B8 A4 led tail lamp euro coding
dtorreci
Spain
C?ID=298227 (NRRT)
Hello all!
I know this is duplicate post, however I'm not able to write onto the original thread since I'm not a evrified user, my apologies for that.
I've managed to bought the 2013 facelift tail lights I'm loking to mount them into my 2011 A4 Allroad, let me say that my car came with tail LED lights from factory, therefore the conversion seemed to be easy. I've source also the cables from Kufatec to I do not need to cut & paste any original cable.
Find below my original coding with some notes I've found over. The problem I'm having is that I'm not being able to find the right coding for my car, if tail fog lights are not failing then the brake (outer) are... I'm a bit lost in coding translation, can any one provide me some "light" into this please?
Thanks a lot!
D
rlarsen
Copenhagen, Denmark
C?ID=78998
Kufatec's coding should be the below - and you also need to have a wire from outer pin 1 to inner pin 1 for the signal light to work:
dtorreci
Spain
C?ID=298227 (NRRT)
Thanks so much Rene! I'll give a try this weekend
dtorreci
Spain
C?ID=298227 (NRRT)
Rene, it worked at the first attempt! again thanks so much for your help
D
