golf mk7 2016
raf0468
C?ID=120244
Thursday,26,January,2017,10:49:35:29062
VCDS Version: 16.8.3.1
VIN: WVWZZZAUZGW209737   License Plate: GOLF 65 REG
Mileage: 46758km-29054mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZGW209737   Mileage: 46758km-29054miles
Address 01: Engine (J623-CUNA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BS    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H22 1541
   Revision: B5H22---
   Coding: 011D0012036505083000
   ASAM Dataset: EV_ECM20TDI01104L906026BS 002003
   ROD: EV_ECM20TDI011_AU37.rod
   VCID: 7CF27853F79AE1A2E0-8028
   Part No SW: 0D9 300 041 J    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4904
   Revision: 06253104    Serial number: TFK01510220720
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1F486FDF06CC5ABAA5-804A
          P1734 00 [002] - -
   Revision: 00000000    Serial number: 63265000000251
   Coding: 01FA8AA134200975077E060341CA2980512C90E0608294F518625078C209
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7AFE7E4BFDAEDF92F2-802E
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 44
                    Mileage: 5622 km
                    Date: 2016.03.11
                    Time: 14:47:48
   Revision: 00021000    Serial number: 0387640890
   Coding: 030C0C
   VCID: 3A7EBE4BBD2E1F92B2-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00120104202100011005000000101002
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6ADE4E0B8D0E6F1202-803E
   Air quality sensor:
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
                    Reset counter: 109
                    Mileage: 45575 km
                    Date: 2017.01.13
                    Time: 16:34:04
                    Voltage terminal 30: 13.8 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 1
                    Auxiliary heater: in stages-Act.value: 2
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
                    Fault Frequency: 65
                    Reset counter: 119
                    Mileage: 33033 km
                    Date: 2016.10.03
                    Time: 08:21:10
                    Voltage terminal 30: 13.9 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.value: 1
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061533900464
   Coding: 03011A46C24122FB0BA44080B11C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 091C1187A848C40AEB-805C
   Component: WWS    151114  042 0551
   Serial number:         151117153921
   Component: RLHS  037 0059
   Serial number: S4Y15M12D11H23M22S45
   Coding: 90A8DD
   Serial number: 000000000ZY15308120N
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033975480
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 91
                    Mileage: 39949 km
                    Date: 2016.12.05
                    Time: 09:43:25
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39391534303093
   Coding: 0071051011
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 4380C3AFCAE45E5AE1-8016
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 03121503213754
   Coding: 001C1300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR1AT6SI
   VCID: 7F088F5FE68CFABAC5-802A
   Belt Pretensioner left:
   Serial number: 34169677B09121540539
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676B09121540964
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 311 15
   Serial number: 3576700000006341E71L
   Subsystem 4 - Part No SW: -----------    HW: 480 002 311 15
   Serial number: 3586700000076A61E71
   Subsystem 5 - Part No SW: -----------    HW: 480 402 411 15
   Serial number: 3516502B51E24312603V
   Subsystem 6 - Part No SW: -----------    HW: 480 402 411 15
   Serial number: 3526502C11E34434219
   Subsystem 7 - Part No SW: -----------    HW: 480 402 711 15
   Serial number: 3556502BF1E3443270AE
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 29111508491032
   Coding: 0410
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_SK48.rod
   VCID: 071817BFBE5CB27AFD-8052
   Part No SW: 5G1 920 957 A    HW: 5G1 920 957 A
   Component: KOMBI         302 6420
   Coding: 27AD09182F80260001886A011400000000000000
   VCID: 2E56821B7166C3321E-807A
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1243
   Revision: --------    Serial number: 0004285042
   Coding: 030100041F087300FB00027E1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 79FC6147F8A8D48AFB-802C
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N
   Serial number: 29150002323970055474
   Coding: 2DFFFF
   Serial number: 6801128603
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
                    Reset counter: 123
                    Mileage: 46465 km
                    Date: 2017.01.21
                    Time: 13:28:21
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: OFF
   Revision: 00000000    Serial number: 15000256945006
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 346290739F4AE9E268-8060
   Serial number: 111115BKA01559
   Coding: 003F1220D001048000001000
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000008323791
   Coding: 0D0000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   VCID: 397CA147B828148ABB-806C
   Serial number: 181115BKH18794
   Coding: 003F1020DE01048000801000
   VCID: 428EC6ABD5FE5752EA-8016
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000008339841
   Coding: 150000
   Coding: 029E01000B000200
   VCID: 408ACCA3DBF24542FC-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    820 0624
   Coding: 02730001FF00000051111101008808001F0202C601200100CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 306A9C636B52D5C20C-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H43 4061
   Serial number: VWZ6Z9R3400094
   Subsystem 2 - Part No SW: 3G0 919 866 H    HW: -----------
   Component: ECE 2015/16  --- 0430
6691 - Local Data Bus
          U10BA 00 [008] - No Communication
                    Fault Frequency: 9
                    Reset counter: 109
                    Mileage: 41491 km
                    Date: 2016.12.18
                    Time: 13:34:59
                    Voltage terminal 30: 13.4 V
                    Network diagnosis-Status: not enabled
   Component: SAS-GEN 2     H06 0014
   Serial number: 151022200247
   VCID: 6BD04B0F82F4761A79-803E
End-------------------------(Elapsed Time: 04:37)--------------------------
