VW PASSAT STEERING LOCK ISSUE
yamin
I am wondering if you can help me. I have just replaced the electronic steering lock from a VW Passat due to the common steering lock issue. I have replaced it with a brand new genuine part from VW. I cannot login to the immobiliser for some reason but I have the correct 5 digit pin. I receive the following Fault upon entering the pin code:
Controller refused the key!
First attempt: Error 35: invalid key
Second Attempt: Error 22: conditions not correct or request sequence error.
The pin code I have is also accepted by security in 01 Engine but I receive the message above when logging in to Immobiliser.
Can somebody help?
camels73
Ireland
C?ID=59731
Hi.After replacing ESCL electronic steering column lock it should be adapted in address 25 immobilizer ecu and the vin number has to be transferred to new fitted ESCL and after this adaptation do not need to adapt any keys previously adapted keys working fine,that is the way when you doing it by ODIS in main Vw Dealer,I don't think so you can do that by VCDS maybe I'am wrong.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
The pin code I have is also accepted by security in 01 Engine but I receive the message above when logging in to Immobilizer.
Can somebody help?
Do not log in, go straight to Adaptation Ch50 in 25-immobilizer ,
But first make sure you do not have any Lock out time at measuring block value 024, if you do just wait till it goes off , switch ignition off/On then go to adaptation CH50.
Let me know how it goes.
yamin
Address 25: Immobilizer (3C0 959 433 K)
15:19:51 Group 002: Key && Adaptation Status
No Variable Code authorized
No Key Status (Transponder)
No Fixed Code authorized
0.0 Immobilizer Status
15:19:51 Group 003: Lock Times && System Status
189.0 Lock Time Immobilizer
0.0 Lock Time Engine
0.0 Lock Time Transponder
0.0 Immobilizer (LED) Status
15:19:51 Group 004: Electronic Steering Column Lock (ESCL) II
0.0 Lock-Time ESCL
189.0 Lock-Time Security Access
0.0 (no units)
OFF ESCL Voltage Supply
Friday,20,January,2017,15:21:38:39280
VCDS Version: 17.1.1.2
Data version: 20170107 DS267.0
Dealer/Shop Name: Autostyle
VIN: License Plate: VO06WMP
Mileage: 288600km-179327mi Repair Order:
15:21:27 Group 001: System Status
No Engine Start permitted
Yes Engine (ECU) responds
No Key Status
0.0 Number of adapted Keys
15:21:27 Group 003: Lock Times && System Status
188.0 Lock Time Immobilizer
15:21:27 Group 005: Electronic Steering Column Lock (ESCL) II
0.0 ESCL Status Mode
ON ESCL Status (Unlocking Bit)
OFF ESCL Status (Locking Bit)
yamin
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D
VIN: WVWZZZ3CZ6P177198   Mileage: 288600km-179327miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 CK    HW: 03G 906 018 CK
   Component: R4 2.0l PPD1.5 G    9629
   Revision: --H05---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 00600 210 88178
   VCID: 70EFFC48633A63C12B-8024
17978 - Engine Start Blocked by Immobilizer
            P1570 - 008 -
                    Fault Status: 11101000
                    Fault Frequency: 15
                    Reset counter: 148
                    Mileage: 288601 km
                    Time: 00:03:02
                    Text:      0    Nm
                    Text:  0.0    %
                    Voltage: 11.53 V
                    Bin. Bits: 00011001
                    Bin. Bits: 00000000
18044 - Powertrain Data Bus
            P1636 - 009 - Missing Message from Airbag Controller - Intermittent
                    Fault Frequency: 15
                    Reset counter: 148
                    Mileage: 288601 km
                    Time: 00:03:02
Readiness: N/A
   Part No SW: 02E 300 042 S    HW: 02E 927 770 AE
   Component: GSG DSG         070 1127
   Revision: 04507000    Serial number: 00000602040444
   Shop #: WSC 00028 028 00001
   VCID: 2345C304E24C8859E6-8076
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0667077512
   Coding: 0013605
   VCID: 306F3C48A3BA23C16B-8064
02840 - Wake-Up Line from Central Convenience Module
                    Reset counter: 147
                    Mileage: 288600 km
                    Time: 17:19:43
                    Reset counter: 147
                    Mileage: 288600 km
                    Time: 17:19:43
   Part No: 1K0 820 047 DP
   Component: Climatic PQ35   090 0505
   VCID: 75E1CD5C1C5846E9F8-8020
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 H    HW: 3C0 937 049 H
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000003756030
   Coding: 00800F0700041A00000A00000F000000000859435C0000
   VCID: 2E532230B98E353179-807A
   Subsystem 1 - Part No: 3C2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 00028
00093 - Terminal 15 for Starting Relevant Consumers
                    Reset counter: 188
                    Mileage: 288601 km
                    Voltage: 10.80 V
01800 - Light Switch (E1)
                    Reset counter: 188
                    Mileage: 288601 km
                    Fault Status: 00101001
