amarok trailer harness
garynudgeeauto
Australia
C?ID=144283
Hello has anyone out there had much to do with the factory trailer harness on a 2012 Amarok vin WVZZZ2HZCA078172 . The bulb warning light is on the dash and the previous owner had a very odd trailer brake controller wired to it .They had removed the red wire which should be the brake light wire and now that wire has constant voltage if reconnected. Does anyone know where the control unit is . I can operate all trailer lights with the VCDS except the brake lights.The constant fault code is in module 69 trailer and is brake circuit open or short to pos. code 02562 .
Thank you from Gary at Nudgee Automotive in Australia
Moved to General VW/Audi Repair from Forum Support & Feedback.
