features and selecting correct settings for paths like these is a bit tricky at times:
That's 20+cm (~8 inches) of snow...
I'd be also grateful to know what each of these bytes do, because coding has indeed gotten much more complicated than previous MQB 4wd + DSG -cars i've seen and coded. There's some thing's i'd like to have selectable at ESP controls, but so far "tips" from the great internet hasn't been quite right for my car.
I'll have to update version once more and take MVB / adaptation scans after working ASAM set..