                    Reset counter: 188
                    Mileage: 288656 km
                    Voltage: 12.50 V
02403 - Terminal 15 for Interior
            006 - Short to Plus - Intermittent
                    Reset counter: 188
                    Mileage: 288656 km
01049 - Supply Voltage Term 50
                    Reset counter: 188
                    Mileage: 288656 km
                    Reset counter: 188
                    Mileage: 288656 km
                    Voltage: 12.50 V
   Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
   Component: 05 AIRBAG VW8   029 2521
   Revision: 09029000    Serial number: 003A2P2CDWU0
   Coding: 0012341
   VCID: 2D51253CB4884E2940-8078
   Subsystem 1 - Serial number: 6332MSME0D1F4024
   Subsystem 2 - Serial number: 6342MSME0D0F652E
   Subsystem 3 - Serial number: 6351HTS64IK2E5B2
   Subsystem 4 - Serial number: 6361HTS63IKUI9N2
   Part No SW: 3C0 953 549 A    HW: 3C0 953 549 A
   Component: Lenksäulenmodul 005 0010
   Revision: 00005000    Serial number: 3C5953507C
   Coding: 0001013
   VCID: 2A5B2E2085665911A5-807E
02768 - Activation Steering Column Lock
   Part No SW: 3C0 920 960 H    HW: 3C0 920 960 H
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: X0014000    Serial number: 00000000000000
   Coding: 0007405
   Shop #: WSC 14400 067 57207
   VCID: 285FD4289B6A6B01B3-807C
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C061310BCE
   Coding: 3FFD2C04C21003
   VCID: 2149C90CF8509A49F4-8074
                    Reset counter: 188
                    Mileage: 288656 km
                    Time: 10:52:44
02638 - Enabling Steering Column Lock
                    Fault Status: 00101100
                    Fault Frequency: 53
                    Reset counter: 188
                    Mileage: 288656 km
                    Time: 11:04:46
   Part No SW: 3C0 959 433 K    HW: 3C0 959 433 K
   Component:    IMMO         038 0367
   Revision: 00038000    Serial number: 00000000000000
   Shop #: WSC 129519 1019 1978335
   VCID: 326B3640ADB611D11D-8066
02823 - Requirements for Locking the Steering Column Lock not met
            000 -  -  - Intermittent
                    Fault Status: 00110000
                    Reset counter: 188
                    Mileage: 288600 km
                    Time: 17:19:45
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2366
   Coding: 0000693
   VCID: 36630A5041DE0DF131-8062
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 3467305857A21FE10F-8060
            000 -  -
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 038 0455
   Coding: 01910A0801860E763804941570085FCE103880
   Shop #: WSC 00704 210 91065
   Subsystem 2 - Part No: 3C0 951 171 A
   Component: Neigungssensor  002 0508
   Subsystem 3 - Part No: 3C0 951 171 A
   Component: Innenraumueberw.002 0508
                    Reset counter: 188
                    Mileage: 288656 km
                    Time: 10:52:44
   Part No: 1K0 959 702 K
   Coding: 0000692
   VCID: 377D075446D4F4F92A-8062
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000012
00576 - Terminal 15
                    Reset counter: 188
                    Mileage: 288600 km
                    Time: 00:24:24
                    Voltage: 11.08 V
                    Count: 41
02443 - Control Head
                    Fault Status: 00111100
                    Reset counter: 188
                    Voltage: 12.32 V
                    Count: 40
   Part No: 1K0 035 186 AF
   Component: Radio GR0       036 0034
   Revision: 0003606S    Serial number: VWZ2Z2H1168685
   Coding: 0010400
   VCID: 6ADBEE2045E6991165-803E
            000 -  -
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2432
   Coding: 0000144
   VCID: 3365334452AC18D916-8066
   Part No: 1K0 959 704 F
   Coding: 0000144
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End-------------------------(Elapsed Time: 02:22)--------------------------
Friday,20,January,2017,15:17:22:39280
VIN: WVWZZZ3CZ6P177198   License Plate: VO06WMP
   Coding: 0000078
Readiness: N/A
   Coding: 0013605
   Coding: 00063445
   Shop #: WSC 00028
   Coding: 0012341
   Coding: 0001013
   Coding: 0007405
                    Reset counter: 188
                    Mileage: 288600 km
                    Time: 17:19:45
   Coding: 0000693
            000 -  -
   Coding: 0000692
   Revision:   013
   Coding: 0000012
   Coding: 0010400
            000 -  -
   Coding: 0000144
   Coding: 0000144
            014 - Defective
End-------------------------(Elapsed Time: 02:12)--------------------------
yamin
sorry i am bit now to fourm .. And meany Thanks for the help !!
One more time:
Please read How to get Verified. It looks like you're in category 2) in that post.
Jetta 97
C?ID=81680
OK , you need to wait very long time with Ignition On before you do anything.
You have Lock time for 188 Minutes , that means you have to leave little over 3hr with ignition On, so need to put some charger on battery .After that do what I suggest in Post #4.
